Old 08-30-2020, 10:44   #106 (permalink)
Member: 148515
Thanks Meter: 19,534
Originally Posted by Zaki Bouzidson View Post
I solved this by downloading the latest DongleManager 1.80 (although I had 1.80 before), replaced the old files & deleted the previous log file & boom!
"Socket Error # 10054" has no relation to DongleManager.
It's a Internet connection issue, in some cases it's related to countries that block Internet access somehow.
solution is VPN
Old 08-30-2020, 10:49   #107 (permalink)
Registered User
Member: 2240574
i was trying to update dongle plz help me
DongleManager [Infinity] v1.80 [2020-08-30 11:48:12] ===
Searching...
Card-Reader: FT SCR2000 0
HWID: 0007938920881292
Box/Dongle is not found
Old 08-30-2020, 10:51   #108 (permalink)
Member: 148515
Searching...
Hello,
1. Install REQUIRED Card-Reader Drivers - https://www.infinity-box.com/support/?r=6
File with Drivers: CardReader_Fetian_FT2K.7z
File with Instruction: Infinity-Box_How_to_update_FT_SCR2000_CardReader_drivers.pd f
Drivers version after installation should be 2.5.6.0823 or 2.5.9.1202
2. Run DongleManager
3. Update Dongle firmware
OR
1. Insert Smart-Card into another Card-Reader. Good result for today gives Alcor Card-Reader.
2. Run DongleManager - https://www.infinity-box.com/support/?r=5
Only ONE update try is allowed !
In case of problem DO NOT update card again !
Old 08-30-2020, 13:30   #109 (permalink)
Member: 402996
Thanks Meter: 18
hellp me this error g730-u10 mt6582
Operation : Read Security [ v2.15 ]
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : MediaTek PreLoader USB VCOM (Android) (COM11)
MODE : PRELOADER PORT
PORT : 11
Waiting BOOT ack ...
PRELOADER : ACK confirmed!
BROM : Init BROM
BROM init passed!
CHIP : MT6582 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0001
TYPE : LEGACY MTK
BROM : SecLevel : 0x00000000
BROM : SecMode : PLAIN [+PRL]
BROM : BROM|BL : 0xFF|0x01
BROM : PRELOADER PORT
MODE : 0_base : BASE_v1712 | Manual : Disabled
AGENT : Look for suitable BootChain in DA ...
AGENT : MTK_AllInOne_DA.bin
AGENT : Found MT6582
AGENT : MTK_DOWNLOAD_AGENT
BROM : Sending 1st DA ...
BROM : 0x00002001 : DA SEND ERROR!
ERROR : SECURE BOOT : MISMATCH BOOT SIGNATURE!
INFO : PRELOADER Level : Connect device in BROM mode!
Error : Fail to init protocol!
>>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation!
Reconnect Power/Cable!
Old 08-30-2020, 16:20   #110 (permalink)
Member: 217170
Thanks Meter: 43
https://mega.nz/file/VAISlaBJ#64cg39...G5xhLDYBEIq_Yc
https://mega.nz/file/VMAyhaJL#BZaTgs...cJOLvtzMuolElM
my fault.bin
Old 08-30-2020, 16:45   #111 (permalink)
Member: 2528595
Thanks Meter: 2
i lost my mtk dongle and card ... can i replace new?
Old 08-30-2020, 21:54   #112 (permalink)
Member: 217170
Thanks Meter: 43
windows 7 64bit infinity not open
here and BEST folder bin
https://mega.nz/file/IJZilKxZ#E6iQnU...PzQZCYG1_0RAzQ
i have very big problem my dongle not working
Old 09-01-2020, 14:25   #113 (permalink)
Member: 148515
Disable keepvid\keepvid pro\downloadres\kv_server.exe
delete fault.bin file
run Infinity software
Old 09-01-2020, 14:26   #114 (permalink)
Member: 148515
The only way - buy new dongle.
If you have more activations at your dongle it's possible to transfer it to new dongle.
Information about activation transfer - https://www.infinity-box.com/doc/?r=20
Old 09-01-2020, 22:26   #115 (permalink)
Member: 2902140
Thanks Meter: 6
Read Firmware error
How to fix?
[IMG][/IMG]
Old 09-02-2020, 00:13   #116 (permalink)
Member: 217170
Thanks Meter: 43
Thank you very mutch my friend !!!!
Old 09-02-2020, 03:03   #117 (permalink)
rebainoor's Avatar
Member: 231728
Thanks Meter: 2,103
Originally Posted by Y-GSM TECH View Post
Read Firmware error
How to fix?
[IMG][/IMG]
May be you have faulty USB port or shorted USB port from this mobile and you get deconnected smart card reader during identify process
The Following User Says Thank You to rebainoor For This Useful Post:
Old 09-02-2020, 04:37   #118 (permalink)
kothamamun's Avatar
Member: 2556542
Thanks Meter: 1,790
Originally Posted by cr@zyboy View Post
hello redmi note 8 pro and note 9 write eng rom support ?
already supported just look at the sky
Old 09-02-2020, 10:08   #119 (permalink)
Member: 148515
Read Firmware error
How to fix?
Try to "read" once again. What is the result ?
If it stop again: does it stop at the same % or not ?
also I suggest use USB 2.0 port but not 3.x
Old 09-02-2020, 13:22   #120 (permalink)
Member: 784847
Thanks Meter: 45
Having trouble using latest vesrsions.
My support is not expired updated yesterday
but still these soft not open
i formated whole drive installed new os w7
same same same issue old exe working even all other tools working .but cm2mtk2 cm2sp2 cm2scr not working
i have recorded screen plz see.
I searched the forum found fault.bin
but there is not fault.bin
I HAVE SENT " INFINITYHELP" YOU PM TOO SCREEN VIDEO LINK
plz help me thank you
Page generated in 0.26310 seconds with 10 queries
