11-20-2021, 00:06 | #1 (permalink) |
No Life Poster Join Date: Feb 2004 Location: Algeria
Member: 56090 Status: Offline Thanks Meter: 162 | Bricked Oppo a93 CPH2121 "download not complete error code 0x99256658" how fix this problem.. Salam |
11-20-2021, 12:19 | #2 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Hello, Post flashing logs. And make sure you are using latest version of firmware. Br. Infinity-Box Team. |
The Following 2 Users Say Thank You to PASSIONATE_BOYS For This Useful Post: |
11-20-2021, 18:14 | #3 (permalink) | |
Member: 56090 Status: Offline Thanks Meter: 162 | Quote:
Code: Operation : Read Firmware [ v2.28 ] ExtSparse : Enabled ForceRead : Disabled 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM17) MODE : BOOTROM PORT : 17 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6779 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 CODE : Lafite TYPE : MODERN [RAPHAEL] BROM : MEID : 83EBD66B326493F0BC6B98B7637952BF BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 7CE6E96E844E00D4C3D616283A98B3B1D83A05FD9C5D70E6259EF5CEEA0522BA BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : FF : Look for EMI BROM : FF : EMI found! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F BROM : PreBoot stage #1 BROM : PreBoot stage #2 AGENT : Xiaomi : Helio [G70][G80] | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : CHANGE : v2112 AGENT : Found MT6779 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_oppo6779.bin EMI : CNT : 000D EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00080000 [ 512,00 KB ] DRAM: 0x200000000 [ 8,00 GB ] UFS: CE014B4D3856373030314A4D2D423831 UFS: VEN : 0x01CE VID : KM8V7001JM-B81 IFW : 1200 LU0 : 0x00400000 [ 4,00 MB ] LU1 : 0x00400000 [ 4,00 MB ] LU2 : 0x1DCB000000 [ 119,17 GB ] FSN : 3bf2aec5991d REG : 0x101010000 CHIP : MT6779 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 762CCBF4FE32260135DD3B23BE567EB1 DA : USB : HIGH-SPEED Boot done! Product Board : oppo6779 Board Platform : mt6779 Product Brand : alps Product Device : oppo6779 Product Manfct : alps Product Model : oppo6779 Product Name : vnd_oppo6779 MT6779__alps__oppo6779 Read : preloader.bin Read : recovery.img Read : opporeserve1.img Read : opporeserve2.img ExtSparse : Compression ratio : 59% Read : oppo_custom.img Read : vbmeta.img Read : persist.img ExtSparse : Compression ratio : 95% Read : proinfo.img Read : nvram.bin Read : ocdt.img Read : cdt_engineering.img Read : md1rom.img Read : spmfw.img Read : audio_dsp.img Read : tinysys-scp.bin Read : sspm.img Read : cam_vpu1.img Read : cam_vpu2.img Read : cam_vpu3.img Read : gz.img Read : lk.bin Read : boot.img Read : logo.bin Read : dtbo.img Read : tz.img Read : special_preload.img ExtSparse : Compression ratio : 99% Read : my_custom.img ExtSparse : Compression ratio : 99% Read : vbmeta_system.img Read : vbmeta_vendor.img Read : super.img ExtSparse : Compression ratio : 86% Read : cache.img Read : userdata.img FW Size : 1,49 GB Android Info saved : _Android_info.txt Scatter : MT6779_Android_scatter.txt Saved to : L:\_Oppo\MT6779__alps__oppo6779\ | |
11-20-2021, 18:22 | #5 (permalink) | |
Member: 56090 Status: Offline Thanks Meter: 162 | Write full flash with memry tool except userdata partition Quote:
11-20-2021, 19:07 | #6 (permalink) |
Member: 56090 Status: Offline Thanks Meter: 162 | Write full flash with memory tool except userdata partition Code: Operation Write Memory Write selected partitions [49] [0] Write partition : PRELOADER Write from : L:\_Oppo\a93\PRELOADER.bin ERR : 0xC0010001 ERR : ERROR ERR : 0x00000000|0x00000000 [1] Write partition : PGPT Write from : L:\_Oppo\a93\PGPT.bin Write partition Ok! [2] Write partition : RECOVERY Write from : L:\_Oppo\a93\RECOVERY.bin Write partition Ok! [3] Write partition : MISC Write from : L:\_Oppo\a93\MISC.bin ERR : 0xC002002A ERR : SEC : IMG TYPE MISMATCH ERR : 0x00080000|0x00080000 [4] Write partition : PARA Write from : L:\_Oppo\a93\PARA.bin ERR : 0xC002002A ERR : SEC : IMG TYPE MISMATCH ERR : 0x00080000|0x00080000 [5] Write partition : OPPORESERVE1 Write from : L:\_Oppo\a93\OPPORESERVE1.bin ERR : 0xC002002A ERR : SEC : IMG TYPE MISMATCH ERR : 0x00800000|0x00800000 [6] Write partition : OPPORESERVE2 Write from : L:\_Oppo\a93\OPPORESERVE2.bin ERR : 0xC002002A ERR : SEC : IMG TYPE MISMATCH ERR : 0x04000000|0x04000000 [7] Write partition : OPPORESERVE3 Write from : L:\_Oppo\a93\OPPORESERVE3.bin ERR : 0xC002002A ERR : SEC : IMG TYPE MISMATCH ERR : 0x04000000|0x04000000 [8] Write partition : OPPO_CUSTOM Write from : L:\_Oppo\a93\OPPO_CUSTOM.bin ERR : 0xC002002A ERR : SEC : IMG TYPE MISMATCH ERR : 0x00100000|0x00100000 [9] Write partition : EXPDB Write from : L:\_Oppo\a93\EXPDB.bin ERR : 0xC002002A ERR : SEC : IMG TYPE MISMATCH ERR : 0x01400000|0x01400000 [10] Write partition : FRP Write from : L:\_Oppo\a93\FRP.bin ERR : 0xC002002A ERR : SEC : IMG TYPE MISMATCH ERR : 0x00100000|0x00100000 [11] Write partition : VBMETA Write from : L:\_Oppo\a93\VBMETA.bin Write partition Ok! [12] Write partition : METADATA Write from : L:\_Oppo\a93\METADATA.bin ERR : 0xC002002A ERR : SEC : IMG TYPE MISMATCH ERR : 0x02000000|0x02000000 [13] Write partition : PROTECT1 Write from : L:\_Oppo\a93\PROTECT1.bin Write partition Ok! [14] Write partition : PROTECT2 Write from : L:\_Oppo\a93\PROTECT2.bin Write partition Ok! [15] Write partition : SECCFG Write from : L:\_Oppo\a93\SECCFG.bin ERR : 0xC002002A ERR : SEC : IMG TYPE MISMATCH ERR : 0x00080000|0x00080000 [16] Write partition : PERSIST Write from : L:\_Oppo\a93\PERSIST.bin Write partition Ok! [17] Write partition : SEC1 Write from : L:\_Oppo\a93\SEC1.bin ERR : 0xC002002A ERR : SEC : IMG TYPE MISMATCH ERR : 0x00200000|0x00200000 [18] Write partition : PROINFO Write from : L:\_Oppo\a93\PROINFO.bin Write partition Ok! [19] Write partition : OCDT Write from : L:\_Oppo\a93\OCDT.bin ERR : 0xC002002A ERR : SEC : IMG TYPE MISMATCH ERR : 0x00800000|0x00800000 [20] Write partition : MAIN_CDT Write from : L:\_Oppo\a93\MAIN_CDT.bin ERR : 0xC002002A ERR : SEC : IMG TYPE MISMATCH ERR : 0x00800000|0x00800000 [21] Write partition : CDT_ENGINEERING Write from : L:\_Oppo\a93\CDT_ENGINEERING.bin ERR : 0xC002002A ERR : SEC : IMG TYPE MISMATCH ERR : 0x00800000|0x00800000 [22] Write partition : MD1IMG Write from : L:\_Oppo\a93\MD1IMG.bin ERR : 0xC0020005 ERR : SEC : IMG TOO LARGE ERR : 0x00000000|0x09600000 [23] Write partition : BOOT_PARA Write from : L:\_Oppo\a93\BOOT_PARA.bin ERR : 0xC002002A ERR : SEC : IMG TYPE MISMATCH ERR : 0x01A00000|0x01A00000 [24] Write partition : SPMFW Write from : L:\_Oppo\a93\SPMFW.bin Write partition Ok! [25] Write partition : AUDIO_DSP Write from : L:\_Oppo\a93\AUDIO_DSP.bin Write partition Ok! [26] Write partition : SCP1 Write from : L:\_Oppo\a93\SCP1.bin Write partition Ok! [27] Write partition : SCP2 Write from : L:\_Oppo\a93\SCP2.bin Write partition Ok! [28] Write partition : SSPM_1 Write from : L:\_Oppo\a93\SSPM_1.bin Write partition Ok! [29] Write partition : SSPM_2 Write from : L:\_Oppo\a93\SSPM_2.bin Write partition Ok! [30] Write partition : CAM_VPU1 Write from : L:\_Oppo\a93\CAM_VPU1.bin Write partition Ok! [31] Write partition : CAM_VPU2 Write from : L:\_Oppo\a93\CAM_VPU2.bin Write partition Ok! [32] Write partition : CAM_VPU3 Write from : L:\_Oppo\a93\CAM_VPU3.bin Write partition Ok! [33] Write partition : GZ1 Write from : L:\_Oppo\a93\GZ1.bin Write partition Ok! [34] Write partition : GZ2 Write from : L:\_Oppo\a93\GZ2.bin Write partition Ok! [35] Write partition : LK Write from : L:\_Oppo\a93\LK.bin Write partition Ok! [36] Write partition : LK2 Write from : L:\_Oppo\a93\LK2.bin Write partition Ok! [37] Write partition : BOOT Write from : L:\_Oppo\a93\BOOT.bin Write partition Ok! [38] Write partition : LOGO Write from : L:\_Oppo\a93\LOGO.bin Write partition Ok! [39] Write partition : DTBO Write from : L:\_Oppo\a93\DTBO.bin Write partition Ok! [40] Write partition : TEE1 Write from : L:\_Oppo\a93\TEE1.bin Write partition Ok! [41] Write partition : TEE2 Write from : L:\_Oppo\a93\TEE2.bin Write partition Ok! [42] Write partition : SPECIAL_PRELOAD Write from : L:\_Oppo\a93\SPECIAL_PRELOAD.bin ERR : 0xC0020005 ERR : SEC : IMG TOO LARGE ERR : 0x00000000|0x30000000 [43] Write partition : MY_CUSTOM Write from : L:\_Oppo\a93\MY_CUSTOM.bin ERR : 0xC0020005 ERR : SEC : IMG TOO LARGE ERR : 0x00000000|0x10000000 [44] Write partition : VBMETA_SYSTEM Write from : L:\_Oppo\a93\VBMETA_SYSTEM.bin Write partition Ok! [45] Write partition : VBMETA_VENDOR Write from : L:\_Oppo\a93\VBMETA_VENDOR.bin Write partition Ok! [46] Write partition : SUPER Write from : L:\_Oppo\a93\SUPER.bin Write partition Ok! [47] Write partition : CACHE Write from : L:\_Oppo\a93\CACHE.bin Write partition Ok! [48] Write partition : MD_UDC Write from : L:\_Oppo\a93\MD_UDC.bin ERR : 0xC002002A ERR : SEC : IMG TYPE MISMATCH ERR : 0x01800000|0x01800000 Operation finished! |
11-21-2021, 10:53 | #8 (permalink) |
Member: 56090 Status: Offline Thanks Meter: 162 | From working phone i cna read my custom.img but can't write it to the breacked one neither to to the working phone Code: [20] Write partition : MY_CUSTOM Write from : L:\_Oppo\MT6779__alps__oppo6779\MY_CUSTOM.img ERR : 0xC002002A ERR : SEC : IMG TYPE MISMATCH ERR : 0x0044B070|0x0044B070 |
11-21-2021, 11:13 | #9 (permalink) |
Member: 56090 Status: Offline Thanks Meter: 162 | Code: \MT6779__alps__oppo6779\OPPORESERVE1.img ERR : 0xC002002A ERR : SEC : IMG TYPE MISMATCH ERR : 0x00459010|0x00459010 [2] Write partition : OPPORESERVE2 Write from : L:\_Oppo\MT6779__alps__oppo6779\OPPORESERVE2.img ERR : 0xC002002A ERR : SEC : IMG TYPE MISMATCH ERR : 0x01A8F2EC|0x01A8F2EC [4] Write partition : OPPO_CUSTOM Write from : L:\_Oppo\MT6779__alps__oppo6779\OPPO_CUSTOM.img ERR : 0xC002002A ERR : SEC : IMG TYPE MISMATCH ERR : 0x00007E00|0x00007E00 [8] Write partition : OCDT Write from : L:\_Oppo\MT6779__alps__oppo6779\OCDT.img ERR : 0xC002002A ERR : SEC : IMG TYPE MISMATCH ERR : 0x00001200|0x00001200 [9] Write partition : CDT_ENGINEERING Write from : L:\_Oppo\MT6779__alps__oppo6779\CDT_ENGINEERING.img ERR : 0xC002002A ERR : SEC : IMG TYPE MISMATCH ERR : 0x00000040|0x00000040 [19] Write partition : SPECIAL_PRELOAD Write from : L:\_Oppo\MT6779__alps__oppo6779\SPECIAL_PRELOAD.img ERR : 0xC002002A ERR : SEC : IMG TYPE MISMATCH ERR : 0x00CA30A0|0x00CA30A0 [20] Write partition : MY_CUSTOM Write from : L:\_Oppo\MT6779__alps__oppo6779\MY_CUSTOM.img ERR : 0xC002002A ERR : SEC : IMG TYPE MISMATCH ERR : 0x0044B070|0x0044B070 |
11-21-2021, 11:14 | #10 (permalink) |
11-22-2021, 02:32 | #14 (permalink) |
Product Supporter Join Date: Jun 2014 Location: India
Member: 2211790 Status: Offline Thanks Meter: 5,118 | Read post #4 again Tick extended mode load scatter Select custom and reserve partition from working phone full flash it It's Fully supported if you know how to do |
11-22-2021, 13:15 | #15 (permalink) | |
Code: v2.28 Load IDBase v718267 Ok! UserName and/or Password not set! Can't continue! Update failed! Check settings and/or internet connection! Created by Infinity-Box (c) 2021 Chinese Miracle II : MediaTek Service Module Device Info file : _Android_info.txt Product Board : oppo6779 Board Platform : mt6779 Product Brand : alps Product Device : oppo6779 Product Manfct : alps Product Model : oppo6779 Product Name : vnd_oppo6779 Preloader [HW DEV] Info : EMI : DEV : MT6752 EMI : SRC : preloader_oppo6779.bin EMI : CNT : 000D EMI : [00] : eUFS : LP_DDR4X : DEV : KM2V7001CM-B706 : RAM : [ 6,00 GB ] EMI : [01] : eUFS : LP_DDR4X : DEV : KM8V7001JA-B813 : RAM : [ 8,00 GB ] EMI : [02] : eMMC : LP_DDR4X : ID : 90014A68433861503E : VEN : HYNIX | DEV : hC8aP> : RAM : [ 4,00 GB ] EMI : [03] : eMMC : LP_DDR4X : ID : 13014E53304A394B39 : VEN : MICRON | DEV : S0J9K9 : RAM : [ 4,00 GB ] EMI : [04] : eUFS : LP_DDR4X : DEV : KM8V7001JM-B810 : RAM : [ 8,00 GB ] EMI : [05] : eUFS : LP_DDR4X : DEV : H9HQ16AECMMDAR : RAM : [ 6,00 GB ] EMI : [06] : eUFS : LP_DDR4X : DEV : H9HQ16AFAMMDAR : RAM : [ 8,00 GB ] EMI : [07] : eUFS : LP_DDR4X : DEV : KM2V8001CM-B707 : RAM : [ 6,00 GB ] EMI : [08] : eUFS : LP_DDR4X : DEV : KM5V7001DM-B621 : RAM : [ 4,00 GB ] EMI : [09] : eUFS : LP_DDR4X : DEV : KM2B8001CM-BB01 : RAM : [ 6,00 GB ] EMI : [0A] : eUFS : LP_DDR4X : DEV : KM8B8001JM-BC01 : RAM : [ 8,00 GB ] EMI : [0B] : eUFS : LP_DDR4X : DEV : KM8V8001JM-B813 : RAM : [ 8,00 GB ] EMI : [0C] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 6,00 GB ] Created by Infinity-Box (c) 2021 Chinese Miracle II : MediaTek Service Module Device Info file : _Android_info.txt Product Board : oppo6779 Board Platform : mt6779 Product Brand : alps Product Device : oppo6779 Product Manfct : alps Product Model : oppo6779 Product Name : vnd_oppo6779 Preloader [HW DEV] Info : EMI : DEV : MT6752 EMI : SRC : preloader_oppo6779.bin EMI : CNT : 000D EMI : [00] : eUFS : LP_DDR4X : DEV : KM2V7001CM-B706 : RAM : [ 6,00 GB ] EMI : [01] : eUFS : LP_DDR4X : DEV : KM8V7001JA-B813 : RAM : [ 8,00 GB ] EMI : [02] : eMMC : LP_DDR4X : ID : 90014A68433861503E : VEN : HYNIX | DEV : hC8aP> : RAM : [ 4,00 GB ] EMI : [03] : eMMC : LP_DDR4X : ID : 13014E53304A394B39 : VEN : MICRON | DEV : S0J9K9 : RAM : [ 4,00 GB ] EMI : [04] : eUFS : LP_DDR4X : DEV : KM8V7001JM-B810 : RAM : [ 8,00 GB ] EMI : [05] : eUFS : LP_DDR4X : DEV : H9HQ16AECMMDAR : RAM : [ 6,00 GB ] EMI : [06] : eUFS : LP_DDR4X : DEV : H9HQ16AFAMMDAR : RAM : [ 8,00 GB ] EMI : [07] : eUFS : LP_DDR4X : DEV : KM2V8001CM-B707 : RAM : [ 6,00 GB ] EMI : [08] : eUFS : LP_DDR4X : DEV : KM5V7001DM-B621 : RAM : [ 4,00 GB ] EMI : [09] : eUFS : LP_DDR4X : DEV : KM2B8001CM-BB01 : RAM : [ 6,00 GB ] EMI : [0A] : eUFS : LP_DDR4X : DEV : KM8B8001JM-BC01 : RAM : [ 8,00 GB ] EMI : [0B] : eUFS : LP_DDR4X : DEV : KM8V8001JM-B813 : RAM : [ 8,00 GB ] EMI : [0C] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 6,00 GB ] Operation : Write Flash [ v2.28 ] Repartition : Enabled Flash Verify : Disabled Reg.Pre-Erase : Disabled Verify HW/SW : Enabled SData Backup : Disabled Safe UserData : Disabled Flash Format : Disabled Files :31 [FL] : Set : preloader_oppo6779.bin [FL] : Set : recovery.img [FL] : Set : opporeserve2.img [FL] : Set : vbmeta.img [FL] : Set : cdt_engineering.img [FL] : Set : md1rom.img [FL] : Set : spmfw.img [FL] : Set : audio_dsp.img [FL] : Set : tinysys-scp.bin [FL] : Set : tinysys-scp.bin [FL] : Set : sspm.img [FL] : Set : sspm.img [FL] : Set : cam_vpu1.img [FL] : Set : cam_vpu2.img [FL] : Set : cam_vpu3.img [FL] : Set : gz.img [FL] : Set : gz.img [FL] : Set : lk.bin [FL] : Set : lk.bin [FL] : Set : boot.img [FL] : Set : logo.bin [FL] : Set : dtbo.img [FL] : Set : tz.img [FL] : Set : tz.img [FL] : Set : special_preload.img [FL] : Set : my_custom.img [FL] : Set : vbmeta_system.img [FL] : Set : vbmeta_vendor.img [FL] : Set : super.img [FL] : Set : cache.img [FL] : Set : userdata.img [FL] : Total size : 0x5B90B9D8 [ 1,43 GB ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM17) MODE : BOOTROM PORT : 17 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6779 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 CODE : Lafite TYPE : MODERN [RAPHAEL] BROM : MEID : 83EBD66B326493F0BC6B98B7637952BF BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 7CE6E96E844E00D4C3D616283A98B3B1D83A05FD9C5D70E6259EF5CEEA0522BA BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F BROM : PreBoot stage #1 BROM : PreBoot stage #2 AGENT : 0_base : BASE_v1712 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : CHANGE : v2112 AGENT : Found MT6779 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : MT6752 EMI : SRC : preloader_oppo6779.bin EMI : CNT : 000D EMI : [00] : eUFS : LP_DDR4X : DEV : KM2V7001CM-B706 : RAM : [ 6,00 GB ] EMI : [01] : eUFS : LP_DDR4X : DEV : KM8V7001JA-B813 : RAM : [ 8,00 GB ] EMI : [02] : eMMC : LP_DDR4X : ID : 90014A68433861503E : VEN : HYNIX | DEV : hC8aP> : RAM : [ 4,00 GB ] EMI : [03] : eMMC : LP_DDR4X : ID : 13014E53304A394B39 : VEN : MICRON | DEV : S0J9K9 : RAM : [ 4,00 GB ] EMI : [04] : eUFS : LP_DDR4X : DEV : KM8V7001JM-B810 : RAM : [ 8,00 GB ] EMI : [05] : eUFS : LP_DDR4X : DEV : H9HQ16AECMMDAR : RAM : [ 6,00 GB ] EMI : [06] : eUFS : LP_DDR4X : DEV : H9HQ16AFAMMDAR : RAM : [ 8,00 GB ] EMI : [07] : eUFS : LP_DDR4X : DEV : KM2V8001CM-B707 : RAM : [ 6,00 GB ] EMI : [08] : eUFS : LP_DDR4X : DEV : KM5V7001DM-B621 : RAM : [ 4,00 GB ] EMI : [09] : eUFS : LP_DDR4X : DEV : KM2B8001CM-BB01 : RAM : [ 6,00 GB ] EMI : [0A] : eUFS : LP_DDR4X : DEV : KM8B8001JM-BC01 : RAM : [ 8,00 GB ] EMI : [0B] : eUFS : LP_DDR4X : DEV : KM8V8001JM-B813 : RAM : [ 8,00 GB ] EMI : [0C] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 6,00 GB ] EMI : Init EMI from PRELOADER EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00080000 [ 512,00 KB ] DRAM: 0x200000000 [ 8,00 GB ] UFS: CE014B4D3856373030314A4D2D423831 UFS: VEN : 0x01CE VID : KM8V7001JM-B81 IFW : 1200 LU0 : 0x00400000 [ 4,00 MB ] LU1 : 0x00400000 [ 4,00 MB ] LU2 : 0x1DCB000000 [ 119,17 GB ] FSN : 3bf2aec5991d REG : 0x101010000 CHIP : MT6779 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 762CCBF4FE32260135DD3B23BE567EB1 DA : USB : HIGH-SPEED Boot done! [FL] : COMBO scatter! Update settings to UFS [FL] : Set : preloader_oppo6779.bin [FL] : Set : recovery.img [FL] : Set : opporeserve2.img [FL] : Set : vbmeta.img [FL] : Set : cdt_engineering.img [FL] : Set : md1rom.img [FL] : Set : spmfw.img [FL] : Set : audio_dsp.img [FL] : Set : tinysys-scp.bin [FL] : Set : tinysys-scp.bin [FL] : Set : sspm.img [FL] : Set : sspm.img [FL] : Set : cam_vpu1.img [FL] : Set : cam_vpu2.img [FL] : Set : cam_vpu3.img [FL] : Set : gz.img [FL] : Set : gz.img [FL] : Set : lk.bin [FL] : Set : lk.bin [FL] : Set : boot.img [FL] : Set : logo.bin [FL] : Set : dtbo.img [FL] : Set : tz.img [FL] : Set : tz.img [FL] : Set : special_preload.img [FL] : Set : my_custom.img [FL] : Set : vbmeta_system.img [FL] : Set : vbmeta_vendor.img [FL] : Set : super.img [FL] : Set : cache.img [FL] : Set : userdata.img [FL] : HW verification passed! SEC_DL : False (RAPHAEL) SEC_ID : 0x494E46494E495459424F584245535432 [FL] : RePartition [FL] : RePartition Ok! [FL] : Flashing now ... Write : PRELOADER Update bootloader backup copy ... Update bootloader backup copy Ok! Write : RECOVERY Write : OPPORESERVE2 FAIL : SEC : IMG TYPE MISMATCH Write : VBMETA Write : CDT_ENGINEERING FAIL : SEC : IMG TYPE MISMATCH Write : MD1IMG FAIL : SEC : IMG TYPE MISMATCH Write : SPMFW Write : AUDIO_DSP Write : SCP1 Write : SCP2 Write : SSPM_1 Write : SSPM_2 Write : CAM_VPU1 Write : CAM_VPU2 Write : CAM_VPU3 Write : GZ1 Write : GZ2 Write : LK Write : LK2 Write : BOOT Write : LOGO Write : DTBO Write : TEE1 Write : TEE2 Write : SPECIAL_PRELOAD FAIL : SEC : IMG TYPE MISMATCH Write : MY_CUSTOM FAIL : SEC : IMG TYPE MISMATCH Write : VBMETA_SYSTEM Write : VBMETA_VENDOR Write : SUPER Write : CACHE Write : USERDATA Ultra : OK! [ All failed parts successfully flashed ] SEC_DL : False (RAPHAEL) SEC_ID : 0x494E46494E495459424F584245535432 [FL] : RePartition [FL] : RePartition Ok! [FL] : Flashing finished! Done! Elapsed: 00:01:21 Reconnect Power/Cable! | |
