05-14-2020, 19:07 | #196 (permalink) |
Junior Member Join Date: Dec 2016
Member: 2663483 Status: Offline Thanks Meter: 0 | Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: Generic EMV Smartcard Reader 0 HWID: 00007C4913114082 Box/Dongle found: Infinity-Box/Dongle Reading... Serial No (S/N): 7F8C7C49 Firmware version: 0138.02 === Process started: 14.05.2020 21:03:08 === Connecting to server Connection to server failedA Host is required ПОМОГИТЕ ПОЖВЛУЙСТА! |
05-15-2020, 01:02 | #197 (permalink) | |
Use latest DongleManager - https://www.infinity-box.com/support/?s=6 | |
05-19-2020, 02:20 | #199 (permalink) | |
Freak Poster Join Date: Jul 2008
Member: 818995 Status: Offline Thanks Meter: 75 | Quote:
Hello respected please more specific on use boot Da for CC7. i don't get please help how to choose Boot DA for CC7. | |
05-20-2020, 12:27 | #200 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | New version released - https://www.infinity-box.com/support/?r=100112 |
06-08-2020, 07:02 | #201 (permalink) | |
Registered User Join Date: Aug 2004 Location: India Age: 46
Member: 77443 Status: Offline Thanks Meter: 24 | error identify pls check below log for model REVVL 2 FROM T MOBILE want to SP UNLOCK PLS GUIDE WHAT TO DO which modelhas to select for sp unlock all diff models option try in alcatel model but cant unlock as per recovery page in phone here is details Code: TCL/REVVL 2 5052W/A30ATMO 8.1.0 / OPM1.171019.011/VAR44-0 Code: Operation : Identify [ v2.11 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM299) MODE : BOOTROM PORT : 299 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0002 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+ARB BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : Alcatel : A3A VF | Manual : Disabled BROM : SOCID : 5B08AEA02285A800D163137AD97F6C7BAFFF59BE34AA6D283E79BF3F8732C694 BROM : ARB : ACTIVE : LOG : F0: 102B 0000 F3: 0000 0000 V0: 0000 0000 [0001] BROM : SLA BROM : Selected Auth/Cert not accepted by device! >>> Check previous message for more info! Reconnect Power/Cable! Quote:
06-14-2020, 13:58 | #202 (permalink) |
Freak Poster Join Date: May 2007 Location: cameroon
Member: 516860 Status: Offline Sonork: chickiesmp Thanks Meter: 12 | Cm2 ver 2 recognizes tecno p904 with mt 8735 chipset as mt 6735...... Please fix this infinity team. I opened the tablet just to see the chipset . It killed the tablet because i downloaded made a back up from another tablet trying to flash the slow older one |
06-14-2020, 14:19 | #203 (permalink) | |
you must always use firmware that suit phone hardware otherwise you can kill phone with wrong firmware | |
06-19-2020, 12:11 | #204 (permalink) |
Member: 516860 Status: Offline Sonork: chickiesmp Thanks Meter: 12 | the chip is mt8735 on the board but your software detects it as mt6735 thats is where the problem comes from. i backed up the firmware from same tablet when it was working and later flashed it but it stops at system. the scatter file reads mt6735 from back up everywhere online too same as mine did against the actual chipset which is mt8735. also i ealier talked about spd 2.05 not having sp unlock whereas spd 1.2.7 has it. instead of dismissing the complaint,look into it. i just activated 2 years on that box because i love what infinity team has for the past years done and represented not to just come complain.i'm facing a problem others face without knowing how to complain about |
06-19-2020, 14:48 | #205 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
