08-12-2013, 17:44 | #1 (permalink) |
Freak Poster Join Date: Nov 2007
Member: 638779 Status: Offline Thanks Meter: 201 | Help with iphone 4 clone 1sim i have this phone i flash it without save backup of flash file but no flash file with same name work for it this is info from phone before flash operation Code: Operation: Read Information mode-2 META interface: META_DLL_v6.1108.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... done Release Power button now ! BaseBand chip version: MT6235B, E00 ECO version: DSP firmware version: 2000.00.00 DSP patch version: 1.0 S/W version: MAUI.08B.W09.12.MP.V13 H/W board version: KINGSTAR35_08B_HW Melody version Melody V0.0 Version: MAUI.08B.W09.12.MP.V13 detecting structure imei... done 81 byte(s) read imei #1: 35541279004189407810 Shutdown... done Finished, time used: 48 sec Remove/Install battery now ! KINGSTAR35_08B_PCB01_GPRS_MT6235B_S01.MAUI_08B_W09 _12_MP_V13__Iphone-4G_2010-10-19_128m_En_Ru_Gr_Nl_Fr_Es_It_Sv_No_Pl_De_Ml_Id_Th_ Vn_Cn_Tr_Farsi_Pt_Cz_Cn_He_Ar.B4M with all this flashes home work fine screen image and icons good condition but digitizer not work!!! *KINGSTAR35_08B_PCB01_GPRS_MT6235B_S01.MAUI_08B_W0 9_12_XQ_V01_2011-07-15__A1332_128m_En_Ru_Gr_Nl_Fr_Es_It_Sv_No_Pl_De_Ml _Id_Th_Vn_Cn_Tr_Farsi_Pt_Cz_Cn_He_Ar.B4M *KINGSTAR35_08B_PCB01_GPRS_MT6235B_S01.MAUI_08B_W0 9_12_4S_CSZ_V0_0_2012-04-27_128m_En_Ru_Gr_Nl_Fr_Es_It_Sv_No_Pl_De_Ml_Id_Th_ Vn_Cn_Tr_Farsi_Pt_Cz_Cn_He_Ar.B4M *KINGSTAR35_08B_PCB01_GPRS_MT6235B_S01.MAUI_08B_W0 9_12_M22_V13_2012-01-07_128m_En_Ru_Gr_Nl_Fr_Es_It_Sv_No_Pl_De_Ml_Id_Th_ Vn_Cn_Tr_Farsi_Pt_Cz_Cn_He_Ar.B4M *KINGSTAR35_08B_PCB01_GPRS_MT6235B_S01.MAUI_08B_W0 9_12_M22_V14_2012-02-17_128m_En_Ru_Gr_Nl_Fr_Es_It_Sv_No_Pl_De_Ml_Id_Th_ Vn_Cn_Tr_Farsi_Pt_Cz_Cn_He_Ar.B4M *KINGSTAR35_08B_PCB01_GPRS_MT6235B_S01.MAUI_08B_W0 9_12_XQ_V01__firmware_20111229-193713.B4M *KINGSTAR35_08B_PCB01_GPRS_MT6235B_S01.MAUI_08B_W0 9_12_XQ_V01_2011-07-15__A1332_128m_En_Ru_Gr_Nl_Fr_Es_It_Sv_No_Pl_De_Ml _Id_Th_Vn_Cn_Tr_Farsi_Pt_Cz_Cn_He_Ar.B4M please help wich flash file can i use for solve problem best regards |
08-12-2013, 18:19 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, You should check operation.log file. You can see there what was original phone firmware version - software read version before any flash process. |
08-12-2013, 18:54 | #3 (permalink) |
Member: 638779 Status: Offline Thanks Meter: 201 | this is the first operation Code: Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8B00:8A00 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0028]: 0020:00F10000001D [ST] ST01GW3B chip size: 128Mb page/spare size: 0800/0040 pages per block: 0040 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: absent done Set baudrate (115200)... done interesting cpu type found: 6235:8B00:8A00 ram test (40000000)... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 04000000/04000000 firmware size: 64Mb ffs size: 64Mb detect sec ro... error:0BF9:S_DA_HANDSET_SEC_INFO_NOT_FOUND detect custom parameters... error:0401:S_CUST_PARA_NOT_SUPPORTED detect project-id... project-id: MAUI.08B.W09.12.MP.V13 detect NAND info... number of areas/bytes to read: 1:001A0000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... bootloader version: KINGSTAR35_08B_BOOTLOADER_V005_MT6235B_MAUI_08B_W09_12_MP_V13.bi nfi area detection (3 cores) finished: Ok TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: KINGSTAR35_08B_PCB01_GPRS_MT6235B_S01.MAUI_08B_W09_12_MP_V13.BIN project-id: MAUI.08B.W09.12.MP.V13, 00000000 code offset: 00000000 ffs offset/size [01]: 04000000/04000000 rom info structure: [standard] type (07) TCL-ID is absent ===> done nfi area detection... bootloader version: KINGSTAR35_08B_BOOTLOADER_V005_MT6235B_MAUI_08B_W09_12_MP_V13.bi nfi area detection (3 cores) finished: Ok startup code area #1 check... done number of cores: 3 loading files... number of areas: 3 done write... write bootloader... . . |
08-15-2013, 10:26 | #5 (permalink) |
Member: 638779 Status: Offline Thanks Meter: 201 | thank you for your help but if i flash it with this one the icons are reverse (upside down) and home button not work KINGSTAR35_08B_PCB01_GPRS_MT6235B_S01.MAUI_08B_W09 _12_MP_V13__Iphone-4G_2010-10-19_128m_En_Ru_Gr_Nl_Fr_Es_It_Sv_No_Pl_De_Ml_Id_Th_ Vn_Cn_Tr_Farsi_Pt_Cz_Cn_He_Ar.B4M other files with same name only have 64mb i flash it with this one phone not power on i think because this flash is 64mb KINGSTAR35_08B_PCB01_GPRS_MT6235B_S01.MAUI_08B_W09 _12_MP_V13_2011-01-04_64m_En_Ru_Gr_Nl_Fr_Es_It_Sv_No_Pl_De_Ml_Id_Th_V n_Cn_Tr_Farsi_Pt_Cz_Cn_He_Ar.B4M |
