Infinity Chinese Miracle-2 MTK/MediaTek v2.18 - Standalone MTK auth ON - new features Infinity Chinese Miracle-2 MTK/MediaTek v2.18 - Standalone MTK auth ON - new models and features As ordinary, unique functions and methods released CM2MT2 v2.17 with info about MT67xx auth and test reports are HERE Core Changed: Protocol updated ( Raphael/Legacy ) Changed: Loader v2044 supported and tested ( v2028 was unstable with MT6765 ) NewChip: MediaTek AC8227 (Car HeadUnits SoC) supported NewChip: MediaTek AC8257 (Car HeadUnits SoC) supported Flasher Changed: Core updated for RAPHAEL line Service Changed: META core updated Changed: HW Report ( RAPHAEL - only ) - LifeStatus identify revised, in some cases it may shown wrong info. Strongly recommend use latest version for HWcheck ! !* Feature also allow automatic select and store for further use BOOTROM connection settings for RAPHAEL devices (DRAM init) !* HWreport not require complete boot in case of semi-dead devices, it is useful for HWdebug !* HWreport result may vary in diffirent models and agents even on the same SoC ! Firmware Reader Changed: Some modern brand-specific changes (Oppo, Realme) Changed: New types supported Changed: Internal Database updated Model DB Changed: New agents included for Tecno, Infinix ( with different SoC lines ) Changed: New DA base v2044 included Other Changed: GUI settings now stored and load select style, settings and other at next run Changed: Environment compatibility issue with 32 bit OS has been fixed Changed: Many different changes and fixes New Drivers_MTK_v2.0.1.1.7z are here Download link #1 Download link #2 Download link #3 How to upload files to support Infinity-Box 16 years updates and support as nobody else since year 2005 https://cdn.infinity-box.com/ico/tg48.png https://cdn.infinity-box.com/ico/yt48.png https://cdn.infinity-box.com/ico/fb48.png https://cdn.infinity-box.com/ico/fb48.png https://cdn.infinity-box.com/ico/tw48.png https://cdn.infinity-box.com/ico/discord48.png https://cdn.infinity-box.com/ico/ios2-48.png https://cdn.infinity-box.com/ico/j48.png https://cdn.infinity-box.com/ico/inst48.png https://cdn.infinity-box.com/ico/file-folder_48t.png |
Oppo A1k cph1923 , Realme C2 RMX1941 Factory Reset Pattern Lock, Password Reset CM2 Oppo A1k cph1923 , Realme C2 RMX1941 Factory Reset Pattern Lock, Password Reset CM2 thanks infinity team:):) |
btw, this CPU atm not supported but will soon |
mi play flash 1 Attachment(s) phone is stuck un mi logo after update all people knows this problemm for mi play now i want to flash it what im doing wrong? help please tryed all DA type |
first do HW Report (Service tab >> HW Report) after that flash your handset |
Redmi 6 gives this error when i do HW Report phone problem is mi account plz solve this https://i.ibb.co/H7bYKmh/Capture.png and stuck on DA Agent started when i do Reset setting/formet https://i.ibb.co/3zVXXwB/Capte.png |
dear kamal singla sir upload oppo A1k and A12 Factory firmware.witch can be flashed by cm2mt2. thanks and best wishes for you |
no result mi play Quote:
Operation : HW Report [ v2.18 ] HWreport : Mode : eMMC 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MTK USB Port (COM38) MODE : BOOTROM PORT : 38 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN RAPHAEL BROM : MEID : 02FE06E436676F2D4253CC52084FE247 BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : Xiaomi : 6A_MIPlay | Manual : Disabled BROM : SOCID : D45844C3BA732EA36818E6F8F8D85A085770A7D41D15247C06 34D32BB108FF71 BROM : SLA : Local Auth BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SETUP HW PARAMS FAILED! PROTO_VER is OLD? Error : Fail to init protocol! >>> Check and select CORRECT SETTINGS for your device! Reconnect Power/Cable! Done! Elapsed: 00:00:21 Operation : Identify [ v2.18 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MTK USB Port (COM38) MODE : BOOTROM PORT : 38 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN RAPHAEL BROM : MEID : 02FE06E436676F2D4253CC52084FE247 BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : Xiaomi : 6A_MIPlay | Manual : Disabled BROM : SOCID : D45844C3BA732EA36818E6F8F8D85A085770A7D41D15247C06 34D32BB108FF71 BROM : SLA : Local Auth BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SETUP HW PARAMS FAILED! PROTO_VER is OLD? Error : Fail to init protocol! >>> Check and select CORRECT SETTINGS for your device! Reconnect Power/Cable! with ssla with forced brom always this |
after change usb cable hw report ok but identify or format not success showing this error https://i.ibb.co/7bq49FJ/Captur.png how to reset mi account for redmi 6 by this tool? |
