Old 12-24-2021, 19:26   #16 (permalink)
Crazy Poster
Member: 2475430
Thanks Meter: 15
thnksssss infinty tem vivo new security repair
Old 12-24-2021, 20:43   #17 (permalink)
Member: 2605906
Thanks Meter: 11
What is rmbp pls
How this can help me with mtk devices
The Following 6 Users Say Thank You to andrios123 For This Useful Post:
Old 12-24-2021, 20:55   #18 (permalink)
Member: 2605906
Thanks Meter: 11
What is rmbp pls
The Following 2 Users Say Thank You to andrios123 For This Useful Post:
Old 12-24-2021, 22:21   #19 (permalink)
khanzada606's Avatar
Member: 2455344
Sonork: Ask me
Thanks Meter: 420
what is RMPB i never hread it befoe
The Following 3 Users Say Thank You to khanzada606 For This Useful Post:
Old 12-24-2021, 22:59   #20 (permalink)
rebainoor's Avatar
Member: 231728
Thanks Meter: 2,102
Thumbs up oppo A93 CPH2121 READ RPMB EASILY AND QUICKLY
JUST PERFECT
Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.32
Load IDBase v1121431 Ok!
Update configuration ...
Operation : Memory Tool Init [ v2.32 ]
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : MediaTek USB Port_V1633 (COM47)
MODE : BOOTROM
PORT : 47
Waiting BOOT ack ...
BROM : Skip ACK verify
BROM : Init BROM
BROM init passed!
     CHIP : MT6779 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000
     CODE : Lafite
     TYPE : MODERN [RAPHAEL]
BROM : MEID : 35C8F90490AB73xxxxxxxxxxxxxxxxx
BROM : SecLevel : 0x000000E5
BROM : SecMode  : SBC+SDA+EXT
BROM : BROM|BL  : 0x05|0xFE
BROM : BOOTROM
BROM : SOCID : 0806F59D6C687FB70C252030BC87AD949386486FFA66822E1BB51F329CE4A59F
BROM : SLA : Local Auth
BROM : SLA : Starting Auth
BROM : SLA : Auth Passed!
BROM : SEC : 0x000000E0
AGENT : 0_base : BASE_v2124 | Manual : Disabled
AGENT : Look for suitable BootChain in DA ...
AGENT : MTK_AllInOne_DA.bin
AGENT : Found MT6779
AGENT : MTK_DOWNLOAD_AGENT
     BROM : Sending 1st DA ...
BROM : DA sent
BROM :Transfer control to DA ...
     DA : AGENT started!
DA : SYNC
     DA : MODE : BROM
DA : EXT_RAM NOT initialized!
     EMI : DEV : FireFly
     EMI : SRC : preloader_oppo6779.bin
     EMI : CNT : 000D
     EMI : Init EMI from INTERNAL DB
     EMI : EXT_RAM CFG Passed!
DA : BOOT to 2nd DA ...
DA : 2ND stage confirmed!
DA : SYNC with DA passed!
DA : Receiving HW info
        SRAM: 0x00080000 [ 512,00 KB ]
        DRAM: 0x200000000 [ 8,00 GB ]
        UFS: CE014B4D3856373xxxxxxxxxxxxxxxx
        UFS:
             VEN  : 0x01CE
             VID  : KM8V7001JM-B81
             IFW  : 1200
             LU0  : 0x00400000 [ 4,00 MB ]
             LU1  : 0x00400000 [ 4,00 MB ]
             LU2  : 0x1DCB000000 [ 119,17 GB ]
             FSN  : 41324dda0301
             REG  : 0x101010000
        CHIP : MT6779 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000
        RNID : 815FD2508FBBC3725C80CB81113871
DA : USB : HIGH-SPEED
Boot done!
Set default path : C:\BOX\InfinityBox\CM2MT2\phdata\
Ready!
MemoryTool Operation : RPMB : Read
RPMB WriteCounter : 0x000000A2
Read now ...
File Size : 0x01000000
File Name : rpmb.bin
File Path : C:\BOX\InfinityBox\CM2MT2\Backup\MT6779__35C8F90490AB73xxxxxxxxxxxxxxxxxxxxx\
Read partition Ok!
Operation finished!
MemoryTool Operation : Make Backup
Backup sensetive data [ 17 ]
Backup path : Backup\MT6779__35C8F90490AB73xxxxxxxxxxxxxx\
Backup done!
Operation finished!
Close MemoryTool session
Done!
Elapsed: 00:02:54
Reconnect Power/Cable!
The Following 6 Users Say Thank You to rebainoor For This Useful Post:
Old 12-24-2021, 23:23   #21 (permalink)
Member: 80599
Sonork: 1621236
Thanks Meter: 280
Hi bro.
RMPB it means Replay Protected Memory Block
special partition that responds to commands like read write
It can withstand replay attacks by requiring a key to write to this region. The rpmb has a key that can be programmed once. Later, the host reads a counter value from the rpmb. It uses this counter value and the programmed key to generate a MAC. The device then checks the MAC given vs the MAC it calculated using the same key, and if it matches, write access is granted
The Following 6 Users Say Thank You to ramoon20 For This Useful Post:
Old 12-24-2021, 23:25   #22 (permalink)
Member: 1043909
Thanks Meter: 60,921
Originally Posted by andrios123 View Post
What is rmbp pls
Please see it here https://en.wikipedia.org/wiki/Replay...d_Memory_Block
The Following User Says Thank You to YellowBoss For This Useful Post:
Old 12-24-2021, 23:26   #23 (permalink)
Member: 1043909
Please see here https://en.wikipedia.org/wiki/Replay...d_Memory_Block
Old 12-24-2021, 23:27   #24 (permalink)
Member: 1043909
Originally Posted by Akamidzi View Post
Thanks team u always the best
but please what about
best dongle update, qualcomm and others?
Merry cristmass
Thank you very much for your very good suggestion!
Please check this page from time to time to see news https://infinity-box.com/news/
Old 12-25-2021, 03:39   #25 (permalink)
ashish800's Avatar
Member: 1889562
Thanks Meter: 617
Originally Posted by GSM AR View Post
Identify [ v2.32 ]
Operation : Identify [ v2.32 ]
Mode : FLASH
PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM4)
MODE : PRELOADER PORT
PORT : 4
PRELOADER : ACK confirmed!
BROM : Init BROM
BROM init passed!
     CHIP : MT6768 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000
     CODE : Talbot
BROM : SecLevel : 0x00000005
BROM : BROM|BL  : 0xFF|0x03
BROM : PRELOADER PORT
AGENT : 0_base : BASE_v2112 | Manual : Disabled
AGENT : Found MT6768
     BROM : Reset Interface!
PTFN : MediaTek USB Port_V1632 (COM3)
MODE : BOOTROM
PORT : 3
BROM : Init BROM
BROM init passed!
     CODE : Talbot
BROM : MEID : 0A13CD02AF235D86390DBDD1FFC8E3C7
BROM : BOOTROM
BROM : SOCID : CEBEBABF6FE0A69728111B18DBD5C8C07CEA1A739F0774B3B13AFDDA6ABB7669
BROM : FF : Look for EMI
BROM : FF : EMI found!
BROM : DA sent
     DA : AGENT started!
DA : SYNC
     DA : MODE : BROM
     EMI : DEV : FireFly
     EMI : SRC : preloader_k69v1_64.bin
     EMI : CNT : 000B
        SRAM: 0x00070000 [ 448.00 KB ]
        DRAM: 0x100000000 [ 4.00 GB ]
        EMMC: CID : 13014E47314331324C101254FC844873
        EMMC: VEN : MICRON : OEM : 78 : ID : 47314331324C
        EMMC: VEN : MICRON : G1C12L
        EMMC: SNN : 307559556 ( 0x1254FC84) , MF : 4/2021
        EMMC:
              BOOT1  : 0x00400000 [ 4.00 MB ]
              BOOT2  : 0x00400000 [ 4.00 MB ]
              RPMB   : 0x01000000 [ 16.00 MB ]
              USER   : 0x1D1F000000 [ 116.48 GB ]
        CHIP : MT6768 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0001 , EVOL : 0x0000
        RNID : 7291CA8B17D5B70EBC45422622AA705E
Boot done!
Product Brand  : vivo
Product Device : 2058
Product Model  : V2058
Product Name   : 2058N
Patch Level    : RP1A.200720.012
Display ID     : RP1A.200720.012 release-keys
Product Info   : k69v1_64
Ver. CodeName  : REL
Ver. Release   : 11
Sec. Patch     : 2021-11-01
Build Time     : 01.12.2021
Product Board  : k69v1_64
Board Platform : mt6768
Product Manfct : vivo
USERDATA : FILESYSTEM : F2FS  with FBE ( File-Base Encryption )
NVRAM : BBK_R0MP1_K69T_V1_64_BSP_MDBIN_PCB01_MT6768_S00.MOLY_LR12A_R3_MP_V136_6_P96
NVRAM : 0xB50AF7E2
NVRAM : State : Ok!
INFO  : WiFi MAC : AA0036004400
INFO  : BlTh MAC : D09CAE6A036D
INFO  : IMEI[1] : 8660xxxxxxxxxxxxx
INFO  : IMEI[2] : 8660xxxxxxxxxxxxx
Backup path : Backup\MT6768__0A13CD02AF235D86390DBDD1FFC8E3C7\
[28] Read : NVRAM
[13] Read : NVDATA
[25] Read : PROINFO
[39] Read : LK
[12] Read : NVCFG
[21] Read : PROTECT1
[1] Read : PGPT
[20] Read : PERSIST
[0] Read : PRELOADER
Backup done!
STORAGE : Life Status : eMMC : OK!
STORAGE : OTP Status : UNLOCKED!
STORAGE : RPMB Status : eMMC : RPMB  KEY PROGRAMMED [UNUSABLE]
Done!
Elapsed: 00:00:50
PORT : 4
BROM : Init BROM
BROM init passed!
     CODE : Talbot
MODE : BOOTROM
PORT : 3
BROM : Init BROM
BROM init passed!
     CODE : Talbot
BROM : BOOTROM
BROM : DA sent
     DA : AGENT started!
DA : SYNC
     DA : MODE : BROM
     EMI : DEV : FireFly
     EMI : CNT : 000B
        EMMC:
Boot done!
Set default path : C:\InfinityBox\CM2MT2\phdata\
Ready!
RPMB WriteCounter : 0x0000005E
Read now ...
File Path : C:\InfinityBox\CM2MT2\Backup\MT6768__0A13CD02AF235D86390DBDD1FFC8E3C7\
Read partition Ok!
Operation finished!
Done!
Elapsed: 00:03:52
AsKInG..........
THIS METhED WORK SAMSUnG Emmc or skhynix emmm?
Old 12-25-2021, 03:41   #26 (permalink)
ashish800's Avatar
Member: 1889562
Thanks Meter: 617
How to use infinity flash file support area
Old 12-25-2021, 03:43   #27 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Originally Posted by umerkhalid1992 View Post
Good updates can we samsung mtk device can do kg unlock
Originally Posted by kngoya View Post
Can we now remove kg lock on mtk samsung devices
can we now remove kg lock with this new feature introduced -RPMB
Yes, we can. But we looks for KG locked samples to check and add that in "SMART RESET EXTRA" mode.
If you have phone with KG - just make service report and leave post on forum about device, we will check it and try add.
We want add it as completely, safe, automatic solution.
The Following 9 Users Say Thank You to JayDi For This Useful Post:
Old 12-25-2021, 03:44   #28 (permalink)
JayDi's Avatar
Member: 462970
Originally Posted by ashish800 View Post
AsKInG..........
What about exactly we talking?
Please, specify your question.
Solution work on all known eMMC and UFS.
The Following User Says Thank You to JayDi For This Useful Post:
Old 12-25-2021, 03:47   #29 (permalink)
JayDi's Avatar
Member: 462970
Originally Posted by ethhab View Post
This big update specially RPMB operations Thank you infinity devloper
Maybe it may help with MT6799 meizu, if FF will work on it. Unfortunately, we didnt get any 6799 device, so, cant say exact.
Old 12-25-2021, 03:48   #30 (permalink)
JayDi's Avatar
Member: 462970
Merry cristmass
All will be updated, we spend alot of time in different directions, but can't make all in one shoot.
The Following 8 Users Say Thank You to JayDi For This Useful Post:
Page generated in 0.29177 seconds with 9 queries
