Old 09-02-2020, 20:21   #121 (permalink)
Member: 1043909
Thanks Meter: 57,002
Originally Posted by gnmughal_786 View Post
Having trouble using latest vesrsions.
My support is not expired updated yesterday
but still these soft not open
i formated whole drive installed new os w7
same same same issue old exe working even all other tools working .but cm2mtk2 cm2sp2 cm2scr not working
i have recorded screen plz see.
I searched the forum found fault.bin
but there is not fault.bin
I HAVE SENT " INFINITYHELP" YOU PM TOO SCREEN VIDEO LINK
plz help me thank you
Hi,
Tech support via PM is not possible.
Images can be attached here.
Supporters do not open any external links like video
post here text with error messge that you see after you run exe
The Following User Says Thank You to YellowBoss For This Useful Post:
Old 09-03-2020, 07:41   #122 (permalink)
Member: 1078531
Sonork: 12345
Thanks Meter: 25
Which box firmware is required for version 2.15?
Old 09-03-2020, 09:07   #123 (permalink)
Member: 784847
Thanks Meter: 45
Originally Posted by YellowBoss View Post
Hi,
no error messege here
my card is updated Card found : S/N : 1F3B8A** , v0145
when i execute exe it show logo then disappear thats it, old exe working all other tools working.i changed sim reader, installed new window nothing helped
https://ibb.co/NZztjSM
Old 09-03-2020, 12:16   #124 (permalink)
Member: 2902140
Thanks Meter: 6
Try to "read" once again. What is the result ?
If it stop again: does it stop at the same % or not ?
also I suggest use USB 2.0 port but not 3.x
I tried several times but it's the same error With different devices I am using port 2.0 only
Old 09-03-2020, 12:22   #125 (permalink)
Member: 1043909
Hello,
Dongle v0145 is required
Old 09-03-2020, 12:23   #126 (permalink)
Member: 1043909
Do you have fault.bin file in CM2MT2 folder ?
Do you have antivirus installed ?
Old 09-04-2020, 14:19   #127 (permalink)
Member: 784847
Thanks Meter: 45
there is no antivirus installed
fault.bin not present in any infinity folder
Old 09-05-2020, 16:11   #128 (permalink)
Member: 1043909
use Dr. Web CureIT https://free.drweb.com/download+cureit+free/?lng=en
and test your PC.
Do you see any alerts by this antivirus ?
After that double check that folder with Infinity software has only original files.
If problem still exist make this:
STEP 1: Download and run Sysinternals Process Explorer - https://download.sysinternals.com/fi...ssExplorer.zip
STEP 2: Run procexp64.exe
STEP 3: go to menu File -> Save
STEP 4: Save file
STEP 5: Copy/paste file content here
Old 09-08-2020, 18:30   #129 (permalink)
Member: 2266425
Thanks Meter: 36
plese add jazz digit 4g sp unlock and other full suport
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : MediaTek USB Port (COM22)
MODE : BOOTROM
PORT : 22
Waiting BOOT ack ...
BROM : Skip ACK verify
BROM : Init BROM
BROM init passed!
CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0002
CODE : Zion
TYPE : MODERN RAPHAEL
BROM : SecLevel : 0x00000000
BROM : SecMode : PLAIN [+PRL]
BROM : BROM|BL : 0x05|0xFE
BROM : BOOTROM
MODE : BQ : SEC_6739 | Manual : Enabled
BROM : SOCID : 17958D317E77B64BA82439C23147476B11CEBDD59F79578917 0D25B510C8DF65
AGENT : Look for suitable BootChain in DA ...
AGENT : DA_PL.bin
AGENT : Found MT6739
AGENT : MTK_DOWNLOAD_AGENT
BROM : Sending 1st DA ...
BROM : DA sent
BROM :Transfer control to DA ...
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
DA : EXT_RAM NOT initialized!
EMI : DEV : INFINITY
EMI : SRC : INFINITY-BOX_INTERNAL_EMIDB_v0
EMI : CNT : 0004
EMI : Init EMI from INTERNAL DB
EMI : EXT_RAM CFG Passed!
DA : BOOT to 2nd DA ...
DA : BOOT 2ND DA FAILED!
ERR : 0xC0070004
ERR : DA_HASH MISMATCH
Error : Fail to init protocol!
>>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation!
Reconnect Power/Cable!
Old 09-08-2020, 22:14   #130 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 18,878
MODE : BOOTROM
PORT : 22
BROM : Init BROM
BROM init passed!
CODE : Zion
BROM : BOOTROM
AGENT : DA_PL.bin
BROM : DA sent
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
EMI : CNT : 0004
ERR : 0xC0070004
Just change emi version to 1-2-3 and it should boot in bootrom mode.
The Following 2 Users Say Thank You to JayDi For This Useful Post:
Old 09-09-2020, 03:45   #131 (permalink)
anoamocreative's Avatar
Member: 919549
Thanks Meter: 130
Vivo pd1818GF
Identify...
Operation : Identify [ v2.15 ]
Mode : FLASH
PTFN : MediaTek PreLoader USB VCOM (Android) (COM5)
MODE : PRELOADER PORT
PORT : 5
PRELOADER : ACK confirmed!
BROM : Init BROM
BROM init passed!
     CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000
     CODE : Cervino
BROM : SecLevel : 0x00000005
BROM : SecMode  : SBC+SDA
BROM : BROM|BL  : 0xFF|0x03
BROM : PRELOADER PORT
MODE : Vivo : SEC_MT6765 | Manual : Disabled
BROM : SOCID : 8F9FAD2B9BF0BFEAAF3124196C8E6B8EE1BF400E1B39EAA577CA08763102ED58
AGENT : MTK_AllInOne_DA.bin
AGENT : Found MT6765
BROM : DA sent
     DA : AGENT started!
DA : SYNC
     DA : MODE : PRELOADER
DA : EXT_RAM initialized!
DA : 2ND stage confirmed!
DA : SYNC with DA passed!
DA : Receiving HW info
        SRAM: 0x00040000 [ 256.00 KB ]
        DRAM: 0x20000000 [ 512.00 MB ]
        EMMC: 150100514436334D42013AEAD3961613
        EMMC: VEN : SAMSUNG | OEM : 01 | DEV : QD63MB
        EMMC:
              BOOT1  : 0x00400000 [ 4.00 MB ]
              BOOT2  : 0x00400000 [ 4.00 MB ]
              RPMB   : 0x01000000 [ 16.00 MB ]
              USER   : 0x747C00000 [ 29.12 GB ]
        CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000
        RNID : 5F24CAF3F6DA22D463841F8B3CEA9CD
DA : USB : HIGH-SPEED
Boot done!
Patch Level    : O11019
Display ID     : O11019 release-keys
Ver. CodeName  : REL
Ver. Release   : 8.1.0
Sec. Patch     : 2020-06-01
Build Time     : 23.07.2020
Product Model  : vivo 1816
Product Brand  : vivo
Product Name   : PD1818GF_EX
Product Device : PD1818GF_EX
Product Manfct : vivo
Product Info   : k62v1_64_bsp
Product Board  : k62v1_64_bsp
Board Platform : mt6765
USERDATA : FILESYSTEM : EXT4  with FDE ( Full Disk Encryption *)
STORAGE : LifeStatus : eMMC : NOT implemented in selected DA!
Done!
Elapsed: 00:00:23
SMArt Reset
Operation : Reset Settings/Format FS [ v2.15 ]
Mode : SMART RESET
PORT : 5
BROM : Init BROM
BROM init passed!
     CODE : Cervino
BROM : DA sent
     DA : AGENT started!
DA : SYNC
        EMMC:
Boot done!
SmartInfo : 0x805757
Format Ok : USERDATA
Format Ok : CACHE
Format Ok : RESET PROTECTION
Done!
Elapsed: 00:00:33
Read Firmware
Operation : Read Firmware [ v2.15 ]
ExtSparse   : Enabled
ForceRead   : Disabled
PORT : 5
BROM : Init BROM
BROM init passed!
     CODE : Cervino
BROM : DA sent
     DA : AGENT started!
DA : SYNC
        EMMC:
Boot done!
Ver. CodeName  : REL
MT6765__vivo__vivo_1816__8.1.0__O11019__k62v1_64_bsp
Read : preloader.bin
Read : recovery.img
Read : backup.img
Read : survival.img
Read : cust.img
ExtSparse : Compression ratio : 97%
Read : persist.img
ExtSparse : Compression ratio : 78%
Read : proinfo.img
Read : efuse.img
Read : md1rom.img
Read : md1dsp.img
Read : spmfw.img
Read : tinysys-scp.bin
Read : tinysys-sspm.bin
Read : nvram.bin
Read : lk.bin
Read : boot.img
Read : logo.bin
Read : odmdtbo.img
Read : tz.img
Read : vendor.img
ExtSparse : Compression ratio : 22%
Read : system.img
ExtSparse : Compression ratio : 5%
Read : cache.img
Read : userdata.img
FW Size  : 3.64 GB
Android Info saved : _Android_info.txt
Scatter  : MT6765_Android_scatter.txt
Saved to : C:\InfinityBox\CM2MT2\Backup\MT6765__vivo__vivo_1816__8.1.0__O11019__k62v1_64_bsp\
Done!
Elapsed: 00:03:38
The Following User Says Thank You to anoamocreative For This Useful Post:
Old 09-09-2020, 03:47   #132 (permalink)
Member: 919549
Thanks Meter: 130
Vivo pd1818GF
Identify...
Mode : FLASH
PORT : 5
BROM : Init BROM
BROM init passed!
     CODE : Cervino
BROM : DA sent
     DA : AGENT started!
DA : SYNC
        EMMC:
Boot done!
Ver. CodeName  : REL
Done!
Elapsed: 00:00:23
SMArt Reset
Mode : SMART RESET
PORT : 5
BROM : Init BROM
BROM init passed!
     CODE : Cervino
BROM : DA sent
     DA : AGENT started!
DA : SYNC
        EMMC:
Boot done!
Format Ok : CACHE
Done!
Elapsed: 00:00:33
Read Firmware
ExtSparse   : Enabled
PORT : 5
BROM : Init BROM
BROM init passed!
     CODE : Cervino
BROM : DA sent
     DA : AGENT started!
DA : SYNC
        EMMC:
Boot done!
Ver. CodeName  : REL
Read : recovery.img
Read : backup.img
Read : survival.img
Read : cust.img
Read : persist.img
Read : proinfo.img
Read : efuse.img
Read : md1rom.img
Read : md1dsp.img
Read : spmfw.img
Read : nvram.bin
Read : lk.bin
Read : boot.img
Read : logo.bin
Read : odmdtbo.img
Read : tz.img
Read : vendor.img
Read : system.img
Read : cache.img
Read : userdata.img
FW Size  : 3.64 GB
Done!
Elapsed: 00:03:38
Old 09-09-2020, 05:50   #133 (permalink)
Member: 2266425
Thanks Meter: 36
also change emi version one by one but no luck
MODE : BOOTROM
PORT : 22
BROM : Init BROM
BROM init passed!
CODE : Zion
BROM : BOOTROM
AGENT : DA_PL.bin
BROM : DA sent
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
EMI : SRC : INFINITY-BOX_INTERNAL_EMIDB_v116
EMI : CNT : 0002
ERR : 0xC0070004
Old 09-09-2020, 12:50   #134 (permalink)
JayDi's Avatar
Member: 462970
There is around 20 variants for MT6739.
Or download FW from support and select it , then it will boot.
The Following User Says Thank You to JayDi For This Useful Post:
Old 09-09-2020, 17:25   #135 (permalink)
Member: 2266425
Thanks Meter: 36
ok sir i will try then post result here
Powered by Searchlight © 2021 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.32216 seconds with 8 queries
