03-15-2022, 20:31 | #17 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
The Following 4 Users Say Thank You to JayDi For This Useful Post: |
03-16-2022, 21:35 | #25 (permalink) |
Registered User Join Date: Mar 2008 Location: @ blacksheep digital
Member: 731353 Status: Offline Thanks Meter: 254 | can we fix error like ' dm-verity error' ,ive a mobicel mtk with that error..did reset/smart reset ..still have error its a mobicel trendy 2 please anyone with revive firmware or solution..can u help with link |
03-17-2022, 07:57 | #26 (permalink) |
No Life Poster Join Date: Nov 2016 Location: ISI
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Please Add This Model VIVO Y21 V2111 Card found : 73CA70CC , v0153 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.34 Load IDBase v312457 Ok! Update configuration ... Load IDBase v312457 Ok! Operation : Identify [ v2.34 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM Port (COM30) MODE : PRELOADER PORT PORT : 30 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : Reset Interface! PTFN : MediaTek PreLoader USB VCOM Port (COM30) MODE : PRELOADER PORT PORT : 30 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : 0x00007024 : DA SEND ERROR! ERROR : SECURE BOOT : SELECTED DA NOT SUPPORTED IN CURRENT DEVICE STATE! INFO : PRELOADER Level : CORRECT DA required : PL/PL_CRYPTO/SWSEC Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! |
The Following User Says Thank You to A.G.Shahid For This Useful Post: |
03-17-2022, 13:05 | #28 (permalink) | |
03-17-2022, 13:06 | #29 (permalink) | |
"fix dm-verity" give nothing, if firmware or hardware damaged. | |
The Following 2 Users Say Thank You to JayDi For This Useful Post: |
03-17-2022, 14:49 | #30 (permalink) |
Freak Poster Join Date: Nov 2013 Location: zimbabwe
Member: 2075865 Status: Offline Thanks Meter: 99 | Operation : SP Unlock [ v2.34 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM6) MODE : BOOTROM PORT : 6 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : 129271AA9657EB121A783080B90F5E2B BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 164CBEC0C74CB94D5BB02F25A3A4A7B48D2FAB5EBBDCCDFCE8 FB3499538ED741 BROM : SLA : Local Auth BROM : SLA : Starting Auth BROM : FF : Look for EMI BROM : FF : EMI found! BROM : SLA : Auth Passed! BROM : SEC : 0x000000E0 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMMC: CID : 880103534C4433324759B2F4332FB7BF EMMC: VEN : FORESEE : OEM : 3 : ID : 534C44333247 : PRV : 0x59 EMMC: VEN : FORESEE : SLD32G EMMC: SNN : 3002348335 ( 0xB2F4332F ) , MF : 11/2020 EMI : DEV : FireFly EMI : SRC : preloader_t99652aa1.bin EMI : CNT : 0005 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: CID : 880103534C4433324759B2F4332FB7BF EMMC: VEN : FORESEE : OEM : 3 : ID : 534C44333247 : PRV : 0x59 EMMC: VEN : FORESEE : SLD32G EMMC: SNN : 3002348335 ( 0xB2F4332F ) , MF : 11/2020 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x73A000000 [ 28.91 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : C2033FF6A8D92769A9B7DC983907D6D6 DA : USB : HIGH-SPEED Boot done! [Info] : Unsupported security type in selected mode! Repeat operation in META mode! INFO : Generating and send report data ... INFO : Report sent! Done! Elapsed: 00:00:54 Operation : SP Unlock [ v2.34 ] Mode : META 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM6) MODE : BOOTROM PORT : 6 Error : Failed to open port! Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Operation : SP Unlock [ v2.34 ] Mode : META 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM6) MODE : BOOTROM PORT : 6 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : 129271AA9657EB121A783080B90F5E2B BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 164CBEC0C74CB94D5BB02F25A3A4A7B48D2FAB5EBBDCCDFCE8 FB3499538ED741 BROM : SLA : Local Auth BROM : SLA : Starting Auth BROM : SLA : Auth Passed! BROM : SEC : 0x000000E0 BROM : Configuring target for META BROM : Failed to setup environment! ErrorCode : 0x1005 : 0x1007 Unknow Error! >>> Check previous message for more info! Reconnect Power/Cable! Operation : SP Unlock [ v2.34 ] Mode : META 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM6) MODE : BOOTROM PORT : 6 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : 129271AA9657EB121A783080B90F5E2B BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 164CBEC0C74CB94D5BB02F25A3A4A7B48D2FAB5EBBDCCDFCE8 FB3499538ED741 BROM : SLA : Local Auth BROM : SLA : Starting Auth BROM : SLA : Auth Passed! BROM : SEC : 0x000000E0 BROM : Configuring target for META BROM : META configured! INIT : META confirmed! Boot done! AP_CHIP : MT6765 AP_SWTM : Tue Jul 6 15:16:21 CST 2021 AP_SWVR : alps-mp-r0.mp1-V7.13_wingtech.r0mp1.k61v1.64.bsp_P49 MD_CHIP : MT6765 MD_SWVR : TK_MD_BASIC_HW IMEI[1] : SPLock Error : empty LTD! IMEI[2] : SPLock Error : empty LTD! Done! Elapsed: 00:01:33 Add nokia g10 and g20 simlock |
The Following User Says Thank You to kngoya For This Useful Post: |
