Old 11-17-2018, 00:16   #151 (permalink)
Member: 1043909
Thanks Meter: 60,926
Originally Posted by diet_mobile View Post
Still not
Infinity-Box Chinese Miracle MediaTek Service Module [ MTK ] v2.02
Load IDBase v11861 Ok!
Update configuration ...
Could not load SSL library.
Update failed! Check settings and/or internet connection!
:bối rối::bối rối::bối rối::bối rối:
Try to install other version of OpenSSL libraries Shining Light Productions - Win32 OpenSSL
Old 11-17-2018, 00:20   #152 (permalink)
Member: 1043909
Originally Posted by yandbass View Post
getting below error if is install v.2.02 and till v.2.0, it is ok. if i run dongle manager, getting message, your dongle is upto date and no update found. do not try again. solution please.
dongle firmware version: v0136
dongle firmware version is outdated
download donglemanager from support and update firmware
Hello,
What is your dongle support validity date ?
How to check - https://www.infinity-box.com/doc/?r=17
If support is expired please contact to any seller and renew support.
Old 11-17-2018, 00:22   #153 (permalink)
Member: 1043909
Originally Posted by petrmo View Post
Hi,
Installed (with version 2.01, now installed again). Windows 7 32, installed ver. Win32. PC restarted.
Tried as administrator as well.
But still the same state:
Regards.
Petr
Hello,
Try to install other lib version - Shining Light Productions - Win32 OpenSSL
Old 11-17-2018, 02:00   #154 (permalink)
Member: 809650
Thanks Meter: 24
This update suppprt vivo y81 ?
Old 11-17-2018, 02:30   #155 (permalink)
Member: 2641850
Sonork: QQ 1037715866
=== DongleManager [Infinity] v1.72 [2018/11/17 星期六 9:29:43] ===
Searching...
Card-Reader: Generic EMV Smartcard Reader 0
HWID: 00003F7A17B14082
Box/Dongle found: Infinity-Box/Dongle
Reading...
Serial No (S/N): 5F3B3F7A
Firmware version: 0136.02
=== Process started: 2018/11/17 星期六 9:29:45 ===
Connecting to server
Server connection successfully established
Checking DongleManager version...
Your DongleManager is up-to-date
Checking Dongle Identification...
Authenticating on server...
Authentication stage error:
Server answer:[0007] No updates found for your Smart-Card. DO NOT try more today !
Old 11-17-2018, 06:51   #156 (permalink)
Aamir8794's Avatar
Member: 2114042
Sonork: 100.1652032
Thanks Meter: 46
how to solve error during cph1823 oppo f9 pro identify
Operation : Identify [ v2.02 ]
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : MediaTek USB Port (COM8)
MODE : BOOTROM
PORT : 8
Waiting BOOT ack ...
BROM : Skip ACK verify
BROM : Init BROM
BROM init passed!
CHIP : MT6771 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000
TYPE : MODERN RAPHAEL
BROM : SecLevel : 0x000000E5
BROM : SecMode : SBC+SDA+SEL
BROM : BOOTROM
MODE : Oppo : F7 | Manual : Disabled
BROM : SLA
BROM : SLA Passed!
AGENT : Look for suitable BootChain in DA ...
AGENT : DA_BR_HIGH.bin
AGENT : Found MT6771
AGENT : MTK_DOWNLOAD_AGENT
BROM : Sending 1st DA ...
BROM : DA sent
BROM :Transfer control to DA ...
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
DA : EXT_RAM NOT initialized!
EMI : DEV : INFINITY
EMI : SRC : INFINITY-BOX_INTERNAL_EMIDB_v0
EMI : CNT : 000E
EMI : Init EMI from INTERNAL DB
EMI : EXT_RAM CFG Passed!
DA : BOOT to 2nd DA ...
DA : BOOT 2ND DA FAILED!
ERR : 0xC0070004
ERR : DA_HASH_MISMATCH
Error : Fail to init protocol!
Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation!
Reconnect Power/Cable!
Old 11-17-2018, 08:42   #157 (permalink)
Crazy Poster
Member: 1943146
Thanks Meter: 11
plzzzzzzzzzzzzzz help sir
=== DongleManager [Infinity] v1.72 [17-11-2018 13:09:16] ===
Box/Dongle type selected: Infinity-Box/Dongle
HWID: 00000FC10EFE4082
Reading...
Serial No (S/N): B2EC0FC1
=== Process started: 17-11-2018 13:09:17 ===
Old 11-17-2018, 08:54   #158 (permalink)
Member: 1677653
Thanks Meter: 2,769
Reading...
Time to renew your support
The Following 2 Users Say Thank You to Yusuf Lawal For This Useful Post:
Old 11-17-2018, 10:27   #159 (permalink)
md_amin's Avatar
Member: 1217931
Sonork: 100.1604251
Thanks Meter: 267
Nokia-3.1 Flashing Problem................
Load : C:\Users\Mohammad\Desktop\Nokia-3.1\Nokia-3.1-Essential-2_ES2-042E-0-00WW-B02\ES2-042E-0-00WW-B02.nb0
Load Ok!
Operation : Write FW [ v1.08 ]
Setting : UserData preserve : False
Setting : Bootloader update : True
- > Info : Press and hold BOTH volume keys, if device boot fail at BROM stage!
PTFN : MTK USB Port (COM11)
MODE : BOOTROM
PORT : 11
Error : Failed to open port!
Remove battery, cable. Check cable and connection. Repeat operation!
Old 11-17-2018, 11:38   #160 (permalink)
Member: 2571580
Infinity Chinese Miracle-2 MTK/Mediatek v2.02 dosnt open on my pc
Old 11-17-2018, 12:17   #161 (permalink)
Member: 798882
please what is the reason i cannot use cm2mt2 2.0r4 any more?
i got message smart card not have active module
Old 11-17-2018, 12:26   #162 (permalink)
golden25's Avatar
Member: 1927114
Sonork: YOU ASK ME
Thanks Meter: 26
CM2 MTK V2 error
I always get bellow error whenever I want to use CM2MT2
the phone will connect on CM2 v1.58 but having da Secure boot error
Operation : Identify [ v2.01 ]
PTFN : MediaTek DA USB VCOM Port (COM56)
MODE : PRELOADER PORT
PORT : 56
Old 11-17-2018, 13:50   #163 (permalink)
golden25's Avatar
Member: 1927114
Sonork: YOU ASK ME
Thanks Meter: 26
DA Problem
Anybody with da file for HOT 6 X606D please...
Log bellow
PTFN : MediaTek PreLoader USB VCOM (Android) (COM117)
PORT : 117
PRELOADER : ACK confirmed!
BROM : Init BROM
BROM init passed!
CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000
TYPE : LEGACY MTK
BROM : SecLevel : 0x00000005
BROM : PRELOADER PORT
MODE : INFINIX : SECURE_BASE | Manual : Disabled
AGENT : MTK_AllInOne_DA_SWSEC.bin
AGENT : Selected AGENT doesn't have required configuration!
Check and select CORRECT SETTINGS for your device!
Old 11-17-2018, 13:50   #164 (permalink)
Member: 2703009
infinity dongle S/N 4BC02014 gives finalizing check error-6e00 at 0\117
Old 11-17-2018, 13:53   #165 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Load Ok!
MODE : BOOTROM
PORT : 11
Reset battery/device power by long hold volume buttons + power On.
After power it off.
Wait 30 seconds.
Start need operation.
Press and hold BOTH volume keys. Connect device.
Page generated in 0.29600 seconds with 9 queries
