07-09-2017, 11:35 | #31 (permalink) |
No Life Poster Join Date: Jun 2010 Location: việt nam
Member: 1327392 Status: Offline Thanks Meter: 405 | Created by Infinity-Box (c) Chinese Miracle II (c) 2016 Device Brand : OPPO Device Model : A1601 Device CPU : MT6755 Device IntName : A1601 Device Version : 5.1 Device Compile : 11/19/2016 10:27:39 AM Device Project : A1601EX_11_A.24_161119 Device ExtInfo : A1601 Chinese Miracle II [MTK module] v 1.58 Operation : Read NVRAM [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 37 ] Sync... Inital Boot Ok! BB_CPU_PID : 6755 BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... DAgent configured successfully Connection agent : BROM [DA_ERROR] : DRAM Configure failed! ErroCode : 0x2122 EMICFG_NOT_ACCEPTED_CONFIG Boot Error! Operation Failed Elapsed: 00:00:23 Reconnect Power/Cable! Operation : Read NVRAM [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 31 ] Sync... Inital Boot Ok! BB_CPU_PID : 6755 BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... DAgent configured successfully Connection agent : PRELOADER DRAM already initialized by Preloader Link with DAgent established eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM46H [eMMC] : FLASH_CID : 150100524836344D4202B7E5CAE814F5 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x0000000E8F800000 [eMMC] : FLASH_UCP : 59640 MiB [eMMC 128 GiB] DEV RID : 0x273623E9BBC12C52263F893915DB92D3 INT RAM : 0x00000000 EXT RAM : 0x80000000 [2 GiB] [NAND] : FLASH : NOT INSTALLED [UFSM] : FLASH : NOT INSTALLED [HSUSB] : MODE : HIGH-SPEED Boot Ok! NVM Read Ok, MT6755_eMMC.spnv Done! Elapsed: 00:00:19 Reconnect Power/Cable! MediaTek Device Info list Created by Infinity-Box (c) Chinese Miracle II (c) 2016 Modem Version : oppo6750_15331_lwg DisplayRes : M_HEIGHT=1280 x M_WIDTH=720 Supported DGT : STOM_KERNEL_TOUCHPANEL=GT1XX Supported CAM : STOM_HAL_IMGSENSOR=s5k3l8_mipi_raw imx258_mipi_raw ov8865_mipi_raw s5k3p3sp_mipi_raw Supported BootLoader HW : FlashID [0] CID : 150100524531424D42 , Name : RE1BMB , Vendor : 15 , [SAMSUNG] FlashID [1] CID : 90014A484247346132 , Name : HBG4a2 , Vendor : 90 , [HYNIX] FlashID [2] CID : 150100525831424D42 , Name : RX1BMB , Vendor : 15 , [SAMSUNG] FlashID [3] CID : 13014E51334A393756 , Name : Q3J97V , Vendor : 13 , [NOT_IN_BASE] FlashID [4] CID : 150100525831344D42 , Name : RX14MB , Vendor : 15 , [SAMSUNG] FlashID [5] CID : 13014E51334A393757 , Name : Q3J97W , Vendor : 13 , [NOT_IN_BASE] FlashID [6] CID : 150100524331344D42 , Name : RC14MB , Vendor : 15 , [SAMSUNG] FlashID [7] CID : 150100524836344D42 , Name : RH64MB , Vendor : 15 , [SAMSUNG] FlashID [8] CID : NONE , DRAM ONLY Device Memory Details ( installed ) : RAM : [2 GiB] ROM : eMMC 128 GiB Manufacturer : [SAMSUNG] Name : BM46H |
The Following User Says Thank You to students For This Useful Post: |
07-09-2017, 12:44 | #32 (permalink) | |
No Life Poster Join Date: May 2005 Location: Romania Focsani
Member: 149135 Status: Offline Thanks Meter: 234 | Quote:
07-09-2017, 15:50 | #37 (permalink) | |
No Life Poster Join Date: Oct 2010 Location: .::: Madina :::.
Member: 1427732 Status: Offline Sonork: ˙·٠•● Thanks Meter: 1,060 | Quote:
than post result | |
07-09-2017, 16:29 | #38 (permalink) |
Freak Poster Join Date: Jul 2013 Location: Tanzania -Shy-Town
Member: 1979644 Status: Offline Sonork: mk47 Thanks Meter: 26 | hi team! who is yellow boss? i want to join this man and his team by buying cm2 activation this man puting in danger volca**fernal. |
07-10-2017, 00:32 | #40 (permalink) |
Freak Poster Join Date: Mar 2016 Location: LIBERIA MONROVIA
Member: 2540958 Status: Offline Thanks Meter: 71 | Really needs improvement on mtk and spd frp cause some are still saying faild so please team work it out in next update comming Last edited by jesse k kondoba; 07-10-2017 at 00:38. |
07-10-2017, 05:19 | #41 (permalink) | |
No Life Poster Join Date: Sep 2006 Location: ---> Hope
Member: 355782 Status: Offline Thanks Meter: 1,265 | Quote:
follow the link below. http://forum.gsmhosting.com/vbb/f296...m2mtk-2225587/ | |
The Following User Says Thank You to Nasir Mobiles For This Useful Post: |
07-10-2017, 10:05 | #44 (permalink) |
No Life Poster Join Date: Apr 2006 Location: I.N.D.I.A
Member: 256247 Status: Offline Thanks Meter: 444 | ----- > Phone/Tablet : 1. Power Off device 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable! Press 'POWER_ON' button for a few second! ----- > IoT/Box : 1. Reset device power 2. PRESS and HOLD 'RESET' KEY! 3. Insert OTG/USB cable! Press 'POWER_ON' button for a few second! Wait for device ... Device Connected! Interface test : Passed Device mode : Normal [ LOADER OPEN ] Machine : RK2928 Device : N12GJ-QZ ExtInfo : 4.1.1 SoC CPU : 292X SoC PDT : 2012 SoC SWN : 0823 SoC REV : V300 Flash CSx : 0x00 Flash Type : ADD794DA74 [ NAND ] Flash Vend : HYNIX Flash Size : 0x0000000100000000 ( 4.00 GiB ) Flash Info : 2097152/8192/42/40/1 Connect Ok! Wiping UserData ... Wipe DATA Ok! Done! Elapsed: 00:00:01 THANKS INFINITY TEAM |
The Following User Says Thank You to irfanboss For This Useful Post: |
