Old 10-12-2020, 22:10   #1 (permalink)
Member: 1043909
Thanks Meter: 60,909
Infinity Chinese Miracle-2 MTK/MediaTek v2.16 - Another step forward
As ordinary, unique functions and methods released
Core
Changed : Protocol updated ( Raphael/Legacy )
BugFix : MT6737M/MT6580
Changed : Internal EMI engine rebuild
!* LEGACY line : DB rebuild and updated, changed and optimized selection features
!* RAPAHEL line : DB rebuild from scratch. Selection feature rebuild. Manual mode removed and changed to automatic.
Summary :
!* Supported almost all existing memory/dram combinations up to current date for LEGACY lines
!* Supported almost all existing memory/dram combinations up to current date for RAPHAEL lines ( up to DIMENSITY line )
!* REMOVED manual EMI selection by bruteforce. NOT NEED ANYMORE set one-by-one internal EMI db counter and boot device every time. All auto.
!* In rare case of discrette DRAM may require change EMI once for some specific devices
!* After device learning ( via HW report feature ) it will be stored in SW Database and used automatic at every service/flash/repair operation
!* Overall : Not need seek compatible preloader files for new/not existing FW's devices, spend time to bruteforce and etc. Just connect and work!
Flasher
Changed : Core updated for LEGACY line
BugFix : MT6737 with Android 10 flashing revised
BugFix : Checksum verify rebuild
BugFix : Changed memory repartition model for modern scatter formats ( used in Android 10 FWs )
BugFix : Different scatter-version dependencies handled now correct
Changed : Core updated for RAPHAEL line
Changed : UltraFlash feature updated, new security workarounds supported
Service
Changed : Identify
!* Legacy platform changes, mostly for Android 10 devices
Changed : Smart Reset
!* Optimized support for different customized and generic cases
NewFeature : HW Report ( RAPHAEL - only )
!* Allow read extended info from device about its HW
- EXTCSD info ( complete, include eMMC version, all flags etc. ) - used in case of identification for HWrepair purposes
- CSD info ( complete, TEMP/PERM write protection status ) - used in case of identification ReadOnly state in some cases
- CID info ( FlashIC base info, name, vendor ) - default info, even if boot can nott be completed by some HW or SW reasons
- LifeInfo ( SLC, MLC, EOL status and use counters ) - allow understand how bad it feels
- RPMB info ( is it key programmed or clean and can be re-used )
!* Feature also allow automatic select and store for further use BOOTROM connection settings for RAPHAEL devices ( DRAM init )
!* HWreport not require complete boot in case of semi-dead devices. Useful for HWdebug
!* HWreport result may vary in diffirent models and agents, even on same SoC!
Firmware Reader
Changed : LEGACY line support updated ( Android 10 line )
Changed : Support more different types
Changed : FileSystem tools updated. Issues with reading on some systems should be fixed.
Changed : More wide range of scatter versions creation according device specific data
Other
BugFix : Lot of minor changes and fixes
Option : GUI ( File -> GUI ) : allow select other interface mode
!* Default - standard V2 line GUI
!* Wide - best for big screen / big distance to monitor
!* Wide Log - extend log window to screen size. Optimal for most cases
Info
!* Strongly recommend to use ONLY Infinity or Factory firmwares for modern Android 9/10 device to avoid lot of issues
- FOTA issues
- Attestation Key Issues
- Tee Key issues
- Security issues
Download link #1
Download link #2
Download link #3
How to upload files to support
Infinity-Box 15 years updates and support as nobody else since year 2005
The Following 76 Users Say Thank You to YellowBoss For This Useful Post:
Old 10-12-2020, 22:35   #2 (permalink)
rebainoor's Avatar
Member: 231728
Thanks Meter: 2,102
This is named UPDATE not only add DA and model name
Thinks
The Following 6 Users Say Thank You to rebainoor For This Useful Post:
Old 10-13-2020, 00:14   #3 (permalink)
Member: 2812901
Thanks Meter: 493
In fact, this update is very fantastic
Old 10-13-2020, 00:35   #4 (permalink)
Member: 2452939
Thanks Meter: 256
Infinity team Always world 1st, in gsm
Old 10-13-2020, 02:47   #5 (permalink)
malka4u's Avatar
Member: 1626780
Thanks Meter: 1,275
!* NOT NEED ANYMORE set one-by-one internal EMI db counter and boot device every time. All auto
This is good very good.
The Following 3 Users Say Thank You to malka4u For This Useful Post:
Old 10-13-2020, 03:21   #6 (permalink)
Member: 818995
Thanks Meter: 75
Great update Infinity. keep going.
Old 10-13-2020, 04:22   #7 (permalink)
kothamamun's Avatar
Member: 2556542
Thanks Meter: 1,787
still waiting cm2 qualcom 1.17 version .
The Following 10 Users Say Thank You to kothamamun For This Useful Post:
Old 10-13-2020, 05:24   #8 (permalink)
Member: 2105933
Sonork: .
Thanks Meter: 5
Angry Qualcomm CPU.
I think the Infinity team is now not working with Qualcomm CPU.
The Following 5 Users Say Thank You to mohandas094 For This Useful Post:
Old 10-13-2020, 05:55   #9 (permalink)
ahmer5050's Avatar
Member: 2385819
Sonork: No More Used
Thanks Meter: 827
Great update Infinity Team....
The Following User Says Thank You to ahmer5050 For This Useful Post:
Old 10-13-2020, 05:57   #10 (permalink)
Member: 2105933
Sonork: .
Thanks Meter: 5
1000%
Sent from my RMX1971 using Tapatalk
Old 10-13-2020, 06:15   #11 (permalink)
.::Mustafa::.'s Avatar
Member: 1857951
Sonork: 100.1638512
Thanks Meter: 261
Amazing update Thanks infinity Team
The Following User Says Thank You to .::Mustafa::. For This Useful Post:
Old 10-13-2020, 06:31   #12 (permalink)
kothamamun's Avatar
Member: 2556542
Thanks Meter: 1,787
everybody knows that cm2 qlm is slepping
The Following User Says Thank You to kothamamun For This Useful Post:
Old 10-13-2020, 07:13   #13 (permalink)
Akhtar Ali Jatt's Avatar
Member: 953334
Sonork: 100.1614005
Thanks Meter: 15,420
Great update with world's 1st features .
The Following 2 Users Say Thank You to Akhtar Ali Jatt For This Useful Post:
Old 10-13-2020, 08:28   #14 (permalink)
Member: 2603633
Sonork: family
Thanks Meter: 214
Great update................
The Following User Says Thank You to haseebkakar For This Useful Post:
Old 10-13-2020, 08:46   #15 (permalink)
Member: 2208114
Thanks Meter: 5
Wao, this is fantastic. Kudos to Infinity Team, I love you more
The Following 3 Users Say Thank You to 5diamond For This Useful Post:
Page generated in 0.23527 seconds with 8 queries
