02-09-2019, 19:28 | #152 (permalink) | |
What function do you want to see released in next update ? | |
02-10-2019, 08:55 | #161 (permalink) | |
No Life Poster Join Date: Nov 2016 Location: ISI
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Quote:
It looks like your dongle support period is expired. How to check - https://www.infinity-box.com/doc/?r=17 If support is expired please contact to your seller and renew support - https://www.infinity-box.com/buy/ | |
02-10-2019, 09:08 | #162 (permalink) |
Freak Poster Join Date: Oct 2012 Location: IRAN.IR ----عل
Member: 1824614 Status: Offline Sonork: ali_f*******[email protected] Thanks Meter: 112 | Scanning devices ...1 found dev[1] AMFIKJZTU4W8GUGY Mode: normal Hardware: mt6580 Manufactory: SMART Model: SLIDE LITE |
02-10-2019, 09:34 | #163 (permalink) |
Member: 1824614 Status: Offline Sonork: ali_f*******[email protected] Thanks Meter: 112 | Wait for phone... Phone found! [ 8 ] Sync... Open port error , something went wrong! Boot Error! Operation Failed Elapsed: 00:00:00 Reconnect Power/Cable! Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 8 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... [DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED Boot Error! Operation Failed Elapsed: 00:00:00 Reconnect Power/Cable! |
02-10-2019, 09:47 | #164 (permalink) |
Member: 1824614 Status: Offline Sonork: ali_f*******[email protected] Thanks Meter: 112 | Operation : Identify [ v2.04 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM8) MODE : PRELOADER PORT PORT : 8 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000001 BROM : SecMode : SBC BROM : PRELOADER PORT MODE : 0_base : BASE_v1820 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6580 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : 0x00002001 : DA SEND ERROR! ERROR : SECURE BOOT : MISMATCH BOOT SIGNATURE! INFO : PRELOADER Level : Connect device in BROM mode! Error : Fail to init protocol! Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! |
02-10-2019, 13:10 | #165 (permalink) | |
No Life Poster Join Date: Dec 2008
Member: 921036 Status: Offline Thanks Meter: 79 | Quote:
After making Test Point Edl mode Operation : Repair Security [ v2.04 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM32) MODE : BOOTROM PORT : 32 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6771 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+ARB BROM : BOOTROM MODE : Oppo : F7 | Manual : Enabled BROM : ARB : ACTIVE : LOG : F0: 102B 0000 F3: 4000 0036 [0200] F3: 4000 0036 F7: 102D 0000 00: 1005 0000 F3: 4000 0036 [0200] F3: 4000 0036 F7: 102D 0000 01: 102A 0001 BROM : SOCID : E79292E77A174956429210ECC52AE22C8F466205EB69F79C18 FB9C47D9DCEEDC BROM : SLA BROM : SLA Passed! BROM : SLA CHLNG not used AGENT : Look for suitable BootChain in DA ... AGENT : DA_BR_HIGH.bin AGENT : Found MT6771 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : INFINITY-BOX_INTERNAL_EMIDB_v0 EMI : CNT : 000E EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : BOOT 2ND DA FAILED! ERR : 0xC0070004 ERR : DA_HASH_MISMATCH Error : Fail to init protocol! Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! still not done | |
