05-23-2018, 18:59 | #1 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Infinity Chinese Miracle-2 MTK/Mediatek v2.00 r3 - More secured devices and features! - Main DownloadAgent version 1816 supported and tested on all supported SoC. Fixed some memory leaks Connection level revised - MemoryTool Fixed multi-selection GPT init revised Preloader init revised - Service Repair Security revised. Fixed issues with some Meizu and other models. - Core Optimized different agents versions support ( DA16xx line ) EMIDB updated Hint/Error explain module updated Activated SymLinks - allow reduce boot base size by redirecting diffirent brand/models if they have same base BootHelper ( stage 1 of 3 ) activated - hints/explanation of boot sequnce and correct file selection MT6758 support under test MT6771 support under test MT6765 support under test - Flasher Show Preloader HW compatibility when load firmware in flash tab Fixed file selection order - if SW package contain mixed types - secure will be selected by default - FW reader New types of firmwares supported Scatter creation optimized for some SoC - New models included Limited Alcatel support Limited Gionee support Limited Wiko support Limited Tecno support And diffirent other models Some other basic "generic" secure devices support optimized NAND devices on MT6570 moved to separate mode ( under base ) - FACTORY for ONLY FACTORY-provided FW flashing, INFINITY - for all rest operations Known issues/warnings/info : 1. [NAND on MT6570] v1712,v1736 loader packages NOT SHOULD BE USED! Since they have ftl/ecc errors! In result you will give read/write FW errors and rest problems at all. Recommend use v1724 for FACTORY FW flashing, v18xx line for Infinity FW Flash Read and Write 2. [NAND on MT6570] In some cases "stuck on logo" devices can be fixed only via FFU (whole flash) format! 3. [MEMORY TOOL] Partitions state on MEMORY TOOL will be empty in MT6570 NAND phones, it is normal and cannot be fixed. Read-Write data, which you want, ignore "EMPTY" states. 4. ADL checksum MAY NOT WORK CORRECT on MT6570 NAND devices! Result - stuck after system/userdata partition flashing 5. FileSystem flashing on some SBC-enabled devices ( except SYSTEM/CACHE/USER ) may fail! Solution - exclude them from flashing list. 6. Cheap MT6739 devices require BATTERY REMOVING after EVERY operation in most cases! 7. Meizu support is limited by Preloader Level ( No BROM SLA ) - you must UNTICK "PMT Update" and "PRELOADER" partition from flashing list! 8. [NAND on MT6570] In some cases device MAY DEAD after flashing! Make sure you have TESTED firmware version! If you have download FW from internet/other source - make sure it preloader CONTAIN 3 EMI record! Preloader jc45btlc with 2 records KILL SOME DEVICE TO UNRECOVERABLE STATE!!! Preloader info shown now during FW load. Credits : gracy_elec - different useful files contribution kamal_singla - testing and useful files contribution merujeffrey - useful files contribution and report logs Download link Upload file to Support Infinity-Box 13 years (2005 - 2018) updates and support as nobody else - News Twitter - Facebook - Telegram Last edited by InfinityHelp; 05-25-2018 at 08:54. |
The Following 108 Users Say Thank You to YellowBoss For This Useful Post: |
05-23-2018, 19:23 | #3 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Albania,City Under The Castle Age: 47
Member: 388033 Status: Offline Thanks Meter: 693 | "- New models included Limited Alcatel support Limited Gionee support Limited Wiko support Limited Tecno support And diffirent other models Some other basic "generic" secure devices support optimized NAND devices on MT6570 moved to separate mode ( under base ) - FACTORY for ONLY FACTORY-provided FW flashing, INFINITY - for all rest operations" Alcatel and Wiko Unlocking is supported? |
05-24-2018, 04:29 | #4 (permalink) |
Junior Member Join Date: Feb 2018
Member: 2814905 Status: Offline Thanks Meter: 0 | please add lenovo tb-7304i mt6737 I tried but show me this message CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 TYPE : LEGACY MTK Info : Device is not supported yet! |
05-24-2018, 04:58 | #5 (permalink) | |
No Life Poster Join Date: May 2014 Location: Peshwar, Pakistan
Member: 2192793 Status: Offline Thanks Meter: 188 | Quote:
My dear when you see "LEGACY MTK" in log, then you should be use CM2MTK 1.58, if you having trouble with booting in 1.58 in that chip mt6737 then hold both keys (valume up n down) to boot up this mobile with 1.58. | |
The Following 4 Users Say Thank You to scorpian1982 For This Useful Post: |
05-24-2018, 10:39 | #8 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
The Following 5 Users Say Thank You to JayDi For This Useful Post: |
05-24-2018, 17:46 | #12 (permalink) |
No Life Poster Join Date: Sep 2013 Location: The Hell Age: 31
Member: 2033150 Status: Offline Thanks Meter: 624 | why would u been bother uploading another copy to some other source ,,, IOS support won't say i don't want to give u my files anyway thanks CM2 team ... |
