Old 01-24-2021, 09:19   #46 (permalink)
kamal_singla's Avatar
Member: 2211790
Thanks Meter: 5,118
@Arslanmayo
once udpate your database
then service tab do HW Report after that repelat flashing may work
The Following User Says Thank You to kamal_singla For This Useful Post:
Old 01-24-2021, 09:19   #47 (permalink)
Member: 2211790
Thanks Meter: 5,118
@Arslanmayo
then service tab do HW Report after that repeat flashing may work
Old 01-24-2021, 09:36   #48 (permalink)
Arslanmayo's Avatar
Member: 2478233
Thanks Meter: 596
Originally Posted by kamal_singla View Post
@Arslanmayo
already done bro will try that next time
Old 01-24-2021, 09:39   #49 (permalink)
Member: 1613469
Thanks Meter: 192
Operation : HW Report [ v2.17 ]
HWreport : Mode : eMMC
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : MediaTek USB Port (COM21)
MODE : BOOTROM
PORT : 21
Waiting BOOT ack ...
BROM : Skip ACK verify
BROM : Init BROM
BROM init passed!
CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000
CODE : Cervino
TYPE : MODERN RAPHAEL
BROM : MEID : 73DC67E3FC75E71D136CB776559BCD88
BROM : SecLevel : 0x000000E7
BROM : SecMode : SBC+SLA+SDA+EXT
BROM : BROM|BL : 0x05|0xFE
BROM : BOOTROM
MODE : Xiaomi : 6A | Manual : Disabled
BROM : SOCID : 5D23C2B462D700C1DB0160B642BF65757A4C87EEA99C159C3D A3A19A46699470
BROM : SLA : Local Auth
BROM : SLA : Auth Passed!
BROM : SLA : 0x0000001F
AGENT : Look for suitable BootChain in DA ...
AGENT : MTK_AllInOne_DA.bin
AGENT : Found MT6765
AGENT : MTK_DOWNLOAD_AGENT
BROM : Sending 1st DA ...
BROM : DA sent
BROM :Transfer control to DA ...
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
DA : EXT_RAM NOT initialized!
EMI : DEV : INFINITY
EMI : SRC : PRELOADER_INFINITY_0
EMI : CNT : 0002
EMI : Init EMI from INTERNAL DB
EMI : EXT_RAM CFG Passed!
DA : BOOT to 2nd DA ...
DA : 2ND stage confirmed!
DA : SYNC with DA passed!
DA : Receiving HW info
SRAM: 0x00038000 [ 224,00 KB ]
DRAM: 0x80000000 [ 2,00 GB ]
EMMC: 90014A484147346132A53AB0C65DB58F
EMMC: VEN : HYNIX | OEM : 4A01 | DEV : HAG4a2
EMMC:
BOOT1 : 0x00400000 [ 4,00 MB ]
BOOT2 : 0x00400000 [ 4,00 MB ]
RPMB : 0x00400000 [ 4,00 MB ]
USER : 0x3AB400000 [ 14,68 GB ]
CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000
RNID : F6226CA323458FE42811B409BC224FC
DA : USB : HIGH-SPEED
Boot done!
Memory Info :
CID : 90014A484147346132A53AB0C65DB58F
MEM : VEN : HYNIX | OEM : 4A01 | DEV : HAG4a2
DAT : Size: 15028 MB, Max.Speed: 52000 kHz, blklen(512), nblks(30777344), ro(0)
EXT_CSD Info :
EXT_CSD rev. : v1.8 ( MMC v5.1 )
CSD struct rev. : v1.2
Supported command sets : 1h
HPI features : 1h
BG operations support : 1h
BG operations status : 0h
Correct prg. sectors : 0h
1st init time after part. : 1000 ms
Min. write perf.(DDR,52MH,8b): 78h
Min. read perf. (DDR,52MH,8b): 8ch
TRIM timeout: 0 ms
Secure feature support: 55h
Secure erase timeout : 30000 ms
Secure trim timeout : 6000 ms
Access size : 3072 bytes
HC erase unit size : 512 kbytes
HC erase timeout : 600 ms
HC write prot grp size: 4096 kbytes
HC erase grp def. : 0h
Reliable write sect count: 1h
Sleep current (VCC) : 7h
Sleep current (VCCQ): 7h
Sleep/awake timeout : 26214400 ns
Sector count : 1d5a000h
Min. WR Perf. (52MH,8b): 8ch
Min. Read Perf.(52MH,8b): 8ch
Min. WR Perf. (26MH,8b,52MH,4b): 46h
Min. Read Perf.(26MH,8b,52MH,4b): 46h
Min. WR Perf. (26MH,4b): 1eh
Min. Read Perf.(26MH,4b): 1eh
Power class: 0
Power class(DDR,52MH,3.6V): 11h
Power class(DDR,52MH,1.9V): 0h
Power class(26MH,3.6V) : 0h
Power class(52MH,3.6V) : 0h
Power class(26MH,1.9V) : 0h
Power class(52MH,1.9V) : 0h
Part. switch timing : 1h
Out-of-INTR busy timing: 5h
Card type : 57h
Command set : 0h
Command set rev.: 0h
HS timing : 0h
Bus width : 0h
Erase memory content : 0h
Partition config : 48h
Boot partition size : 4096 kbytes
Boot information : 7h
Boot config protection: 0h
Boot bus width : 2h
Boot area write prot : 0h
User area write prot : 0h
FW configuration : 0h
RPMB size : 4096 kbytes
Write rel. setting : 1fh
Write rel. parameter: 15h
Start background ops : 0h
Enable background ops: 2h
H/W reset function : 1h
HPI management : 0h
Max. enhanced area size : 756h (7692288 kbytes)
Part. support : 7h
Part. attribute: 0h
Part. setting : 0h
General purpose 1 size : 0h (0 kbytes)
General purpose 2 size : 0h (0 kbytes)
General purpose 3 size : 0h (0 kbytes)
General purpose 4 size : 0h (0 kbytes)
Enh. user area size : 0h (0 kbytes)
Enh. user area start: 0h
Bad block mgmt mode: 0h
Overall status :
MLC status : 0% - 10% used
SLC status : 0% - 10% used
RPMB : RPMB KEY EXISTS! [State : NOT CLEAN : UNUSABLE]
Done!
Elapsed: 00:00:29
The Following 3 Users Say Thank You to washipolar For This Useful Post:
Old 01-24-2021, 09:41   #50 (permalink)
Member: 1677653
Thanks Meter: 2,769
Infinity-Box Official Telegram Group
https://forum.gsmhosting.com/vbb/14310656-post2.html
The Following User Says Thank You to Yusuf Lawal For This Useful Post:
Old 01-24-2021, 09:42   #51 (permalink)
Member: 1815000
Thanks Meter: 54
Wow! I really admire the Russian programmer 😍
Dra-lx2 sla challenge can by bypassed? 🤔
Old 01-24-2021, 09:44   #52 (permalink)
Member: 1677653
Thanks Meter: 2,769
Try it and give us feedback...
The Following 2 Users Say Thank You to Yusuf Lawal For This Useful Post:
Old 01-24-2021, 09:44   #53 (permalink)
sky73's Avatar
Member: 1876736
Thanks Meter: 735
Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.17
Failed to prepare enivorment!
Load IDBase v1118158 Ok!
Update configuration ...
Update Ok!
HWreport : Mode : UFS
PTFN : MediaTek USB Port (COM50)
MODE : BOOTROM
PORT : 50
BROM : Init BROM
BROM init passed!
     CHIP : MT6785 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000
     CODE : Krug
BROM : MEID : 1FB8A78A8588C16045047908D997E311
BROM : BOOTROM
MODE : 0_base : BASE_v2028 | Manual : Disabled
BROM : SOCID : C5482772FE6A2F90E2D772EC083342C3B03B5BD3AAD378BA6DD60E341789FF47
BROM  : Selected Auth/Cert not accepted by device!
>>> Check previous message for more info!
Reconnect Power/Cable!
Info : LEGACY : HW reporting feature unavailable for current device!
Done!
Elapsed: 00:00:12
redmi not 8 pro
how can i fix this ?
Old 01-24-2021, 09:44   #54 (permalink)
Member: 1535920
Thanks Meter: 31
Thank you team for this update. Thank you Jaydi sir and every member of the team. You have been giving us unique solutions all these years. This is amazing
Sent from my iPhone using Tapatalk
Old 01-24-2021, 09:46   #55 (permalink)
Member: 1169259
Sonork: 100.1648194
Thanks Meter: 149
Will support more type of cpu in sSLA next update
Old 01-24-2021, 09:48   #56 (permalink)
Member: 1613469
Thanks Meter: 192
Operation : Identify [ v2.17 ]
Mode : FLASH
MODE : BOOTROM
PORT : 21
BROM : Init BROM
BROM init passed!
CODE : Cervino
BROM : BOOTROM
BROM : DA sent
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
EMI : CNT : 0002
EMMC:
Boot done!
Patch Level : PPR1.180610.011
Display ID : SW_S98506AE1_V009_M13_XM_C3C_USR
Ver. CodeName : REL
Ver. Release : 9
Sec. Patch : 2020-05-01
Build Time : 08.05.2020
Product Model : Redmi 6A
Product Brand : xiaomi
Product Name : cactus
Product Device : cactus
Product Info : cactus
Product Manfct : Xiaomi
Product Board : cactus
Board Platform : mt6765
USERDATA : FILESYSTEM : EXT4 with FDE ( Full Disk Encryption **)
STORAGE : LifeStatus : eMMC : OK!
PRELOADER : DEVICE :
DEV : MT6765
NME : preloader_cactus.bin
CNT : 0007
EMI : [00] : eMMC : DDR3 : ID : 150100514536334D42 : VEN : SAMSUNG | DEV : QE63MB : RAM : [ 2,00 GB ]
EMI : [01] : eMMC : DDR3 : ID : 90014A484147346132 : VEN : HYNIX | DEV : HAG4a2 : RAM : [ 2,00 GB ]
EMI : [02] : eMMC : DDR3 : ID : 13014E53304A394137 : VEN : MICRON | DEV : S0J9A7 : RAM : [ 2,00 GB ]
EMI : [03] : eMMC : DDR3 : ID : 150100514436334D42 : VEN : SAMSUNG | DEV : QD63MB : RAM : [ 2,00 GB ]
EMI : [04] : eMMC : DDR3 : ID : 150100474436424D42 : VEN : SAMSUNG | DEV : GD6BMB : RAM : [ 3,00 GB ]
EMI : [05] : eMMC : DDR3 : ID : 13014E53304A394237 : VEN : MICRON | DEV : S0J9B7 : RAM : [ 3,00 GB ]
EMI : [06] : eMMC : DDR3 : ID : 90014A484247346132 : VEN : HYNIX | DEV : HBG4a2 : RAM : [ 3,00 GB ]
Done!
Elapsed: 00:00:50
Old 01-24-2021, 09:52   #57 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
[Failed to prepare enivorment!
meant something wrong with your installation.
How to fix that :
1.
Install C:\InfinityBox\tools\boot-helper-a.exe
Reboot PC
2. Add CM2MT2 folder to your AV exclude list.
3. Connect device and try make sSLA enabled phone.
We tested on win7, win10 x64 system and found that working even on clean system.
The Following 8 Users Say Thank You to JayDi For This Useful Post:
Old 01-24-2021, 09:52   #58 (permalink)
Member: 1613469
Thanks Meter: 192
Mode : FLASH
MODE : BOOTROM
PORT : 21
BROM : Init BROM
BROM init passed!
CODE : Cervino
BROM : BOOTROM
BROM : DA sent
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
EMI : CNT : 0002
EMMC:
Boot done!
Ver. CodeName : REL
Ver. Release : 9
DEV : MT6765
CNT : 0007
Done!
Elapsed: 00:00:50
The Following 2 Users Say Thank You to washipolar For This Useful Post:
Old 01-24-2021, 09:53   #59 (permalink)
JayDi's Avatar
Member: 462970
Why HWreport matter?
It allow you select CORRECT device setting and you NOT NEED select any PRELOADER or whatever else. We made that to make life easier! Just use it once, then can proceed whatecer want.
The Following 16 Users Say Thank You to JayDi For This Useful Post:
Old 01-24-2021, 10:23   #60 (permalink)
Member: 2518014
Thanks Meter: 43
Infinity good & great team infinex x690b frp remove ad this update ?
Page generated in 0.30421 seconds with 10 queries
