12-04-2021, 18:01 | #1 (permalink) |
Freak Poster Join Date: Oct 2010 Location: Transylvania
Member: 1423806 Status: Offline Sonork: 100.1685119 Thanks Meter: 44 | Nokia G20_TA-1336 cannot flash with CM2 Card found : AA****** , v0151 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.28 Load IDBase v1121431 Ok! Update configuration ... Update Ok! Load IDBase v1121431 Ok! Preloader [HW DEV] Info : EMI : DEV : MT6765 EMI : SRC : preloader_t99653aa1.bin EMI : CNT : 0001 EMI : [00] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 4,00 GB ] Operation : Write Flash [ v2.28 ] Repartition : Enabled Flash Verify : Disabled Reg.Pre-Erase : Enabled Verify HW/SW : Enabled SData Backup : Disabled Safe UserData : Disabled Flash Format : Disabled Files :14 [FL] : Set : preloader_T99653AA1.bin [FL] : Set : logo-verified.bin [FL] : Set : md1img-verified.img [FL] : Set : spmfw-verified.img [FL] : Set : scp-verified.img [FL] : Set : sspm-verified.img [FL] : Set : gz-verified.img [FL] : Set : lk-verified.img [FL] : Set : dtbo.img [FL] : Set : tee-verified.img [FL] : Set : wt_custom.img [FL] : Set : logo-verified.bin [FL] : Set : super.img [FL] : Set : userdata.img [FL] : Total size : 0xFB688FCC [ 3,93 GB ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM14) MODE : BOOTROM PORT : 14 Error : Failed to open port! Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! |
12-04-2021, 18:26 | #2 (permalink) |
Member: 1423806 Status: Offline Sonork: 100.1685119 Thanks Meter: 44 | When I try to flash, it gives me the following: Card found : AA****** , v0151 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.28 Load IDBase v1121431 Ok! Update configuration ... Update Ok! Load IDBase v1121431 Ok! Preloader [HW DEV] Info : EMI : DEV : MT6765 EMI : SRC : preloader_t99653aa1.bin EMI : CNT : 0001 EMI : [00] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 4,00 GB ] Operation : Write Flash [ v2.28 ] Repartition : Enabled Flash Verify : Disabled Reg.Pre-Erase : Enabled Verify HW/SW : Enabled SData Backup : Disabled Safe UserData : Disabled Flash Format : Disabled Files :14 [FL] : Set : preloader_T99653AA1.bin [FL] : Set : logo-verified.bin [FL] : Set : md1img-verified.img [FL] : Set : spmfw-verified.img [FL] : Set : scp-verified.img [FL] : Set : sspm-verified.img [FL] : Set : gz-verified.img [FL] : Set : lk-verified.img [FL] : Set : dtbo.img [FL] : Set : tee-verified.img [FL] : Set : wt_custom.img [FL] : Set : logo-verified.bin [FL] : Set : super.img [FL] : Set : userdata.img [FL] : Total size : 0xFB688FCC [ 3,93 GB ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MTK USB Port (COM5) MODE : BOOTROM PORT : 5 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! |
12-04-2021, 19:00 | #3 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Latest CM2MT2 is v2.30 but not v2.28 Last edited by YellowBoss; 12-04-2021 at 20:31. |
12-04-2021, 19:59 | #4 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Reset power, power off device. Wait 10-15 seconds. Repeat operation. Make sure, if you use TP - not hold it during boot. |
12-05-2021, 14:57 | #5 (permalink) |
Member: 1423806 Status: Offline Sonork: 100.1685119 Thanks Meter: 44 | Thank you all! Finally this was the solution: - disconnect phone - press and hold [power] button until phone is restarting - install "Drivers_MTK_v2.0.1.1" - press and hold [vol+]+[vol-] and insert usb cable |
The Following User Says Thank You to redbaronn For This Useful Post: |
