Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | [ Easy-JTAG ] | Direct Unlock Source | Search | Today's Posts | Mark Forums Read |
![]() | #481 (permalink) |
Junior Member ![]() Join Date: May 2015 Location: Kwekwe Zimbabwe
Member: 2401507 Status: Offline Thanks Meter: 1 | xiaomi 6a failed boot tried chane emi a lot times but still giving this error Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM8) MODE : BOOTROM PORT : 8 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN RAPHAEL BROM : MEID : 1F958D21EE6AF041B2690C59F6D332F2 BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2028 | Manual : Disabled BROM : SOCID : 68BE79D358102CF8C7ED758BC4C26A773189E76F64FFCD181C 59A95446FEFDA1 BROM : SLA : Local Auth BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! DA : EMI : Failed to get EMI info from selected source! Error : Fail to init protocol! >>> Internal EMI : Select other EMI number! External Preloader - make sure it correct for connected device! Reconnect Power/Cable! Operation : Identify [ v2.17 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM8) MODE : BOOTROM PORT : 8 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN RAPHAEL BROM : MEID : 1F958D21EE6AF041B2690C59F6D332F2 BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2028 | Manual : Disabled BROM : SOCID : 68BE79D358102CF8C7ED758BC4C26A773189E76F64FFCD181C 59A95446FEFDA1 BROM : SLA : Local Auth BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! DA : EMI : Failed to get EMI info from selected source! Error : Fail to init protocol! >>> Internal EMI : Select other EMI number! External Preloader - make sure it correct for connected device! Reconnect Power/Cable! |
![]() | #487 (permalink) |
Product Supporter ![]() ![]() ![]() Join Date: Jun 2009
Member: 1043909 Status: Offline Thanks Meter: 59,601 | New version CM2MT2 v2.11 is here https://forum.gsmhosting.com/vbb/f29...t81xx-2944434/ |
![]() | #488 (permalink) |
Crazy Poster ![]() ![]() ![]() Join Date: May 2009
Member: 1035611 Status: Offline Thanks Meter: 2 | can you help me nokia c5 endi PTFN : MediaTek USB Port (COM44) MODE : BOOTROM PORT : 44 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN RAPHAEL BROM : MEID : 46CEB4A51124C096BE797EF3CA5EF8BB BROM : SecLevel : 0x000000E3 BROM : SecMode : SBC+SLA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2044 | Manual : Enabled BROM : SOCID : C73DF0951FFCBA5E96C4C47FC19BAAC72B220D81EE6004701B CC3D36468EB110 AGENT : Look for suitable BootChain in DA ... AGENT : ANT-0-0020-0000-MTK_AllInOne_DA.bin AGENT : Selected AGENT doesn't have required configuration! >>> Check and select CORRECT SETTINGS for your device! Reconnect Power/Cable! WHAT configuration for hard reset? thanks |
![]() | #490 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Sep 2004 Location: guada lajara Age: 48
Member: 80599 Status: Offline Sonork: 1621236 Thanks Meter: 270 | nokia c5 Hi. we need da files for nokia c5 regards ![]() nokia c5 endi PTFN : MediaTek USB Port (COM44) MODE : BOOTROM PORT : 44 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN RAPHAEL BROM : MEID : 46CEB4A51124C096BE797EF3CA5EF8BB BROM : SecLevel : 0x000000E3 BROM : SecMode : SBC+SLA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2044 | Manual : Enabled BROM : SOCID : C73DF0951FFCBA5E96C4C47FC19BAAC72B220D81EE6004701B CC3D36468EB110 AGENT : Look for suitable BootChain in DA ... AGENT : ANT-0-0020-0000-MTK_AllInOne_DA.bin AGENT : Selected AGENT doesn't have required configuration! >>> Check and select CORRECT SETTINGS for your device! Reconnect Power/Cable! |
![]() | #491 (permalink) |
Major Poster ![]() ![]() Join Date: Jan 2017
Member: 2672863 Status: Offline Thanks Meter: 8 | Use lastest version on cm2 mtk 2 Brother use latest version of cm2mtk2 Select model from list and flash eng frimware if problems not sloved with stock one Leaving link to eng frimware if anyone is interested https://sanihow-root.********.com.co...-frimware.html Last edited by arslan0072; 04-03-2021 at 13:10. |
![]() | #493 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 59,601 | |
