11-23-2021, 22:09 | #62 (permalink) |
No Life Poster Join Date: Sep 2005 Location: Lebanon-Beirut Age: 43
Member: 180903 Status: Offline Sonork: 100.1637253 Thanks Meter: 70 | Frp is still onnnnnnn 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM15) MODE : PRELOADER PORT PORT : 15 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT PTFN : MediaTek USB Port (COM16) MODE : BOOTROM PORT : 16 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : 9166A21B1C2C54E72F0E9EF6FE36C6B5 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : EB2061B834898A01F227C2F103E6C023B08509CA90B68F2726 12651421BD3E3A BROM : Sending FireFly FireFly : Starting ... FireFly : Init Core FireFly : Core init done! FireFly : Running : v04.04.04 on MT6765 FireFly : eMMC init passed! EMMC: CSD : D02701320F5903FFF6DBFFEF8E40400D EMMC: CSD : TEMP_WRITE_PROTECT: False EMMC: CSD : PERM_WRITE_PROTECT: False EMMC: CID : 150100525036344142002C62CA479851 EMMC: VEN : SAMSUNG : OEM : 0 : ID : 525036344142 EMMC: VEN : SAMSUNG : RP64AB EMMC: SNN : 744671815 ( 0x2C62CA47) , MF : 9/2021 EMMC: EXTCSD : rev1.8 ( eMMC 5.1 ) EMMC: EXTCSD [BOOT_BUS_WIDTH] : 0x02 EMMC: EXTCSD [PARTITION_CONFIG] : 0x48 EMMC: EXTCSD [SIZE] : Market : 64 GB EMMC: EXTCSD [SIZE] : Actual : 0xE8F800000 [ 58.24 GB ] EMMC: EXTCSD [EOL] : EOL status : Normal ( Less than 80% reserved blocks used ) EMMC: EXTCSD [EOL_A] : SLC status : 0% - 10% used EMMC: EXTCSD [EOL_B] : MLC status : 0% - 10% used EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] DA : USB : HIGH-SPEED Boot done! Format Ok : RESET PROTECTION Format Ok : USERDATA Format Ok : USERDATA Format Ok : USERDATA Done! Elapsed: 00:00:19 Reconnect Power/Cable! |
The Following User Says Thank You to SAAD3000 For This Useful Post: |
11-23-2021, 22:36 | #63 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
11-24-2021, 07:15 | #66 (permalink) | |
No Life Poster Join Date: Jan 2009 Location: india
Member: 942210 Status: Offline Sonork: 1511 Thanks Meter: 91 | Quote:
11-24-2021, 09:03 | #67 (permalink) |
Crazy Poster Join Date: Jun 2021 Location: ATTOCK Pakistan Age: 39
Member: 2990669 Status: Offline Sonork: 100.1660561 Thanks Meter: 61 | thanks Infinity Team Operation : Identify [ v2.29 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM12) MODE : PRELOADER PORT PORT : 12 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY [MTK] BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN BROM : BROM|BL : 0xFF|0x01 BROM : PRELOADER PORT AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6580 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 460001154D37324A8D6D02422FA2F0CC DAInf: 4 : 2 : 156 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: CID : 150100464A32374D42026D8DCCF0A22F EMMC: VEN : SAMSUNG : OEM : 0 : ID : 464A32374D42 EMMC: VEN : SAMSUNG : FJ27MB EMMC: SNN : 1838009584 ( 0x6D8DCCF0) , MF : 10/2015 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00080000 [ 512.00 KB ] USER : 0xE9000000 [ 3.64 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x30000000 [ 768.00 MB ] CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : BF21CE13808163BE6ACA1F4CF73F378 STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! Patch Level : LMY47I Display ID : ALPS.L1.MP6.V2_TINNO6580.WE.L Ver. CodeName : REL Ver. Release : 5.1 Build Time : 22.11.2016 Product Model : QMobile i6i Product Brand : QMobile Product Name : QMobile i6i Product Device : QMobile Product Manfct : QMobile Board Platform : mt6580 Product Info : QMobile Product Model : i6i USERDATA : FILESYSTEM : EXT4 NVRAM : 0x750293B6 NVRAM : State : Ok! INFO : WiFi MAC : BC44344B3A3D INFO : BlTh MAC : BC44344C01A7 INFO : IMEI[1] : 354242072xxxxxx INFO : IMEI[2] : 354242077xxxxxx Backup sensetive data [ 16 ] Backup path : Backup\MT6580__BF21CE130808163BE6ACA1F4CF73F378\ [3] Read : NVRAM [14] Read : NVDATA [2] Read : PROINFO [7] Read : LK [4] Read : PROTECT1 [5] Read : PROTECT2 [0] Read : PRELOADER Backup done! Done! Elapsed: 00:00:33 |
The Following User Says Thank You to geo/mobile For This Useful Post: |
11-24-2021, 10:50 | #69 (permalink) | |
Freak Poster Join Date: Dec 2005 Location: Russia, 163 region
Member: 210685 Status: Offline Thanks Meter: 20 | Quote:
No shared drivers installed. It remains only to reinstall the operating system or buy a new computer | |
11-24-2021, 11:05 | #71 (permalink) | ||
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
Try remove named driver from system32, reboot PC and check result. Warning - such method of removing may damage whole usb subsystem, so, first remove such software, after remove and still issue present, possible to remove their left pieces. | ||
11-24-2021, 11:39 | #74 (permalink) | |
No Life Poster Join Date: Feb 2003 Location: Somewhere
Member: 22466 Status: Offline Thanks Meter: 282 | Brom problem Quote:
11-24-2021, 12:20 | #75 (permalink) |
No Life Poster Join Date: Apr 2017 Location: GOLD SINDH
Member: 2705849 Status: Offline Thanks Meter: 664 | Always rocking King Cm2 update,kindly update latest security patch 2020/2021 all mtk cpu's in next update |
The Following User Says Thank You to Iftakhar Rajper For This Useful Post: |
