01-27-2021, 22:13 | #451 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Tick "Manual" in Platform tab, under model selection. Press EMI and cancel after. Do HWReport after and then, most probably, you can do any other operation after. |
The Following 2 Users Say Thank You to JayDi For This Useful Post: |
01-28-2021, 07:54 | #452 (permalink) | |
No Life Poster Join Date: Mar 2007 Location: Allways here
Member: 476774 Status: Offline Thanks Meter: 399 | Quote:
Card found : 08AD856F , v0147 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.19 Load IDBase v125162 Ok! Operation : HW Report [ v2.19 ] HWreport : Mode : eMMC 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM8) MODE : BOOTROM PORT : 8 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN RAPHAEL BROM : MEID : D515A2C1FE456B3796CC3AE326BE61D8 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v1712 | Manual : Enabled BROM : SOCID : 581B587954238966F1EBE39AD53C0BC8CE943C5E5B9E91483F 60796B1C18A115 BROM : SLA : Local Auth BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Selected AGENT doesn't have required configuration! >>> Check and select CORRECT SETTINGS for your device! Reconnect Power/Cable! Info : LEGACY : HW reporting feature unavailable for current device! Done! Elapsed: 00:00:13 | |
01-28-2021, 10:11 | #453 (permalink) |
Freak Poster Join Date: Sep 2007 Location: algeria Age: 35
Member: 580077 Status: Offline Sonork: 100.1591941 Thanks Meter: 207 | Code: Operation : Identify [ v2.19 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM86) MODE : BOOTROM PORT : 86 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6771 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Sylvia TYPE : MODERN RAPHAEL BROM : MEID : 7D4FB65C05A565FC4E34737586DB6E8C BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2044 | Manual : Disabled BROM : SOCID : C97732AC0469C52FBC59403FF1D1B4B3312AF991EC748989EF5927A3AA64DF35 BROM : SLA : Local Auth BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6771 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : PRELOADER_INFINITY_0 EMI : CNT : 0002 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00039000 [ 228,00 KB ] DRAM: 0x180000000 [ 6,00 GB ] EMMC: 150100335636434D42027E346A9656DB EMMC: VEN : SAMSUNG | OEM : 01 | DEV : 3V6CMB EMMC: BOOT1 : 0x00400000 [ 4,00 MB ] BOOT2 : 0x00400000 [ 4,00 MB ] RPMB : 0x01000000 [ 16,00 MB ] USER : 0x1D1EC00000 [ 116,48 GB ] CHIP : MT6771 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 55694BFFCF8338586C50E2D266F28174 DA : USB : HIGH-SPEED Boot done! Done! Elapsed: 00:00:30 Reconnect Power/Cable! Operation : Identify [ v2.19 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM86) MODE : BOOTROM PORT : 86 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6771 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Sylvia TYPE : MODERN RAPHAEL BROM : MEID : 7D4FB65C05A565FC4E34737586DB6E8C BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2044 | Manual : Disabled BROM : SOCID : C97732AC0469C52FBC59403FF1D1B4B3312AF991EC748989EF5927A3AA64DF35 BROM : SLA : Local Auth BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6771 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : PRELOADER_INFINITY_0 EMI : CNT : 0002 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00039000 [ 228,00 KB ] DRAM: 0x180000000 [ 6,00 GB ] EMMC: 150100335636434D42027E346A9656DB EMMC: VEN : SAMSUNG | OEM : 01 | DEV : 3V6CMB EMMC: BOOT1 : 0x00400000 [ 4,00 MB ] BOOT2 : 0x00400000 [ 4,00 MB ] RPMB : 0x01000000 [ 16,00 MB ] USER : 0x1D1EC00000 [ 116,48 GB ] CHIP : MT6771 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 55694BFFCF8338586C50E2D266F28174 DA : USB : HIGH-SPEED Boot done! Patch Level : PPR1.180610.011 Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2019-11-05 Product Manfct : OPPO Build Time : 12.11.2019 Product Brand : OPPO Product Model : PCAM10 Product Info : PCAM10 Product Name : PCAM10 Product Device : OP46F1 SW OTA Version : PCAM10_11.A.16_0160_201911122158 Display ID : PCAM10_11_A.16 Kernel Info : 4.4.146 USERDATA : FILESYSTEM : EXT4 with FBE ( File-Base Encryption ) STORAGE : LifeStatus : eMMC : OK! Done! Elapsed: 00:00:26 |
The Following 3 Users Say Thank You to nori2007 For This Useful Post: |
01-28-2021, 11:11 | #454 (permalink) |
No Life Poster Join Date: Dec 2009 Location: pilapil marangle
Member: 1190283 Status: Offline Thanks Meter: 67 | realme c2 password/ what is the error? Operation : Reset Settings/Format FS [ v2.18 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM3) MODE : BOOTROM PORT : 3 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN RAPHAEL BROM : MEID : 773F55B988E5933784A56F556EFD200C BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2044 | Manual : Disabled BROM : SOCID : CD109B189AFD9E343867AAEB3D886747C57CBFB44F6A91BAAF E394AFE4940787 BROM : SLA : Local Auth BROM : Selected Auth/Cert not accepted by device! >>> Check previous message for more info! Reconnect Power/Cable! |
01-28-2021, 11:47 | #455 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
01-28-2021, 11:49 | #456 (permalink) | |
01-28-2021, 16:03 | #457 (permalink) |
Freak Poster Join Date: Nov 2005
Member: 201238 Status: Offline Thanks Meter: 24 | OPPO CPH1823 F9...ALWAYS ERROR.. IS THIS MODEL SUPORTTED.. Card found : ECFF56E3 , v0147 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.18 Load IDBase v125162 Ok! Operation : HW Report [ v2.18 ] HWreport : Mode : eMMC 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM16) MODE : PRELOADER PORT PORT : 16 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6771 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Sylvia TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT MODE : 0_base : BASE_v2044 | Manual : Disabled BROM : SOCID : D9667CCE00837E0BC53EB520AF665B9130817DAF94963E751F 5FD92983D6A1A9 AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6771 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : 0x00007024 : DA SEND ERROR! ERROR : SECURE BOOT : SELECTED DA NOT SUPPORTED IN CURRENT DEVICE STATE! INFO : PRELOADER Level : CORRECT DA required : PL/PL_CRYPTO/SWSEC Info : LEGACY : HW reporting feature unavailable for current device! Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Done! Elapsed: 00:00:12 |
01-28-2021, 16:45 | #458 (permalink) | |
01-28-2021, 16:47 | #459 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Algeria
Member: 574410 Status: Offline Thanks Meter: 93 | is reno 2F supported MT6771 PTFN : MediaTek USB Port (COM93) MODE : BOOTROM PORT : 93 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6771 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Sylvia TYPE : MODERN RAPHAEL BROM : MEID : 7FEE66FC1208C993D72BF02714AB1F50 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2044 | Manual : Enabled BROM : SOCID : 762D23CDCF8395B8B52A88FAFC11CF88FBCBEBFE9F99BED79C 19AF8AD3780892 BROM : LOG : F0: 102B 0000 F3: 1001 0000 [0200] F3: 1001 0000 F7: 0000 0000 V0: 0000 0000 [0001] AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6771 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : 0x00007017 : DA SEND ERROR! ERROR : SECURE BOOT : SLA REQUIRED IN BROM MODE! INFO : BROM Level : CERT/AUTH required! Try boot device in PRELOADER mode with select PL/PL_CRYPTO/SWSEC type! Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! |
01-28-2021, 16:54 | #460 (permalink) | |
01-30-2021, 12:51 | #465 (permalink) |
Product Supporter Join Date: Dec 2016
Member: 2665389 Status: Offline Thanks Meter: 2,342 | Clarifications: - Preloader Port protocol: The phone is completely turned off and we do not press any key that is to say neither vol + nor vol- or both at the same time and we connect with the usb cable. -Brom Port protocol: The phone is completely off and we press vol +, vol- or both keys at the same time depending on the brand and model of the phone and connect with the usb cable, in some phones we have to force boot with test point. BR |
