Infinity Box Chinese Miracle2 CM2 MTK V2 Relesed Infinity Box Chinese Miracle2 CM2 MTK V2 Relesed:) This release DO NOT require Smart-Card update! Smart-Card version required is 01.36 MTK 6570 CPU support: with NAND memory with eMMC memory Read Info - Complete device info, Security info Read Firmware - Factory Scatter format [ NAND supported - WorldFirst and unique! ] Write Firmware - Factory Scatter Format [ NAND supported - WorldFirst and unique! ] Read NVRAM Write NVRAM Repair Security Formay FS - FRP, Settings, Privacy ( and mixed/special mode ) MemoryTool MTK 6750 CPU support: Read Info - Complete device info, Security info Read Firmware Write Firmware Read NVRAM Write NVRAM Repair Security Formay FS - FRP, Settings, Privacy ( and mixed/special mode ) MemoryTool MTK 6755 CPU support: Read Info - Complete device info, Security info Read Firmware Write Firmware Read NVRAM Write NVRAM Repair Security Formay FS - FRP, Settings, Privacy ( and mixed/special mode ) MemoryTool MTK 6757 CPU support: Read Info - Complete device info, Security info Read Firmware Write Firmware Read NVRAM Write NVRAM Repair Security Formay FS - FRP, Settings, Privacy ( and mixed/special mode ) MemoryTool MTK 6763 CPU support: Read Info - Complete device info, Security info Read Firmware Write Firmware Read NVRAM Write NVRAM Repair Security Formay FS - FRP, Settings, Privacy ( and mixed/special mode ) MemoryTool MTK 6797 CPU support: Read Info - Complete device info, Security info Read Firmware Write Firmware Read NVRAM Write NVRAM Repair Security Formay FS - FRP, Settings, Privacy ( and mixed/special mode ) MemoryTool Under Test -------------------------------------------------------- MTK 6758 CPU support: Read Info - Complete device info, Security info Read Firmware Write Firmware Read NVRAM Write NVRAM Repair Security Formay FS - FRP, Settings, Privacy ( and mixed/special mode ) MemoryTool MTK 6739 CPU support: with NAND memory with eMMC memory Read Info - Complete device info, Security info Read Firmware Write Firmware Read NVRAM Write NVRAM Repair Security Formay FS - FRP, Settings, Privacy ( and mixed/special mode ) MemoryTool Main - New look and design. All simplified and optimized much, as possible. [ please refer to v2 interface introduction ] - New core. All code made from scratch. - New boot chain selection mode - automatic ( via defined user combination ) or manual. - New connection - Complete error handling and explanation - Internal EMIDB cover 99% of existing memory devices on both - NAND and eMMC devices - Easy end user customization for adding support for new device and e.t.c. Flasher - Completely new flasher design, which allow customize whole flashing process [ please refer to v2 interface introduction ] FW Reader - Completely new core, which allow handle all existing types and flash devices. Service - Security repair NOT require reboot to meta, not required CDC drivers or whatever else. All direct. - Format FS include different mode, optimized for different secure devices type ( with FORMAT, WRITE protection ) - During NVRAM read/write SW also verify it condition and data MEMORY TOOL activated! Easy, fast and ultimate solution now come in MTK too! - Support eMMC and NAND flash IC`secure - Allow READ, WRITE, ERASE partitions - Show partitions states and info only for eMMC devices - Allow RE-init PMT ( from scatter ) Other Lot of other changes from v1 line, which not mandatory to mention Known issues/warnings/info: 1. [NAND on MT6570] v1712, v1736 loader packages NOT SHOULD BE USED! Since they have ftl/ecc errors! In result you will give read/write FW errors and rest problems at all. Recommend use v1724 for FACTORY FW flashing, v18xx line for Infinity FW Flash Read and Write 2. [NAND on MT6570] In some cases "stuck on logo" devices can be fixed only via FFU (whole flash) format! 1. [NAND on MT6570] UBI SPARSE image flashing may take MUCH time (up to 5 minutes and more) for some devices! 3. [MEMORY TOOL] Partitions state on MEMORY TOOL will be empty in MT6570 NAND phones, it is normal and cannot be fixed. Read-write data, which you want, ignore "EMPTY" states. 4. [MEMORY TOOL] Old protocol secure devices (MT6750/MT6755) - LeEco and similar In some cases WIPE partition may not work! 5. ADL checksum MAY NOT WORK CORRECT on MT6570 NAND/eMMC devices! Result - stuck after system/userdata partition flashing 6. FileSyhstems flashing on some SBC-enabled devices ( except SYSTEM/CACHE/USER ) may fail! Solution - exclude them from flashing list. 7. Device with NV_TYPE2 security may not work yet for repair sec! Index of pub/software/ Br Raza400:) |
are you sure it's official public version ? there are no official information yet https://www.infinity-box.com/news/ |
if you have any thought leave it dont download:D Br Raza400 |
https://s9.postimg.cc/lr4ifj1bj/Screenshot_1.jpg https://s9.postimg.cc/led49cyhb/Screenshot_2.jpg |
@SR9 that is not your job to warn me when i warn you i am a ps of a tool who are you??? dont discus here offtopic come private if you have personal problem with me |
change base one by one and repeat prosess |
alredy cng But same result |
my small advice - wait for official release |
This cm2 MTv2.0 not working on any phone I tried on 2 phones changed base one by one and tried to use my own downloaded DA and auth but it giving always error so I think it's full fake update Sent from my XT1033 using Tapatalk |
