02-29-2020, 17:32 | #1 (permalink) |
Major Poster Join Date: Dec 2006 Location: khenchela
Member: 407790 Status: Offline Thanks Meter: 7 | Problem in my smart card Problem in my smart card after last attempt was interrupted DongleManager [Infinity] v1.72 [29/02/2020 11:20:15] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: Gemalto e-gate Smart Card 0 HWID: 0002287A00001942 === Process started: 29/02/2020 11:20:15 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. Contact to http://www.infinity-box.com/support/?r=2 |
02-29-2020, 22:12 | #2 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
Update dongle firmware with DongleManager once again now. Result ? | |
03-01-2020, 10:56 | #3 (permalink) |
Member: 407790 Status: Offline Thanks Meter: 7 | the same problem = DongleManager [Infinity] v1.72 [01/03/2020 10:53:57] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 00011D1521344082 === Process started: 01/03/2020 10:53:58 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. Contact to http://www.infinity-box.com/support/?r=2 |
03-01-2020, 11:09 | #4 (permalink) | |
This Smart-Card is not an Infinity Smart-Card - Disconnect all other Boxes and Dongles from PC - Connect ONLY one Infinity Box/Dongle to PC | |
03-03-2020, 12:36 | #10 (permalink) |
Member: 407790 Status: Offline Thanks Meter: 7 | SamPhone <[email protected]> À :[email protected] mar. 1 avr. 2014 à 18:04 Salam, SamPhone a le plaisir de t'informer que votre licence SPT-Box software activation for Infinity Box (SN : 9F63287A) a été activée chez Infinity Team, Pour finalser votre Activation Veuillez Suivre les instructions suivantes: Instruction: 1. follow the "Activation procedure" step 7. etc. from this manual : http://www.infinity-box.com/download..._procedure.pdf 2. for final activation step to get user.ini file follow this link : SPT-Box Cordialement, SamPh)ne Team |
03-03-2020, 12:55 | #12 (permalink) |
Member: 407790 Status: Offline Thanks Meter: 7 | === DongleManager [Infinity] v1.72 [03/03/2020 12:54:19] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: Gemalto e-gate Smart Card 0 HWID: 0002287A00001942 === Process started: 03/03/2020 12:54:20 === Connecting to server Server connection successfully established Checking DongleManager version... Version check error: Socket Error # 10054 Connection reset by peer. |
03-03-2020, 20:08 | #14 (permalink) | |
Try to update it once again now. Result ? | |
