Infinity Chinese Miracle-2 CM2MT2 v2.38 Beta Code: !!! WARNING !!! https://dl1.infinity-box.com/00/pub/?dir=software/beta/ |
Sir, it's for very experienced engineers only |
=== [19-10-2022 09:25:46 C:\InfinityBox\CM2MT2\CM2MT2.exe] === S/N: 0AF77168 v0153 Infinity [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.38 Load IDBase v723487 Ok Backup files: 18 dirs: 0 Check for updates... Installed v2.38 Latest v2.37 Required card v0153 No updates found Update configuration... Configuration [12060] updated Load IDBase v723487 Ok Operation : Reset Settings/Format FS [ v2.38 ] Mode: SMART RESET Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device Waiting for device connection... PTFN: MediaTek PreLoader USB VCOM_V1633 (Android) (COM3) MODE: PRELOADER PORT PORT: 3 Waiting BOOT ack... PRELOADER: ACK confirm FAIL BROM: Init BROM BROM init passed CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] BROM: SecLevel: 0x00000005 BROM: SecMode : SBC+SDA BROM: BROM|BL : 0xFF|0x03 BROM: PRELOADER PORT AGENT: 0_base : BASE_v2112 | Manual : Disabled AGENT: Looking for suitable BootChain in DA... AGENT: [0656ff20] C:\InfinityBox\CM2MT2\boot\0_base\BASE_v2112\MTK_A llInOne_DA.bin AGENT: Found MT6765 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... BROM: Reset Interface PTFN: MediaTek USB Port_V1633 (COM15) MODE: BOOTROM PORT: 15 Waiting BOOT ack... BROM: Skip ACK verify BROM: Init BROM BROM init passed CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] BROM: MEID: 47D7587F8D1F82774F7BA93D84E14FEA BROM: SecLevel: 0x000000E5 BROM: SecMode : SBC+SDA+EXT BROM: BROM|BL : 0x05|0xFE BROM: BOOTROM BROM: SOCID: B2B0411C77111E51CECCC66BF09ED959A024C19A9D59BB28AF 95A74C6A42CDF7 BROM: SLA: Local Auth BROM: SLA: Starting Auth BROM: FF : Look for EMI BROM: FF : EMI found BROM: SLA: Auth Passed BROM: SEC: 0x000000E0 AGENT: 0_base : BASE_v2112 | Manual : Disabled AGENT: Looking for suitable BootChain in DA... AGENT: [0656ff20] C:\InfinityBox\CM2MT2\boot\0_base\BASE_v2112\MTK_A llInOne_DA.bin AGENT: Found MT6765 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... BROM: DA sent BROM: Transfer control to DA... DA: AGENT started DA: SYNC DA: MODE: BROM DA: EXT_RAM NOT initialized EMMC: CID: 150100514436334D42036C4D9BB69623 EMMC: VEN: Samsung : OEM: 0 : ID: 514436334D42 : PRV: 0x03 EMMC: VEN: Samsung : QD63MB EMMC: SNN: 1817025462 ( 0x6C4D9BB6 ) MF: 9/2019 EMI: FireFly preloader_s96116aa1.bin with 3 memory type(s) supported EMI: Init EMI from INTERNAL DB EMI: EXT_RAM CFG Passed DA: BOOT to 2nd DA... DA: 2ND stage confirmed DA: SYNC with DA passed DA: Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: CID: 150100514436334D42036C4D9BB69623 EMMC: VEN: Samsung : OEM: 0 : ID: 514436334D42 : PRV: 0x03 EMMC: VEN: Samsung : QD63MB EMMC: SNN: 1817025462 ( 0x6C4D9BB6 ) MF: 9/2019 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: 21BAB6C44648499890D74A7891284E9 DA: USB: HIGH-SPEED Boot done SmartInfo: AndroidVer: 9 UserDataFS: 0x02 CacheFS: 0x02 Verify device config... Ok No loaders to verify Steps: 6 RESET PROTECTION... Format Ok: RESET PROTECTION USERDATA... Format Ok: USERDATA CACHE... Format Ok: CACHE USERDATA... Format Ok: USERDATA Done: 00:00:52 Reconnect Power/Cable now |
I suggest you always make Identify before any other operation due to in this case you will have a backup created automatically. |
Samsung A10s Frp Code: Operation : Memory Tool Init [ v2.38 ] |
WALTON Primo_NF4_2GB Code: Operation : Identify Device [ v2.38 ] |
if not - auto-make it, or force to do identify first ? that way even #1 noob can't say "cm2 killed my phone" not to mention that for full flash format - this should be a must. b.r. Alex |
Yes, just uploaded beta make backup during Identify and Reset and check is previous backup exist. Making step-by-step |
Oppo A1k Smart Reset Done V2.38 Operation : Reset Settings/Format FS [ v2.38 ] Mode: SMART RESET [+] Sensitive Data Backup Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device Waiting for device connection... PTFN: MediaTek USB Port_V1632 (COM3) MODE: BOOTROM PORT: 3 Waiting BOOT ack... BROM: Skip ACK verify BROM: Init BROM BROM init passed CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] BROM: MEID: 63FD924825DBDAF1F2A63B59593A40AC BROM: SecLevel: 0x000000E5 BROM: SecMode : SBC+SDA+EXT BROM: BROM|BL : 0x05|0xFE BROM: BOOTROM BROM: SOCID: 20F33ED859636C29AA82DABD87B57EAA868ED78EC6067D522B 6D7B927594BB6E BROM: Sending FireFly FireFly: Starting... FireFly: Init Core FireFly: Core init done FireFly: Running : v05.05.05 on MT6765 FireFly: eMMC init passed EMMC: CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC: CSD: TEMP_WRITE_PROTECT: False EMMC: CSD: PERM_WRITE_PROTECT: False EMMC: CID: 150100514436334D4203DA5307CDB6ED EMMC: VEN: Samsung : OEM: 0 : ID: 514436334D42 : PRV: 0x03 EMMC: VEN: Samsung : QD63MB EMMC: SNN: 3662874573 ( 0xDA5307CD ) MF: 11/2019 EMMC: EXTCSD: rev1.8 ( eMMC 5.1 ) EMMC: EXTCSD [CONFIG] : 0x48 0x02 0x01 EMMC: EXTCSD [PARTITION_CONFIG] : 0x48 EMMC: EXTCSD [BOOT_BUS_WIDTH] : 0x02 EMMC: EXTCSD [RST_N_FUNCTION] : 0x01 EMMC: EXTCSD [PART_S_COMPLETED] : False EMMC: EXTCSD [SIZE] : Market : 32 GB EMMC: EXTCSD [SIZE] : Actual : 0x747C00000 [ 29.12 GB ] EMMC: EXTCSD [EOL] : EOL status : Normal ( Less than 80% reserved blocks used ) EMMC: EXTCSD [EOL_A] : SLC status : 10% - 20% used EMMC: EXTCSD [EOL_B] : MLC status : 10% - 20% used EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] USER : 0x747C00000 [ 29.12 GB ] DA: USB: HIGH-SPEED Boot done Reading... SmartInfo: AndroidVer: 9 UserDataFS: 0x02 CacheFS: 0x02 Verify device config... Ok No loaders to verify Backup already exist. Overwrite? No Steps: 6 RESET PROTECTION... Format Ok: RESET PROTECTION USERDATA... Format Ok: USERDATA CACHE... Format Ok: CACHE USERDATA... Format Ok: USERDATA Done: 00:01:06 Reconnect Power/Cable now |
Realme C25s RMX3195 Code: Operation : Identify Device [ v2.38 ] |
Oppo A83 Code: Operation : Reset Settings/Format FS [ v2.38 ] |
beta verson 2.38g found virus and not run. windows defender caled trojan:win32/wacatac.B?ml |
Anyway updated "2.38h" version was uploaded short time ago, try it |
Jaz Digit 4G Music Smart Reset Done With 2.38H Beta Operation: Reset Settings/Format FS [ v2.38 ] Platform: MTK SmartPhone - MT65/67/68/81/83/87 | Helio G/P/X Mode: SMART RESET [+] Sensitive Data Backup Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device Waiting for device connection... PTFN: MediaTek USB Port_V1632 (COM3) MODE: BOOTROM PORT: 3 Waiting BOOT ack... BROM: Skip ACK verify BROM: Init BROM BROM init passed CHIP: MT6739 SBID: 0x8A00 HWVR: 0xCB00 SWVR: 0x0002 EVOL: 0x0000 HWC: 0x0699 CODE: Zion TYPE: MODERN [RAPHAEL] BROM: MEID: F9D66CC3FA98D23D64D80CAA0B022DAB BROM: SecLevel: 0x00000000 BROM: SecMode : PLAIN BROM: BROM|BL : 0x05|0xFE BROM: BOOTROM BROM: SOCID: 89A8BA78BB12B13D9EE6C32AE189D1B6C5E7479F7590153100 05B6ECDB68A81B BROM: EMI: Search BROM: EMI: Found AGENT: 0_base : BASE_v2112 | Manual : Disabled AGENT: Looking for suitable BootChain in DA... AGENT: [0656ff20] C:\InfinityBox\CM2MT2\boot\0_base\BASE_v2112\MTK_A llInOne_DA.bin AGENT: Found MT6739 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... BROM: DA sent BROM: Transfer control to DA... DA: AGENT started DA: SYNC DA: MODE: BROM DA: EXT_RAM NOT initialized EMI: FireFly preloader_fise6731_kaio_m.bin with 6 memory type(s) supported EMI: Init EMI from INTERNAL DB EMI: EXT_RAM CFG Passed DA: BOOT to 2nd DA... DA: 2ND stage confirmed DA: SYNC with DA passed DA: Receiving HW info SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x20000000 [ 512.00 MB ] EMMC: CID: 90014A48344732611102250011C492FD EMMC: VEN: Hynix : OEM: 74 : ID: 483447326111 : PRV: 0x02 EMMC: VEN: Hynix : H4G2a EMMC: SNN: 620761540 ( 0x250011C4 ) MF: 9/2015 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0xE9000000 [ 3.64 GB ] CHIP: MT6739 SBID: 0x8A00 HWVR: 0xCB00 SWVR: 0x0001 EVOL: 0x0000 HWC: 0x0699 CODE: Zion TYPE: MODERN [RAPHAEL] RNID: ACBC89C395E4897130B880E8D59E890A DA: USB: HIGH-SPEED Boot done (1) Reading... SmartInfo: AndroidVer: 6 UserDataFS: 0x01 CacheFS: 0x01 Verify device config... Ok Backup sensitive data [18] to C:\InfinityBox\CM2MT2\backup\MT6739__F9D66CC3FA98D 23D64D80CAA0B022DAB\ [21] Read: NVRAM [8] Read: NVDATA [14] Read: PROINFO [22] Read: LK [7] Read: NVCFG [10] Read: PROTECT1 [1] Read: PGPT [0] Read: PRELOADER Done Compact: C:\InfinityBox\CM2MT2\backup\MT6739__F9D66CC3FA98D 23D64D80CAA0B022DAB\ Cleanup... Ok: 9 Verify C:\InfinityBox\CM2MT2\backup\MT6739__F9D66CC3FA98D 23D64D80CAA0B022DAB.zip Verified Ok Steps: 6 RESET PROTECTION... Format Ok: RESET PROTECTION USERDATA... Format Ok: USERDATA CACHE... Format Ok: CACHE USERDATA... Format Ok: USERDATA Done: 00:01:12 Reconnect Power/Cable now |
