09-16-2016, 17:43 | #16 (permalink) |
No Life Poster Join Date: Oct 2007 Location: EGYPT
Member: 601566 Status: Offline Sonork: 100.1637134 Thanks Meter: 551 | Activated ability of flashing SIGNED firmwares - WorldFirst ! Activated ability of flashing SECURE firmwares - WorldFirst ! MT65xx, MT67xx, MT81xx specific changes: Activated SECURED type detection - WorldFirst |
09-16-2016, 20:07 | #24 (permalink) |
Freak Poster Join Date: Jul 2011 Location: South Sulawesi
Member: 1622614 Status: Offline Thanks Meter: 71 | Detection done BEFORE any operation with phone - that mean DEVICE COMPLETELY IN SAFE, if there is any problem can happen Real Safe I have flash it before with Flashtool using firmware upgreade but make it dead Thanks Infinity Team |
The Following 4 Users Say Thank You to azharslamajer For This Useful Post: |
09-16-2016, 20:16 | #27 (permalink) |
Member: 1622614 Status: Offline Thanks Meter: 71 | You have Warning Before..! now my phone vibra only but Am not worry am still Happy becouse u never know till you have tried ones more thank to Infinity team |
The Following User Says Thank You to azharslamajer For This Useful Post: |
09-16-2016, 20:17 | #28 (permalink) |
Freak Poster Join Date: Jul 2009
Member: 1076060 Status: Offline Thanks Meter: 26 | ALWAYS need help for: SFR STARTRAIL 7 MT6735 WHITOUT PRESS BOOT TO THE PHONE: Card found : S/N : 59XXXXXX , v0132 Chinese Miracle II [MTK module] v 1.55 Operation : Format FileSystem [ v1.55 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 36 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... [DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED Boot Error! Operation Failed Elapsed: 00:00:19 Reconnect Power/Cable! IF PRESS BOOT VOL DOWN TO THE PHONE: Operation : Format FileSystem [ v1.55 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 114 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 484A01906531473878AF07056F75D735 Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0xC40B0000 EMICFG_RET_FAILED CodeDefine : DA_DEVICE_NOT_FOUND Boot Error! Operation Failed Elapsed: 00:00:51 Reconnect Power/Cable! PLEASE ADD THIS PHONE MODEL PLEASE!!!! |
09-16-2016, 20:28 | #29 (permalink) |
No Life Poster Join Date: May 2014 Location: Tamil_Nadu Rasipuram
Member: 2185083 Status: Offline Sonork: 100.1670782:dineshras Thanks Meter: 185 | great team! great update!!! Thanks for this update infnity team plz add flash before auto preloader backup function |
The Following User Says Thank You to dineshras For This Useful Post: |
09-16-2016, 20:29 | #30 (permalink) |
Member: 1076060 Status: Offline Thanks Meter: 26 | ALWAYS ASK YOU ABOUT IT PLEASE!!!! ADD TO UNLOCK NETWORK PLEASE !!! phone model:VIKKO N1 device CPU : MT6735 Device Version : 5.1 if you put other sim card nothing if you call, it say: to use the simcard,first unlock it it is locked for one operator IF YOU UNLOCK TO CM2 MTK: cm2 SAY the phone is not locked this is nv : MT6735_S00_MOLY_LR9_W1444_MD_LWTG_MP_V48_P4_1_lwg_ n_eMMC |
The Following User Says Thank You to genylle For This Useful Post: |
