03-01-2019, 16:09 | #1 (permalink) |
No Life Poster Join Date: Oct 2015 Location: Pakistan
Member: 2478233 Status: Offline Thanks Meter: 596 | true super 4 read flash faild phone with network lock now dead Set mode to : SP SC77xx [Model Select] Loading : Super4_Unlock_Sim2.pac CRVersion : BP_R1.0.0 PacCPUinfo : SharkLSGLobalMarlinAndroid5.1 PacVersion : Super4_Unlock_Sim2 FastCheck : 0x005B7CEA17 Loading files ... File : fdl1-sign.bin File : fdl2-sign.bin File : boot_fd4bc0_hexedit.bin File : system_COM121.img File : userdata.img File : cache.img File : SharkLSGLobalMarlinAndroid5.1.xml Load Ok! Operation : Check/Read Info [ v1.27 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Device boot not done Check Drivers Try again Reconnect Power/Cable! Operation : Check/Read Info [ v1.27 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 14 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FLASH : eMMC Flash , Structure : Ok! Reading extended info ... Model Name : F09_32v4 Model Brand : SPRD Model Device: F09_32v4 AndrVersion : 6.0 BaseBand CPU: F09_32V4 CompileDate : 21/10/2016 9:10:38 AM Project Ver : True_Super4_V12_161021 Model Ext : Super 4 ExtraInfo : HWInfo not exists, normal phone Elapsed: 00:00:27 Reconnect Power/Cable! Operation : Read FullFlash [ v1.27 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 14 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac Boot failed! Lost connection with Target! Boot failed! Reconnect Power/Cable! |
