Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | -= Z3X JTAG PLUS =- | Search | Today's Posts | Mark Forums Read |
![]() | #16 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Feb 2017 Location: Quelimane Mz Age: 22
Member: 2680008 Status: Online Thanks Meter: 774 ![]() | ![]() |
The Following 4 Users Say Thank You to yuranc8 For This Useful Post: |
![]() | #17 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Aug 2011 Location: Jhapa,Nepal
Member: 1626780 Status: Online Thanks Meter: 991 | Code: Operation : HW Report [ v2.16 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM76) MODE : PRELOADER PORT PORT : 76 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0002 CODE : Zion TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT MODE : 0_base : BASE_v2028 | Manual : Disabled BROM : SOCID : 057DF4EC15BF9044882159C36B6A1444105E263E7450E0F083426C45709C63D5 AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6739 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: 90014A484247346132A56200276215C9 EMMC: VEN : HYNIX | OEM : 4A01 | DEV : HBG4a2 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : E66E91377E5AF485BCD43EB9FD0E9457 DA : USB : HIGH-SPEED Boot done! Memory Info : CID : 90014A484247346132A56200276215C9 MEM : VEN : HYNIX | OEM : 4A01 | DEV : HBG4a2 EXT_CSD Info : TRIM timeout : 0 ms Secure erase timeout : 60000 ms Secure trim timeout : 6000 ms HC erase unit size : 512 kbytes HC erase timeout : 600 ms HC write prot grp size: 4096 kbytes HC erase grp def. : 0h Sector count : 3a3e000h HS timing : 0h Bus width : 0h Erase memory content : 0h Partition config : 48h Boot partition size : 4096 kbytes Boot information : 7h Boot config protection: 0h Boot bus width : 0h Boot area write prot : 0h User area write prot : 0h RPMB size : 4096 kbytes H/W reset function : 1h FW version(low) : a50h Overall status : RPMB : RPMB KEY NOT set! [State : CLEAN : USABLE] Done! Elapsed: 00:00:57 |
The Following 3 Users Say Thank You to malka4u For This Useful Post: |
![]() | #21 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Dec 2009
Member: 1174820 Status: Offline Thanks Meter: 59 | Everybody knows that you are always-crying and never-satisfied sunday unlocker. And what ? Try to start work but not cry like 65-years-old unsatisfied single woman with 13 cats on hands. Once you start work instead of cry you will see that your life turns to you by better side. good luck crying man ! |
The Following 3 Users Say Thank You to mk.nau For This Useful Post: |
![]() | #22 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Nov 2016
Member: 2649950 Status: Offline Thanks Meter: 27 | Operation : HW Report [ v2.16 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM6) MODE : BOOTROM PORT : 6 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6570 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Rushmore TYPE : MODERN RAPHAEL BROM : MEID : 1FC2389781813B7437B2AF7D7CD91B1A BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2028 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6570 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : PRELOADER_INFINITY_0 EMI : CNT : 0003 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00018000 [ 96,00 KB ] DRAM: 0x20000000 [ 512,00 MB ] EMMC: 700100543232373038013B48935B64F1 EMMC: VEN : KINGSTON | OEM : 01 | DEV : T22708 EMMC: BOOT1 : 0x00400000 [ 4,00 MB ] BOOT2 : 0x00400000 [ 4,00 MB ] RPMB : 0x00400000 [ 4,00 MB ] USER : 0x1C8000000 [ 7,13 GB ] CHIP : MT6570 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 3B82BB9BDFCE5A5853C97986A454896C DA : USB : FULL-SPEED DA : USB : Change Port Speed Error : Failed to setup HS_USB port! Memory Info : Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! CID : 700100543232373038013B48935B64F1 CSD : D04F01320F5903FFFFFFFFEF8A400061 MEM : VEN : KINGSTON | OEM : 01 | DEV : T22708 DAT : Size: 7296 MB, Max.Speed: 52000 kHz, blklen(512), nblks(14942208), ro(0) artem konstantinov, [12.10.20 21:32] EXT_CSD Info : EXT_CSD rev. : v1.7 ( MMC v5.0 ) CSD struct rev. : v1.2 Supported command sets : 1h HPI features : 1h BG operations support : 1h BG operations status : 0h Correct prg. sectors : 0h 1st init time after part. : 10000 ms Min. write perf.(DDR,52MH,8b): 0h Min. read perf. (DDR,52MH,8b): 0h TRIM timeout: 16 ms Secure feature support: 55h Secure erase timeout : 5100 ms Secure trim timeout : 5100 ms Access size : 3072 bytes HC erase unit size : 512 kbytes HC erase timeout : 5100 ms HC write prot grp size: 8192 kbytes HC erase grp def. : 0h Reliable write sect count: 1h Sleep current (VCC) : 8h Sleep current (VCCQ): 8h Sleep/awake timeout : 52428800 ns Sector count : e40000h Min. WR Perf. (52MH,8b): 8h Min. Read Perf.(52MH,8b): 8h Min. WR Perf. (26MH,8b,52MH,4b): 8h Min. Read Perf.(26MH,8b,52MH,4b): 8h Min. WR Perf. (26MH,4b): 8h Min. Read Perf.(26MH,4b): 8h Power class: 0 Power class(DDR,52MH,3.6V): 0h Power class(DDR,52MH,1.9V): 0h Power class(26MH,3.6V) : 0h Power class(52MH,3.6V) : 0h Power class(26MH,1.9V) : 0h Power class(52MH,1.9V) : 0h Part. switch timing : 3h Out-of-INTR busy timing: ah Card type : 57h Command set : 0h Command set rev.: 0h HS timing : 0h Bus width : 0h Erase memory content : 0h Partition config : 48h Boot partition size : 4096 kbytes Boot information : 7h Boot config protection: 0h Boot bus width : 0h Boot area write prot : 0h User area write prot : 0h FW configuration : 0h RPMB size : 4096 kbytes Write rel. setting : 0h Write rel. parameter: 15h Start background ops : 0h Enable background ops: 0h H/W reset function : 1h HPI management : 0h Max. enhanced area size : 97h (1236992 kbytes) Part. support : 7h Part. attribute: 0h Part. setting : 0h General purpose 1 size : 0h (0 kbytes) General purpose 2 size : 0h (0 kbytes) General purpose 3 size : 0h (0 kbytes) General purpose 4 size : 0h (0 kbytes) Enh. user area size : 0h (0 kbytes) Enh. user area start: 0h Bad block mgmt mode: 0h Overall status : PERM_WRITE_PROTECT : Disabled TEMP_WRITE_PROTECT : Disabled MLC status : 0% - 10% used SLC status : 10% - 20% used EOL status : Warning ( Used from 80% to 90% reserved blocks ) Done! Elapsed: 00:00:28 |
The Following 7 Users Say Thank You to Z_Felix For This Useful Post: |
![]() | #23 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Oct 2015
Member: 2466934 Status: Offline Thanks Meter: 30 | I'll renew activation after any Qualcomm update, till then i have to stick with old mt2 2.11 version & UMT Dongle.. |
The Following User Says Thank You to AM19x For This Useful Post: |
![]() | #26 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2014 Location: B A N G L A D E S H
Member: 2171294 Status: Offline Sonork: 100.1659207 Thanks Meter: 690 ![]() | Wow, nice update NewFeature : HW Report ( RAPHAEL - only ) |
The Following User Says Thank You to tapas770 For This Useful Post: |
![]() | #28 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: May 2007 Location: P A K I S T A N
Member: 515406 Status: Online Sonork: 100.1603457 Thanks Meter: 800 | nice update keep it up....and also waiting for qlm update |
The Following User Says Thank You to saqib2009 For This Useful Post: |
