Old 01-24-2021, 02:09   #1 (permalink)
Member: 1043909
Thanks Meter: 60,926
Infinity Chinese Miracle-2 MTK/MediaTek v2.17 - Standalone auth ON
As ordinary unique solutions by World famous Infinity Team !
Core
Changed : Protocol updated ( Raphael/Legacy )
NewFeature: Standalone SLA/Auth [Raphael] **
Changed : Internal EMI engine updated : RAPAHEL : UFS support rebuild
Flasher
Changed: Core updated for RAPHAEL line
Changed: UltraFlash feature updated, new security workarounds supported
Service
Changed: Identify
!* Read new Android 10 specific fields, vendor-specific fields
Changed: Smart Reset
!* Optimized support for different customized and generic cases
Changed: HW Report ( RAPHAEL - only )
!* UFS line devices now supported with following features:
- CID info ( FlashIC base info, name, vendor ) - default info, even if boot can nott be completed by some HW or SW reasons
- LifeInfo ( SLC, MLC, EOL status and use counters ) - allow understand how bad it feels
- RPMB info ( is it key programmed or clean and can be re-used )
- Partitioning details and other
- HWreport log saving enabled ( for further analyze )
!* Feature also allow automatic select and store for further use BOOTROM connection settings for RAPHAEL devices ( DRAM init )
!* HWreport not require complete boot in case of semi-dead devices. Useful for HWdebug
!* HWreport result may vary in diffirent models and agents even on the same SoC !
Firmware Reader
Changed : Some modern brand-specific changes ( Xiaomi, Oppo, Vivo, Realme )
Changed : New types supported
Other
BugFix : Many different minor changes and fixes
Changed : Generic protocol rebuild
Info
- Standalone SLA/Auth allow you ignore device security setting and allow boot it without having any DA/Auth/Remote auth support
- You can boot ( with supported SoC ) device with any generic da and perform any need operations
- Support MT6765 - All security versions, no auth need, no special da need, no remote service need
Support Xiaomi, Oppo, Vivo, Realme, Huawei and whatever else existing
- Support MT6785 - All security versions, no auth need, no special da need, no remote service need
New Drivers_MTK_v2.0.1.1.7z are here
NOTE: special boot-helper tool should be installed - included in CM2MT2 package
How to Install:
Important step !
Dongle Firmware version required: v0147
Password for archive: 12345678
Download link #1
Download link #2
How to upload files to support
Infinity-Box 16 years updates and support as nobody else since year 2005
The Following 102 Users Say Thank You to YellowBoss For This Useful Post:
Old 01-24-2021, 02:34   #2 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
READMI 6A
HWreport :
Operation : HW Report [ v2.17 ]
HWreport : Mode : eMMC
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : MediaTek USB Port (COM23)
MODE : BOOTROM
PORT : 23
Waiting BOOT ack ...
BROM : Skip ACK verify
BROM : Init BROM
BROM init passed!
     CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000
     CODE : Cervino
     TYPE : MODERN RAPHAEL
BROM : MEID : xxxxxxxxxxxxxxxxxxxxx
BROM : SecLevel : 0x000000E7
BROM : SecMode  : SBC+SLA+SDA+EXT
BROM : BROM|BL  : 0x05|0xFE
BROM : BOOTROM
MODE : 0_base : BASE_v1944 | Manual : Disabled
BROM : SOCID : xxxxxxxxxxxxxxxxxxxxxxx
BROM : SLA : Local Auth
BROM : SLA : Auth Passed!
BROM : SLA : 0x0000001F
AGENT : Look for suitable BootChain in DA ...
AGENT : MTK_AllInOne_DA.bin
AGENT : Found MT6765
AGENT : MTK_DOWNLOAD_AGENT
     BROM : Sending 1st DA ...
BROM : DA sent
BROM :Transfer control to DA ...
     DA : AGENT started!
DA : SYNC
     DA : MODE : BROM
DA : EXT_RAM NOT initialized!
     EMI : DEV : INFINITY
     EMI : SRC : PRELOADER_INFINITY_0
     EMI : CNT : 0001
     EMI : Init EMI from INTERNAL DB
     EMI : EXT_RAM CFG Passed!
DA : BOOT to 2nd DA ...
DA : 2ND stage confirmed!
DA : SYNC with DA passed!
DA : Receiving HW info
        SRAM: 0x00038000 [ 224,00 KB ]
        DRAM: 0x80000000 [ 2,00 GB ]
        EMMC: 150100514536334D42xxxxxxxxxxxxx
        EMMC: VEN : SAMSUNG | OEM : 01 | DEV : QE63MB
        EMMC:
              BOOT1  : 0x00400000 [ 4,00 MB ]
              BOOT2  : 0x00400000 [ 4,00 MB ]
              RPMB   : 0x00400000 [ 4,00 MB ]
              USER   : 0x3A3E00000 [ 14,56 GB ]
        CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000
        RNID : xxxxxxxxxxxxxxxxxxxxxxx
DA : USB : HIGH-SPEED
Boot done!
Memory Info :
    CID : 150100514536334D42xxxxxxxxxxxxx
    MEM : VEN : SAMSUNG | OEM : 01 | DEV : QE63MB
    DAT :  Size: 14910 MB, Max.Speed: 52000 kHz, blklen(512), nblks(30535680), ro(0)
EXT_CSD Info :
EXT_CSD rev.		 : v1.8 ( MMC v5.1 )
     CSD struct rev.		 : v1.2
     Supported command sets	 : 1h
     HPI features		 : 1h
     BG operations support	 : 1h
     BG operations status	 : 0h
     Correct prg. sectors	 : 0h
     1st init time after part. : 3000 ms
     Min. write perf.(DDR,52MH,8b): 0h
     Min. read perf. (DDR,52MH,8b): 0h
     TRIM timeout: 0 ms
     Secure feature support: 55h
     Secure erase timeout  : 8100 ms
     Secure trim timeout   : 5100 ms
     Access size	     : 3584 bytes
     HC erase unit size    : 512 kbytes
     HC erase timeout      : 300 ms
     HC write prot grp size: 8192 kbytes
     HC erase grp def.     : 0h
     Reliable write sect count: 1h
     Sleep current (VCC) : 7h
     Sleep current (VCCQ): 7h
     Sleep/awake timeout : 26214400 ns
     Sector count : 1d1f000h
     Min. WR Perf.  (52MH,8b): 0h
     Min. Read Perf.(52MH,8b): 0h
     Min. WR Perf.  (26MH,8b,52MH,4b): 0h
     Min. Read Perf.(26MH,8b,52MH,4b): 0h
     Min. WR Perf.  (26MH,4b): 0h
     Min. Read Perf.(26MH,4b): 0h
     Power class: 0
     Power class(DDR,52MH,3.6V): 0h
     Power class(DDR,52MH,1.9V): 0h
     Power class(26MH,3.6V)	 : 0h
     Power class(52MH,3.6V)	 : 0h
     Power class(26MH,1.9V)	 : 0h
     Power class(52MH,1.9V)	 : 0h
     Part. switch timing    : 2h
     Out-of-INTR busy timing: ah
     Card type       : 57h
     Command set     : 0h
     Command set rev.: 0h
     HS timing       : 0h
     Bus width       : 0h
     Erase memory content : 0h
     Partition config      : 48h
     Boot partition size   : 4096 kbytes
     Boot information      : 7h
     Boot config protection: 0h
     Boot bus width	     : 2h
     Boot area write prot  : 0h
     User area write prot  : 0h
     FW configuration      : 0h
     RPMB size : 4096 kbytes
     Write rel. setting  : 1fh
     Write rel. parameter: 14h
     Start background ops : 0h
     Enable background ops: 2h
     H/W reset function   : 1h
     HPI management	    : 0h
     Max. enhanced area size : 3a3h (7626752 kbytes)
     Part. support  : 7h
     Part. attribute: 0h
     Part. setting  : 0h
     General purpose 1 size : 0h (0 kbytes)
     General purpose 2 size : 0h (0 kbytes)
     General purpose 3 size : 0h (0 kbytes)
     General purpose 4 size : 0h (0 kbytes)
     Enh. user area size : 0h (0 kbytes)
     Enh. user area start: 0h
     Bad block mgmt mode: 0h
Overall status :
    MLC status : 0% - 10% used
    SLC status : 0% - 10% used
    EOL status : Normal  ( Less than 80% reserved blocks used )
    RPMB : RPMB  KEY EXISTS!  [State : NOT CLEAN : UNUSABLE]
Done!
Elapsed: 00:00:22
Identify :
Operation : Identify [ v2.17 ]
Mode : FLASH
MODE : BOOTROM
PORT : 23
BROM : Init BROM
BROM init passed!
     CODE : Cervino
BROM : MEID : xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
BROM : BOOTROM
BROM : SOCID : xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
BROM : DA sent
     DA : AGENT started!
DA : SYNC
     DA : MODE : BROM
     EMI : CNT : 0001
        EMMC: 150100514536334D420xxxxxxxxxxxxxxxxxx
        EMMC:
        RNID : xxxxxxxxxxxxxxxxxxxxxxxxxxxxx
Boot done!
Patch Level    : O11019
Display ID     : O11019
Ver. CodeName  : REL
Ver. Release   : 8.1.0
Sec. Patch     : 2018-05-05
Build Time     : 11.06.2018
Product Model  : Redmi 6A
Product Brand  : xiaomi
Product Name   : cactus
Product Device : cactus
Product Info   : cactus
Product Manfct : Xiaomi
Board Platform : mt6765
USERDATA : FILESYSTEM : EXT4  with FDE ( Full Disk Encryption *)
NVRAM check : Passed!
NVRAM : SEC SIGNED  [ IMEI RSA SIGNED ]
Backup sensetive data [ 8 ]
Backup path : Backup\MT6765__xxxxxxxxxxxxx\
[25] Read : NVRAM
[8] Read : NVDATA
[15] Read : PROINFO
[27] Read : LK
[7] Read : NVCFG
[10] Read : PROTECT1
[11] Read : PROTECT2
Backup done!
STORAGE : LifeStatus : eMMC : OK!
PRELOADER : DEVICE :
DEV : MT6765
NME : preloader_cactus.bin
CNT : 000A
 EMI : [00] : eMMC : DDR3 : ID : 90014A484247346132 : VEN : HYNIX     | DEV : HBG4a2 : RAM : [ 3,00 GB ]
 EMI : [01] : eMMC : DDR3 : ID : 90014A68423861503E : VEN : HYNIX     | DEV : hB8aP> : RAM : [ 3,00 GB ]
 EMI : [02] : eMMC : DDR3 : ID : 90014A484147346132 : VEN : HYNIX     | DEV : HAG4a2 : RAM : [ 2,00 GB ]
 EMI : [03] : eMMC : DDR3 : ID : 13014E53304A394237 : VEN : MICRON    | DEV : S0J9B7 : RAM : [ 3,00 GB ]
 EMI : [04] : eMMC : DDR3 : ID : 150100514536334D42 : VEN : SAMSUNG   | DEV : QE63MB : RAM : [ 2,00 GB ]
 EMI : [05] : eMMC : DDR3 : ID : 150100474436424D42 : VEN : SAMSUNG   | DEV : GD6BMB : RAM : [ 3,00 GB ]
 EMI : [06] : eMMC : DDR3 : ID : 13014E53304A394137 : VEN : MICRON    | DEV : S0J9A7 : RAM : [ 2,00 GB ]
 EMI : [07] : eMMC : DDR3 : ID : 150100524836344142 : VEN : SAMSUNG   | DEV : RH64AB : RAM : [ 4,00 GB ]
 EMI : [08] : eMMC : DDR3 : ID : 90014A484347386134 : VEN : HYNIX     | DEV : HCG8a4 : RAM : [ 4,00 GB ]
 EMI : [09] : eMMC : DDR3 : ID : 150100514436334D42 : VEN : SAMSUNG   | DEV : QD63MB : RAM : [ 2,00 GB ]
Done!
Elapsed: 00:00:39
Read FW:
Operation : Read Firmware [ v2.17 ]
ExtSparse   : Enabled
ForceRead   : Disabled
MODE : BOOTROM
PORT : 23
BROM : Init BROM
BROM init passed!
     CODE : Cervino
BROM : MEID : xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
BROM : BOOTROM
BROM : DA sent
     DA : AGENT started!
DA : SYNC
     DA : MODE : BROM
     EMI : CNT : 0001
        EMMC: 150100514536334D4203Cxxxxxxxxxxx
        EMMC:
Boot done!
Display ID     : O11019
Ver. CodeName  : REL
MT6765__Xiaomi__Redmi_6A__8.1.0__O11019__O11019__cactus
Read : preloader.bin
Read : recovery.img
Read : persist.img
ExtSparse : Compression ratio : 100%
Read : proinfo.img
Read : efuse.img
Read : md1rom.img
Read : spmfw.img
Read : tinysys-scp.bin
Read : tinysys-sspm.bin
Read : nvram.bin
Read : vbmeta.img
Read : lk.bin
Read : boot.img
Read : logo.bin
Read : odmdtbo.img
Read : cust.img
ExtSparse : Compression ratio : 32%
Read : tz.img
Read : vendor.img
ExtSparse : Compression ratio : 53%
Read : system.img
ExtSparse : Compression ratio : 24%
Read : cache.img
Read : userdata.img
FW Size  : 2,86 GB
Android Info saved : _Android_info.txt
Scatter  : MT6765_Android_scatter.txt
Saved to : C:\MT6765__Xiaomi__Redmi_6A__8.1.0__O11019__O11019__cactus\
Done!
Elapsed: 00:07:26
Flash :
Created by Infinity-Box (c) 2021
Chinese Miracle II : MediaTek Service Module
Device Info file   : _Android_info.txt
Display ID     : O11019
Ver. CodeName  : REL
Preloader [HW DEV] Info :
 EMI : DEV : MT6765
 EMI : SRC : preloader_cactus.bin
 EMI : CNT : 000A
Operation : Write Flash [ v2.17 ]
Repartition   : Enabled
Flash Verify  : Enabled
Reg.Pre-Erase : Enabled
Verify HW/SW  : Enabled
SData Backup  : Disabled
Safe UserData : Disabled
Flash Format  : Disabled
Files :22
[FL] : Set : preloader_cactus.bin
[FL] : Set : recovery.img
[FL] : Set : efuse.img
[FL] : Set : md1rom.img
[FL] : Set : spmfw.img
[FL] : Set : tinysys-scp.bin
[FL] : Set : tinysys-sspm.bin
[FL] : Set : vbmeta.img
[FL] : Set : lk.bin
[FL] : Set : lk.bin
[FL] : Set : boot.img
[FL] : Set : logo.bin
[FL] : Set : odmdtbo.img
[FL] : Set : cust.img
[FL] : Set : tz.img
[FL] : Set : tz.img
[FL] : Set : vendor.img
[FL] : Set : system.img
[FL] : Set : cache.img
[FL] : Set : userdata.img
[FL] : Total size : 0xB32BDBC8 [ 2,80 GB ]
MODE : BOOTROM
PORT : 23
BROM : Init BROM
BROM init passed!
     CODE : Cervino
BROM : BOOTROM
BROM : SOCID : xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
BROM : DA sent
     DA : AGENT started!
DA : SYNC
     DA : MODE : BROM
     EMI : DEV : MT6765
     EMI : CNT : 000A
     EMI : Init EMI from PRELOADER
        EMMC:
        RNID : xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
Boot done!
[FL] : HW verification passed!
SEC_DL : False (RAPHAEL)
SEC_ID : 0x494E46494E495459424F584245535432
[FL] : Pre-Erase
Erase : 0x0000000000000000 : 0x0000000005688000
Erase : 0x0000000007688000 : 0x0000000006000000
Erase : 0x000000000E800000 : 0x0000000000800000
Erase : 0x0000000013000000 : 0x0000000000200000
Erase : 0x0000000013500000 : 0x0000000008980000
Erase : 0x000000001FE80000 : 0x00000000FA980000
Erase : 0x000000011B000000 : 0x00000000D0000000
[FL] : RePartition
[FL] : RePartition Ok!
[FL] : Flashing now ...
Write : PRELOADER
Update bootloader backup copy ...
Update bootloader backup copy Ok!
Write : RECOVERY
Write : EFUSE
Write : MD1IMG
Write : SPMFW
Write : SCP1
Write : SCP2
Write : SSPM_1
Write : SSPM_2
Write : VBMETA
Write : LK
Write : LK2
Write : BOOT
Write : LOGO
Write : ODMDTBO
Write : CUST
FAIL : SEC : IMG TOO LARGE
Write : TEE1
Write : TEE2
Write : VENDOR
Write : SYSTEM
Write : CACHE
Write : USERDATA
Ultra : Ok!
[FL] : RePartition
[FL] : Flashing finished!
Done!
Elapsed: 00:02:21
Reconnect Power/Cable!
The Following 49 Users Say Thank You to JayDi For This Useful Post:
Old 01-24-2021, 02:39   #3 (permalink)
JayDi's Avatar
Member: 462970
RMnote 8Pro :
HWreport :
HWreport : Mode : UFS
MODE : BOOTROM
PORT : 23
BROM : Init BROM
BROM init passed!
     CHIP : MT6785 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000
     CODE : Krug
BROM : BOOTROM
MODE : 0_base : BASE_v2028 | Manual : Disabled
BROM : SOCID : xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxC
AGENT : Found MT6785
BROM : DA sent
     DA : AGENT started!
DA : SYNC
     DA : MODE : BROM
     EMI : CNT : 0001
        SRAM: 0x00080000 [ 512,00 KB ]
        DRAM: 0x180000000 [ 6,00 GB ]
        UFS: AD014839485131364145434D4D444152
        UFS:
             VEN  : 0x01AD
             VID  : H9HQ16AECMMDAR
             IFW  : A107
             LU0  : 0x00400000 [ 4,00 MB ]
             LU1  : 0x00400000 [ 4,00 MB ]
             LU2  : 0x1DCB000000 [ 119,17 GB ]
             FSN  : 15xxxxxxxxxxx8000000000000
             REG  : 0x101010000
        CHIP : MT6785 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000
Boot done!
Memory Info :
    CID : H9HQ16AECMMDAR
EXT_CSD Info :
[UFS] Device Desc:
[UFS] String Desc: Serial Number INDEX 3, LENGTH 12
[UFS] Serial Number: 15cxxxxxxxxxxx8000000000000
[UFS] life cycle check, pre_eol_info=1, life_time_est_a=1, life_time_est_b=1
[UFS] vendor id : 0x1ad
[UFS] ufs id : H9HQ16AECMMDAR
[UFS] ufs fwver: A107
[UFS] dev_quirk = 0x10000000
[UFS] Custom force provison=0, TW size=-1GB, TW no red=1, HPB size=-1GB
[UFS] info: number of active LU: 3, check OK.
[UFS] info: number of Boot LU: 2, check OK.
[UFS] info: LU Configuration Check OK. Bootable UFS
[UFS] info: Boot LU Configuration Check OK. Active Boot LU: LU0
[UFS] info: HS-G3-2
Overall status :
    RPMB : RPMB  KEY NOT set! [State : CLEAN : USABLE]
Done!
Elapsed: 00:00:15
Identify :
Mode : FLASH
MODE : BOOTROM
PORT : 23
BROM : Init BROM
BROM init passed!
     CODE : Krug
BROM : BOOTROM
BROM : SOCID : xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxC
BROM : DA sent
     DA : AGENT started!
DA : SYNC
     DA : MODE : BROM
     EMI : CNT : 0001
        UFS:
             VEN  : 0x01AD
             IFW  : A107
             FSN  : 158xxxxxxxx8000000000000
             REG  : 0x101010000
Boot done!
Patch Level    : PPR1.180610.011
Display ID     : PPR1.180610.011
Ver. CodeName  : REL
Ver. Release   : 9
Sec. Patch     : 2019-12-01
Build Time     : 07.01.2020
Product Model  : Redmi Note 8 Pro
Product Brand  : Redmi
Product Name   : begonia
Product Device : begonia
Product Info   : begonia
Product Board  : begonia
Board Platform : mt6785
NVRAM check : Failed! NVRAM damaged!
Backup path : Backup\MT6785__xxxxxxxxxxxxxxx\
Backup done!
STORAGE : LifeStatus : UFS : OK!
DEV : MT6752
NME : preloader_begonia.bin
CNT : 000A
 EMI : [00] : eUFS : LP_DDR4X : DEV : H9HQ16AECMMDAR : RAM : [ 6,00 GB ]
 EMI : [01] : eUFS : LP_DDR4X : DEV : H9HQ53ACPMMDAR : RAM : [ 4,00 GB ]
 EMI : [02] : eUFS : LP_DDR4X : DEV : H9HQ53AECMMDAR : RAM : [ 6,00 GB ]
 EMI : [03] : eUFS : LP_DDR4X : DEV : KM5H7001DM-B424 : RAM : [ 4,00 GB ]
 EMI : [04] : eUFS : LP_DDR4X : DEV : KM2H7001CM-B518 : RAM : [ 6,00 GB ]
 EMI : [05] : eUFS : LP_DDR4X : DEV : KM2V8001CM-B707 : RAM : [ 6,00 GB ]
 EMI : [06] : eUFS : LP_DDR4X : DEV : MT064GASAO2U21 : RAM : [ 4,00 GB ]
 EMI : [07] : eUFS : LP_DDR4X : DEV : H9HQ16AFAMMDAR : RAM : [ 8,00 GB ]
 EMI : [08] : eUFS : LP_DDR4X : DEV : MT128GASAO4U21 : RAM : [ 6,00 GB ]
 EMI : [09] : eUFS : LP_DDR4X : DEV : H9HQ21AFAMZDAR : RAM : [ 8,00 GB ]
Done!
Elapsed: 00:00:23
Read FW :
ExtSparse   : Enabled
MODE : BOOTROM
PORT : 23
BROM : Init BROM
BROM init passed!
     CODE : Krug
BROM : BOOTROM
BROM : SOCID : xxxxxxxxxxxxxxxxxxxxxxC
BROM : DA sent
     DA : AGENT started!
DA : SYNC
     DA : MODE : BROM
     EMI : CNT : 0001
        UFS:
             VEN  : 0x01AD
             IFW  : A107
             FSN  : 15xxxxxxxxxx000000000000
             REG  : 0x101010000
Boot done!
Ver. CodeName  : REL
Ver. Release   : 9
MT6785__Xiaomi__Redmi_Note_8_Pro__9__PPR1.180610.011__PPR1.180610.011__begonia
Read : recovery.img
Read : vbmeta.img
Read : persist.img
Read : proinfo.img
Read : efuse.img
Read : nvram.bin
Read : md1rom.img
Read : spmfw.img
Read : audio_dsp.img
Read : cam_vpu1.img
Read : cam_vpu2.img
Read : cam_vpu3.img
Read : gz.img
Read : lk.bin
Read : boot.img
Read : logo.bin
Read : dtbo.img
Read : tz.img
Read : vendor.img
ExtSparse : Compression ratio : 40%
Read : system.img
ExtSparse : Compression ratio : 7%
Read : cache.img
Read : cust.img
ExtSparse : Compression ratio : 17%
Read : userdata.img
FW Size  : 5,17 GB
Scatter  : MT6785_Android_scatter.txt
Saved to : C:\MT6785__Xiaomi__Redmi_Note_8_Pro__9__PPR1.180610.011__PPR1.180610.011__begonia\
Done!
Elapsed: 00:07:08
The Following 30 Users Say Thank You to JayDi For This Useful Post:
Old 01-24-2021, 02:53   #4 (permalink)
JayDi's Avatar
Member: 462970
Random VIVO
HWreport :
MODE : BOOTROM
PORT : 23
BROM : Init BROM
BROM init passed!
     CODE : Cervino
BROM : SecLevel : 0x000000E5
BROM : SecMode  : SBC+SDA+EXT
BROM : BOOTROM
BROM : DA sent
     DA : AGENT started!
DA : SYNC
     DA : MODE : BROM
     EMI : CNT : 0001
        DRAM: 0x100000000 [ 4,00 GB ]
        EMMC: 150100444836444D42054xxxxxxxxxxxxxx
        EMMC: VEN : SAMSUNG | OEM : 01 | DEV : DH6DMB
        EMMC:
              USER   : 0xE8F800000 [ 58,24 GB ]
Boot done!
Memory Info :
    CID : 150100444836444D4205xxxxxxxxxxxx
    MEM : VEN : SAMSUNG | OEM : 01 | DEV : DH6DMB
    DAT :  Size: 59640 MB, Max.Speed: 52000 kHz, blklen(512), nblks(122142720), ro(0)
EXT_CSD Info :
     HPI features		 : 1h
     TRIM timeout: 0 ms
     Sector count : 747c000h
     Power class: 0
     Card type       : 57h
     Command set     : 0h
     HS timing       : 0h
     Bus width       : 0h
     Boot bus width	     : 2h
     HPI management	    : 0h
     Max. enhanced area size : e8fh (30531584 kbytes)
     Part. support  : 7h
     Part. attribute: 0h
     Part. setting  : 0h
Overall status :
Done!
Elapsed: 00:00:19
Identify :
Mode : FLASH
MODE : BOOTROM
PORT : 23
BROM : Init BROM
BROM init passed!
     CODE : Cervino
BROM : BOOTROM
BROM : DA sent
     DA : AGENT started!
DA : SYNC
     DA : MODE : BROM
     EMI : CNT : 0001
        EMMC: 150100444836444D420540xxxxxxxxxxxxx
        EMMC:
Boot done!
Display ID     : PPR1.180610.011 release-keys
Ver. CodeName  : REL
Ver. Release   : 9
Sec. Patch     : 2020-04-05
Build Time     : 10.04.2020
Product Model  : vivo 1902
Product Brand  : vivo
Product Name   : PD1901F_EX
Product Device : PD1901F_EX
Product Manfct : vivo
Product Info   : k65v1_64_bsp
Product Board  : k65v1_64_bsp
Product Name   : full_k65v1_64_bsp
Product Device : k65v1_64_bsp
USERDATA : FILESYSTEM : EXT4  with FDE ( Full Disk Encryption **)
NVRAM : SEC NORMAL  [ No extra security ]
Backup path : Backup\MT6765__xxxxxxxxxxxxxxxxxxxxxxxxxxx\
[29] Read : NVRAM
[8] Read : NVDATA
[19] Read : PROINFO
[30] Read : LK
[7] Read : NVCFG
[14] Read : PROTECT1
[15] Read : PROTECT2
Backup done!
DEV : MT6765
NME : preloader_k65v1_64_bsp.bin
CNT : 000C
 EMI : [00] : eMMC : LP_DDR4X : ID : 150100445636444D42 : VEN : SAMSUNG   | DEV : DV6DMB : RAM : [ 4,00 GB ]
 EMI : [01] : eMMC : LP_DDR4X : ID : 13014E53304A394B39 : VEN : MICRON    | DEV : S0J9K9 : RAM : [ 4,00 GB ]
 EMI : [02] : eMMC : LP_DDR4X : ID : 150100444836444142 : VEN : SAMSUNG   | DEV : DH6DAB : RAM : [ 4,00 GB ]
 EMI : [03] : eMMC : LP_DDR4X : ID : 90014A484347386134 : VEN : HYNIX     | DEV : HCG8a4 : RAM : [ 4,00 GB ]
 EMI : [04] : eMMC : LP_DDR4X : ID : 150100444836444D42 : VEN : SAMSUNG   | DEV : DH6DMB : RAM : [ 4,00 GB ]
 EMI : [05] : eMMC : DDR3 : ID : 150100525036344D42 : VEN : SAMSUNG   | DEV : RP64MB : RAM : [ 4,00 GB ]
 EMI : [06] : eMMC : DDR3 : ID : 90014A684339615033 : VEN : HYNIX     | DEV : hC9aP3 : RAM : [ 4,00 GB ]
 EMI : [07] : eMMC : DDR3 : ID : 90014A484347386134 : VEN : HYNIX     | DEV : HCG8a4 : RAM : [ 4,00 GB ]
 EMI : [08] : eMMC : LP_DDR4X : ID : 90014A684339615033 : VEN : HYNIX     | DEV : hC9aP3 : RAM : [ 4,00 GB ]
 EMI : [09] : eMMC : LP_DDR4X : ID : 150100335636434D42 : VEN : SAMSUNG   | DEV : 3V6CMB : RAM : [ 6,00 GB ]
 EMI : [0A] : eMMC : LP_DDR4X : ID : 13014E47314A395238 : VEN : MICRON    | DEV : G1J9R8 : RAM : [ 4,00 GB ]
 EMI : [0B] : eMMC : LP_DDR4X : ID : 13014E47314A395339 : VEN : MICRON    | DEV : G1J9S9 : RAM : [ 4,00 GB ]
Done!
Elapsed: 00:00:50
The Following 27 Users Say Thank You to JayDi For This Useful Post:
Old 01-24-2021, 02:53   #5 (permalink)
JayDi's Avatar
Member: 462970
Random HUAWEI
HWreport :
MODE : BOOTROM
PORT : 23
BROM : Init BROM
BROM init passed!
     CODE : Cervino
BROM : BOOTROM
BROM : DA sent
     DA : AGENT started!
DA : SYNC
     DA : MODE : BROM
     EMI : CNT : 0002
        DRAM: 0xC0000000 [ 3,00 GB ]
        EMMC: 150100475036424D4201xxxxxxxxxxxx
        EMMC: VEN : SAMSUNG | OEM : 01 | DEV : GP6BMB
        EMMC:
              RPMB   : 0x01000000 [ 16,00 MB ]
Boot done!
Memory Info :
    CID : 150100475036424D420xxxxxxxxxxxxxxxxxx
    MEM : VEN : SAMSUNG | OEM : 01 | DEV : GP6BMB
EXT_CSD Info :
     HPI features		 : 1h
     TRIM timeout: 0 ms
     Power class: 0
     Card type       : 57h
     Command set     : 0h
     HS timing       : 0h
     Bus width       : 0h
     Boot bus width	     : 2h
     RPMB size : 16384 kbytes
     HPI management	    : 0h
     Max. enhanced area size : 9b5h (20357120 kbytes)
     Part. support  : 7h
     Part. attribute: 0h
     Part. setting  : 0h
Overall status :
Done!
Elapsed: 00:00:26
Identify :
Mode : FLASH
MODE : BOOTROM
PORT : 23
BROM : Init BROM
BROM init passed!
     CODE : Cervino
BROM : BOOTROM
BROM : SOCID : xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
BROM : DA sent
     DA : AGENT started!
DA : SYNC
     DA : MODE : BROM
     EMI : CNT : 0002
        EMMC: 150100475036424D420xxxxxxxxxxxxx
        EMMC:
Boot done!
Sec. Patch     : 2019-07-05
Product Brand  : alps
Product Name   : full_k62v1_64_mex_a32
Product Device : k62v1_64_mex_a32
Product Info   : k62v1_64_mex_a32
Product Board  : k62v1_64_mexico
Product Manfct : HUAWEI
Product Model  : k62v1_64_mex_a32
Ver. CodeName  : REL
Ver. Release   : 9
Build Time     : 10.07.2019
Product Model  : HUAWEI
Product Manfct : alps
USERDATA : FILESYSTEM : F2FS  with FBE ( File-Base Encryption )
Backup path : Backup\MT6765__xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx\
Backup done!
DEV : MT6765
NME : preloader_k62v1_64_mexico.bin
CNT : 001E
 EMI : [00] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN   | DEV :  : RAM : [ 512,00 MB ]
 EMI : [01] : eMMC : DDR3 : ID : 90014A484147346132 : VEN : HYNIX     | DEV : HAG4a2 : RAM : [ 2,00 GB ]
 EMI : [02] : eMMC : DDR3 : ID : 90014A68423861503E : VEN : HYNIX     | DEV : hB8aP> : RAM : [ 3,00 GB ]
 EMI : [03] : eMMC : DDR3 : ID : 90014A484347386134 : VEN : HYNIX     | DEV : HCG8a4 : RAM : [ 4,00 GB ]
 EMI : [05] : eMMC : DDR3 : ID : 150100514436334D42 : VEN : SAMSUNG   | DEV : QD63MB : RAM : [ 2,00 GB ]
 EMI : [06] : eMMC : DDR3 : ID : 150100474436424D42 : VEN : SAMSUNG   | DEV : GD6BMB : RAM : [ 3,00 GB ]
 EMI : [07] : eMMC : DDR3 : ID : 150100475036424D42 : VEN : SAMSUNG   | DEV : GP6BMB : RAM : [ 3,00 GB ]
 EMI : [08] : eMMC : DDR3 : ID : 150100524836344142 : VEN : SAMSUNG   | DEV : RH64AB : RAM : [ 4,00 GB ]
 EMI : [09] : eMMC : DDR3 : ID : 13014E53304A394137 : VEN : MICRON    | DEV : S0J9A7 : RAM : [ 2,00 GB ]
 EMI : [0A] : eMMC : DDR3 : ID : 13014E53304A394E38 : VEN : MICRON    | DEV : S0J9N8 : RAM : [ 4,00 GB ]
 EMI : [0B] : eMMC : DDR3 : ID : 90014A68433861503E : VEN : HYNIX     | DEV : hC8aP> : RAM : [ 3,00 GB ]
 EMI : [0C] : eMMC : DDR3 : ID : 90014A68423861503E : VEN : HYNIX     | DEV : hB8aP> : RAM : [ 2,00 GB ]
 EMI : [0D] : eMMC : DDR3 : ID : 90014A684339615033 : VEN : HYNIX     | DEV : hC9aP3 : RAM : [ 4,00 GB ]
 EMI : [0E] : eMMC : DDR3 : ID : 150100525036344D42 : VEN : SAMSUNG   | DEV : RP64MB : RAM : [ 4,00 GB ]
 EMI : [0F] : eMMC : LP_DDR4X : ID : 150100445636444D42 : VEN : SAMSUNG   | DEV : DV6DMB : RAM : [ 4,00 GB ]
 EMI : [10] : eMMC : LP_DDR4X : ID : 13014E53304A394B39 : VEN : MICRON    | DEV : S0J9K9 : RAM : [ 4,00 GB ]
 EMI : [11] : eMMC : LP_DDR4X : ID : 450100444134313238 : VEN : SANDISK   | DEV : DA4128 : RAM : [ 4,00 GB ]
 EMI : [12] : eMMC : DDR3 : ID : 13014E53304A394237 : VEN : MICRON    | DEV : S0J9B7 : RAM : [ 3,00 GB ]
 EMI : [13] : eMMC : LP_DDR4X : ID : 90014A684445615033 : VEN : HYNIX     | DEV : hDEaP3 : RAM : [ 4,00 GB ]
 EMI : [14] : eMMC : DDR3 : ID : 150100475036424142 : VEN : SAMSUNG   | DEV : GP6BAB : RAM : [ 3,00 GB ]
 EMI : [15] : eMMC : DDR3 : ID : 150100475836424142 : VEN : SAMSUNG   | DEV : GX6BAB : RAM : [ 3,00 GB ]
 EMI : [16] : eMMC : DDR3 : ID : 150100515836334142 : VEN : SAMSUNG   | DEV : QX63AB : RAM : [ 2,00 GB ]
 EMI : [17] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN   | DEV :  : RAM : [ 4,00 GB ]
 EMI : [18] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN   | DEV :  : RAM : [ 4,00 GB ]
 EMI : [19] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN   | DEV :  : RAM : [ 2,00 GB ]
 EMI : [1A] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN   | DEV :  : RAM : [ 3,00 GB ]
 EMI : [1B] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN   | DEV :  : RAM : [ 3,00 GB ]
 EMI : [1C] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN   | DEV :  : RAM : [ 4,00 GB ]
 EMI : [1D] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN   | DEV :  : RAM : [ 2,00 GB ]
Done!
Elapsed: 00:00:23
Old 01-24-2021, 02:56   #6 (permalink)
JayDi's Avatar
Member: 462970
XIAOMI 6A
XIAOMI 8 Pro
VIVO
HUAWEI
All test are made with default DA.
No preloader,
No auth,
No da
has been selected.
Just sSLA option enabled and BROM mode.
That way allow you boot most of devices already.
Now a bit more possiblities open
The Following 60 Users Say Thank You to JayDi For This Useful Post:
Old 01-24-2021, 02:58   #7 (permalink)
Member: 1328371
Thanks Meter: 121
[QUOTE=YellowBoss;14313180]Infinity Chinese Miracle-2 MTK/MediaTek v2.17 - Standalone auth ON
Core
Flasher
Service
Changed: Identify
Firmware Reader
Other
Info
How to Install:
Important step !
Download link #1
Download link #2
Download link #3
Please check Infinity Chinese Miracle-2 MTK/MediaTek v2.17 Installer is corrupted.I downloaded 3x but i can not install.
The Following 2 Users Say Thank You to john kenneth For This Useful Post:
Old 01-24-2021, 03:15   #8 (permalink)
Member: 1328371
Thanks Meter: 121
I can install Infinity Chinese Miracle-2 MTK/MediaTek v2.17 set-up now.
The Following User Says Thank You to john kenneth For This Useful Post:
Old 01-24-2021, 03:25   #9 (permalink)
Member: 1043909
You was too fast and downloaded it before upload was completed.
You can download it now from link #1
The Following 7 Users Say Thank You to YellowBoss For This Useful Post:
Old 01-24-2021, 03:29   #10 (permalink)
Member: 1328371
Thanks Meter: 121
sorry!!!excited
Old 01-24-2021, 04:18   #11 (permalink)
VIJAY2U2's Avatar
Member: 1039903
Thanks Meter: 2,040
Beautiful.....
Great News....
All Offline Thanks Team,👍👍👍
The Following User Says Thank You to VIJAY2U2 For This Useful Post:
Old 01-24-2021, 05:10   #12 (permalink)
sneha's Avatar
Member: 327043
Sonork: 100.1587811
Thanks Meter: 1,514
redmi 6 error on read info
Originally Posted by JayDi View Post
XIAOMI 6A
XIAOMI 8 Pro
VIVO
HUAWEI
No preloader,
No auth,
No da
has been selected.
Mode : FLASH
PTFN : MediaTek USB Port_V1632 (COM7)
MODE : BOOTROM
PORT : 7
BROM : Init BROM
BROM init passed!
     CODE : Cervino
BROM : MEID : 3EF21FB41CCDBA61DA0977B58997E263
BROM : BOOTROM
BROM : SOCID : 23E625E005A0F886EAAC6E203203F11D214EE88D775FA68E436BC0E710760FDA
BROM : DA sent
     DA : AGENT started!
DA : SYNC
     DA : MODE : BROM
     EMI : CNT : 0008
     DA : SETUP EMI PARAMS FAILED!
  ERROR : ABORT
Error : Fail to init protocol!
>>> Internal EMI : Select other EMI number! External Preloader - make sure it correct for connected device!
with fectory preloader its done great JayDi
Mode : FLASH
MODE : BOOTROM
PORT : 7
BROM : Init BROM
BROM init passed!
CODE : Cervino
BROM : BOOTROM
MODE : 0_base : BASE_v1944 | Manual : Enabled
BROM : SOCID : 23E625E005A0F886EAAC6E203203F11D214EE88D775FA68E43 6BC0E710760FDA
BROM : DA sent
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
EMI : DEV : MT6765
EMI : SRC : preloader_cereus.bin
EMI : CNT : 000B
EMI : [00] : eMMC : DDR3 : ID : 90014A484247346132 : VEN : HYNIX | DEV : HBG4a2 : RAM : [ 3.00 GB ]
EMI : [01] : eMMC : DDR3 : ID : 90014A68423861503E : VEN : HYNIX | DEV : hB8aP> : RAM : [ 3.00 GB ]
EMI : [02] : eMMC : DDR3 : ID : 90014A484147346132 : VEN : HYNIX | DEV : HAG4a2 : RAM : [ 2.00 GB ]
EMI : [03] : eMMC : DDR3 : ID : 13014E53304A394237 : VEN : MICRON | DEV : S0J9B7 : RAM : [ 3.00 GB ]
EMI : [04] : eMMC : DDR3 : ID : 150100514536334D42 : VEN : SAMSUNG | DEV : QE63MB : RAM : [ 2.00 GB ]
EMI : [05] : eMMC : DDR3 : ID : 150100474436424D42 : VEN : SAMSUNG | DEV : GD6BMB : RAM : [ 3.00 GB ]
EMI : [06] : eMMC : DDR3 : ID : 13014E53304A394137 : VEN : MICRON | DEV : S0J9A7 : RAM : [ 2.00 GB ]
EMI : [07] : eMMC : DDR3 : ID : 150100524836344142 : VEN : SAMSUNG | DEV : RH64AB : RAM : [ 4.00 GB ]
EMI : [08] : eMMC : DDR3 : ID : 90014A484347386134 : VEN : HYNIX | DEV : HCG8a4 : RAM : [ 4.00 GB ]
EMI : [09] : eMMC : DDR3 : ID : 150100514436334D42 : VEN : SAMSUNG | DEV : QD63MB : RAM : [ 2.00 GB ]
EMI : [0A] : eMMC : DDR3 : ID : 150100475036424D42 : VEN : SAMSUNG | DEV : GP6BMB : RAM : [ 3.00 GB ]
SRAM: 0x00038000 [ 224.00 KB ]
DRAM: 0xC0000000 [ 3.00 GB ]
EMMC: 90014A484247346132A42683C15D93EB
EMMC: VEN : HYNIX | OEM : 4A01 | DEV : HBG4a2
EMMC:
BOOT1 : 0x00400000 [ 4.00 MB ]
BOOT2 : 0x00400000 [ 4.00 MB ]
RPMB : 0x00400000 [ 4.00 MB ]
USER : 0x747C00000 [ 29.12 GB ]
RNID : 98D011CA3BDFDF3EF45473A87731637A
Boot done!
Display ID : O11019
Ver. CodeName : REL
Sec. Patch : 2019-08-01
Build Time : 23.08.2019
Product Name : cereus
Product Device : cereus
Product Info : cereus
Backup sensetive data [ 11 ]
Backup path : Backup\MT6765__98D011CA3BDFDF3EF45473A87731637A\
[25] Read : NVRAM
[8] Read : NVDATA
[15] Read : PROINFO
[27] Read : LK
[7] Read : NVCFG
[13] Read : PERSIST
[0] Read : PRELOADER
[12] Read : SECCFG
Backup done!
DEV : MT6765
NME : preloader_cereus.bin
CNT : 000B
Done!
Elapsed: 00:00:57
The Following 8 Users Say Thank You to sneha For This Useful Post:
Old 01-24-2021, 05:26   #13 (permalink)
Member: 2559678
Thanks Meter: 29
Thank infinity team. Please add also support for mtk6580 and Sim Me lock unlocking
Sent from my SM-G570F using Tapatalk
The Following User Says Thank You to inomfia For This Useful Post:
Old 01-24-2021, 05:33   #14 (permalink)
kamal_singla's Avatar
Member: 2211790
Thanks Meter: 5,118
Have you tried on latest mtk setup ?
The Following User Says Thank You to kamal_singla For This Useful Post:
Old 01-24-2021, 05:40   #15 (permalink)
Member: 2643931
Sonork: ******
Thanks Meter: 225
Please update QLM
The Following 6 Users Say Thank You to afghanistanmob For This Useful Post:
Page generated in 0.49708 seconds with 10 queries
