01-24-2021, 02:09 | #1 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Infinity Chinese Miracle-2 MTK/MediaTek v2.17 - Standalone auth ON As ordinary unique solutions by World famous Infinity Team ! Core Changed : Protocol updated ( Raphael/Legacy ) NewFeature: Standalone SLA/Auth [Raphael] ** Changed : Internal EMI engine updated : RAPAHEL : UFS support rebuild Flasher Changed: Core updated for RAPHAEL line Changed: UltraFlash feature updated, new security workarounds supported Service Changed: Identify !* Read new Android 10 specific fields, vendor-specific fields Changed: Smart Reset !* Optimized support for different customized and generic cases Changed: HW Report ( RAPHAEL - only ) !* UFS line devices now supported with following features: - CID info ( FlashIC base info, name, vendor ) - default info, even if boot can nott be completed by some HW or SW reasons - LifeInfo ( SLC, MLC, EOL status and use counters ) - allow understand how bad it feels - RPMB info ( is it key programmed or clean and can be re-used ) - Partitioning details and other - HWreport log saving enabled ( for further analyze ) !* Feature also allow automatic select and store for further use BOOTROM connection settings for RAPHAEL devices ( DRAM init ) !* HWreport not require complete boot in case of semi-dead devices. Useful for HWdebug !* HWreport result may vary in diffirent models and agents even on the same SoC ! Firmware Reader Changed : Some modern brand-specific changes ( Xiaomi, Oppo, Vivo, Realme ) Changed : New types supported Other BugFix : Many different minor changes and fixes Changed : Generic protocol rebuild Info !** - Standalone SLA/Auth allow you ignore device security setting and allow boot it without having any DA/Auth/Remote auth support - You can boot ( with supported SoC ) device with any generic da and perform any need operations - Support MT6765 - All security versions, no auth need, no special da need, no remote service need Support Xiaomi, Oppo, Vivo, Realme, Huawei and whatever else existing - Support MT6785 - All security versions, no auth need, no special da need, no remote service need Support Xiaomi, Oppo, Vivo, Realme, Huawei and whatever else existing New Drivers_MTK_v2.0.1.1.7z are here NOTE: special boot-helper tool should be installed - included in CM2MT2 package How to Install: Important step ! Dongle Firmware version required: v0147 Password for archive: 12345678 Download link #1 Download link #2 How to upload files to support Infinity-Box 16 years updates and support as nobody else since year 2005 Last edited by YellowBoss; 02-04-2021 at 12:42. |
The Following 102 Users Say Thank You to YellowBoss For This Useful Post: |
01-24-2021, 02:34 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | READMI 6A HWreport : Code: Operation : HW Report [ v2.17 ] HWreport : Mode : eMMC 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM23) MODE : BOOTROM PORT : 23 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN RAPHAEL BROM : MEID : xxxxxxxxxxxxxxxxxxxxx BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v1944 | Manual : Disabled BROM : SOCID : xxxxxxxxxxxxxxxxxxxxxxx BROM : SLA : Local Auth BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : PRELOADER_INFINITY_0 EMI : CNT : 0001 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00038000 [ 224,00 KB ] DRAM: 0x80000000 [ 2,00 GB ] EMMC: 150100514536334D42xxxxxxxxxxxxx EMMC: VEN : SAMSUNG | OEM : 01 | DEV : QE63MB EMMC: BOOT1 : 0x00400000 [ 4,00 MB ] BOOT2 : 0x00400000 [ 4,00 MB ] RPMB : 0x00400000 [ 4,00 MB ] USER : 0x3A3E00000 [ 14,56 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : xxxxxxxxxxxxxxxxxxxxxxx DA : USB : HIGH-SPEED Boot done! Memory Info : CID : 150100514536334D42xxxxxxxxxxxxx MEM : VEN : SAMSUNG | OEM : 01 | DEV : QE63MB DAT : Size: 14910 MB, Max.Speed: 52000 kHz, blklen(512), nblks(30535680), ro(0) EXT_CSD Info : EXT_CSD rev. : v1.8 ( MMC v5.1 ) CSD struct rev. : v1.2 Supported command sets : 1h HPI features : 1h BG operations support : 1h BG operations status : 0h Correct prg. sectors : 0h 1st init time after part. : 3000 ms Min. write perf.(DDR,52MH,8b): 0h Min. read perf. (DDR,52MH,8b): 0h TRIM timeout: 0 ms Secure feature support: 55h Secure erase timeout : 8100 ms Secure trim timeout : 5100 ms Access size : 3584 bytes HC erase unit size : 512 kbytes HC erase timeout : 300 ms HC write prot grp size: 8192 kbytes HC erase grp def. : 0h Reliable write sect count: 1h Sleep current (VCC) : 7h Sleep current (VCCQ): 7h Sleep/awake timeout : 26214400 ns Sector count : 1d1f000h Min. WR Perf. (52MH,8b): 0h Min. Read Perf.(52MH,8b): 0h Min. WR Perf. (26MH,8b,52MH,4b): 0h Min. Read Perf.(26MH,8b,52MH,4b): 0h Min. WR Perf. (26MH,4b): 0h Min. Read Perf.(26MH,4b): 0h Power class: 0 Power class(DDR,52MH,3.6V): 0h Power class(DDR,52MH,1.9V): 0h Power class(26MH,3.6V) : 0h Power class(52MH,3.6V) : 0h Power class(26MH,1.9V) : 0h Power class(52MH,1.9V) : 0h Part. switch timing : 2h Out-of-INTR busy timing: ah Card type : 57h Command set : 0h Command set rev.: 0h HS timing : 0h Bus width : 0h Erase memory content : 0h Partition config : 48h Boot partition size : 4096 kbytes Boot information : 7h Boot config protection: 0h Boot bus width : 2h Boot area write prot : 0h User area write prot : 0h FW configuration : 0h RPMB size : 4096 kbytes Write rel. setting : 1fh Write rel. parameter: 14h Start background ops : 0h Enable background ops: 2h H/W reset function : 1h HPI management : 0h Max. enhanced area size : 3a3h (7626752 kbytes) Part. support : 7h Part. attribute: 0h Part. setting : 0h General purpose 1 size : 0h (0 kbytes) General purpose 2 size : 0h (0 kbytes) General purpose 3 size : 0h (0 kbytes) General purpose 4 size : 0h (0 kbytes) Enh. user area size : 0h (0 kbytes) Enh. user area start: 0h Bad block mgmt mode: 0h Overall status : MLC status : 0% - 10% used SLC status : 0% - 10% used EOL status : Normal ( Less than 80% reserved blocks used ) RPMB : RPMB KEY EXISTS! [State : NOT CLEAN : UNUSABLE] Done! Elapsed: 00:00:22 Code: Operation : Identify [ v2.17 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM23) MODE : BOOTROM PORT : 23 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN RAPHAEL BROM : MEID : xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v1944 | Manual : Disabled BROM : SOCID : xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx BROM : SLA : Local Auth BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : PRELOADER_INFINITY_0 EMI : CNT : 0001 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00038000 [ 224,00 KB ] DRAM: 0x80000000 [ 2,00 GB ] EMMC: 150100514536334D420xxxxxxxxxxxxxxxxxx EMMC: VEN : SAMSUNG | OEM : 01 | DEV : QE63MB EMMC: BOOT1 : 0x00400000 [ 4,00 MB ] BOOT2 : 0x00400000 [ 4,00 MB ] RPMB : 0x00400000 [ 4,00 MB ] USER : 0x3A3E00000 [ 14,56 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : xxxxxxxxxxxxxxxxxxxxxxxxxxxxx DA : USB : HIGH-SPEED Boot done! Patch Level : O11019 Display ID : O11019 Ver. CodeName : REL Ver. Release : 8.1.0 Sec. Patch : 2018-05-05 Build Time : 11.06.2018 Product Model : Redmi 6A Product Brand : xiaomi Product Name : cactus Product Device : cactus Product Info : cactus Product Manfct : Xiaomi Board Platform : mt6765 USERDATA : FILESYSTEM : EXT4 with FDE ( Full Disk Encryption *) NVRAM check : Passed! NVRAM : SEC SIGNED [ IMEI RSA SIGNED ] Backup sensetive data [ 8 ] Backup path : Backup\MT6765__xxxxxxxxxxxxx\ [25] Read : NVRAM [8] Read : NVDATA [15] Read : PROINFO [27] Read : LK [7] Read : NVCFG [10] Read : PROTECT1 [11] Read : PROTECT2 Backup done! STORAGE : LifeStatus : eMMC : OK! PRELOADER : DEVICE : DEV : MT6765 NME : preloader_cactus.bin CNT : 000A EMI : [00] : eMMC : DDR3 : ID : 90014A484247346132 : VEN : HYNIX | DEV : HBG4a2 : RAM : [ 3,00 GB ] EMI : [01] : eMMC : DDR3 : ID : 90014A68423861503E : VEN : HYNIX | DEV : hB8aP> : RAM : [ 3,00 GB ] EMI : [02] : eMMC : DDR3 : ID : 90014A484147346132 : VEN : HYNIX | DEV : HAG4a2 : RAM : [ 2,00 GB ] EMI : [03] : eMMC : DDR3 : ID : 13014E53304A394237 : VEN : MICRON | DEV : S0J9B7 : RAM : [ 3,00 GB ] EMI : [04] : eMMC : DDR3 : ID : 150100514536334D42 : VEN : SAMSUNG | DEV : QE63MB : RAM : [ 2,00 GB ] EMI : [05] : eMMC : DDR3 : ID : 150100474436424D42 : VEN : SAMSUNG | DEV : GD6BMB : RAM : [ 3,00 GB ] EMI : [06] : eMMC : DDR3 : ID : 13014E53304A394137 : VEN : MICRON | DEV : S0J9A7 : RAM : [ 2,00 GB ] EMI : [07] : eMMC : DDR3 : ID : 150100524836344142 : VEN : SAMSUNG | DEV : RH64AB : RAM : [ 4,00 GB ] EMI : [08] : eMMC : DDR3 : ID : 90014A484347386134 : VEN : HYNIX | DEV : HCG8a4 : RAM : [ 4,00 GB ] EMI : [09] : eMMC : DDR3 : ID : 150100514436334D42 : VEN : SAMSUNG | DEV : QD63MB : RAM : [ 2,00 GB ] Done! Elapsed: 00:00:39 Code: Operation : Read Firmware [ v2.17 ] ExtSparse : Enabled ForceRead : Disabled 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM23) MODE : BOOTROM PORT : 23 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN RAPHAEL BROM : MEID : xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v1944 | Manual : Disabled BROM : SOCID : xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx BROM : SLA : Local Auth BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : PRELOADER_INFINITY_0 EMI : CNT : 0001 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00038000 [ 224,00 KB ] DRAM: 0x80000000 [ 2,00 GB ] EMMC: 150100514536334D4203Cxxxxxxxxxxx EMMC: VEN : SAMSUNG | OEM : 01 | DEV : QE63MB EMMC: BOOT1 : 0x00400000 [ 4,00 MB ] BOOT2 : 0x00400000 [ 4,00 MB ] RPMB : 0x00400000 [ 4,00 MB ] USER : 0x3A3E00000 [ 14,56 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : xxxxxxxxxxxxxxxxxxxxxxx DA : USB : HIGH-SPEED Boot done! Patch Level : O11019 Display ID : O11019 Ver. CodeName : REL Ver. Release : 8.1.0 Sec. Patch : 2018-05-05 Build Time : 11.06.2018 Product Model : Redmi 6A Product Brand : xiaomi Product Name : cactus Product Device : cactus Product Info : cactus Product Manfct : Xiaomi Board Platform : mt6765 MT6765__Xiaomi__Redmi_6A__8.1.0__O11019__O11019__cactus Read : preloader.bin Read : recovery.img Read : persist.img ExtSparse : Compression ratio : 100% Read : proinfo.img Read : efuse.img Read : md1rom.img Read : spmfw.img Read : tinysys-scp.bin Read : tinysys-sspm.bin Read : nvram.bin Read : vbmeta.img Read : lk.bin Read : boot.img Read : logo.bin Read : odmdtbo.img Read : cust.img ExtSparse : Compression ratio : 32% Read : tz.img Read : vendor.img ExtSparse : Compression ratio : 53% Read : system.img ExtSparse : Compression ratio : 24% Read : cache.img Read : userdata.img FW Size : 2,86 GB Android Info saved : _Android_info.txt Scatter : MT6765_Android_scatter.txt Saved to : C:\MT6765__Xiaomi__Redmi_6A__8.1.0__O11019__O11019__cactus\ Done! Elapsed: 00:07:26 Code: Created by Infinity-Box (c) 2021 Chinese Miracle II : MediaTek Service Module Device Info file : _Android_info.txt Patch Level : O11019 Display ID : O11019 Ver. CodeName : REL Ver. Release : 8.1.0 Sec. Patch : 2018-05-05 Build Time : 11.06.2018 Product Model : Redmi 6A Product Brand : xiaomi Product Name : cactus Product Device : cactus Product Info : cactus Product Manfct : Xiaomi Board Platform : mt6765 Preloader [HW DEV] Info : EMI : DEV : MT6765 EMI : SRC : preloader_cactus.bin EMI : CNT : 000A EMI : [00] : eMMC : DDR3 : ID : 90014A484247346132 : VEN : HYNIX | DEV : HBG4a2 : RAM : [ 3,00 GB ] EMI : [01] : eMMC : DDR3 : ID : 90014A68423861503E : VEN : HYNIX | DEV : hB8aP> : RAM : [ 3,00 GB ] EMI : [02] : eMMC : DDR3 : ID : 90014A484147346132 : VEN : HYNIX | DEV : HAG4a2 : RAM : [ 2,00 GB ] EMI : [03] : eMMC : DDR3 : ID : 13014E53304A394237 : VEN : MICRON | DEV : S0J9B7 : RAM : [ 3,00 GB ] EMI : [04] : eMMC : DDR3 : ID : 150100514536334D42 : VEN : SAMSUNG | DEV : QE63MB : RAM : [ 2,00 GB ] EMI : [05] : eMMC : DDR3 : ID : 150100474436424D42 : VEN : SAMSUNG | DEV : GD6BMB : RAM : [ 3,00 GB ] EMI : [06] : eMMC : DDR3 : ID : 13014E53304A394137 : VEN : MICRON | DEV : S0J9A7 : RAM : [ 2,00 GB ] EMI : [07] : eMMC : DDR3 : ID : 150100524836344142 : VEN : SAMSUNG | DEV : RH64AB : RAM : [ 4,00 GB ] EMI : [08] : eMMC : DDR3 : ID : 90014A484347386134 : VEN : HYNIX | DEV : HCG8a4 : RAM : [ 4,00 GB ] EMI : [09] : eMMC : DDR3 : ID : 150100514436334D42 : VEN : SAMSUNG | DEV : QD63MB : RAM : [ 2,00 GB ] Operation : Write Flash [ v2.17 ] Repartition : Enabled Flash Verify : Enabled Reg.Pre-Erase : Enabled Verify HW/SW : Enabled SData Backup : Disabled Safe UserData : Disabled Flash Format : Disabled Files :22 [FL] : Set : preloader_cactus.bin [FL] : Set : recovery.img [FL] : Set : efuse.img [FL] : Set : md1rom.img [FL] : Set : spmfw.img [FL] : Set : tinysys-scp.bin [FL] : Set : tinysys-scp.bin [FL] : Set : tinysys-sspm.bin [FL] : Set : tinysys-sspm.bin [FL] : Set : vbmeta.img [FL] : Set : lk.bin [FL] : Set : lk.bin [FL] : Set : boot.img [FL] : Set : logo.bin [FL] : Set : odmdtbo.img [FL] : Set : cust.img [FL] : Set : tz.img [FL] : Set : tz.img [FL] : Set : vendor.img [FL] : Set : system.img [FL] : Set : cache.img [FL] : Set : userdata.img [FL] : Total size : 0xB32BDBC8 [ 2,80 GB ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM23) MODE : BOOTROM PORT : 23 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN RAPHAEL BROM : MEID : xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v1944 | Manual : Disabled BROM : SOCID : xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx BROM : SLA : Local Auth BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : MT6765 EMI : SRC : preloader_cactus.bin EMI : CNT : 000A EMI : [00] : eMMC : DDR3 : ID : 90014A484247346132 : VEN : HYNIX | DEV : HBG4a2 : RAM : [ 3,00 GB ] EMI : [01] : eMMC : DDR3 : ID : 90014A68423861503E : VEN : HYNIX | DEV : hB8aP> : RAM : [ 3,00 GB ] EMI : [02] : eMMC : DDR3 : ID : 90014A484147346132 : VEN : HYNIX | DEV : HAG4a2 : RAM : [ 2,00 GB ] EMI : [03] : eMMC : DDR3 : ID : 13014E53304A394237 : VEN : MICRON | DEV : S0J9B7 : RAM : [ 3,00 GB ] EMI : [04] : eMMC : DDR3 : ID : 150100514536334D42 : VEN : SAMSUNG | DEV : QE63MB : RAM : [ 2,00 GB ] EMI : [05] : eMMC : DDR3 : ID : 150100474436424D42 : VEN : SAMSUNG | DEV : GD6BMB : RAM : [ 3,00 GB ] EMI : [06] : eMMC : DDR3 : ID : 13014E53304A394137 : VEN : MICRON | DEV : S0J9A7 : RAM : [ 2,00 GB ] EMI : [07] : eMMC : DDR3 : ID : 150100524836344142 : VEN : SAMSUNG | DEV : RH64AB : RAM : [ 4,00 GB ] EMI : [08] : eMMC : DDR3 : ID : 90014A484347386134 : VEN : HYNIX | DEV : HCG8a4 : RAM : [ 4,00 GB ] EMI : [09] : eMMC : DDR3 : ID : 150100514436334D42 : VEN : SAMSUNG | DEV : QD63MB : RAM : [ 2,00 GB ] EMI : Init EMI from PRELOADER EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00038000 [ 224,00 KB ] DRAM: 0x80000000 [ 2,00 GB ] EMMC: 150100514536334D4203Cxxxxxxxx EMMC: VEN : SAMSUNG | OEM : 01 | DEV : QE63MB EMMC: BOOT1 : 0x00400000 [ 4,00 MB ] BOOT2 : 0x00400000 [ 4,00 MB ] RPMB : 0x00400000 [ 4,00 MB ] USER : 0x3A3E00000 [ 14,56 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx DA : USB : HIGH-SPEED Boot done! [FL] : HW verification passed! SEC_DL : False (RAPHAEL) SEC_ID : 0x494E46494E495459424F584245535432 [FL] : Pre-Erase Erase : 0x0000000000000000 : 0x0000000005688000 Erase : 0x0000000007688000 : 0x0000000006000000 Erase : 0x000000000E800000 : 0x0000000000800000 Erase : 0x0000000013000000 : 0x0000000000200000 Erase : 0x0000000013500000 : 0x0000000008980000 Erase : 0x000000001FE80000 : 0x00000000FA980000 Erase : 0x000000011B000000 : 0x00000000D0000000 [FL] : RePartition [FL] : RePartition Ok! [FL] : Flashing now ... Write : PRELOADER Update bootloader backup copy ... Update bootloader backup copy Ok! Write : RECOVERY Write : EFUSE Write : MD1IMG Write : SPMFW Write : SCP1 Write : SCP2 Write : SSPM_1 Write : SSPM_2 Write : VBMETA Write : LK Write : LK2 Write : BOOT Write : LOGO Write : ODMDTBO Write : CUST FAIL : SEC : IMG TOO LARGE Write : TEE1 Write : TEE2 Write : VENDOR Write : SYSTEM Write : CACHE Write : USERDATA Ultra : Ok! SEC_DL : False (RAPHAEL) SEC_ID : 0x494E46494E495459424F584245535432 [FL] : RePartition [FL] : RePartition Ok! [FL] : Flashing finished! Done! Elapsed: 00:02:21 Reconnect Power/Cable! |
The Following 49 Users Say Thank You to JayDi For This Useful Post: |
01-24-2021, 02:39 | #3 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | RMnote 8Pro : HWreport : Code: Operation : HW Report [ v2.17 ] HWreport : Mode : UFS 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM23) MODE : BOOTROM PORT : 23 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6785 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Krug TYPE : MODERN RAPHAEL BROM : MEID : xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2028 | Manual : Disabled BROM : SOCID : xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxC BROM : SLA : Local Auth BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6785 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : PRELOADER_INFINITY_0 EMI : CNT : 0001 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00080000 [ 512,00 KB ] DRAM: 0x180000000 [ 6,00 GB ] UFS: AD014839485131364145434D4D444152 UFS: VEN : 0x01AD VID : H9HQ16AECMMDAR IFW : A107 LU0 : 0x00400000 [ 4,00 MB ] LU1 : 0x00400000 [ 4,00 MB ] LU2 : 0x1DCB000000 [ 119,17 GB ] FSN : 15xxxxxxxxxxx8000000000000 REG : 0x101010000 CHIP : MT6785 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : xxxxxxxxxxxxxxxxxxxxxxxxxxxx DA : USB : HIGH-SPEED Boot done! Memory Info : CID : H9HQ16AECMMDAR EXT_CSD Info : [UFS] Device Desc: [UFS] String Desc: Serial Number INDEX 3, LENGTH 12 [UFS] Serial Number: 15cxxxxxxxxxxx8000000000000 [UFS] life cycle check, pre_eol_info=1, life_time_est_a=1, life_time_est_b=1 [UFS] vendor id : 0x1ad [UFS] ufs id : H9HQ16AECMMDAR [UFS] ufs fwver: A107 [UFS] dev_quirk = 0x10000000 [UFS] Custom force provison=0, TW size=-1GB, TW no red=1, HPB size=-1GB [UFS] info: number of active LU: 3, check OK. [UFS] info: number of Boot LU: 2, check OK. [UFS] info: LU Configuration Check OK. Bootable UFS [UFS] info: Boot LU Configuration Check OK. Active Boot LU: LU0 [UFS] info: HS-G3-2 Overall status : MLC status : 0% - 10% used SLC status : 0% - 10% used EOL status : Normal ( Less than 80% reserved blocks used ) RPMB : RPMB KEY NOT set! [State : CLEAN : USABLE] Done! Elapsed: 00:00:15 Code: Operation : Identify [ v2.17 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM23) MODE : BOOTROM PORT : 23 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6785 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Krug TYPE : MODERN RAPHAEL BROM : MEID : xxxxxxxxxxxxxxxxxxxxxxxxxxxx BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2028 | Manual : Disabled BROM : SOCID : xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxC BROM : SLA : Local Auth BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6785 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : PRELOADER_INFINITY_0 EMI : CNT : 0001 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00080000 [ 512,00 KB ] DRAM: 0x180000000 [ 6,00 GB ] UFS: AD014839485131364145434D4D444152 UFS: VEN : 0x01AD VID : H9HQ16AECMMDAR IFW : A107 LU0 : 0x00400000 [ 4,00 MB ] LU1 : 0x00400000 [ 4,00 MB ] LU2 : 0x1DCB000000 [ 119,17 GB ] FSN : 158xxxxxxxx8000000000000 REG : 0x101010000 CHIP : MT6785 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : xxxxxxxxxxxxxxxxxxxxxxxxxxx DA : USB : HIGH-SPEED Boot done! Patch Level : PPR1.180610.011 Display ID : PPR1.180610.011 Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2019-12-01 Build Time : 07.01.2020 Product Model : Redmi Note 8 Pro Product Brand : Redmi Product Name : begonia Product Device : begonia Product Info : begonia Product Manfct : Xiaomi Product Board : begonia Board Platform : mt6785 NVRAM check : Failed! NVRAM damaged! NVRAM : SEC SIGNED [ IMEI RSA SIGNED ] Backup sensetive data [ 8 ] Backup path : Backup\MT6785__xxxxxxxxxxxxxxx\ Backup done! STORAGE : LifeStatus : UFS : OK! PRELOADER : DEVICE : DEV : MT6752 NME : preloader_begonia.bin CNT : 000A EMI : [00] : eUFS : LP_DDR4X : DEV : H9HQ16AECMMDAR : RAM : [ 6,00 GB ] EMI : [01] : eUFS : LP_DDR4X : DEV : H9HQ53ACPMMDAR : RAM : [ 4,00 GB ] EMI : [02] : eUFS : LP_DDR4X : DEV : H9HQ53AECMMDAR : RAM : [ 6,00 GB ] EMI : [03] : eUFS : LP_DDR4X : DEV : KM5H7001DM-B424 : RAM : [ 4,00 GB ] EMI : [04] : eUFS : LP_DDR4X : DEV : KM2H7001CM-B518 : RAM : [ 6,00 GB ] EMI : [05] : eUFS : LP_DDR4X : DEV : KM2V8001CM-B707 : RAM : [ 6,00 GB ] EMI : [06] : eUFS : LP_DDR4X : DEV : MT064GASAO2U21 : RAM : [ 4,00 GB ] EMI : [07] : eUFS : LP_DDR4X : DEV : H9HQ16AFAMMDAR : RAM : [ 8,00 GB ] EMI : [08] : eUFS : LP_DDR4X : DEV : MT128GASAO4U21 : RAM : [ 6,00 GB ] EMI : [09] : eUFS : LP_DDR4X : DEV : H9HQ21AFAMZDAR : RAM : [ 8,00 GB ] Done! Elapsed: 00:00:23 Code: Operation : Read Firmware [ v2.17 ] ExtSparse : Enabled ForceRead : Disabled 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM23) MODE : BOOTROM PORT : 23 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6785 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Krug TYPE : MODERN RAPHAEL BROM : MEID : xxxxxxxxxxxxxxxxxxxxxxxxxxxx BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2028 | Manual : Disabled BROM : SOCID : xxxxxxxxxxxxxxxxxxxxxxC BROM : SLA : Local Auth BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6785 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : PRELOADER_INFINITY_0 EMI : CNT : 0001 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00080000 [ 512,00 KB ] DRAM: 0x180000000 [ 6,00 GB ] UFS: AD014839485131364145434D4D444152 UFS: VEN : 0x01AD VID : H9HQ16AECMMDAR IFW : A107 LU0 : 0x00400000 [ 4,00 MB ] LU1 : 0x00400000 [ 4,00 MB ] LU2 : 0x1DCB000000 [ 119,17 GB ] FSN : 15xxxxxxxxxx000000000000 REG : 0x101010000 CHIP : MT6785 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : xxxxxxxxxxxxxxxxxxxx DA : USB : HIGH-SPEED Boot done! Patch Level : PPR1.180610.011 Display ID : PPR1.180610.011 Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2019-12-01 Build Time : 07.01.2020 Product Model : Redmi Note 8 Pro Product Brand : Redmi Product Name : begonia Product Device : begonia Product Info : begonia Product Manfct : Xiaomi Product Board : begonia Board Platform : mt6785 MT6785__Xiaomi__Redmi_Note_8_Pro__9__PPR1.180610.011__PPR1.180610.011__begonia Read : preloader.bin Read : recovery.img Read : vbmeta.img Read : persist.img ExtSparse : Compression ratio : 100% Read : proinfo.img Read : efuse.img Read : nvram.bin Read : md1rom.img Read : spmfw.img Read : audio_dsp.img Read : tinysys-scp.bin Read : tinysys-sspm.bin Read : cam_vpu1.img Read : cam_vpu2.img Read : cam_vpu3.img Read : gz.img Read : lk.bin Read : boot.img Read : logo.bin Read : dtbo.img Read : tz.img Read : vendor.img ExtSparse : Compression ratio : 40% Read : system.img ExtSparse : Compression ratio : 7% Read : cache.img Read : cust.img ExtSparse : Compression ratio : 17% Read : userdata.img FW Size : 5,17 GB Android Info saved : _Android_info.txt Scatter : MT6785_Android_scatter.txt Saved to : C:\MT6785__Xiaomi__Redmi_Note_8_Pro__9__PPR1.180610.011__PPR1.180610.011__begonia\ Done! Elapsed: 00:07:08 |
The Following 30 Users Say Thank You to JayDi For This Useful Post: |
01-24-2021, 02:53 | #4 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Random VIVO HWreport : Code: Operation : HW Report [ v2.17 ] HWreport : Mode : eMMC 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM23) MODE : BOOTROM PORT : 23 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN RAPHAEL BROM : MEID : xxxxxxxxxxxxxxxxxxxxxxxxxx BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v1944 | Manual : Disabled BROM : SOCID : xxxxxxxxxxxxxxxxxxxxxxxxxxx BROM : SLA : Local Auth BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : PRELOADER_INFINITY_0 EMI : CNT : 0001 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00038000 [ 224,00 KB ] DRAM: 0x100000000 [ 4,00 GB ] EMMC: 150100444836444D42054xxxxxxxxxxxxxx EMMC: VEN : SAMSUNG | OEM : 01 | DEV : DH6DMB EMMC: BOOT1 : 0x00400000 [ 4,00 MB ] BOOT2 : 0x00400000 [ 4,00 MB ] RPMB : 0x00400000 [ 4,00 MB ] USER : 0xE8F800000 [ 58,24 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : xxxxxxxxxxxxxxxxxxxxxxxxxx DA : USB : HIGH-SPEED Boot done! Memory Info : CID : 150100444836444D4205xxxxxxxxxxxx MEM : VEN : SAMSUNG | OEM : 01 | DEV : DH6DMB DAT : Size: 59640 MB, Max.Speed: 52000 kHz, blklen(512), nblks(122142720), ro(0) EXT_CSD Info : EXT_CSD rev. : v1.8 ( MMC v5.1 ) CSD struct rev. : v1.2 Supported command sets : 1h HPI features : 1h BG operations support : 1h BG operations status : 0h Correct prg. sectors : 0h 1st init time after part. : 3000 ms Min. write perf.(DDR,52MH,8b): 0h Min. read perf. (DDR,52MH,8b): 0h TRIM timeout: 0 ms Secure feature support: 55h Secure erase timeout : 8100 ms Secure trim timeout : 5100 ms Access size : 3584 bytes HC erase unit size : 512 kbytes HC erase timeout : 300 ms HC write prot grp size: 8192 kbytes HC erase grp def. : 0h Reliable write sect count: 1h Sleep current (VCC) : 7h Sleep current (VCCQ): 7h Sleep/awake timeout : 26214400 ns Sector count : 747c000h Min. WR Perf. (52MH,8b): 0h Min. Read Perf.(52MH,8b): 0h Min. WR Perf. (26MH,8b,52MH,4b): 0h Min. Read Perf.(26MH,8b,52MH,4b): 0h Min. WR Perf. (26MH,4b): 0h Min. Read Perf.(26MH,4b): 0h Power class: 0 Power class(DDR,52MH,3.6V): 0h Power class(DDR,52MH,1.9V): 0h Power class(26MH,3.6V) : 0h Power class(52MH,3.6V) : 0h Power class(26MH,1.9V) : 0h Power class(52MH,1.9V) : 0h Part. switch timing : 2h Out-of-INTR busy timing: ah Card type : 57h Command set : 0h Command set rev.: 0h HS timing : 0h Bus width : 0h Erase memory content : 0h Partition config : 48h Boot partition size : 4096 kbytes Boot information : 7h Boot config protection: 0h Boot bus width : 2h Boot area write prot : 0h User area write prot : 0h FW configuration : 0h RPMB size : 4096 kbytes Write rel. setting : 1fh Write rel. parameter: 14h Start background ops : 0h Enable background ops: 2h H/W reset function : 1h HPI management : 0h Max. enhanced area size : e8fh (30531584 kbytes) Part. support : 7h Part. attribute: 0h Part. setting : 0h General purpose 1 size : 0h (0 kbytes) General purpose 2 size : 0h (0 kbytes) General purpose 3 size : 0h (0 kbytes) General purpose 4 size : 0h (0 kbytes) Enh. user area size : 0h (0 kbytes) Enh. user area start: 0h Bad block mgmt mode: 0h Overall status : MLC status : 0% - 10% used SLC status : 0% - 10% used EOL status : Normal ( Less than 80% reserved blocks used ) RPMB : RPMB KEY EXISTS! [State : NOT CLEAN : UNUSABLE] Done! Elapsed: 00:00:19 Code: Operation : Identify [ v2.17 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM23) MODE : BOOTROM PORT : 23 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN RAPHAEL BROM : MEID : xxxxxxxxxxxxxxxxxxxxxxxxxxx BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v1944 | Manual : Disabled BROM : SOCID : xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx BROM : SLA : Local Auth BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : PRELOADER_INFINITY_0 EMI : CNT : 0001 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00038000 [ 224,00 KB ] DRAM: 0x100000000 [ 4,00 GB ] EMMC: 150100444836444D420540xxxxxxxxxxxxx EMMC: VEN : SAMSUNG | OEM : 01 | DEV : DH6DMB EMMC: BOOT1 : 0x00400000 [ 4,00 MB ] BOOT2 : 0x00400000 [ 4,00 MB ] RPMB : 0x00400000 [ 4,00 MB ] USER : 0xE8F800000 [ 58,24 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : xxxxxxxxxxxxxxxxxxxxxxxxx DA : USB : HIGH-SPEED Boot done! Patch Level : PPR1.180610.011 Display ID : PPR1.180610.011 release-keys Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2020-04-05 Build Time : 10.04.2020 Product Model : vivo 1902 Product Brand : vivo Product Name : PD1901F_EX Product Device : PD1901F_EX Product Manfct : vivo Product Info : k65v1_64_bsp Product Board : k65v1_64_bsp Board Platform : mt6765 Product Name : full_k65v1_64_bsp Product Device : k65v1_64_bsp USERDATA : FILESYSTEM : EXT4 with FDE ( Full Disk Encryption **) NVRAM check : Passed! NVRAM : SEC NORMAL [ No extra security ] Backup sensetive data [ 8 ] Backup path : Backup\MT6765__xxxxxxxxxxxxxxxxxxxxxxxxxxx\ [29] Read : NVRAM [8] Read : NVDATA [19] Read : PROINFO [30] Read : LK [7] Read : NVCFG [14] Read : PROTECT1 [15] Read : PROTECT2 Backup done! STORAGE : LifeStatus : eMMC : OK! PRELOADER : DEVICE : DEV : MT6765 NME : preloader_k65v1_64_bsp.bin CNT : 000C EMI : [00] : eMMC : LP_DDR4X : ID : 150100445636444D42 : VEN : SAMSUNG | DEV : DV6DMB : RAM : [ 4,00 GB ] EMI : [01] : eMMC : LP_DDR4X : ID : 13014E53304A394B39 : VEN : MICRON | DEV : S0J9K9 : RAM : [ 4,00 GB ] EMI : [02] : eMMC : LP_DDR4X : ID : 150100444836444142 : VEN : SAMSUNG | DEV : DH6DAB : RAM : [ 4,00 GB ] EMI : [03] : eMMC : LP_DDR4X : ID : 90014A484347386134 : VEN : HYNIX | DEV : HCG8a4 : RAM : [ 4,00 GB ] EMI : [04] : eMMC : LP_DDR4X : ID : 150100444836444D42 : VEN : SAMSUNG | DEV : DH6DMB : RAM : [ 4,00 GB ] EMI : [05] : eMMC : DDR3 : ID : 150100525036344D42 : VEN : SAMSUNG | DEV : RP64MB : RAM : [ 4,00 GB ] EMI : [06] : eMMC : DDR3 : ID : 90014A684339615033 : VEN : HYNIX | DEV : hC9aP3 : RAM : [ 4,00 GB ] EMI : [07] : eMMC : DDR3 : ID : 90014A484347386134 : VEN : HYNIX | DEV : HCG8a4 : RAM : [ 4,00 GB ] EMI : [08] : eMMC : LP_DDR4X : ID : 90014A684339615033 : VEN : HYNIX | DEV : hC9aP3 : RAM : [ 4,00 GB ] EMI : [09] : eMMC : LP_DDR4X : ID : 150100335636434D42 : VEN : SAMSUNG | DEV : 3V6CMB : RAM : [ 6,00 GB ] EMI : [0A] : eMMC : LP_DDR4X : ID : 13014E47314A395238 : VEN : MICRON | DEV : G1J9R8 : RAM : [ 4,00 GB ] EMI : [0B] : eMMC : LP_DDR4X : ID : 13014E47314A395339 : VEN : MICRON | DEV : G1J9S9 : RAM : [ 4,00 GB ] Done! Elapsed: 00:00:50 |
The Following 27 Users Say Thank You to JayDi For This Useful Post: |
01-24-2021, 02:53 | #5 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Random HUAWEI HWreport : Code: Operation : HW Report [ v2.17 ] HWreport : Mode : eMMC 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM23) MODE : BOOTROM PORT : 23 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN RAPHAEL BROM : MEID : xxxxxxxxxxxxxxxxxxxxxxxxxxxxx BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v1944 | Manual : Disabled BROM : SOCID : xxxxxxxxxxxxxxxxxxxxxxxxxxxxx BROM : SLA : Local Auth BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : PRELOADER_INFINITY_0 EMI : CNT : 0002 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00038000 [ 224,00 KB ] DRAM: 0xC0000000 [ 3,00 GB ] EMMC: 150100475036424D4201xxxxxxxxxxxx EMMC: VEN : SAMSUNG | OEM : 01 | DEV : GP6BMB EMMC: BOOT1 : 0x00400000 [ 4,00 MB ] BOOT2 : 0x00400000 [ 4,00 MB ] RPMB : 0x01000000 [ 16,00 MB ] USER : 0xE8F800000 [ 58,24 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : xxxxxxxxxxxxxxxxxxxxxxxxxxxxx DA : USB : HIGH-SPEED Boot done! Memory Info : CID : 150100475036424D420xxxxxxxxxxxxxxxxxx MEM : VEN : SAMSUNG | OEM : 01 | DEV : GP6BMB DAT : Size: 59640 MB, Max.Speed: 52000 kHz, blklen(512), nblks(122142720), ro(0) EXT_CSD Info : EXT_CSD rev. : v1.8 ( MMC v5.1 ) CSD struct rev. : v1.2 Supported command sets : 1h HPI features : 1h BG operations support : 1h BG operations status : 0h Correct prg. sectors : 0h 1st init time after part. : 3000 ms Min. write perf.(DDR,52MH,8b): 0h Min. read perf. (DDR,52MH,8b): 0h TRIM timeout: 0 ms Secure feature support: 55h Secure erase timeout : 8100 ms Secure trim timeout : 5100 ms Access size : 3584 bytes HC erase unit size : 512 kbytes HC erase timeout : 300 ms HC write prot grp size: 8192 kbytes HC erase grp def. : 0h Reliable write sect count: 1h Sleep current (VCC) : 7h Sleep current (VCCQ): 7h Sleep/awake timeout : 26214400 ns Sector count : 747c000h Min. WR Perf. (52MH,8b): 0h Min. Read Perf.(52MH,8b): 0h Min. WR Perf. (26MH,8b,52MH,4b): 0h Min. Read Perf.(26MH,8b,52MH,4b): 0h Min. WR Perf. (26MH,4b): 0h Min. Read Perf.(26MH,4b): 0h Power class: 0 Power class(DDR,52MH,3.6V): 0h Power class(DDR,52MH,1.9V): 0h Power class(26MH,3.6V) : 0h Power class(52MH,3.6V) : 0h Power class(26MH,1.9V) : 0h Power class(52MH,1.9V) : 0h Part. switch timing : 2h Out-of-INTR busy timing: ah Card type : 57h Command set : 0h Command set rev.: 0h HS timing : 0h Bus width : 0h Erase memory content : 0h Partition config : 48h Boot partition size : 4096 kbytes Boot information : 7h Boot config protection: 0h Boot bus width : 2h Boot area write prot : 0h User area write prot : 0h FW configuration : 0h RPMB size : 16384 kbytes Write rel. setting : 1fh Write rel. parameter: 14h Start background ops : 0h Enable background ops: 2h H/W reset function : 1h HPI management : 0h Max. enhanced area size : 9b5h (20357120 kbytes) Part. support : 7h Part. attribute: 0h Part. setting : 0h General purpose 1 size : 0h (0 kbytes) General purpose 2 size : 0h (0 kbytes) General purpose 3 size : 0h (0 kbytes) General purpose 4 size : 0h (0 kbytes) Enh. user area size : 0h (0 kbytes) Enh. user area start: 0h Bad block mgmt mode: 0h Overall status : MLC status : 0% - 10% used SLC status : 0% - 10% used EOL status : Normal ( Less than 80% reserved blocks used ) RPMB : RPMB KEY EXISTS! [State : NOT CLEAN : UNUSABLE] Done! Elapsed: 00:00:26 Code: Operation : Identify [ v2.17 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM23) MODE : BOOTROM PORT : 23 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN RAPHAEL BROM : MEID : xxxxxxxxxxxxxxxxxxxxxxxxxxx BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v1944 | Manual : Disabled BROM : SOCID : xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx BROM : SLA : Local Auth BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : PRELOADER_INFINITY_0 EMI : CNT : 0002 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00038000 [ 224,00 KB ] DRAM: 0xC0000000 [ 3,00 GB ] EMMC: 150100475036424D420xxxxxxxxxxxxx EMMC: VEN : SAMSUNG | OEM : 01 | DEV : GP6BMB EMMC: BOOT1 : 0x00400000 [ 4,00 MB ] BOOT2 : 0x00400000 [ 4,00 MB ] RPMB : 0x01000000 [ 16,00 MB ] USER : 0xE8F800000 [ 58,24 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : xxxxxxxxxxxxxxxxxxxxxxxxxxx DA : USB : HIGH-SPEED Boot done! Sec. Patch : 2019-07-05 Product Brand : alps Product Name : full_k62v1_64_mex_a32 Product Device : k62v1_64_mex_a32 Board Platform : mt6765 Product Info : k62v1_64_mex_a32 Product Board : k62v1_64_mexico Product Manfct : HUAWEI Product Model : k62v1_64_mex_a32 Patch Level : PPR1.180610.011 Ver. CodeName : REL Ver. Release : 9 Build Time : 10.07.2019 Product Model : HUAWEI Product Manfct : alps USERDATA : FILESYSTEM : F2FS with FBE ( File-Base Encryption ) NVRAM check : Passed! NVRAM : SEC NORMAL [ No extra security ] Backup sensetive data [ 8 ] Backup path : Backup\MT6765__xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx\ Backup done! STORAGE : LifeStatus : eMMC : OK! PRELOADER : DEVICE : DEV : MT6765 NME : preloader_k62v1_64_mexico.bin CNT : 001E EMI : [00] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 512,00 MB ] EMI : [01] : eMMC : DDR3 : ID : 90014A484147346132 : VEN : HYNIX | DEV : HAG4a2 : RAM : [ 2,00 GB ] EMI : [02] : eMMC : DDR3 : ID : 90014A68423861503E : VEN : HYNIX | DEV : hB8aP> : RAM : [ 3,00 GB ] EMI : [03] : eMMC : DDR3 : ID : 90014A484347386134 : VEN : HYNIX | DEV : HCG8a4 : RAM : [ 4,00 GB ] EMI : [04] : eMMC : DDR3 : ID : 150100514536334D42 : VEN : SAMSUNG | DEV : QE63MB : RAM : [ 2,00 GB ] EMI : [05] : eMMC : DDR3 : ID : 150100514436334D42 : VEN : SAMSUNG | DEV : QD63MB : RAM : [ 2,00 GB ] EMI : [06] : eMMC : DDR3 : ID : 150100474436424D42 : VEN : SAMSUNG | DEV : GD6BMB : RAM : [ 3,00 GB ] EMI : [07] : eMMC : DDR3 : ID : 150100475036424D42 : VEN : SAMSUNG | DEV : GP6BMB : RAM : [ 3,00 GB ] EMI : [08] : eMMC : DDR3 : ID : 150100524836344142 : VEN : SAMSUNG | DEV : RH64AB : RAM : [ 4,00 GB ] EMI : [09] : eMMC : DDR3 : ID : 13014E53304A394137 : VEN : MICRON | DEV : S0J9A7 : RAM : [ 2,00 GB ] EMI : [0A] : eMMC : DDR3 : ID : 13014E53304A394E38 : VEN : MICRON | DEV : S0J9N8 : RAM : [ 4,00 GB ] EMI : [0B] : eMMC : DDR3 : ID : 90014A68433861503E : VEN : HYNIX | DEV : hC8aP> : RAM : [ 3,00 GB ] EMI : [0C] : eMMC : DDR3 : ID : 90014A68423861503E : VEN : HYNIX | DEV : hB8aP> : RAM : [ 2,00 GB ] EMI : [0D] : eMMC : DDR3 : ID : 90014A684339615033 : VEN : HYNIX | DEV : hC9aP3 : RAM : [ 4,00 GB ] EMI : [0E] : eMMC : DDR3 : ID : 150100525036344D42 : VEN : SAMSUNG | DEV : RP64MB : RAM : [ 4,00 GB ] EMI : [0F] : eMMC : LP_DDR4X : ID : 150100445636444D42 : VEN : SAMSUNG | DEV : DV6DMB : RAM : [ 4,00 GB ] EMI : [10] : eMMC : LP_DDR4X : ID : 13014E53304A394B39 : VEN : MICRON | DEV : S0J9K9 : RAM : [ 4,00 GB ] EMI : [11] : eMMC : LP_DDR4X : ID : 450100444134313238 : VEN : SANDISK | DEV : DA4128 : RAM : [ 4,00 GB ] EMI : [12] : eMMC : DDR3 : ID : 13014E53304A394237 : VEN : MICRON | DEV : S0J9B7 : RAM : [ 3,00 GB ] EMI : [13] : eMMC : LP_DDR4X : ID : 90014A684445615033 : VEN : HYNIX | DEV : hDEaP3 : RAM : [ 4,00 GB ] EMI : [14] : eMMC : DDR3 : ID : 150100475036424142 : VEN : SAMSUNG | DEV : GP6BAB : RAM : [ 3,00 GB ] EMI : [15] : eMMC : DDR3 : ID : 150100475836424142 : VEN : SAMSUNG | DEV : GX6BAB : RAM : [ 3,00 GB ] EMI : [16] : eMMC : DDR3 : ID : 150100515836334142 : VEN : SAMSUNG | DEV : QX63AB : RAM : [ 2,00 GB ] EMI : [17] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 4,00 GB ] EMI : [18] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 4,00 GB ] EMI : [19] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 2,00 GB ] EMI : [1A] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 3,00 GB ] EMI : [1B] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 3,00 GB ] EMI : [1C] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 4,00 GB ] EMI : [1D] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 2,00 GB ] Done! Elapsed: 00:00:23 |
01-24-2021, 02:56 | #6 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | XIAOMI 6A XIAOMI 8 Pro VIVO HUAWEI All test are made with default DA. No preloader, No auth, No da has been selected. Just sSLA option enabled and BROM mode. That way allow you boot most of devices already. Now a bit more possiblities open Last edited by JayDi; 01-24-2021 at 03:01. |
The Following 60 Users Say Thank You to JayDi For This Useful Post: |
01-24-2021, 02:58 | #7 (permalink) |
Freak Poster Join Date: Jun 2010 Location: Philippines
Member: 1328371 Status: Offline Thanks Meter: 121 | [QUOTE=YellowBoss;14313180]Infinity Chinese Miracle-2 MTK/MediaTek v2.17 - Standalone auth ON As ordinary unique solutions by World famous Infinity Team ! Core Changed : Protocol updated ( Raphael/Legacy ) NewFeature: Standalone SLA/Auth [Raphael] ** Changed : Internal EMI engine updated : RAPAHEL : UFS support rebuild Flasher Changed: Core updated for RAPHAEL line Changed: UltraFlash feature updated, new security workarounds supported Service Changed: Identify !* Read new Android 10 specific fields, vendor-specific fields Changed: Smart Reset !* Optimized support for different customized and generic cases Changed: HW Report ( RAPHAEL - only ) !* UFS line devices now supported with following features: - CID info ( FlashIC base info, name, vendor ) - default info, even if boot can nott be completed by some HW or SW reasons - LifeInfo ( SLC, MLC, EOL status and use counters ) - allow understand how bad it feels - RPMB info ( is it key programmed or clean and can be re-used ) - Partitioning details and other - HWreport log saving enabled ( for further analyze ) !* Feature also allow automatic select and store for further use BOOTROM connection settings for RAPHAEL devices ( DRAM init ) !* HWreport not require complete boot in case of semi-dead devices. Useful for HWdebug !* HWreport result may vary in diffirent models and agents even on the same SoC ! Firmware Reader Changed : Some modern brand-specific changes ( Xiaomi, Oppo, Vivo, Realme ) Changed : New types supported Other BugFix : Many different minor changes and fixes Changed : Generic protocol rebuild Info !** - Standalone SLA/Auth allow you ignore device security setting and allow boot it without having any DA/Auth/Remote auth support - You can boot ( with supported SoC ) device with any generic da and perform any need operations - Support MT6765 - All security versions, no auth need, no special da need, no remote service need Support Xiaomi, Oppo, Vivo, Realme, Huawei and whatever else existing - Support MT6785 - All security versions, no auth need, no special da need, no remote service need Support Xiaomi, Oppo, Vivo, Realme, Huawei and whatever else existing NOTE: special boot-helper tool should be installed - included in CM2MT2 package How to Install: Important step ! Download link #1 Download link #2 Download link #3 How to upload files to support Infinity-Box 16 years updates and support as nobody else since year 2005 ... Please check Infinity Chinese Miracle-2 MTK/MediaTek v2.17 Installer is corrupted.I downloaded 3x but i can not install. Last edited by YellowBoss; 02-09-2021 at 01:44. |
The Following 2 Users Say Thank You to john kenneth For This Useful Post: |
01-24-2021, 05:10 | #12 (permalink) | |
No Life Poster Join Date: Aug 2006 Location: BHARAT
Member: 327043 Status: Offline Sonork: 100.1587811 Thanks Meter: 1,514 | redmi 6 error on read info Quote:
Code: Operation : Identify [ v2.17 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM7) MODE : BOOTROM PORT : 7 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN RAPHAEL BROM : MEID : 3EF21FB41CCDBA61DA0977B58997E263 BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2028 | Manual : Disabled BROM : SOCID : 23E625E005A0F886EAAC6E203203F11D214EE88D775FA68E436BC0E710760FDA BROM : SLA : Local Auth BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : PRELOADER_INFINITY_0 EMI : CNT : 0008 EMI : Init EMI from INTERNAL DB DA : SETUP EMI PARAMS FAILED! ERROR : ABORT Error : Fail to init protocol! >>> Internal EMI : Select other EMI number! External Preloader - make sure it correct for connected device! Reconnect Power/Cable! Operation : Identify [ v2.17 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM7) MODE : BOOTROM PORT : 7 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN RAPHAEL BROM : MEID : 3EF21FB41CCDBA61DA0977B58997E263 BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v1944 | Manual : Enabled BROM : SOCID : 23E625E005A0F886EAAC6E203203F11D214EE88D775FA68E43 6BC0E710760FDA BROM : SLA : Local Auth BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : MT6765 EMI : SRC : preloader_cereus.bin EMI : CNT : 000B EMI : [00] : eMMC : DDR3 : ID : 90014A484247346132 : VEN : HYNIX | DEV : HBG4a2 : RAM : [ 3.00 GB ] EMI : [01] : eMMC : DDR3 : ID : 90014A68423861503E : VEN : HYNIX | DEV : hB8aP> : RAM : [ 3.00 GB ] EMI : [02] : eMMC : DDR3 : ID : 90014A484147346132 : VEN : HYNIX | DEV : HAG4a2 : RAM : [ 2.00 GB ] EMI : [03] : eMMC : DDR3 : ID : 13014E53304A394237 : VEN : MICRON | DEV : S0J9B7 : RAM : [ 3.00 GB ] EMI : [04] : eMMC : DDR3 : ID : 150100514536334D42 : VEN : SAMSUNG | DEV : QE63MB : RAM : [ 2.00 GB ] EMI : [05] : eMMC : DDR3 : ID : 150100474436424D42 : VEN : SAMSUNG | DEV : GD6BMB : RAM : [ 3.00 GB ] EMI : [06] : eMMC : DDR3 : ID : 13014E53304A394137 : VEN : MICRON | DEV : S0J9A7 : RAM : [ 2.00 GB ] EMI : [07] : eMMC : DDR3 : ID : 150100524836344142 : VEN : SAMSUNG | DEV : RH64AB : RAM : [ 4.00 GB ] EMI : [08] : eMMC : DDR3 : ID : 90014A484347386134 : VEN : HYNIX | DEV : HCG8a4 : RAM : [ 4.00 GB ] EMI : [09] : eMMC : DDR3 : ID : 150100514436334D42 : VEN : SAMSUNG | DEV : QD63MB : RAM : [ 2.00 GB ] EMI : [0A] : eMMC : DDR3 : ID : 150100475036424D42 : VEN : SAMSUNG | DEV : GP6BMB : RAM : [ 3.00 GB ] EMI : Init EMI from PRELOADER EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00038000 [ 224.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: 90014A484247346132A42683C15D93EB EMMC: VEN : HYNIX | OEM : 4A01 | DEV : HBG4a2 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 98D011CA3BDFDF3EF45473A87731637A DA : USB : HIGH-SPEED Boot done! Patch Level : O11019 Display ID : O11019 Ver. CodeName : REL Ver. Release : 8.1.0 Sec. Patch : 2019-08-01 Build Time : 23.08.2019 Product Model : Redmi 6 Product Brand : xiaomi Product Name : cereus Product Device : cereus Product Info : cereus Product Manfct : Xiaomi Board Platform : mt6765 USERDATA : FILESYSTEM : EXT4 with FDE ( Full Disk Encryption *) NVRAM check : Passed! NVRAM : SEC NORMAL [ No extra security ] Backup sensetive data [ 11 ] Backup path : Backup\MT6765__98D011CA3BDFDF3EF45473A87731637A\ [25] Read : NVRAM [8] Read : NVDATA [15] Read : PROINFO [27] Read : LK [7] Read : NVCFG [10] Read : PROTECT1 [11] Read : PROTECT2 [13] Read : PERSIST [0] Read : PRELOADER [12] Read : SECCFG Backup done! STORAGE : LifeStatus : eMMC : OK! PRELOADER : DEVICE : DEV : MT6765 NME : preloader_cereus.bin CNT : 000B EMI : [00] : eMMC : DDR3 : ID : 90014A484247346132 : VEN : HYNIX | DEV : HBG4a2 : RAM : [ 3.00 GB ] EMI : [01] : eMMC : DDR3 : ID : 90014A68423861503E : VEN : HYNIX | DEV : hB8aP> : RAM : [ 3.00 GB ] EMI : [02] : eMMC : DDR3 : ID : 90014A484147346132 : VEN : HYNIX | DEV : HAG4a2 : RAM : [ 2.00 GB ] EMI : [03] : eMMC : DDR3 : ID : 13014E53304A394237 : VEN : MICRON | DEV : S0J9B7 : RAM : [ 3.00 GB ] EMI : [04] : eMMC : DDR3 : ID : 150100514536334D42 : VEN : SAMSUNG | DEV : QE63MB : RAM : [ 2.00 GB ] EMI : [05] : eMMC : DDR3 : ID : 150100474436424D42 : VEN : SAMSUNG | DEV : GD6BMB : RAM : [ 3.00 GB ] EMI : [06] : eMMC : DDR3 : ID : 13014E53304A394137 : VEN : MICRON | DEV : S0J9A7 : RAM : [ 2.00 GB ] EMI : [07] : eMMC : DDR3 : ID : 150100524836344142 : VEN : SAMSUNG | DEV : RH64AB : RAM : [ 4.00 GB ] EMI : [08] : eMMC : DDR3 : ID : 90014A484347386134 : VEN : HYNIX | DEV : HCG8a4 : RAM : [ 4.00 GB ] EMI : [09] : eMMC : DDR3 : ID : 150100514436334D42 : VEN : SAMSUNG | DEV : QD63MB : RAM : [ 2.00 GB ] EMI : [0A] : eMMC : DDR3 : ID : 150100475036424D42 : VEN : SAMSUNG | DEV : GP6BMB : RAM : [ 3.00 GB ] Done! Elapsed: 00:00:57 Last edited by sneha; 01-24-2021 at 05:16. | |
The Following 8 Users Say Thank You to sneha For This Useful Post: |
01-24-2021, 05:26 | #13 (permalink) |
Freak Poster Join Date: Apr 2016 Location: Zimbabwe,chitown Age: 36
Member: 2559678 Status: Offline Thanks Meter: 29 | Thank infinity team. Please add also support for mtk6580 and Sim Me lock unlocking Sent from my SM-G570F using Tapatalk |
The Following User Says Thank You to inomfia For This Useful Post: |
