06-02-2010, 19:18 | #1 (permalink) |
No Life Poster Join Date: Dec 2003 Location: in the center of the heart
Member: 46125 Status: Offline Thanks Meter: 59 | infinity but now the phone is in ON/OFF state this is the previous phones firmware on which i flashed the available support file what went wrong? plz can u help me? COM5 [VCP0] selected module v3.39 Device: LG-GX200 Checking data, wait... Action: read/check information interface: BROM_DLL_v3.952.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8A04:8A01 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0007]: 00EC:00F100000095 [SAMSUNG] K9F1G08X0M chip size: 128Mb page/spare size: 0800/0040 pages per block: 0040 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: absent done Set baudrate (115200)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02000000/06000000 firmware size: 32Mb ffs size: 96Mb detect sec ro... detect custom parameters... detect project-id... project-id: GX200-00-V10c-404-XX-FEB-24-2010 detect NAND info... number of areas/bytes to read: 1:001A0000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... bootloader version: ARIMA6235_GEMINI_09A_BOOTLOADER_V005_MT6235B_GX200-00-V10C-404-X nfi area detection finished: Ok TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: ARIMA6235_GEMINI_09A_PCB01_GPRS_MT6235B_S01.GX200-00-V10C-404-XX-FEB-24-2010.BIN project-id: GX200-00-V10c-404-XX-FEB-24-2010, 00000000 code offset: 00000000 ffs offset/size [01]: 02000000/06000000 rom info structure: 2nd [standard] generation TCL-ID is absent ===> done ==================== New firmware detected (v.3.39, database date: 28.05.2010): ARIMA6235_GEMINI_09A_PCB01_GPRS_MT6235B_S01.GX200-00-V10C-404-XX-FEB-24-2010.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare: 1-CLICK Web hosting - Easy Filehosting or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== Disconnect... done Finished, time used: 3 min 21 sec Remove/Install battery now ! .................................................. .................................................. .... this was the original firmware in the phone and on this i flashed the available firmware on support now after flashing my phone is on off this is the log for the ON/OFF PHONE COM5 [VCP0] selected module v3.39 Device: LG-GX200 Checking data, wait... Action: read/check information interface: BROM_DLL_v3.952.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8A04:8A01 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0007]: 00EC:00F100000095 [SAMSUNG] K9F1G08X0M chip size: 128Mb page/spare size: 0800/0040 pages per block: 0040 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: absent done Set baudrate (115200)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02000000/06000000 firmware size: 32Mb ffs size: 96Mb detect sec ro... detect custom parameters... detect project-id... project-id: GX200-00-V10f-CIS-XX-JAN-09-2010 detect NAND info... number of areas/bytes to read: 1:001A0000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... bootloader version: ARIMA6235_GEMINI_09A_BOOTLOADER_V005_MT6235B_GX200-00-V10F-CIS-X nfi area detection finished: Ok TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: ARIMA6235_GEMINI_09A_PCB01_GPRS_MT6235B_S01.GX200-00-V10F-CIS-XX-JAN-09-2010.BIN project-id: GX200-00-V10f-CIS-XX-JAN-09-2010, 00000000 code offset: 00000000 ffs offset/size [01]: 02000000/06000000 rom info structure: 2nd [standard] generation TCL-ID is absent ===> done Disconnect... done Finished, time used: 3 min 6 sec Remove/Install battery now ! |
06-02-2010, 21:25 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Do you have original full flash backup ? Did you tried to flash phone with this firmware from support area ? GX200_ARIMA6235_GEMINI_09A_PCB01_GPRS_MT6235B_S01. GX200-00-V10E-724-XX-FEB-24-2010_En_Pt.B4M.bin |
06-03-2010, 08:44 | #3 (permalink) |
Member: 46125 Status: Offline Thanks Meter: 59 | yes i do have original flash backup .and i revived the phone back but i need to change language so i flashed it with the support firmware ill try flashing it with the firmware ure saying and post result wbr |
06-07-2010, 11:55 | #5 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, New firmware uploaded in "main" support area: GX200_ARIMA6235_GEMINI_09A_PCB01_GPRS_MT6235B_S01. GX200-00-V10F-AME-XX-MAR-28-2010_En_Ru_Fr_Tr_Farsi_Pt_Ar.B4M.bin |
06-08-2010, 16:36 | #6 (permalink) |
Member: 46125 Status: Offline Thanks Meter: 59 | hello sir i flashed this file on gx200 and now the phone is in ON/OFF STATE none files work....... except one which has eng and portuguese language in it works perfect wbr |
06-09-2010, 15:15 | #7 (permalink) |
Member: 46125 Status: Offline Thanks Meter: 59 | hello need a perfect working file for GX200 with french language files present on infinity are not working just one file with english and portuguese is working fine |
06-10-2010, 05:24 | #8 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Flash files in support area should be Ok. I think that it may be some kind of firmware <-> hardware incompatibility. If you have any backup files from other good working GX200 please send it to [email protected] |
06-10-2010, 08:08 | #9 (permalink) |
Member: 46125 Status: Offline Thanks Meter: 59 | i have already send u last time ...it had hindi and english language i uploaded it here is the link again RapidShare: 1-CLICK Web hosting - Easy Filehosting RapidShare: 1-CLICK Web hosting - Easy Filehosting |
06-10-2010, 08:51 | #12 (permalink) |
Member: 46125 Status: Offline Thanks Meter: 59 | yes sir this is the file i send ...then on this i flashed all the files available on support but the phone is in ON/OFF STATE ONLY ONE FILE WORKS ON THIS ...WHICH HAS ENGLISH AND PORTUGUESE BUT I NEED FRENCH wbr |
06-14-2010, 12:33 | #14 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Sorry, we did not provide any kind of firmware editing service. You can try to add/modify language by yourself with Language Editor software: Language Pack Editor Dongle |
12-16-2010, 13:08 | #15 (permalink) |
Freak Poster Join Date: Jan 2008 Location: punjab ,jalandher
Member: 672494 Status: Offline Thanks Meter: 109 | hello bro, i have a problem in lg gx200 the phone taking one simcard and he not taking second simcard u can tellme its hardwere problem or softwere????????? i get one more phone same one i test the phone the simcard reading is same , can i flash it in infinity??????????????????????????? |
Need schematic Infinity USB Phoenix | homer66 | Off Topic Zone | 0 | 05-25-2004 18:34 |
Animated GIF Loops only infinate on X100! | masterdwarf01 | SYSOL Platform | 2 | 03-04-2004 11:01 |
Infinity USB | brain2kx | Hardware Equipments for GSM | 0 | 12-04-2003 13:19 |
infinity usb... | voransoy | Sim Cloning and Scaning | 2 | 02-19-2003 09:43 |
URGENT : can i read imsi & ki by Infinity USB ? | sadom | Sim Cloning and Scaning | 4 | 02-10-2003 08:31 |
