GSMSERVER GSM Shop
Old 07-27-2020, 20:25   #16 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 16,921
Originally Posted by Charstone View Post
Very great update.... But what about KaiOs SPD/MTK SP Unlock feature!??
What wrong with MTK SP unlock feature? More info, please. Better with unlock and identify logs.
The Following User Says Thank You to JayDi For This Useful Post:
Old 07-27-2020, 22:41   #17 (permalink)
allttar's Avatar
Member: 136220
Thanks Meter: 116
Thanks for the update
The Following User Says Thank You to allttar For This Useful Post:
Old 07-27-2020, 23:11   #18 (permalink)
rebainoor's Avatar
Member: 231728
Thanks Meter: 1,541
Unic Ultraflash work with legacy mtk (have signed firmware) ?
Old 07-27-2020, 23:50   #19 (permalink)
Member: 2902804
Sonork: 100.1660513
Thanks Meter: 400
thanks
Service
Changed : Reset PrivacyLock updated
!* Action selection now depend on different factors ( Android 6, 9 issues fixes )
Changed : Smart Reset
!* Optimized support for Android 5, 6
!* Optimized support for "customized" cases
The Following User Says Thank You to Gsm-Boss. For This Useful Post:
Old 07-28-2020, 03:12   #20 (permalink)
Member: 1436822
Thanks Meter: 3
very good update but what about samsung years of not updating and it is paid activation
The Following User Says Thank You to centeno For This Useful Post:
Old 07-28-2020, 04:04   #21 (permalink)
Member: 704044
Thanks Meter: 191
dear supporter kindly consider this
Old 07-28-2020, 06:17   #22 (permalink)
Member: 383211
Thanks Meter: 104
coolpad 8298-a01 not conecting in cm2mtk2 2.14
i try all cm2mtk2 da and without da but conected in any modle . now flash try to read with new update but no luckfor coolpad 8298-a01.its cpu is mt6735.please guide me how i conecct it
Card found : 53471D69 , v0144
Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.14
Load IDBase v714150 Ok!
Operation : Identify [ v2.14 ]
Mode : FLASH
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : MediaTek PreLoader USB VCOM (Android) (COM13)
MODE : PRELOADER PORT
PORT : 13
Waiting BOOT ack ...
PRELOADER : ACK confirmed!
BROM : Init BROM
BROM init passed!
CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000
TYPE : LEGACY MTK
BROM : SecLevel : 0x00000001
BROM : SecMode : SBC
BROM : BROM|BL : 0xFF|0x01
BROM : PRELOADER PORT
MODE : 0_base : BASE_v1712 | Manual : Disabled
AGENT : Look for suitable BootChain in DA ...
AGENT : MTK_AllInOne_DA.bin
AGENT : Found MT6735
AGENT : MTK_DOWNLOAD_AGENT
BROM : Sending 1st DA ...
BROM : DA sent
BROM : JUMP TO DA FAILED!
Error : Fail to init protocol!
>>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation!
Reconnect Power/Cable!
Mode : FLASH
PORT : 13
BROM : Init BROM
BROM init passed!
TYPE : LEGACY MTK
MODE : 0_base : BASE_v1724 | Manual : Enabled
BROM : DA sent
Preloader [HW DEV] Info :
EMI : DEV : MT6752
EMI : SRC : preloader_cp8298_a01.bin
EMI : CNT : 0002
EMI : [00] : eMMC : DDR3 : ID : 90014A483847316505 : VEN : HYNIX | DEV : H8G1e : RAM : [ 2.00 GB ]
EMI : [01] : eMMC : DDR3 : ID : 150100514E31334D4206 : VEN : SAMSUNG | DEV : QN13MB : RAM : [ 2.00 GB ]
Operation : Read Firmware [ v2.14 ]
ExtSparse : Enabled
ForceRead : Disabled
PORT : 13
BROM : Init BROM
BROM init passed!
TYPE : LEGACY MTK
BROM : DA sent
ExtSparse : Enabled
ForceRead : Enabled
PORT : 13
PRELOADER : ACK confirm FAIL!
BROM : Init BROM
BROM init passed!
TYPE : LEGACY MTK
BROM : DA sent
Operation : Write Flash [ v2.14 ]
Repartition : Enabled
Flash Verify : Disabled
Reg.Pre-Erase : Enabled
Verify HW/SW : Enabled
SData Backup : Disabled
Safe UserData : Disabled
Flash Format : Disabled
Files :15
[FL] : Set : preloader.bin
[FL] : Set : lk-verified.bin
[FL] : Set : boot-verified.img
[FL] : Set : recovery-verified.img
[FL] : Set : logo-verified.bin
[FL] : Set : YL-params.bin
[FL] : Set : autobak.img
[FL] : Set : panic.img
[FL] : Set : lk_bak-verified.bin
[FL] : Set : secro-verified.img
[FL] : Set : trustzone.bin
[FL] : Set : system.img
[FL] : Set : cache.img
[FL] : Set : userdata.img
[FL] : Total size : 0x8F680C90 [ 2.24 GB ]
PORT : 13
BROM : Init BROM
BROM init passed!
TYPE : LEGACY MTK
BROM : DA sent
Old 07-28-2020, 07:52   #23 (permalink)
Member: 1525038
Sonork: Danigee
Thanks Meter: 5
Very Good update Infinity Team plz add real pin pattren lock opption
Old 07-28-2020, 08:05   #24 (permalink)
Member: 1758871
Sonork: bhatti
Thanks Meter: 116
Good
PLZ update ( QLM Tool )
Old 07-28-2020, 08:57   #25 (permalink)
Member: 2761624
Thanks Meter: 35
Now No one can under estimate the power of infinity silent work...
Old 07-28-2020, 10:16   #26 (permalink)
Member: 2692658
Please add Sp unlock function for spd on SC7731E
Old 07-28-2020, 10:57   #27 (permalink)
Member: 148515
Thanks Meter: 16,696
Originally Posted by Khadaff_papillo View Post
major updates are really working. but we are waiting for new updates for the Spd module mainly the Sp unlock function for cell phones based on SC7731E chips.
Thank you for your advice !
Let me tell you one important thing:
Here is MTK thread.
MTK is not the same as SPD.
If you want to say something about SPD you should use SPD thread but not MTK because people who manage SPD tool never read posts in MTK thread.
Old 07-28-2020, 10:58   #28 (permalink)
Member: 148515
Hi,
SPD is not the same as MTK, both are quite different CPU lines.
Old 07-28-2020, 11:26   #29 (permalink)
Member: 2460709
Thanks Meter: 3
good work team great ,But please we kindly need u to work more on BEST DONGLE TOO to be able to work with new NOKIA DEVICES PLEASE|||||||||
The Following User Says Thank You to Akamidzi For This Useful Post:
Old 07-28-2020, 11:30   #30 (permalink)
Member: 2606732
Thanks Meter: 6
good work mtk and spd
tnx team...plz uptodate qlm tool
Page generated in 0.23610 seconds with 7 queries
