11-26-2021, 10:28 | #1 (permalink) |
Freak Poster Join Date: Jul 2008 Location: GSM,Pakistan
Member: 811049 Status: Offline Thanks Meter: 99 | infinix x657b frp reset failed Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.28 Load IDBase v718267 Ok! UserName and/or Password not set! Can't continue! Update failed! Check settings and/or internet connection! Operation : Reset Settings/Format FS [ v2.28 ] Mode : FRP [ RESET PROTECTION ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM3) MODE : PRELOADER PORT PORT : 3 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0200 CODE : Merlot TYPE : MODERN [RAPHAEL] BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT BROM : PreBoot stage #1 BROM : PreBoot stage #2 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6761 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : Reset Interface! PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM3) MODE : PRELOADER PORT PORT : 3 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0200 CODE : Merlot TYPE : MODERN [RAPHAEL] BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT BROM : PreBoot stage #1 BROM : PreBoot stage #2 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6761 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : 0x00007024 : DA SEND ERROR! ERROR : SECURE BOOT : SELECTED DA NOT SUPPORTED IN CURRENT DEVICE STATE! INFO : PRELOADER Level : CORRECT DA required : PL/PL_CRYPTO/SWSEC Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Operation : Reset Settings/Format FS [ v2.28 ] Mode : FRP [ RESET PROTECTION ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM3) MODE : PRELOADER PORT PORT : 3 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0200 CODE : Merlot TYPE : MODERN [RAPHAEL] BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT BROM : PreBoot stage #1 BROM : PreBoot stage #2 AGENT : 0_base : X_FireFly | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6761 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : Reset Interface! PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM3) MODE : PRELOADER PORT PORT : 3 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0200 CODE : Merlot TYPE : MODERN [RAPHAEL] BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT BROM : PreBoot stage #1 BROM : PreBoot stage #2 AGENT : 0_base : X_FireFly | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6761 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : 0x00007024 : DA SEND ERROR! ERROR : SECURE BOOT : SELECTED DA NOT SUPPORTED IN CURRENT DEVICE STATE! INFO : PRELOADER Level : CORRECT DA required : PL/PL_CRYPTO/SWSEC Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! |
