Old 01-14-2016, 09:48   #1 (permalink)
sky73's Avatar
Member: 1876736
Thanks Meter: 735
y360-u61 dead
its Preloader Status : Not active (Erased)
how can i fix this?
Operation : HW Test [ v1.40 ]
Wait for phone...
Phone found! [ 12 ]
Sync...
Inital regs read done
Boot Info :
BB_CPU_ID : 6582
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0001
BB_CPU_NM : [MediaTek] MT6582_S00
Processing BROM stage
SecCfgVal : 0x00000000
BromVersion : 0x05
BLVersion : 0xFE
Processing DA stage
DA Select done , sending
DA Ver : MTK_AllInOne_DA_v5.1540.01.01
NAND_ID : 00000000000000000000000000000000
eMMC_ID : 110100303034474530016C1E6E339289
DA Stat : v4.2 on BBID : 0x87
DRAM not initialized , configure DRAM Settings
DRAM EmiReq Ok , 0x00BC
Error : DA init Failed! Error code : 0x5
LErr : 00000BBF
Boot Error!
Operation Failed
Elapsed: 00:00:08
Reconnect Power/Cable!
Operation : Flash [ v1.40 ]
======= Flash
Wait for phone...
Phone found! [ 12 ]
Sync...
Boot Info :
BB_CPU_ID : 6582
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0001
BromVersion : 0x05
BLVersion : 0xFE
Processing DA stage
LErr : 00000BBF
Boot Error!
Operation Failed
Elapsed: 00:00:09
plz help
thx
Old 01-14-2016, 10:09   #2 (permalink)
sky73's Avatar
Member: 1876736
Thanks Meter: 735
plz help .....................
The Following User Says Thank You to sky73 For This Useful Post:
Old 01-14-2016, 11:28   #3 (permalink)
sky73's Avatar
Member: 1876736
Thanks Meter: 735
How to flash this? There is way?
Old 01-14-2016, 12:34   #4 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
It can't init DRAM by some reason.
Do you flashing it with CORRECT fw?
The Following User Says Thank You to JayDi For This Useful Post:
Old 01-14-2016, 12:45   #5 (permalink)
farsi_007's Avatar
Member: 472592
Sonork: 100.1664052
Thanks Meter: 180
fORMAT ALL IN SP FLASH TOOL THEN FIRMWARE UPGRADE,
IT'LL OK
The Following User Says Thank You to farsi_007 For This Useful Post:
Old 01-14-2016, 13:32   #6 (permalink)
GSM KPK's Avatar
Member: 2166444
Thanks Meter: 298
infinity support models Y360-U61
Operation : Check / Read Info [ v1.40 ]
Wait for phone...
Phone found! [ 10 ]
Sync...
Boot Info :
BB_CPU_ID : 6582
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0001
BromVersion : 0xFF
BLVersion : 0x01
Preloader Status : Alive
Processing DA stage
eMMC_ID : 45010053454D30344740F555C0B45291
DA Sent. Configure setting now ...
DA started successuflly
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0045 , OEM : 0100
[eMMC] : FLASH_INF : [SANDISK] , G40ME
[eMMC] : FLASH_CID : 45010053454D30344740F555C0B45291
[eMMC] : FLASH_EXT : 0x00200000 , 0x00200000 , 0x00200000
[eMMC] : FLASH_LEN : 0x00000000EC000000
[eMMC] : FLASH_UCP : 3776 MiB
INT RAM : 0x00020000
EXT RAM : 0x20000000
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
[AP] : Initial info read Ok!
Brand : HUAWEI
ProdName : Y360-U61
ProdModel : HUAWEI Y360-U61
Device : HWY360-U
AndroidVer: 4.4.2
MTKxCPU : MT6582
MTKxPRJ : ALPS.KK1.MP1.V2.10
MODEM :
BaseBand : MT6582_S00_MOLY_WR8_W1315_MD_WG_MP_V34_P43_1_wg_n
EXTRA :
LCD [0] : nt35512_wvga_dsi_vdo
LCD [1] : hx8379c_wvga_dsi_vdo ili9806e_dsi_vdo
LCD Res : 800x480
TOUCH [0] : GT1143
TOUCH [1] : MSG2138
TOUCH [2] : ft6336
CAM [0] : gc2355_mipi_raw
CAM [1] : ov2680_mipi_raw
CAM [2] : ov2680_mipi_raw_yiweili
CAM [3] : ov5670_mipi_raw
CAM [4] : hi551_mipi_raw
CAM [5] : ov5670_mipi_raw_yiweili
MODEM : wingtech82_wet_82kk_hspa_wt_pa_sky77590_band18_std _98360c1
LOCALE : es_US en_US zh_CN pt_BR es_ES pt_PT fr_FR de_DE ru_RU it_IT zh_HK zh_TW sv_SE nb_NO da_DK cs_CZ hu_HU sk_SK pl_PL ro_RO el_GR sr_RS mk_MK bg_BG fi_FI et_EE lv_LV lt_LT sl_SI hr_HR uk_UA tr_TR vi_VN in_ID ar_EG nl_NL th_TH ms_MY ca_ES hi_IN en_GB my_MM ko_KR bs_BA mk_MK fa_IR
Done!
Elapsed: 00:00:12
The Following User Says Thank You to GSM KPK For This Useful Post:
Old 01-14-2016, 14:22   #7 (permalink)
sky73's Avatar
Member: 1876736
Thanks Meter: 735
customer say after install app this happed
i cant format with spflashtools or erase with cm2
i think its hardware problem
thx anyway
Old 10-23-2016, 12:45   #8 (permalink)
Member: 2139605
Thanks Meter: 31
Y360-U61 Dead Invalid imei & Unknown Baseband repair 100000% solution
https://docs.google.com/uc?id=0B9XMa...xport=download
The Following User Says Thank You to ziakpk For This Useful Post:
Old 03-25-2017, 08:40   #9 (permalink)
Member: 2617870
thx anyway
Did you succed on this phone . I have same problem
Page generated in 0.23972 seconds with 8 queries
