Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | [ Easy-JTAG ] | Direct Unlock Source | Search | Today's Posts | Mark Forums Read |
![]() | #1 (permalink) |
Product Supporter ![]() ![]() ![]() Join Date: Jun 2009
Member: 1043909 Status: Offline Thanks Meter: 58,952 | Infinity Chinese Miracle-2 MTK/MediaTek v2.16 - Another step forward As ordinary, unique functions and methods released Core Changed : Protocol updated ( Raphael/Legacy ) BugFix : MT6737M/MT6580 Changed : Internal EMI engine rebuild !* LEGACY line : DB rebuild and updated, changed and optimized selection features !* RAPAHEL line : DB rebuild from scratch. Selection feature rebuild. Manual mode removed and changed to automatic. Summary : !* Supported almost all existing memory/dram combinations up to current date for LEGACY lines !* Supported almost all existing memory/dram combinations up to current date for RAPHAEL lines ( up to DIMENSITY line ) !* REMOVED manual EMI selection by bruteforce. NOT NEED ANYMORE set one-by-one internal EMI db counter and boot device every time. All auto. !* In rare case of discrette DRAM may require change EMI once for some specific devices !* After device learning ( via HW report feature ) it will be stored in SW Database and used automatic at every service/flash/repair operation !* Overall : Not need seek compatible preloader files for new/not existing FW's devices, spend time to bruteforce and etc. Just connect and work! Flasher Changed : Core updated for LEGACY line BugFix : MT6737 with Android 10 flashing revised BugFix : Checksum verify rebuild BugFix : Changed memory repartition model for modern scatter formats ( used in Android 10 FWs ) BugFix : Different scatter-version dependencies handled now correct Changed : Core updated for RAPHAEL line Changed : UltraFlash feature updated, new security workarounds supported Service Changed : Identify !* Legacy platform changes, mostly for Android 10 devices Changed : Smart Reset !* Optimized support for different customized and generic cases NewFeature : HW Report ( RAPHAEL - only ) !* Allow read extended info from device about its HW - EXTCSD info ( complete, include eMMC version, all flags etc. ) - used in case of identification for HWrepair purposes - CSD info ( complete, TEMP/PERM write protection status ) - used in case of identification ReadOnly state in some cases - CID info ( FlashIC base info, name, vendor ) - default info, even if boot can nott be completed by some HW or SW reasons - LifeInfo ( SLC, MLC, EOL status and use counters ) - allow understand how bad it feels - RPMB info ( is it key programmed or clean and can be re-used ) !* Feature also allow automatic select and store for further use BOOTROM connection settings for RAPHAEL devices ( DRAM init ) !* HWreport not require complete boot in case of semi-dead devices. Useful for HWdebug !* HWreport result may vary in diffirent models and agents, even on same SoC! Firmware Reader Changed : LEGACY line support updated ( Android 10 line ) Changed : Support more different types Changed : FileSystem tools updated. Issues with reading on some systems should be fixed. Changed : More wide range of scatter versions creation according device specific data Other BugFix : Lot of minor changes and fixes Option : GUI ( File -> GUI ) : allow select other interface mode !* Default - standard V2 line GUI !* Wide - best for big screen / big distance to monitor !* Wide Log - extend log window to screen size. Optimal for most cases Info !* Strongly recommend to use ONLY Infinity or Factory firmwares for modern Android 9/10 device to avoid lot of issues - FOTA issues - Attestation Key Issues - Tee Key issues - Security issues Download link #1 Download link #2 Download link #3 How to upload files to support Infinity-Box 15 years updates and support as nobody else since year 2005 ![]() ![]() ![]() ![]() ![]() ![]() |
The Following 76 Users Say Thank You to YellowBoss For This Useful Post: |
![]() | #5 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Aug 2011 Location: Jhapa,Nepal
Member: 1626780 Status: Offline Thanks Meter: 1,228 | Code: !* NOT NEED ANYMORE set one-by-one internal EMI db counter and boot device every time. All auto |
The Following 3 Users Say Thank You to malka4u For This Useful Post: |
