01-24-2021, 11:03 | #76 (permalink) | |
Junior Member Join Date: May 2018
Member: 2837941 Status: Offline Thanks Meter: 18 | please screenshot tutorial give me Quote:
2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM19) MODE : BOOTROM PORT : 19 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN RAPHAEL BROM : MEID : ADC43AC6790B0CBCEE107D1754030EF3 BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : Xiaomi : 6A | Manual : Disabled BROM : SOCID : 2C592C651AF02DE46F111B1242131158FA48E9AED85CF0DAB0 64B4B88E7A062F BROM : SLA : Local Auth BROM : Selected Auth/Cert not accepted by device! >>> Check previous message for more info! Reconnect Power/Cable! | |
01-24-2021, 11:07 | #77 (permalink) | |
No Life Poster Join Date: Jan 2013 Location: gsmhosting Age: 29
Member: 1876736 Status: Offline Thanks Meter: 735 | Quote:
Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.17 Load IDBase v1118158 Ok! Update configuration ... Update Ok! Load IDBase v1118158 Ok! Operation : HW Report [ v2.17 ] HWreport : Mode : UFS 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM7) MODE : BOOTROM PORT : 7 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6785 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Krug TYPE : MODERN RAPHAEL BROM : MEID : 1FB8A78A8588C16045047908D997E311 BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2028 | Manual : Disabled BROM : SOCID : C5482772FE6A2F90E2D772EC083342C3B03B5BD3AAD378BA6D D60E341789FF47 BROM : SLA : Local Auth BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6785 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : PRELOADER_INFINITY_0 EMI : CNT : 0001 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00080000 [ 512.00 KB ] DRAM: 0x180000000 [ 6.00 GB ] UFS: AD014839485131364145434D4D444152 UFS: VEN : 0x01AD VID : H9HQ16AECMMDAR IFW : A107 LU0 : 0x00400000 [ 4.00 MB ] LU1 : 0x00400000 [ 4.00 MB ] LU2 : 0x1DCB000000 [ 119.17 GB ] FSN : 158c46531324000000000000 REG : 0x101010000 CHIP : MT6785 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : B4CDE74EB39309D9D125D9EC2DC77097 DA : USB : HIGH-SPEED Boot done! Memory Info : CID : H9HQ16AECMMDAR EXT_CSD Info : [UFS] Device Desc: [UFS] String Desc: Serial Number INDEX 3, LENGTH 12 [UFS] Serial Number: 158c46531324000000000000 [UFS] life cycle check, pre_eol_info=1, life_time_est_a=1, life_time_est_b=1 [UFS] vendor id : 0x1ad [UFS] ufs id : H9HQ16AECMMDAR [UFS] ufs fwver: A107 [UFS] dev_quirk = 0x10000000 [UFS] Custom force provison=0, TW size=-1GB, TW no red=1, HPB size=-1GB [UFS] info: number of active LU: 3, check OK. [UFS] info: number of Boot LU: 2, check OK. [UFS] info: LU Configuration Check OK. Bootable UFS [UFS] info: Boot LU Configuration Check OK. Active Boot LU: LU0 [UFS] info: HS-G3-2 Overall status : MLC status : 0% - 10% used SLC status : 0% - 10% used EOL status : Normal ( Less than 80% reserved blocks used ) RPMB : RPMB KEY NOT set! [State : CLEAN : USABLE] Done! Elapsed: 00:01:05 | |
The Following 3 Users Say Thank You to sky73 For This Useful Post: |
01-24-2021, 11:14 | #78 (permalink) | |
Member: 2837941 Status: Offline Thanks Meter: 18 | Failed to prepare enivorment how to update Quote:
Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.17 Failed to prepare enivorment! Load IDBase v729152 Ok! | |
01-24-2021, 11:16 | #79 (permalink) |
Junior Member Join Date: Mar 2016 Location: Faisalabad
Member: 2546130 Status: Offline Thanks Meter: 6 | Solution Please I Used Windows 10 32Bit I Tried All Way You Mention Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.17 Failed to prepare enivorment! Load IDBase v729152 Ok! Update configuration ... Update Ok! Load IDBase v1118158 Ok! |
01-24-2021, 11:31 | #81 (permalink) |
Freak Poster Join Date: Jan 2016 Location: South Africa
Member: 2518179 Status: Offline Thanks Meter: 39 | after updating smartcard firmware to 147.02 its giving this error with all modules (dongle misconfiguration) |
The Following User Says Thank You to gabbar7040 For This Useful Post: |
