Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | [ Easy-JTAG ] | Direct Unlock Source | Search | Today's Posts | Mark Forums Read |
![]() | #47 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2002 Location: HYDRA.anyone know were. Age: 53
Member: 18688 Status: Offline Thanks Meter: 69 | Connecting to server... Connection successfully established Checking DongleManager version... DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer: [0007] No update available Why? 1.Smart-Card has latest firmware version. Update is not required. OR 2.Support period is expired, check it here - https://www.infinity-box.com/doc/?r=17 If support expired contact to any seller and renew - https://www.infinity-box.com/buy/ |
The Following User Says Thank You to zino For This Useful Post: |
![]() | #48 (permalink) |
Major Poster ![]() ![]() Join Date: Dec 2011
Member: 1699920 Status: Offline Thanks Meter: 6 | ![]() Redmi 9A, 9C, 9C+NFC bootloader unlocked successfully! Tried to unlock bootloader on Xiaomi Redmi Note 8 Pro. Code: Operation : Unlock BootLoader [ v2.28 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM40) MODE : BOOTROM PORT : 40 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6785 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Krug TYPE : MODERN [RAPHAEL] BROM : MEID : 08520606FADBBF090687046C448077A2 BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM Error : Fail to init protocol! >>> Device not supported for selected operation! |
The Following User Says Thank You to Blockster For This Useful Post: |
![]() | #49 (permalink) |
Product Supporter ![]() ![]() ![]() Join Date: Jun 2009
Member: 1043909 Status: Offline Thanks Meter: 58,947 | New software will be released as soon as it will be finished and well tested. Work is in progress. Please do not ask exact day/time, software research and development is not like potatoes trading, it's impossible to say any exact time. I am sure you undersand this because you are experienced man. |
![]() | #50 (permalink) | |
Member: 1043909 Status: Offline Thanks Meter: 58,947 | Quote:
![]() | #53 (permalink) | |
![]() | #55 (permalink) | |
If it's Ok for you to buy again and again the same tools with different names - no problem at all. | |
![]() | #57 (permalink) | |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2011 Location: Faisalabad
Member: 1527968 Status: Offline Sonork: 100.1651182 Thanks Meter: 432 | Quote:
Operation : Repair Security [ v2.28 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM19) MODE : PRELOADER PORT PORT : 19 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT PTFN : MediaTek USB Port_V1632 (COM35) MODE : BOOTROM PORT : 35 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : 8A621F460E0AE59E39015C4306CEB6EB BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : FCA5E3E56B3C2B96D3A79EAD19B5EBEC2335E3EB3B418BF71C 63665E8F430BA4 BROM : Sending FireFly FireFly : Starting ... FireFly : Init Core FireFly : Core init done! FireFly : Running : v04.04.04 on MT6765 FireFly : eMMC init passed! EMMC: CSD : D05F01328F5913FFFFFFFFEF964000A9 EMMC: CSD : TEMP_WRITE_PROTECT: False EMMC: CSD : PERM_WRITE_PROTECT: False EMMC: CID : 13014E53304A394B39101B4529B3575D EMMC: VEN : MICRON : OEM : 78 : ID : 53304A394B39 EMMC: VEN : MICRON : S0J9K9 EMMC: SNN : 457517491 ( 0x1B4529B3) , MF : 5/2020 EMMC: EXTCSD : rev1.8 ( eMMC 5.1 ) EMMC: EXTCSD [BOOT_BUS_WIDTH] : 0x02 EMMC: EXTCSD [PARTITION_CONFIG] : 0x48 EMMC: EXTCSD [SIZE] : Market : 128 GB EMMC: EXTCSD [SIZE] : Actual : 0x1D1F000000 [ 116.48 GB ] EMMC: EXTCSD [EOL] : EOL status : Normal ( Less than 80% reserved blocks used ) EMMC: EXTCSD [EOL_A] : SLC status : 0% - 10% used EMMC: EXTCSD [EOL_B] : MLC status : 0% - 10% used EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] USER : 0x1D1F000000 [ 116.48 GB ] DA : USB : HIGH-SPEED Boot done! NVRAM : 0xB7125127 NVRAM : State : Ok! INFO : WiFi MAC : 708F47E46F79 INFO : BlTh MAC : 708F47E46F78 INFO : IMEI[1] : xxxxxxxxxxxxxxxx INFO : IMEI[2] : xxxxxxxxxxxxxxxx INFO : set IMEI[1] : xxxxxxxxxxxxxxxxx INFO : set IMEI[2] : xxxxxxxxxxxxxxxxx Update NVRAM ... Update dependencies ... Done! Elapsed: 00:01:55 Reconnect Power/Cable! | |
