Member: 597610
Thanks Meter: 50 | mi 6a locked Quote:
Originally Posted by JayDi READMI 6A HWreport : Code: Operation : HW Report [ v2.17 ]
HWreport : Mode : eMMC
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : MediaTek USB Port (COM23)
MODE : BOOTROM
PORT : 23
Waiting BOOT ack ...
BROM : Skip ACK verify
BROM : Init BROM
BROM init passed!
CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000
CODE : Cervino
TYPE : MODERN RAPHAEL
BROM : MEID : xxxxxxxxxxxxxxxxxxxxx
BROM : SecLevel : 0x000000E7
BROM : SecMode : SBC+SLA+SDA+EXT
BROM : BROM|BL : 0x05|0xFE
BROM : BOOTROM
MODE : 0_base : BASE_v1944 | Manual : Disabled
BROM : SOCID : xxxxxxxxxxxxxxxxxxxxxxx
BROM : SLA : Local Auth
BROM : SLA : Auth Passed!
BROM : SLA : 0x0000001F
AGENT : Look for suitable BootChain in DA ...
AGENT : MTK_AllInOne_DA.bin
AGENT : Found MT6765
AGENT : MTK_DOWNLOAD_AGENT
BROM : Sending 1st DA ...
BROM : DA sent
BROM :Transfer control to DA ...
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
DA : EXT_RAM NOT initialized!
EMI : DEV : INFINITY
EMI : SRC : PRELOADER_INFINITY_0
EMI : CNT : 0001
EMI : Init EMI from INTERNAL DB
EMI : EXT_RAM CFG Passed!
DA : BOOT to 2nd DA ...
DA : 2ND stage confirmed!
DA : SYNC with DA passed!
DA : Receiving HW info
SRAM: 0x00038000 [ 224,00 KB ]
DRAM: 0x80000000 [ 2,00 GB ]
EMMC: 150100514536334D42xxxxxxxxxxxxx
EMMC: VEN : SAMSUNG | OEM : 01 | DEV : QE63MB
EMMC:
BOOT1 : 0x00400000 [ 4,00 MB ]
BOOT2 : 0x00400000 [ 4,00 MB ]
RPMB : 0x00400000 [ 4,00 MB ]
USER : 0x3A3E00000 [ 14,56 GB ]
CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000
RNID : xxxxxxxxxxxxxxxxxxxxxxx
DA : USB : HIGH-SPEED
Boot done!
Memory Info :
CID : 150100514536334D42xxxxxxxxxxxxx
MEM : VEN : SAMSUNG | OEM : 01 | DEV : QE63MB
DAT : Size: 14910 MB, Max.Speed: 52000 kHz, blklen(512), nblks(30535680), ro(0)
EXT_CSD Info :
EXT_CSD rev. : v1.8 ( MMC v5.1 )
CSD struct rev. : v1.2
Supported command sets : 1h
HPI features : 1h
BG operations support : 1h
BG operations status : 0h
Correct prg. sectors : 0h
1st init time after part. : 3000 ms
Min. write perf.(DDR,52MH,8b): 0h
Min. read perf. (DDR,52MH,8b): 0h
TRIM timeout: 0 ms
Secure feature support: 55h
Secure erase timeout : 8100 ms
Secure trim timeout : 5100 ms
Access size : 3584 bytes
HC erase unit size : 512 kbytes
HC erase timeout : 300 ms
HC write prot grp size: 8192 kbytes
HC erase grp def. : 0h
Reliable write sect count: 1h
Sleep current (VCC) : 7h
Sleep current (VCCQ): 7h
Sleep/awake timeout : 26214400 ns
Sector count : 1d1f000h
Min. WR Perf. (52MH,8b): 0h
Min. Read Perf.(52MH,8b): 0h
Min. WR Perf. (26MH,8b,52MH,4b): 0h
Min. Read Perf.(26MH,8b,52MH,4b): 0h
Min. WR Perf. (26MH,4b): 0h
Min. Read Perf.(26MH,4b): 0h
Power class: 0
Power class(DDR,52MH,3.6V): 0h
Power class(DDR,52MH,1.9V): 0h
Power class(26MH,3.6V) : 0h
Power class(52MH,3.6V) : 0h
Power class(26MH,1.9V) : 0h
Power class(52MH,1.9V) : 0h
Part. switch timing : 2h
Out-of-INTR busy timing: ah
Card type : 57h
Command set : 0h
Command set rev.: 0h
HS timing : 0h
Bus width : 0h
Erase memory content : 0h
Partition config : 48h
Boot partition size : 4096 kbytes
Boot information : 7h
Boot config protection: 0h
Boot bus width : 2h
Boot area write prot : 0h
User area write prot : 0h
FW configuration : 0h
RPMB size : 4096 kbytes
Write rel. setting : 1fh
Write rel. parameter: 14h
Start background ops : 0h
Enable background ops: 2h
H/W reset function : 1h
HPI management : 0h
Max. enhanced area size : 3a3h (7626752 kbytes)
Part. support : 7h
Part. attribute: 0h
Part. setting : 0h
General purpose 1 size : 0h (0 kbytes)
General purpose 2 size : 0h (0 kbytes)
General purpose 3 size : 0h (0 kbytes)
General purpose 4 size : 0h (0 kbytes)
Enh. user area size : 0h (0 kbytes)
Enh. user area start: 0h
Bad block mgmt mode: 0h
Overall status :
MLC status : 0% - 10% used
SLC status : 0% - 10% used
EOL status : Normal ( Less than 80% reserved blocks used )
RPMB : RPMB KEY EXISTS! [State : NOT CLEAN : UNUSABLE]
Done!
Elapsed: 00:00:22 Identify : Code: Operation : Identify [ v2.17 ]
Mode : FLASH
MODE : BOOTROM
PORT : 23
BROM : Init BROM
BROM init passed!
CODE : Cervino
BROM : MEID : xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
BROM : BOOTROM
BROM : SOCID : xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
BROM : DA sent
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
EMI : CNT : 0001
EMMC: 150100514536334D420xxxxxxxxxxxxxxxxxx
EMMC:
RNID : xxxxxxxxxxxxxxxxxxxxxxxxxxxxx
Boot done!
Patch Level : O11019
Display ID : O11019
Ver. CodeName : REL
Ver. Release : 8.1.0
Sec. Patch : 2018-05-05
Build Time : 11.06.2018
Product Model : Redmi 6A
Product Brand : xiaomi
Product Name : cactus
Product Device : cactus
Product Info : cactus
Product Manfct : Xiaomi
Board Platform : mt6765
USERDATA : FILESYSTEM : EXT4 with FDE ( Full Disk Encryption *)
NVRAM check : Passed!
NVRAM : SEC SIGNED [ IMEI RSA SIGNED ]
Backup sensetive data [ 8 ]
Backup path : Backup\MT6765__xxxxxxxxxxxxx\
[25] Read : NVRAM
[8] Read : NVDATA
[15] Read : PROINFO
[27] Read : LK
[7] Read : NVCFG
[10] Read : PROTECT1
[11] Read : PROTECT2
Backup done!
STORAGE : LifeStatus : eMMC : OK!
PRELOADER : DEVICE :
DEV : MT6765
NME : preloader_cactus.bin
CNT : 000A
EMI : [00] : eMMC : DDR3 : ID : 90014A484247346132 : VEN : HYNIX | DEV : HBG4a2 : RAM : [ 3,00 GB ]
EMI : [01] : eMMC : DDR3 : ID : 90014A68423861503E : VEN : HYNIX | DEV : hB8aP> : RAM : [ 3,00 GB ]
EMI : [02] : eMMC : DDR3 : ID : 90014A484147346132 : VEN : HYNIX | DEV : HAG4a2 : RAM : [ 2,00 GB ]
EMI : [03] : eMMC : DDR3 : ID : 13014E53304A394237 : VEN : MICRON | DEV : S0J9B7 : RAM : [ 3,00 GB ]
EMI : [04] : eMMC : DDR3 : ID : 150100514536334D42 : VEN : SAMSUNG | DEV : QE63MB : RAM : [ 2,00 GB ]
EMI : [05] : eMMC : DDR3 : ID : 150100474436424D42 : VEN : SAMSUNG | DEV : GD6BMB : RAM : [ 3,00 GB ]
EMI : [06] : eMMC : DDR3 : ID : 13014E53304A394137 : VEN : MICRON | DEV : S0J9A7 : RAM : [ 2,00 GB ]
EMI : [07] : eMMC : DDR3 : ID : 150100524836344142 : VEN : SAMSUNG | DEV : RH64AB : RAM : [ 4,00 GB ]
EMI : [08] : eMMC : DDR3 : ID : 90014A484347386134 : VEN : HYNIX | DEV : HCG8a4 : RAM : [ 4,00 GB ]
EMI : [09] : eMMC : DDR3 : ID : 150100514436334D42 : VEN : SAMSUNG | DEV : QD63MB : RAM : [ 2,00 GB ]
Done!
Elapsed: 00:00:39 Read FW: Code: Operation : Read Firmware [ v2.17 ]
ExtSparse : Enabled
ForceRead : Disabled
MODE : BOOTROM
PORT : 23
BROM : Init BROM
BROM init passed!
CODE : Cervino
BROM : MEID : xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
BROM : BOOTROM
BROM : DA sent
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
EMI : CNT : 0001
EMMC: 150100514536334D4203Cxxxxxxxxxxx
EMMC:
Boot done!
Display ID : O11019
Ver. CodeName : REL
MT6765__Xiaomi__Redmi_6A__8.1.0__O11019__O11019__cactus
Read : preloader.bin
Read : recovery.img
Read : persist.img
ExtSparse : Compression ratio : 100%
Read : proinfo.img
Read : efuse.img
Read : md1rom.img
Read : spmfw.img
Read : tinysys-scp.bin
Read : tinysys-sspm.bin
Read : nvram.bin
Read : vbmeta.img
Read : lk.bin
Read : boot.img
Read : logo.bin
Read : odmdtbo.img
Read : cust.img
ExtSparse : Compression ratio : 32%
Read : tz.img
Read : vendor.img
ExtSparse : Compression ratio : 53%
Read : system.img
ExtSparse : Compression ratio : 24%
Read : cache.img
Read : userdata.img
FW Size : 2,86 GB
Android Info saved : _Android_info.txt
Scatter : MT6765_Android_scatter.txt
Saved to : C:\MT6765__Xiaomi__Redmi_6A__8.1.0__O11019__O11019__cactus\
Done!
Elapsed: 00:07:26 Flash : Code: Created by Infinity-Box (c) 2021
Chinese Miracle II : MediaTek Service Module
Device Info file : _Android_info.txt
Display ID : O11019
Ver. CodeName : REL
Preloader [HW DEV] Info :
EMI : DEV : MT6765
EMI : SRC : preloader_cactus.bin
EMI : CNT : 000A
Operation : Write Flash [ v2.17 ]
Repartition : Enabled
Flash Verify : Enabled
Reg.Pre-Erase : Enabled
Verify HW/SW : Enabled
SData Backup : Disabled
Safe UserData : Disabled
Flash Format : Disabled
Files :22
[FL] : Set : preloader_cactus.bin
[FL] : Set : recovery.img
[FL] : Set : efuse.img
[FL] : Set : md1rom.img
[FL] : Set : spmfw.img
[FL] : Set : tinysys-scp.bin
[FL] : Set : tinysys-sspm.bin
[FL] : Set : vbmeta.img
[FL] : Set : lk.bin
[FL] : Set : lk.bin
[FL] : Set : boot.img
[FL] : Set : logo.bin
[FL] : Set : odmdtbo.img
[FL] : Set : cust.img
[FL] : Set : tz.img
[FL] : Set : tz.img
[FL] : Set : vendor.img
[FL] : Set : system.img
[FL] : Set : cache.img
[FL] : Set : userdata.img
[FL] : Total size : 0xB32BDBC8 [ 2,80 GB ]
MODE : BOOTROM
PORT : 23
BROM : Init BROM
BROM init passed!
CODE : Cervino
BROM : BOOTROM
BROM : SOCID : xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
BROM : DA sent
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
EMI : DEV : MT6765
EMI : CNT : 000A
EMI : Init EMI from PRELOADER
EMMC:
RNID : xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
Boot done!
[FL] : HW verification passed!
SEC_DL : False (RAPHAEL)
SEC_ID : 0x494E46494E495459424F584245535432
[FL] : Pre-Erase
Erase : 0x0000000000000000 : 0x0000000005688000
Erase : 0x0000000007688000 : 0x0000000006000000
Erase : 0x000000000E800000 : 0x0000000000800000
Erase : 0x0000000013000000 : 0x0000000000200000
Erase : 0x0000000013500000 : 0x0000000008980000
Erase : 0x000000001FE80000 : 0x00000000FA980000
Erase : 0x000000011B000000 : 0x00000000D0000000
[FL] : RePartition
[FL] : RePartition Ok!
[FL] : Flashing now ...
Write : PRELOADER
Update bootloader backup copy ...
Update bootloader backup copy Ok!
Write : RECOVERY
Write : EFUSE
Write : MD1IMG
Write : SPMFW
Write : SCP1
Write : SCP2
Write : SSPM_1
Write : SSPM_2
Write : VBMETA
Write : LK
Write : LK2
Write : BOOT
Write : LOGO
Write : ODMDTBO
Write : CUST
FAIL : SEC : IMG TOO LARGE
Write : TEE1
Write : TEE2
Write : VENDOR
Write : SYSTEM
Write : CACHE
Write : USERDATA
Ultra : Ok!
[FL] : RePartition
[FL] : Flashing finished!
Done!
Elapsed: 00:02:21
Reconnect Power/Cable! |
all ok but mi account still locked ...................how to unlock mi account |
