11-20-2008, 19:15 | #1 (permalink) |
No Life Poster Join Date: Apr 2006 Location: cameroon
Member: 260658 Status: Offline Thanks Meter: 184 | Infinity Can't unlock HUAWAI T156 i try to unlock huawai T156, soft say unlock ok, but phone still locked? please see log below COM1 [VCP0] selected module v1.55 Device: Huawei-T156 Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 0001:22C4 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-sta... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T156_eeprom-sta_20081120-191011.B1E.bin loading data... data loaded reading eeprom-sec... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T156_eeprom-sec_20081120-191014.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T156_eeprom-complete_20081120-191017.B1E.bin reading additional data... done backup critical area Done Check memory ... current status: 0 Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 25 sec Remove/Install battery now ! Unlock instruction: 1. Power-On phone 2. Enter code: 12345678 |
The Following User Says Thank You to nyakam For This Useful Post: |
11-20-2008, 19:30 | #3 (permalink) |
Member: 260658 Status: Offline Thanks Meter: 184 | when i try to writhe eeprom from support, it say error COM1 [VCP0] selected module v1.55 Device: Huawei-T156 Checking data, wait... Action: flash write Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 0001:22C4 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-sta... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T156_eeprom-sta_20081120-192651.B1E.bin loading data... data loaded reading eeprom-sec... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T156_eeprom-sec_20081120-192653.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T156_eeprom-complete_20081120-192655.B1E.bin backup critical area Done Check memory ... unlocking... error: unknown firmware, read flash and send to support ! error: operation failed Check memory Done Write ... reset... done Erasing: Eeprom Writing: Eeprom Write Done Finished, time used: 22 sec Remove/Install battery now ! |
11-20-2008, 19:33 | #5 (permalink) | |
Product Supporter Join Date: Sep 2004 Location: *In the right way*
Member: 84268 Status: Offline Sonork: 100.114149 Thanks Meter: 2,569 | Quote:
please answer at this question: What text you see at phone LCD when you power-on phone with sim card ? | |
11-20-2008, 20:37 | #10 (permalink) |
Member: 84268 Status: Offline Sonork: 100.114149 Thanks Meter: 2,569 | dear, if you didn't see in lcd enter unlock code that's maen : not possible to unlock with infinity box i think it's clear. |
11-21-2008, 08:28 | #12 (permalink) |
No Life Poster Join Date: Feb 2006 Location: Madagascar
Member: 233142 Status: Offline Sonork: 100.1595099 Thanks Meter: 527 | Huawei T161L unlock success Need select T158 COM4 [VCP0] selected module v1.55 Device: Huawei-T158 Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 0001:22C4 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-sta... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T158_eeprom-sta_20081121-091253.B1E.bin loading data... data loaded reading eeprom-sec... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T158_eeprom-sec_20081121-091256.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T158_eeprom-complete_20081121-091259.B1E.bin reading additional data... done backup critical area Done Check memory ... current status: 0 Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 24 sec Remove/Install battery now ! Unlock instruction: 1. Power-On phone 2. Enter code: 12345678 |
The Following User Says Thank You to said4 For This Useful Post: |
11-21-2008, 13:43 | #13 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @said4 Thanks for test report ! Please, read flash from your phone and send full flash backup to [email protected] @all If you have any problems with unlock, please, try to use this new Pana01 v1.56 software: http://www.infinity-box.com/download...na01_v1.56.rar We are waiting for your results. |
11-21-2008, 15:18 | #14 (permalink) | |
Member: 260658 Status: Offline Thanks Meter: 184 | Quote:
COM1 [VCP0] selected module v1.56 Device: Huawei-T156 Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 0001:22C4 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-sta... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T156_eeprom-sta_20081121-145758.B1E.bin loading data... data loaded reading eeprom-sec... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T156_eeprom-sec_20081121-145801.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T156_eeprom-complete_20081121-145803.B1E.bin reading additional data... done backup critical area Done Check memory ... lock found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 22 sec Remove/Install battery now ! Thank you infinity team | |
02-10-2009, 23:00 | #15 (permalink) |
Freak Poster Join Date: Mar 2007
Member: 474339 Status: Offline Thanks Meter: 44 | hi can anybody plz explain this ... bcz i tried on many fones but getting this error... also changed pc. Set Baud Done Connecting ... flash: 00EC:257E Connecting Done Check hardware ... sw version: -PT-P108A2V1.0.0B05 VDF-P108A2B07-Pt-PT04 g3dBV2.0 Sep 22 2008 1 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... loading data... error: source buffer too small: 00000000 instead of 0000000A reading eeprom-security... reading eeprom-complete... reading additional data... error: can't read lock-area backup critical area Failed Finished, time used: 20 sec Remove/Install battery now ! wbr infinity team |
My infinity can't unlock any phone product support please need your help | magucha | Infinity-Box | 3 | 12-21-2009 20:38 |
Infinity can't unlock MXNEC N9 chip Infineon 7880, Infinity team help me ! | coolderheart | Infinity-Box | 1 | 11-15-2009 06:12 |
infinity can't unlock EF 51??????????, | mscomp | Infinity-Box | 1 | 10-21-2009 10:29 |
huawai t156 bleu white not unlock with infinity | santocon | Infinity-Box | 8 | 06-11-2009 09:12 |
Unlock ok huawai t156 with polar ::: THX FOR REPORT :) ::: | nyakam | PolarBox 3 | 1 | 12-04-2008 16:20 |
