07-14-2020, 20:36 | #1 (permalink) |
Banned Join Date: Mar 2003 Location: Bosnia and Hercegovina Zenica Age: 57
Member: 24975 Status: Offline Thanks Meter: 29 | Infinity best work ok ,not work HUA dongle == DongleManager [Infinity] v1.80 [14.7.2020. 21:32:51] === Searching... Card-Reader: FT SCR2000 0 HWID: 0008786510321292 Box/Dongle found: [BEST] Reading... Serial No (S/N): 88AD7865 Firmware version: 0122.02 === Process started: 14.7.2020. 21:32:53 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0007] No updates found for your Smart-Card. DO NOT try more today ! |
07-15-2020, 11:00 | #2 (permalink) | |
What is the problem with Hua ? | |
07-16-2020, 11:00 | #3 (permalink) |
Member: 24975 Status: Offline Thanks Meter: 29 | After ubdate box dead. Card-Reader: FT SCR2000 0 is HWID: 0008786510321292 Box/Dongle found: [BEST] Serial No (S/N): 88AD7865 Firmware version: 0122.02 "UK Edition" status: On Last launched Application: 0031 v.0122 => Activations: - 03: [BEST] v0122 - 07: #7 - 0E: #14 => Options: - Infinity BEST - Infinity SM - hua === DongleManager [Infinity] v1.80 [16.7.2020. 11:51:13] === Box/Dongle type selected: [BEST] Card-Reader: FT SCR2000 0 HWID: 0008786510321292 Box/Dongle found: [BEST] Reading... Serial No (S/N): 88AD7865 Firmware version: 0122.02 === Process started: 16.7.2020. 11:51:14 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication successfull Service stage 1 confirmed Securing session... Session secured ok Upgrading dongle... Wait 4-5 minutes ! DO NOT disconnect Box/Dongle ! Card returned error - 0000 at 4890/15613 Error upgrading applets: Card returned error - 0000 at 4890/15613 Disconnected === DongleManager [Infinity] v1.80 [16.7.2020. 11:51:57] === Searching... Card-Reader: FT SCR2000 0 HWID: 0008786510321292 Box/Dongle is not found === DongleManager [Infinity] v1.80 [16.7.2020. 11:52:02] === Searching... Card-Reader: FT SCR2000 0 HWID: 0008786510321292 Select Token Type: instead of Autodetect === DongleManager [Infinity] v1.80 [16.7.2020. 11:52:15] === Box/Dongle type selected: [BEST] Card-Reader: FT SCR2000 0 HWID: 0008786510321292 === Process started: 16.7.2020. 11:52:15 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. Contact to http://www.infinity-box.com/support/?r=2 === DongleManager [Infinity] v1.80 [16.7.2020. 12:08:10] === Box/Dongle type selected: [BEST] Card-Reader: FT SCR2000 0 HWID: 0008786510321292 === Process started: 16.7.2020. 12:08:10 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication successfull Service stage 1 confirmed Securing session... Session secured ok Upgrading dongle... Wait 4-5 minutes ! DO NOT disconnect Box/Dongle ! Card returned error - 0000 at 667/15613 Error upgrading applets: Card returned error - 0000 at 667/15613 Disconnected Last edited by alminkad; 07-16-2020 at 11:09. |
07-16-2020, 11:07 | #4 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Install required Card-Reader Drivers: - File with Drivers: CardReader_Fetian_FT2K.7z - File with Instruction: Infinity-Box_How_to_update_FT_SCR2000_CardReader_drivers.pd f Drivers version after installation should be 2.5.6.0823 or 2.5.9.1202 Download files - https://www.infinity-box.com/support/?r=6 OR Insert Smart-Card into another Card-Reader (good result for today is with Alcor Card-Reader) The next steps are: - run DongleManager - update Dongle firmware IMPORTANT: only ONE update try is allowed so in case of problem DO NOT try to update card again ! |
07-16-2020, 11:20 | #5 (permalink) |
Member: 24975 Status: Offline Thanks Meter: 29 | HelooI,ihave been using your tools for 6 years, I have been doing the job for 20 years, I use a lot of tools, I know very well where the problem is. Thanks Inserted another smart card. === DongleManager [Infinity] v1.80 [16.7.2020. 12:22:48] === Box/Dongle type selected: [BEST] Card-Reader: FT SCR2000 0 HWID: 0008786510321292 === Process started: 16.7.2020. 12:22:49 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. Contact to http://www.infinity-box.com/support/?r=2 Last edited by alminkad; 07-16-2020 at 11:26. |
07-16-2020, 12:11 | #8 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
Have you installed drivers for FT SCR2000 as per instruction ? | |
07-16-2020, 12:21 | #11 (permalink) |
Product Supporter Join Date: Jan 2015 Location: Space
Member: 2331209 Status: Offline Thanks Meter: 2,725 | === Process started: 7/16/2020 16:45:27 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. Contact to http://www.infinity-box.com/support/?r=2 |
07-16-2020, 12:30 | #12 (permalink) | |
07-16-2020, 12:50 | #14 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Dear Sir ! 1. You have got step-by-step instruction how to update card-reader drivers. Please answer, have you updated it ? 2. You have got this info: IMPORTANT: only ONE update try is allowed so in case of problem DO NOT try to update card again ! Yes, all, even very experienced users always want to try more, and in your case it was already 7 (seven) tries. Please follow the instruction and answer us about driver installation instead of repeat attempts ! |
