Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | -= Z3X JTAG PLUS =- | Search | Today's Posts | Mark Forums Read |
![]() | #136 (permalink) | |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: May 2008
Member: 770503 Status: Offline Thanks Meter: 1,121 | Quote:
Select emi from this FW & post result | |
![]() | #137 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Nov 2013
Member: 2075865 Status: Offline Thanks Meter: 50 | Add stylo s40 life simlock, has OTP partition. chipset 6580, tried unlock in meta, it failed to enter meta mode it start charging, tried in flash mode just says done but still locked. here are the logs below for meta above and flash mode at the bottom. Operation : SP Unlock [ v2.15 ] Mode : META 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM48) MODE : PRELOADER PORT PORT : 48 Waiting BOOT ack ... PRELOADER : ACK confirmed! INIT : META enter failed by timeout! Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Operation : SP Unlock [ v2.15 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM48) MODE : PRELOADER PORT PORT : 48 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : BROM|BL : 0xFF|0x01 BROM : PRELOADER PORT MODE : 0_base : BASE_v2028 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6580 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 490101044F434F530553164D73962F67 DAInf: 4 : 2 : 156 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 4010149534F434F4D165305672F9673 EMMC: VEN : UNKNOWN | OEM : 101 | DEV : ISOCOM EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x1D2000000 [ 7.28 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x20000000 [ 512.00 MB ] CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 94311C2E2ABB45E618972C09C3E79 STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! ID0 : Lock : Not Locked | MNC : 0 | CNT : 5 | CODE : 12345678 ID1 : Lock : Not Locked | MNC : 0 | CNT : 5 | CODE : 56781234 ID2 : Lock : Not Locked | MNC : 0 | CNT : 5 | CODE : 11112222 ID3 : Lock : Not Locked | MNC : 0 | CNT : 5 | CODE : 33334444 ID4 : Lock : Not Locked | MNC : 0 | CNT : 5 | CODE : 55556666 ID5 : Lock : Not Locked | MNC : 0 | CNT : 5 | CODE : 77778888 ID6 : Lock : Not Locked | MNC : 0 | CNT : 5 | CODE : 99990000 |
![]() | #138 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Feb 2006 Location: In my LAB
Member: 231728 Status: Offline Thanks Meter: 1,931 ![]() | add option to auto repaire old scatter created by old cm2mt2 release like : vendor partition in old scatter cant be flashed and some userdata patition in old scatter flashed with ext4 file system but it f2FS |
![]() | #139 (permalink) |
Member: 231728 Status: Offline Thanks Meter: 1,931 ![]() | F2fs file system created successfull Code: Operation : Memory Tool Init [ v2.15 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM76) MODE : PRELOADER PORT PORT : 76 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : BROM|BL : 0xFF|0x01 BROM : PRELOADER PORT MODE : 0_base : BASE_v2028 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6580 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 54000170303732323B0C01383D464482 DAInf: 4 : 2 : 156 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 700100543232373038010C3B8244463D EMMC: VEN : KINGSTON | OEM : 01 | DEV : T22708 EMMC: BOOT1 : 0x00400000 [ 4,00 MB ] BOOT2 : 0x00400000 [ 4,00 MB ] RPMB : 0x00400000 [ 4,00 MB ] USER : 0x1C8000000 [ 7,13 GB ] SRAM: 0x00020000 [ 128,00 KB ] DRAM: 0x40000000 [ 1,00 GB ] CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : E0275422A027D9564A4EA99B77E29A31 STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! Set default path : C:\BOX\InfinityBox\CM2MT2\phdata\ Ready! Operation : Initialize FILESYSTEM Partition selected : userdata [ 5,14 GB ] FileSystem selected : F2FS Create FileSystem ... Writing FileSystem ... Write partition Ok! Operation finished! Close MemoryTool session Done! Elapsed: 00:01:08 Reconnect Power/Cable! |
![]() | #140 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Dec 2008 Location: Indonesia
Member: 919549 Status: Offline Thanks Meter: 130 | Oppo A5S Pattern lock Done Identify... Code: Operation : Identify [ v2.15 ] Mode : META 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM12) MODE : BOOTROM PORT : 12 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+ARB BROM : BOOTROM BROM : ARB : ACTIVE : LOG : F0: 102B 0000 F3: 0000 0000 [0200] V0: 0000 0000 [0001] BROM : SOCID : 7ACF97DD081228B3E5CECFC2E2E01259BC0F29F43A24C9F5991B1C72B468ED73 BROM : Configuring target for META BROM : META configured! INIT : META confirmed! Boot done! AP_CHIP : MT6765,S01 AP_SWTM : Thu Jul 16 22:09:52 CST 2020 AP_SWVR : CPH1909_11_A.39_200716_3c30b5de AP_HWVR : S01 MD_CHIP : MT6765 MD_SWTM : 2000.00.00 MD_DSPV : 1.0 MD_DSPP : MOLY.LR12A.R2.TC16.SP.V50.5.P95 MD_SWVR : OPPO_O1MP6_K65V1_64_BSP_HW MD_HWVR : Unknown Patch Level : O11019 Ver. CodeName : REL Ver. Release : 8.1.0 Sec. Patch : 2020-07-05 Product Manfct : OPPO Done! Elapsed: 00:01:27 Smart reset Code: Operation : Reset Settings/Format FS [ v2.15 ] Mode : META 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM7) MODE : BOOTROM PORT : 7 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+ARB BROM : BOOTROM BROM : ARB : ACTIVE : LOG : F0: 102B 0000 F3: 0000 0000 [0200] V0: 0000 0000 [0001] BROM : SOCID : 7ACF97DD081228B3E5CECFC2E2E01259BC0F29F43A24C9F5991B1C72B468ED73 BROM : Configuring target for META BROM : META configured! INIT : META confirmed! Boot done! AP_CHIP : MT6765,S01 AP_SWTM : Thu Jul 16 22:09:52 CST 2020 AP_SWVR : CPH1909_11_A.39_200716_3c30b5de AP_HWVR : S01 Format Ok : UserData - > Format in META will NOT reset FRP! Done! Elapsed: 00:00:42 |
The Following User Says Thank You to anoamocreative For This Useful Post: |
![]() | #145 (permalink) |
Junior Member ![]() ![]() Join Date: Nov 2009
Member: 1162553 Status: Offline Thanks Meter: 4 | please add oppo A9 - 2020 mtk mt6771 Please, reconnect battery, press and hold "Vol+" or "Vol-" button and connect USB cable. Searching for a phone. Please wait... Found phone on COM238 Port name: MediaTek USB Port (COM238) Detecting Chip Version... HW Chip: MT6771: 0788.0000 HW Version: 8A00.CA00.0000.0000 Connecting... Brom Version: 05 BootLoader Version: FE Sending auth... Searching Download Agent... |
![]() | #146 (permalink) | |
Product Supporter ![]() ![]() ![]() Join Date: Jun 2009
Member: 1043909 Status: Offline Thanks Meter: 56,546 | Quote:
What CM2MT2 version do you use ? | |
![]() | #150 (permalink) |
Member: 231728 Status: Offline Thanks Meter: 1,931 ![]() | Brandt_BPRIMES_mt6797 out of memory bypass by forced read DONE always with unic features of CM2MT2 Code: Operation : Read Firmware [ v2.15 ] ExtSparse : Enabled ForceRead : Enabled 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM28) MODE : PRELOADER PORT PORT : 28 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6797 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : BROM|BL : 0xFF|0x02 BROM : PRELOADER PORT MODE : 0_base : BASE_v1912 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6797 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00038000 [ 224,00 KB ] DRAM: 0x100000000 [ 4,00 GB ] EMMC: 8801034E436172642017D6692606543 EMMC: VEN : FORESEE | OEM : 301 | DEV : NCard EMMC: BOOT1 : 0x00400000 [ 4,00 MB ] BOOT2 : 0x00400000 [ 4,00 MB ] RPMB : 0x00400000 [ 4,00 MB ] USER : 0x73A000000 [ 28,91 GB ] CHIP : MT6797 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 7D134A6DC66B6B67EDF918518999D7F DA : USB : HIGH-SPEED Boot done! Patch Level : O00623 Display ID : BTA60F8S25032019 Ver. CodeName : REL Ver. Release : 8.0.0 Sec. Patch : 2018-08-05 Build Time : 25.03.2019 Product Model : BPRIMES Product Brand : Brandt Product Name : BPRIMES Product Device : BPRIMES Product Manfct : Vanzo Product Info : BPRIMES Product Board : x17 Board Platform : mt6797 MT6797__Vanzo__BPRIMES__8.0.0__BTA60F8S25032019__O00623__BPRIMES Read : preloader.bin Read : recovery.img Read : proinfo.img Read : md1rom.img Read : md1dsp.img Read : md1arm7.img Read : md3rom.img Read : tinysys-scp.bin Read : nvram.bin Read : lk.bin Read : boot.img Read : logo.bin Read : odmdtbo.img Read : tz.img Read : vendor.img ExtSparse : Compression ratio : 44% Read : system.img ExtSparse : Compression ratio : 30% Read : cache.img Read : userdata.img FW Size : 2,17 GB Android Info saved : _Android_info.txt Scatter : MT6797_Android_scatter.txt Saved to : E:\BRANDT\B Prime S\MT6797__Vanzo__BPRIMES__8.0.0__BTA60F8S25032019__O00623__BPRIMES\ Done! Elapsed: 00:03:39 |
The Following User Says Thank You to rebainoor For This Useful Post: |
