08-24-2020, 15:24 | #46 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Normally, software show message why it not. It should clear all questions. If there is no start at all - make sure your PC is clean. Use Dr.Web CureIt, as example. It is trusted, free, one-time-use software to check your home PC for viruses and clean it. |
08-24-2020, 19:07 | #47 (permalink) |
No Life Poster Join Date: Jan 2008 Location: Every 1's heart
Member: 682054 Status: Offline Sonork: 100.1602688 Thanks Meter: 144 | Thank you so much for your hard work sir Sir i updated my dongle firmware but when i open software it says dongle needs update |
08-24-2020, 20:05 | #49 (permalink) |
No Life Poster Join Date: Feb 2006 Location: In my LAB
Member: 231728 Status: Offline Thanks Meter: 2,103 | very nice identify info thinks Code: Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.15 Load IDBase v729152 Ok! Update configuration ... Update Ok! Load IDBase v729152 Ok! Operation : Identify [ v2.15 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM77) MODE : PRELOADER PORT PORT : 77 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : BROM|BL : 0xFF|0x01 BROM : PRELOADER PORT MODE : 0_base : BASE_v2028 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6580 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 4403018836314439A195244771956049 DAInf: 4 : 2 : 156 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 8801034439443136472495A149609571 EMMC: VEN : FORESEE | OEM : 301 | DEV : D9D16G EMMC: BOOT1 : 0x00400000 [ 4,00 MB ] BOOT2 : 0x00400000 [ 4,00 MB ] RPMB : 0x00400000 [ 4,00 MB ] USER : 0x39D000000 [ 14,45 GB ] SRAM: 0x00020000 [ 128,00 KB ] DRAM: 0x40000000 [ 1,00 GB ] CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : F3BBBEBDB8DE08BB40919D934CAF7DE STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! Patch Level : MRA58K Display ID : G-PADLITE-16G-2018-08-01 Ver. CodeName : REL Ver. Release : 6.0 Sec. Patch : 2017-11-05 Build Time : 01.08.2018 Product Model : G-PADLITE Product Brand : K708 Product Name : G-PADLITE Product Device : K708 Product Board : K708 Product Manfct : Benzo Board Platform : mt6580 Product Info : mt8321_tb_m USERDATA : FILESYSTEM : EXT4 with FDE ( Full Disk Encryption ***) IMEI[0] : 3568xxxxxxxxxxxx IMEI[1] : 3568xxxxxxxxxxxx NVRAM check : Passed! NVRAM : SEC NORMAL [ No extra security ] PRELOADER : DEVICE : DEV : MT6752 NME : preloader_mt8321_tb_m.bin CNT : 0001 Done! Elapsed: 00:01:48 |
The Following 2 Users Say Thank You to rebainoor For This Useful Post: |
08-24-2020, 21:20 | #51 (permalink) | |
No Life Poster Join Date: Jan 2006 Location: Greece
Member: 217170 Status: Offline Thanks Meter: 43 | MTK2 not open Quote:
only logo and termined no message! | |
08-25-2020, 10:57 | #58 (permalink) |
Junior Member Join Date: Sep 2009
Member: 1110854 Status: Offline Thanks Meter: 7 | oppo a12 pettern look not romove 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM35) MODE : BOOTROM PORT : 35 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN RAPHAEL BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+ARB BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2028 | Manual : Disabled BROM : SOCID : 3742319C3FA46816FFC8F5AA7064368D6BB4C4CC69407692E8 66CA13137F7EB3 BROM : ARB : ACTIVE : LOG : F0: 102B 0000 F3: 0000 0000 [0200] V0: 0000 0000 [0001] AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : 0x00007017 : DA SEND ERROR! ERROR : SECURE BOOT : SLA REQUIRED IN BROM MODE! INFO : BROM Level : CERT/AUTH required! Try boot device in PRELOADER mode with select PL/PL_CRYPTO/SWSEC type! Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! meta Operation : Reset Settings/Format FS [ v2.15 ] Mode : META 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM35) MODE : BOOTROM PORT : 35 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+ARB BROM : BOOTROM BROM : ARB : ACTIVE : LOG : F0: 102B 0000 F3: 0000 0000 [0200] V0: 0000 0000 [0001] BROM : SOCID : 3742319C3FA46816FFC8F5AA7064368D6BB4C4CC69407692E8 66CA13137F7EB3 BROM : Configuring target for META BROM : META configured! INIT : META confirmed! Boot done! AP_CHIP : MT6765 AP_SWTM : Fri Jul 10 23:04:31 CST 2020 AP_SWVR : CPH2083_11_A.21_200710_433b5205 AP_HWVR : 3 Format Ok : UserData - > Format in META will NOT reset FRP! Done! Elapsed: 00:00:41 Reconnect Power/Cable! {not romove look: same condition} |
