Old 11-06-2018, 13:18   #1 (permalink)
sahassan82's Avatar
Member: 116955
Sonork: 100.1604268
Thanks Meter: 992
Arrow Infinity Chinese Miracle-2 MTK/Mediatek v2.01 - LEGACY support and other features !
Important:
- Software installed to new folder /CM2MT2/ and designed to support new models
Legacy core support activated:
MT6571
MT6572
MT6580
MT6582
MT6589
MT6592
MT6595
MT6597
MT6732
MT6735
MT6737
MT6752
MT6753
MT6795
MT8127
MT8163
MT8321
MT8732
MT8735
MT8752
Identify: full device info, security info
Flash Factory Firmware
Read Factory Firmware
Reset Settings / Format FS
Reset FRP
Repair Security (Flash Mode, Direct)
SP unlock
MemoryTool - complete device control, service, repair, forensic etc.
- Main
Loader database optimized, size reduced.
DA v1820 line support tested and activated
DA v1836 line support tested and activated
Connection level revised
BROM level support optimized
Optimized and changed HighSpeed port selection
FlashEngine revised
NVRAM tool revised
Global option PWM - allow switch SW between two different work modes for RAPHAEL.
> Use second one if first mode give errors at writing f.e. restore NVRAM on F5 like device etc.
> For LEGACY phone it used in MEMORY TOOL ( WRITE / WIPE )
- Service
Repair Security revised
> Old LEGACY types require FORMAT FS/FACTORY RESET for accept changes !
Format FS - new mode activated: Forced Erase
Format FS - fixed WIPE mode
- Core
EMIDB updated
New EMI engine for LEGACY line
> EMI engine support almost all existing LEGACY line
> New types for RAPHAEL included
- FW reader
LEGACY core supported ( unsigned and static signed types are supported )
New types of firmwares supported
Scatter creation optimized
- Other
Settings tab activated ( firmware path settings and other features can be found here )
AutoUpdate ( module files ) feature activated
Many other changes and fixes
Known issues/warnings/info:
1. FileSystem flashing on some SBC-enabled RAPHAEL devices (except SYSTEM/CACHE/USER) may fail ! Solution - exclude them from flashing list.
2. Meizu support is limited by Preloader Level ( No BROM SLA ) - you must UNTICK "PMT Update" and "PRELOADER" partition from flashing list !
3. MT6589 supported ONLY up to DAv17xx line, after DAv1728 support has been removed.
4. MT6592 support on DAv18xx loader line broken ( DA issue )
5. EMI/DRAM init module in LEGACY line is almost auto, but in some case require CHANGE EMI setting, if used internal DB ( since much RAMsize/Revision of eMMC/eMCP )
6. MOST of LEGACY phone can be booted via BROM mode from now ( PLAIN, PRL, SBC )
7. NAND support on LEGACY line is not activated yet
Download Link : http://dl1.infinity-box.com/00/pub.php?dir=software/&uid=17842&file=InfinityBox_install_CM2MT2_v2.01.7 z
The Following 12 Users Say Thank You to sahassan82 For This Useful Post:
Old 11-06-2018, 14:02   #2 (permalink)
>>Gsmmilon>>'s Avatar
Member: 2142580
Thanks Meter: 1,214
i have show this
Old 11-06-2018, 14:07   #3 (permalink)
sahassan82's Avatar
Member: 116955
Sonork: 100.1604268
Thanks Meter: 992
1st Renew then update from Dongle Manager
Old 11-06-2018, 15:05   #4 (permalink)
localizator's Avatar
Member: 2550141
Thanks Meter: 1,115
Originally Posted by >>Gsmmilon>> View Post
i have show this
renew support and try now
Old 11-06-2018, 15:06   #5 (permalink)
gulka's Avatar
Member: 276322
Thanks Meter: 293
XIAOMI Redmi 6A supported?
The Following User Says Thank You to gulka For This Useful Post:
Old 11-06-2018, 15:29   #6 (permalink)
Member: 2550141
Thanks Meter: 1,115
Old 11-06-2018, 15:35   #7 (permalink)
kamal_singla's Avatar
Member: 2211790
Thanks Meter: 5,118
Read update logs
You will let know supported or not
Old 11-06-2018, 15:40   #8 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
Hello,
Not supported!
Until signed loader/auth data is out not possible to support.
Br.
Infinity Box Team.
Old 11-06-2018, 15:47   #9 (permalink)
Arslanmayo's Avatar
Member: 2478233
Thanks Meter: 596
mine is working fine
will check and post result
Old 11-06-2018, 15:50   #10 (permalink)
Member: 2550141
Thanks Meter: 1,115
Old 11-06-2018, 16:06   #11 (permalink)
rmstk's Avatar
Member: 2484144
Sonork: QQ_3272429273
Thanks Meter: 318
what problem
Old 11-06-2018, 16:11   #12 (permalink)
Arslanmayo's Avatar
Member: 2478233
Thanks Meter: 596
Originally Posted by rmstk View Post
what problem
try to change file save location is solved my problem by this way for example local disk d not c which windows installed
The Following User Says Thank You to Arslanmayo For This Useful Post:
Old 11-06-2018, 16:12   #13 (permalink)
Member: 2171555
Thanks Meter: 129
mt6739 ? ............
Old 11-06-2018, 16:15   #14 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
P22 line almost all had ask-challenge security subsystem. VIP DA required.
Old 11-06-2018, 16:16   #15 (permalink)
JayDi's Avatar
Member: 462970
what problem
Post log in text format, stored in Operation.log file in SW folder.
Page generated in 0.26682 seconds with 8 queries
