07-04-2020, 08:33 | #48 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
SW automatically detect device size and extend, reduce if need, to make it working ( 8/16/32/64/128 models are tested and working ) Let us know with example of model and logs, if something wrong - it will be fixed. | |
The Following 2 Users Say Thank You to JayDi For This Useful Post: |
07-04-2020, 08:34 | #49 (permalink) | |
Thanks for info and report! | |
The Following 6 Users Say Thank You to JayDi For This Useful Post: |
07-04-2020, 09:37 | #50 (permalink) |
No Life Poster Join Date: Jan 2010
Member: 1212133 Status: Offline Thanks Meter: 58 | Thanks for the update but still the bug does not seem to be repaired Operation : Identify [ v2.12 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM40) MODE : PRELOADER PORT PORT : 40 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6583 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0001 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : BROM|BL : 0xFF|0x01 BROM : PRELOADER PORT MODE : 0_base : BASE_v1712 | Manual : Enabled AGENT : Look for suitable BootChain in DA ... AGENT : DA_SWSEC.bin AGENT : Found MT6583 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DA : DRAM NOT SUPPORT NAND : 000000000000000000000000 eMMC : OK eMMC : 00000000000000001501004D41473247 DAInf: 180 : 187 : 18 DA : EXT_RAM NOT initialized! eMMC : eMMC : BF0B0000000000001501004D41473247 NAND : NAND : 470800000BC0000000000000 EMI : DEV : INFINITY EMI : SRC : INFINITY-BOX_INTERNAL_EMIDB_v0 DA : EMI : Failed to get EMI info from selected source! DA : Failed to configure DA! Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! see https://forum.gsmhosting.com/vbb/f29...oblem-2846611/ Or is there any other solution? Thanks |
07-04-2020, 11:24 | #51 (permalink) | |
Need agent for check and verify, or need use older base ( 17xx ) and brom mode | |
07-04-2020, 14:42 | #53 (permalink) | |
Member: 1212133 Status: Offline Thanks Meter: 58 | Quote:
07-04-2020, 16:49 | #55 (permalink) |
Freak Poster Join Date: Nov 2017 Location: In Your Mind
Member: 2778467 Status: Offline Sonork: only Telegram Thanks Meter: 265 | Oppo F5 Reset Setting Done Without TP Operation : Reset Settings/Format FS [ v2.12 ] Mode : FULL FACTORY ( FORCED + FRP ) 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM110) MODE : BOOTROM PORT : 110 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6763 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0001 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+ARB BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : Oppo : F5 | Manual : Disabled BROM : SOCID : DE359859DE9AD164BD203E545A0BF7E76D2B32E1B2D4715E82 F31884F9408D09 BROM : ARB : ACTIVE : LOG : F0: 102B 0000 F3: 0000 0000 V0: 0000 0000 [0001] BROM : SLA BROM : SLA Passed! BROM : SLA CHLNG not used AGENT : Look for suitable BootChain in DA ... AGENT : DA_PL_CRYPTO.bin AGENT : Found MT6763 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : MT6763 EMI : SRC : preloader_oppo6763_17031.bin EMI : CNT : 000F EMI : [00] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 0 B ] EMI : [01] : eMMC : LP_DDR4X : ID : 150100444836444D42 : VEN : SAMSUNG | DEV : DH6DMB : RAM : [ 4.00 GB ] EMI : [02] : eMMC : DDR3 : ID : 150100525836344D42 : VEN : SAMSUNG | DEV : RX64MB : RAM : [ 4.00 GB ] EMI : [03] : eMMC : DDR3 : ID : 150100524836344142 : VEN : SAMSUNG | DEV : RH64AB : RAM : [ 4.00 GB ] EMI : [04] : eMMC : LP_DDR4X : ID : 150100334836434D42 : VEN : SAMSUNG | DEV : 3H6CMB : RAM : [ 6.00 GB ] EMI : [05] : eMMC : DDR3 : ID : 150100524836344D42 : VEN : SAMSUNG | DEV : RH64MB : RAM : [ 4.00 GB ] EMI : [06] : eMMC : DDR3 : ID : 150100474436424D42 : VEN : SAMSUNG | DEV : GD6BMB : RAM : [ 3.00 GB ] EMI : [07] : eMMC : DDR3 : ID : 150100475836424D42 : VEN : SAMSUNG | DEV : GX6BMB : RAM : [ 3.00 GB ] EMI : [08] : eMMC : DDR3 : ID : 150100474536424D42 : VEN : SAMSUNG | DEV : GE6BMB : RAM : [ 3.00 GB ] EMI : [09] : eMMC : DDR3 : ID : 150100524436344D42 : VEN : SAMSUNG | DEV : RD64MB : RAM : [ 4.00 GB ] EMI : [0A] : eMMC : DDR3 : ID : 13014E53304A394237 : VEN : MICRON | DEV : S0J9B7 : RAM : [ 3.00 GB ] EMI : [0B] : DRAM : DDR3 : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 4.00 GB ] EMI : [0C] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 4.00 GB ] EMI : [0D] : DRAM : DDR3 : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 3.00 GB ] EMI : [0E] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 6.00 GB ] EMI : Init EMI from PRELOADER EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: 90014A484247346132A529A0583A4DB EMMC: VEN : HYNIX | OEM : 4A01 | DEV : HBG4a2 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6763 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 53AE7310320A0234CB807EF0BBF84B04 DA : USB : HIGH-SPEED Boot done! Format Ok : USERDATA Format Ok : CACHE Format Ok : RESET PROTECTION Format Ok : USERDATA Done! Elapsed: 00:01:18 Reconnect Power/Cable! |
The Following 4 Users Say Thank You to sajidi1984 For This Useful Post: |
07-04-2020, 22:19 | #59 (permalink) |
Major Poster Join Date: May 2014
Member: 2190317 Status: Offline Thanks Meter: 9 | Frp for box and dongle Originally Posted by Nelsonlanga View Post Wow great work team, But I wish team can make account creation to add on an new pc like if I open a dongle first time on pc ask login like in infinite best because when they stealing the dongle the get free to use Yellow boss reply It is good idea but I think it may gives many problems to other users. Just imagine - you need Internet connection each time you run software, it's complicated way for many people. thanks for the update but sir what i think they are trying to say is not only applicable to this great team (infinity box) i think they mean a kind of security for users in case if box or dongle is stolen,it cannot be activated on a new system without the owners maybe email and password as the case may be infant a kind of frp (scp(system change protection) for dongle and box.I've been a victim before in one of the cases i wrote to infinity team they transferred my other activations to the new dongle but the other cases of lost dongle other team did nothing.i think we need to creat a new trade for this.also an anti crack trade Thanks greatest team Last edited by nwaobiaram; 07-04-2020 at 22:26. |
07-05-2020, 11:19 | #60 (permalink) |
Major Poster Join Date: Apr 2011 Location: kampala
Member: 1563468 Status: Offline Sonork: featuring Thanks Meter: 9 | To be sincere on the issue of rom or phone storage reducing after flashing, i used the version 2.6 to flash tecno cf8 and cc7 but all reduced to 4GB but when the owner of tecno cc7 took it some where it was flashed and its memory was restored |
