01-26-2021, 11:32 | #1 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Infinity Chinese Miracle-2 MTK/MediaTek v2.18 - Standalone MTK auth ON - new features As ordinary, unique functions and methods released CM2MT2 v2.17 with info about MT67xx auth and test reports are HERE Core Changed: Protocol updated ( Raphael/Legacy ) Changed: Loader v2044 supported and tested ( v2028 was unstable with MT6765 ) NewChip: MediaTek AC8227 (Car HeadUnits SoC) supported NewChip: MediaTek AC8257 (Car HeadUnits SoC) supported Flasher Changed: Core updated for RAPHAEL line Service Changed: META core updated Changed: HW Report ( RAPHAEL - only ) - LifeStatus identify revised, in some cases it may shown wrong info. Strongly recommend use latest version for HWcheck ! !* Feature also allow automatic select and store for further use BOOTROM connection settings for RAPHAEL devices (DRAM init) !* HWreport not require complete boot in case of semi-dead devices, it is useful for HWdebug !* HWreport result may vary in diffirent models and agents even on the same SoC ! Firmware Reader Changed: Some modern brand-specific changes (Oppo, Realme) Changed: New types supported Changed: Internal Database updated Model DB Changed: New agents included for Tecno, Infinix ( with different SoC lines ) Changed: New DA base v2044 included Other Changed: GUI settings now stored and load select style, settings and other at next run Changed: Environment compatibility issue with 32 bit OS has been fixed Changed: Many different changes and fixes New Drivers_MTK_v2.0.1.1.7z are here Download link #1 Download link #2 Download link #3 How to upload files to support Infinity-Box 16 years updates and support as nobody else since year 2005 Last edited by YellowBoss; 02-04-2021 at 12:47. |
The Following 47 Users Say Thank You to YellowBoss For This Useful Post: |
01-26-2021, 12:20 | #3 (permalink) | |
Insane Poster Join Date: Feb 2008
Member: 713735 Status: Offline Thanks Meter: 10 | Quote:
01-26-2021, 12:22 | #4 (permalink) |
No Life Poster Join Date: Jan 2015 Location: Narsingdi, Dhaka, Bangladesh Age: 28
Member: 2325851 Status: Offline Sonork: 100.1680491 Thanks Meter: 2,363 | Oppo A1k cph1923 , Realme C2 RMX1941 Factory Reset Pattern Lock, Password Reset CM2 Oppo A1k cph1923 , Realme C2 RMX1941 Factory Reset Pattern Lock, Password Reset CM2 thanks infinity team |
The Following 16 Users Say Thank You to pintu_das For This Useful Post: |
01-26-2021, 12:32 | #6 (permalink) | |
Product Supporter Join Date: Jun 2014 Location: India
Member: 2211790 Status: Offline Thanks Meter: 5,118 | Quote: btw, this CPU atm not supported but will soon | |
The Following 2 Users Say Thank You to kamal_singla For This Useful Post: |
01-26-2021, 12:42 | #8 (permalink) |
No Life Poster Join Date: Oct 2005 Location: georgia tbilisi
Member: 194939 Status: Offline Sonork: 100.168.25.6 Thanks Meter: 623 | mi play flash phone is stuck un mi logo after update all people knows this problemm for mi play now i want to flash it what im doing wrong? help please tryed all DA type |
The Following User Says Thank You to laduka For This Useful Post: |
01-26-2021, 12:55 | #10 (permalink) |
No Life Poster Join Date: Feb 2006 Location: In my LAB
Member: 231728 Status: Offline Thanks Meter: 2,102 | |
01-26-2021, 12:57 | #11 (permalink) |
Freak Poster Join Date: Oct 2011 Location: Dhaka
Member: 1676988 Status: Offline Sonork: 12345 Thanks Meter: 28 | Redmi 6 gives this error when i do HW Report phone problem is mi account plz solve this and stuck on DA Agent started when i do Reset setting/formet |
01-26-2021, 13:01 | #13 (permalink) | |
Member: 194939 Status: Offline Sonork: 100.168.25.6 Thanks Meter: 623 | no result mi play Quote:
Operation : HW Report [ v2.18 ] HWreport : Mode : eMMC 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MTK USB Port (COM38) MODE : BOOTROM PORT : 38 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN RAPHAEL BROM : MEID : 02FE06E436676F2D4253CC52084FE247 BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : Xiaomi : 6A_MIPlay | Manual : Disabled BROM : SOCID : D45844C3BA732EA36818E6F8F8D85A085770A7D41D15247C06 34D32BB108FF71 BROM : SLA : Local Auth BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SETUP HW PARAMS FAILED! PROTO_VER is OLD? Error : Fail to init protocol! >>> Check and select CORRECT SETTINGS for your device! Reconnect Power/Cable! Done! Elapsed: 00:00:21 Operation : Identify [ v2.18 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MTK USB Port (COM38) MODE : BOOTROM PORT : 38 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN RAPHAEL BROM : MEID : 02FE06E436676F2D4253CC52084FE247 BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : Xiaomi : 6A_MIPlay | Manual : Disabled BROM : SOCID : D45844C3BA732EA36818E6F8F8D85A085770A7D41D15247C06 34D32BB108FF71 BROM : SLA : Local Auth BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SETUP HW PARAMS FAILED! PROTO_VER is OLD? Error : Fail to init protocol! >>> Check and select CORRECT SETTINGS for your device! Reconnect Power/Cable! with ssla with forced brom always this | |
01-26-2021, 13:05 | #14 (permalink) | |
Member: 231728 Status: Offline Thanks Meter: 2,102 | Quote:
The Following User Says Thank You to rebainoor For This Useful Post: |
01-26-2021, 13:14 | #15 (permalink) |
Member: 1676988 Status: Offline Sonork: 12345 Thanks Meter: 28 | after change usb cable hw report ok but identify or format not success showing this error how to reset mi account for redmi 6 by this tool? |
The Following User Says Thank You to alamin2011 For This Useful Post: |
