05-22-2020, 10:12 | #106 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
Please do not forget to check instruction once again - https://www.infinity-box.com/news/?r=3999 | |
05-22-2020, 18:48 | #108 (permalink) |
Freak Poster Join Date: Nov 2015 Location: Pakistan Age: 24
Member: 2488001 Status: Offline Sonork: 100.1669288 Thanks Meter: 295 | hello team please solved my problem lenovo xt2025-3 dead now show this error Operation : Identify [ v2.10 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM79) MODE : BOOTROM PORT : 79 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+ARB BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v1712 | Manual : Disabled BROM : SOCID : 3440A1EDDBA33F5A828D64770FE688F0BE8AF8C1F0A8FD3405 CE22D7F15C3A3D BROM : ARB : ACTIVE : LOG : F0: 102B 0000 F3: 4002 0000 [0200] F3: 1006 0033 F3: 4002 0000 00: 1005 0000 F3: 4002 0000 [0200] F3: 4001 00E0 01: 102A 0001 AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Selected AGENT doesn't have required configuration! >>> Check and select CORRECT SETTINGS for your device! Reconnect Power/Cable! help |
05-22-2020, 20:22 | #109 (permalink) | |
05-23-2020, 06:26 | #113 (permalink) |
Freak Poster Join Date: Dec 2007 Location: indonesia
Member: 658821 Status: Offline Thanks Meter: 12 | === DongleManager [Infinity] v1.80 [5/23/2020 12:18:53] === Searching... Card-Reader: Generic EMV Smartcard Reader 0 HWID: 0000220A11384082 Box/Dongle found: Infinity-Box/Dongle Reading... Serial No (S/N): A834220A Firmware version: 0143.02 === Process started: 5/23/2020 12:18:54 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. Contact to http://www.infinity-box.com/support/?r=2 === DongleManager [Infinity] v1.80 [5/23/2020 12:18:53] === Searching... Card-Reader: Generic EMV Smartcard Reader 0 HWID: 0000220A11384082 Box/Dongle found: Infinity-Box/Dongle Reading... Serial No (S/N): A834220A Firmware version: 0143.02 === Process started: 5/23/2020 12:18:54 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. Contact to http://www.infinity-box.com/support/?r=2 Serial No (S/N): A834220A Last edited by InfinityHelp; 05-23-2020 at 07:17. |
05-23-2020, 07:17 | #114 (permalink) | |
Fix PC as per instruction - https://www.infinity-box.com/news/?r=3999 After that update dongle firmware with DongleManager to fix "misconfiguration" message | |
05-23-2020, 12:05 | #115 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | New version CM2MT2 v2.11 released - https://www.infinity-box.com/support/?r=100113 |
05-24-2020, 20:21 | #116 (permalink) |
No Life Poster Join Date: Jan 2008 Location: Hell
Member: 679176 Status: Offline Sonork: 1585224 Thanks Meter: 119 | it's real rubbish, you pay for it a year of license that you can't use after 1 year without subsequent updates, I activated the best dongle to make frp xiomi, I didn't even make a frp, at mtk the same I will never be active again |
05-24-2020, 22:24 | #117 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Dear Frind ! Thank you very much for your interesting report ! The big advantage of Infinity activation system is that you can activate new software anytime and exactly at that time when you really need it. For example, you have an ourdated dongle and you have no job for a year, you sleep, eat and relax and you don't want to work - no problem. But once you want return back to work and when you see atat "wow, Infinity released TODAY very nice feature" - you can wake up, stop to eat and start to discuss with seller to renew your Infinity dongle support. And in compare with other tools who block software after support expired, Infinity software can be used for ages even with expired support. Thank you once again for your nice post, now you know much better about Infinity software and about activation system ! |
05-27-2020, 07:49 | #118 (permalink) | |
Member: 679176 Status: Offline Sonork: 1585224 Thanks Meter: 119 | Quote:
if i try to use old version say module not activated | |
05-28-2020, 14:41 | #120 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | It looks like your skills are not so good and you do not know how to use software. It's ordinary mistake that sunday unlockers and other people with low level knowledge makes at regular base. Anyway supporters are always here and ready to help beginners with low level skills. What software module do you want to run (name and version) ? What is your dongle S/N ? |
