Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | [ Easy-JTAG ] | Direct Unlock Source | Search | Today's Posts | Mark Forums Read |
![]() | #46 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jun 2014 Location: India
Member: 2211790 Status: Offline Thanks Meter: 5,031 | once udpate your database then service tab do HW Report after that repelat flashing may work |
The Following User Says Thank You to kamal_singla For This Useful Post: |
![]() | #47 (permalink) |
Member: 2211790 Status: Offline Thanks Meter: 5,031 | @Arslanmayo once udpate your database then service tab do HW Report after that repeat flashing may work |
![]() | #49 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2011
Member: 1613469 Status: Offline Thanks Meter: 192 | Operation : HW Report [ v2.17 ] HWreport : Mode : eMMC 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM21) MODE : BOOTROM PORT : 21 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN RAPHAEL BROM : MEID : 73DC67E3FC75E71D136CB776559BCD88 BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : Xiaomi : 6A | Manual : Disabled BROM : SOCID : 5D23C2B462D700C1DB0160B642BF65757A4C87EEA99C159C3D A3A19A46699470 BROM : SLA : Local Auth BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : PRELOADER_INFINITY_0 EMI : CNT : 0002 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00038000 [ 224,00 KB ] DRAM: 0x80000000 [ 2,00 GB ] EMMC: 90014A484147346132A53AB0C65DB58F EMMC: VEN : HYNIX | OEM : 4A01 | DEV : HAG4a2 EMMC: BOOT1 : 0x00400000 [ 4,00 MB ] BOOT2 : 0x00400000 [ 4,00 MB ] RPMB : 0x00400000 [ 4,00 MB ] USER : 0x3AB400000 [ 14,68 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : F6226CA323458FE42811B409BC224FC DA : USB : HIGH-SPEED Boot done! Memory Info : CID : 90014A484147346132A53AB0C65DB58F MEM : VEN : HYNIX | OEM : 4A01 | DEV : HAG4a2 DAT : Size: 15028 MB, Max.Speed: 52000 kHz, blklen(512), nblks(30777344), ro(0) EXT_CSD Info : EXT_CSD rev. : v1.8 ( MMC v5.1 ) CSD struct rev. : v1.2 Supported command sets : 1h HPI features : 1h BG operations support : 1h BG operations status : 0h Correct prg. sectors : 0h 1st init time after part. : 1000 ms Min. write perf.(DDR,52MH,8b): 78h Min. read perf. (DDR,52MH,8b): 8ch TRIM timeout: 0 ms Secure feature support: 55h Secure erase timeout : 30000 ms Secure trim timeout : 6000 ms Access size : 3072 bytes HC erase unit size : 512 kbytes HC erase timeout : 600 ms HC write prot grp size: 4096 kbytes HC erase grp def. : 0h Reliable write sect count: 1h Sleep current (VCC) : 7h Sleep current (VCCQ): 7h Sleep/awake timeout : 26214400 ns Sector count : 1d5a000h Min. WR Perf. (52MH,8b): 8ch Min. Read Perf.(52MH,8b): 8ch Min. WR Perf. (26MH,8b,52MH,4b): 46h Min. Read Perf.(26MH,8b,52MH,4b): 46h Min. WR Perf. (26MH,4b): 1eh Min. Read Perf.(26MH,4b): 1eh Power class: 0 Power class(DDR,52MH,3.6V): 11h Power class(DDR,52MH,1.9V): 0h Power class(26MH,3.6V) : 0h Power class(52MH,3.6V) : 0h Power class(26MH,1.9V) : 0h Power class(52MH,1.9V) : 0h Part. switch timing : 1h Out-of-INTR busy timing: 5h Card type : 57h Command set : 0h Command set rev.: 0h HS timing : 0h Bus width : 0h Erase memory content : 0h Partition config : 48h Boot partition size : 4096 kbytes Boot information : 7h Boot config protection: 0h Boot bus width : 2h Boot area write prot : 0h User area write prot : 0h FW configuration : 0h RPMB size : 4096 kbytes Write rel. setting : 1fh Write rel. parameter: 15h Start background ops : 0h Enable background ops: 2h H/W reset function : 1h HPI management : 0h Max. enhanced area size : 756h (7692288 kbytes) Part. support : 7h Part. attribute: 0h Part. setting : 0h General purpose 1 size : 0h (0 kbytes) General purpose 2 size : 0h (0 kbytes) General purpose 3 size : 0h (0 kbytes) General purpose 4 size : 0h (0 kbytes) Enh. user area size : 0h (0 kbytes) Enh. user area start: 0h Bad block mgmt mode: 0h Overall status : MLC status : 0% - 10% used SLC status : 0% - 10% used RPMB : RPMB KEY EXISTS! [State : NOT CLEAN : UNUSABLE] Done! Elapsed: 00:00:29 |
The Following 3 Users Say Thank You to washipolar For This Useful Post: |
![]() | #53 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2013 Location: gsmhosting Age: 27
Member: 1876736 Status: Offline Thanks Meter: 734 | Code: Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.17 Failed to prepare enivorment! Load IDBase v1118158 Ok! Update configuration ... Update Ok! Load IDBase v1118158 Ok! Operation : HW Report [ v2.17 ] HWreport : Mode : UFS 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM50) MODE : BOOTROM PORT : 50 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6785 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Krug TYPE : MODERN RAPHAEL BROM : MEID : 1FB8A78A8588C16045047908D997E311 BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2028 | Manual : Disabled BROM : SOCID : C5482772FE6A2F90E2D772EC083342C3B03B5BD3AAD378BA6DD60E341789FF47 BROM : SLA : Local Auth BROM : Selected Auth/Cert not accepted by device! >>> Check previous message for more info! Reconnect Power/Cable! Info : LEGACY : HW reporting feature unavailable for current device! Done! Elapsed: 00:00:12 how can i fix this ? |
![]() | #54 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Mar 2011
Member: 1535920 Status: Offline Thanks Meter: 31 | Thank you team for this update. Thank you Jaydi sir and every member of the team. You have been giving us unique solutions all these years. This is amazing Sent from my iPhone using Tapatalk |
![]() | #56 (permalink) |
Member: 1613469 Status: Offline Thanks Meter: 192 | Operation : Identify [ v2.17 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM21) MODE : BOOTROM PORT : 21 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN RAPHAEL BROM : MEID : 73DC67E3FC75E71D136CB776559BCD88 BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : Xiaomi : 6A | Manual : Disabled BROM : SOCID : 5D23C2B462D700C1DB0160B642BF65757A4C87EEA99C159C3D A3A19A46699470 BROM : SLA : Local Auth BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : PRELOADER_INFINITY_0 EMI : CNT : 0002 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00038000 [ 224,00 KB ] DRAM: 0x80000000 [ 2,00 GB ] EMMC: 90014A484147346132A53AB0C65DB58F EMMC: VEN : HYNIX | OEM : 4A01 | DEV : HAG4a2 EMMC: BOOT1 : 0x00400000 [ 4,00 MB ] BOOT2 : 0x00400000 [ 4,00 MB ] RPMB : 0x00400000 [ 4,00 MB ] USER : 0x3AB400000 [ 14,68 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : F6226CA323458FE42811B409BC224FC DA : USB : HIGH-SPEED Boot done! Patch Level : PPR1.180610.011 Display ID : SW_S98506AE1_V009_M13_XM_C3C_USR Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2020-05-01 Build Time : 08.05.2020 Product Model : Redmi 6A Product Brand : xiaomi Product Name : cactus Product Device : cactus Product Info : cactus Product Manfct : Xiaomi Product Board : cactus Board Platform : mt6765 USERDATA : FILESYSTEM : EXT4 with FDE ( Full Disk Encryption **) STORAGE : LifeStatus : eMMC : OK! PRELOADER : DEVICE : DEV : MT6765 NME : preloader_cactus.bin CNT : 0007 EMI : [00] : eMMC : DDR3 : ID : 150100514536334D42 : VEN : SAMSUNG | DEV : QE63MB : RAM : [ 2,00 GB ] EMI : [01] : eMMC : DDR3 : ID : 90014A484147346132 : VEN : HYNIX | DEV : HAG4a2 : RAM : [ 2,00 GB ] EMI : [02] : eMMC : DDR3 : ID : 13014E53304A394137 : VEN : MICRON | DEV : S0J9A7 : RAM : [ 2,00 GB ] EMI : [03] : eMMC : DDR3 : ID : 150100514436334D42 : VEN : SAMSUNG | DEV : QD63MB : RAM : [ 2,00 GB ] EMI : [04] : eMMC : DDR3 : ID : 150100474436424D42 : VEN : SAMSUNG | DEV : GD6BMB : RAM : [ 3,00 GB ] EMI : [05] : eMMC : DDR3 : ID : 13014E53304A394237 : VEN : MICRON | DEV : S0J9B7 : RAM : [ 3,00 GB ] EMI : [06] : eMMC : DDR3 : ID : 90014A484247346132 : VEN : HYNIX | DEV : HBG4a2 : RAM : [ 3,00 GB ] Done! Elapsed: 00:00:50 |
![]() | #57 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2007
Member: 462970 Status: Offline Thanks Meter: 20,309 | Code: [Failed to prepare enivorment! How to fix that : 1. Install C:\InfinityBox\tools\boot-helper-a.exe Reboot PC 2. Add CM2MT2 folder to your AV exclude list. 3. Connect device and try make sSLA enabled phone. We tested on win7, win10 x64 system and found that working even on clean system. |
The Following 8 Users Say Thank You to JayDi For This Useful Post: |
![]() | #58 (permalink) |
Member: 1613469 Status: Offline Thanks Meter: 192 | ![]() Operation : Identify [ v2.17 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM21) MODE : BOOTROM PORT : 21 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN RAPHAEL BROM : MEID : 73DC67E3FC75E71D136CB776559BCD88 BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : Xiaomi : 6A | Manual : Disabled BROM : SOCID : 5D23C2B462D700C1DB0160B642BF65757A4C87EEA99C159C3D A3A19A46699470 BROM : SLA : Local Auth BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : PRELOADER_INFINITY_0 EMI : CNT : 0002 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00038000 [ 224,00 KB ] DRAM: 0x80000000 [ 2,00 GB ] EMMC: 90014A484147346132A53AB0C65DB58F EMMC: VEN : HYNIX | OEM : 4A01 | DEV : HAG4a2 EMMC: BOOT1 : 0x00400000 [ 4,00 MB ] BOOT2 : 0x00400000 [ 4,00 MB ] RPMB : 0x00400000 [ 4,00 MB ] USER : 0x3AB400000 [ 14,68 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : F6226CA323458FE42811B409BC224FC DA : USB : HIGH-SPEED Boot done! Patch Level : PPR1.180610.011 Display ID : SW_S98506AE1_V009_M13_XM_C3C_USR Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2020-05-01 Build Time : 08.05.2020 Product Model : Redmi 6A Product Brand : xiaomi Product Name : cactus Product Device : cactus Product Info : cactus Product Manfct : Xiaomi Product Board : cactus Board Platform : mt6765 USERDATA : FILESYSTEM : EXT4 with FDE ( Full Disk Encryption **) STORAGE : LifeStatus : eMMC : OK! PRELOADER : DEVICE : DEV : MT6765 NME : preloader_cactus.bin CNT : 0007 EMI : [00] : eMMC : DDR3 : ID : 150100514536334D42 : VEN : SAMSUNG | DEV : QE63MB : RAM : [ 2,00 GB ] EMI : [01] : eMMC : DDR3 : ID : 90014A484147346132 : VEN : HYNIX | DEV : HAG4a2 : RAM : [ 2,00 GB ] EMI : [02] : eMMC : DDR3 : ID : 13014E53304A394137 : VEN : MICRON | DEV : S0J9A7 : RAM : [ 2,00 GB ] EMI : [03] : eMMC : DDR3 : ID : 150100514436334D42 : VEN : SAMSUNG | DEV : QD63MB : RAM : [ 2,00 GB ] EMI : [04] : eMMC : DDR3 : ID : 150100474436424D42 : VEN : SAMSUNG | DEV : GD6BMB : RAM : [ 3,00 GB ] EMI : [05] : eMMC : DDR3 : ID : 13014E53304A394237 : VEN : MICRON | DEV : S0J9B7 : RAM : [ 3,00 GB ] EMI : [06] : eMMC : DDR3 : ID : 90014A484247346132 : VEN : HYNIX | DEV : HBG4a2 : RAM : [ 3,00 GB ] Done! Elapsed: 00:00:50 |
The Following 2 Users Say Thank You to washipolar For This Useful Post: |
![]() | #59 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,309 | Why HWreport matter? It allow you select CORRECT device setting and you NOT NEED select any PRELOADER or whatever else. We made that to make life easier! Just use it once, then can proceed whatecer want. |
The Following 16 Users Say Thank You to JayDi For This Useful Post: |
