08-03-2020, 10:35 | #94 (permalink) |
No Life Poster Join Date: Apr 2011 Location: Pakistan
Member: 1555233 Status: Offline Thanks Meter: 2,192 | BUG REPORT SIR Infinix S5 Lite ( X652B /Format FS ERROR BUT password remove success Operation : Identify [ v2.14 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM7) MODE : PRELOADER PORT PORT : 7 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT MODE : 0_base : BASE_v2012 | Manual : Enabled BROM : SOCID : E27C29EDF36718B386060D728080B209F4E0638AA2C304B9EF EA277F4B2EB1A9 AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00080000 [ 512.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC: 90014A68433961503301C3526CA6C6E9 EMMC: VEN : HYNIX | OEM : 4A01 | DEV : hC9aP3 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : E50374DF13B0CBD98881393FDA884E8A DA : USB : HIGH-SPEED Boot done! Patch Level : PPR1.180610.011 Display ID : X652B-H627CDM-P-200413V239 Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2020-04-05 Build Time : 1586821956 Product Model : Infinix X652B Product Brand : Infinix Product Name : H627 Product Device : Infinix-X652B Product Manfct : INFINIX MOBILITY LIMITED Product Info : x652b_h627 Product Board : Infinix-X652B Board Platform : mt6765 Product Brand : orange USERDATA : FILESYSTEM : F2FS with FDE ( Full Disk Encryption *) STORAGE : LifeStatus : Verify NOT supported by DA/HW! Done! Elapsed: 00:00:36 Operation : Reset Settings/Format FS [ v2.14 ] Mode : FULL FACTORY ( WIPE + FRP ) 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM7) MODE : PRELOADER PORT PORT : 7 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT MODE : 0_base : BASE_v2012 | Manual : Enabled BROM : SOCID : E27C29EDF36718B386060D728080B209F4E0638AA2C304B9EF EA277F4B2EB1A9 AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00080000 [ 512.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC: 90014A68433961503301C3526CA6C6E9 EMMC: VEN : HYNIX | OEM : 4A01 | DEV : hC9aP3 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : E50374DF13B0CBD98881393FDA884E8A DA : USB : HIGH-SPEED Boot done! ERR : 0xC002002A ERR : SEC : IMG TYPE MISMATCH ERR : 0x00001000|0x00001000 Error : Failed erase block! >>> Try select another format mode! Reconnect Power/Cable! |
The Following 3 Users Say Thank You to amjadnona For This Useful Post: |
08-03-2020, 12:07 | #96 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
08-03-2020, 22:01 | #100 (permalink) | |
Dr. Web CureIT https://free.drweb.com/download+cureit+free/?lng=en after that re-install CM2MT2 result ? | |
08-03-2020, 22:27 | #101 (permalink) |
Junior Member Join Date: May 2009
Member: 1032636 Status: Offline Thanks Meter: 0 | Operation : Identify [ v2.14 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM27) MODE : PRELOADER PORT PORT : 27 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000001 BROM : SecMode : SBC BROM : BROM|BL : 0xFF|0x01 BROM : PRELOADER PORT MODE : 0_base : BASE_v2012 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6735 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : 0x00002001 : DA SEND ERROR! ERROR : SECURE BOOT : MISMATCH BOOT SIGNATURE! INFO : PRELOADER Level : Connect device in BROM mode! Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! |
08-09-2020, 07:30 | #105 (permalink) | |
No Life Poster Join Date: Aug 2005 Location: MOON Age: 43
Member: 174173 Status: Offline Thanks Meter: 115 | Any solution, i flash stock rom, dump other phone work not solved Un written tee key Un written google key Logs Quote:
