11-23-2021, 10:25 | #46 (permalink) |
Freak Poster Join Date: Oct 2010 Location: indore
Member: 1409652 Status: Offline Sonork: 100.1670588 Thanks Meter: 76 | geonee f10 frp remove done with cm2 Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC9863x_BASE : SC9863_eMMC_2GB_RS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0004 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : Control transfered! Boot Done! Device info : Patch Level : PPR1.180610.011 Display ID : GIONEE_F10_V05_20191017 Ver. Incmt : 132 Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2019-09-05 Build Time : 17.10.2019 Product Model : GIONEE F10 Product Brand : GIONEE Product Name : F10 Product Device : F10 Product Manfct : GIONEE Product Info : F10 Product Board : sp9863a_1h10 Board Platform : sp9863a NVMng : SecurityInfo IMEI[1] : 3 IMEI[2] : 35 IMEI[3] : SEC : SLS:0, SKS:0, SKV:4 Platform Version: MOCORTM_18B_W19.10.2_P21_Debug Project Version: sharkl3_pub BASE Version: FM_BASE_18B_W19.10.2_P21 HW Version: sc9863A_modem CMP_Time : 09-04-2019 19:22:09 MODEM TAG : MOCORTM_18B_W19.10.2_P21_Debug_FM_BASE_18B_W19.10. 2_P21_sc9863A_modem_sharkl3_pub USERDATA : FILESYSTEM : F2FS with FDE ( Full Disk Encryption ***) - > INFO : Remove cable from device to switch it off! Done! Elapsed: 00.01.22 Operation : Format FS / Reset Settings [ v2.14 ] Mode : Reset FRP BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC9863x_BASE : SC9863_eMMC_2GB_RS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0004 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : Control transfered! Boot Done! Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00.00.20 |
The Following 3 Users Say Thank You to ishtiyaque_24 For This Useful Post: |
11-23-2021, 13:51 | #48 (permalink) |
Freak Poster Join Date: Jan 2016 Location: faisalabad Age: 41
Member: 2518014 Status: Offline Thanks Meter: 43 | It was a small bug with install package. Fixed version will be at support area in few minutes its work fine THANKS infinity TEAM |
The Following User Says Thank You to Viaraja786 For This Useful Post: |
11-23-2021, 14:18 | #50 (permalink) |
Junior Member Join Date: Sep 2014 Location: Egypt
Member: 2259751 Status: Offline Sonork: [email protected] Thanks Meter: 0 | Card found : E8BC1E4E , v0151 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.29 Load IDBase v1121431 Ok! UserName and/or Password not set! Can't continue! Load IDBase v1121431 Ok! Operation : Identify [ v2.29 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM12) MODE : BOOTROM PORT : 12 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! hanging |
11-23-2021, 15:33 | #52 (permalink) | |
11-23-2021, 15:58 | #53 (permalink) |
Freak Poster Join Date: Oct 2013 Location: tehran Age: 37
Member: 2048880 Status: Offline Thanks Meter: 63 | hang sir plz help Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.29 Load IDBase v1121xxx Ok! UserName and/or Password not set! Can't continue! Load IDBase v1121xxx Ok! Operation : Reset PrivacyLock [ v2.29 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM94) MODE : PRELOADER PORT PORT : 94 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! Hanging here since..... |
11-23-2021, 16:31 | #54 (permalink) |
Member: 2259751 Status: Offline Sonork: [email protected] Thanks Meter: 0 | |
11-23-2021, 17:18 | #55 (permalink) | |
Dead or water damaged or hardware damaged? | |
11-23-2021, 18:12 | #59 (permalink) |
11-23-2021, 18:13 | #60 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Pakistan
Member: 265626 Status: Offline Sonork: 100.1591486 Thanks Meter: 2,982 | working ok now with new update on support Thanks Always hard and good work Infinity Team |
The Following User Says Thank You to hasnain For This Useful Post: |
