01-28-2021, 16:12 | #31 (permalink) |
No Life Poster Join Date: Dec 2004 Location: Uganda Age: 45
Member: 96478 Status: Offline Sonork: 100.1674604 Thanks Meter: 1,420 | Code: Operation : Identify [ v2.19 ] Mode : META 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM17) MODE : PRELOADER PORT PORT : 17 Waiting BOOT ack ... PRELOADER : ACK confirmed! INIT : META confirmed! Boot done! AP_CHIP : MT6580 AP_SWTM : Mon Jun 22 14:31:27 CST 2020 AP_SWVR : alps-mp-p0.mp2-V3.163 MD_CHIP : MT6580B, E00 MD_SWTM : 2000.00.00 MD_DSPV : 1.0 MD_DSPP : MOLY.WR8.W1449.MD.WG.MP.V282.3 MD_SWVR : CHIPC_P0MP2_TB8321P2_BSP_HSPA_HW MD_HWVR : Unknown Patch Level : PPR1.180610.011 Display ID : UG_AT_ZTE_V971LMV1.0.0 Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2020-05-05 Build Time : 22.06.2020 Product Model : ZTE_V971LM Product Brand : ZTE Product Name : ZTE_V971LM Product Device : ZTE_V971LM Product Manfct : ZTE Product Info : tb8321p2_bsp_2g IMEI[1] : 86X09XXXXXXXXX IMEI[2] : 112222223333324 NVRAM : SEC NORMAL [ No extra security ] Done! Elapsed: 00:01:21 Code: Operation : Identify [ v2.19 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM17) MODE : PRELOADER PORT PORT : 17 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x01 BROM : PRELOADER PORT MODE : 0_base : BASE_v2044 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6580 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : 0x00002001 : DA SEND ERROR! ERROR : SECURE BOOT : MISMATCH BOOT SIGNATURE! INFO : PRELOADER Level : CORRECT DA required : PL/PL_CRYPTO/SWSEC Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! |
The Following User Says Thank You to Kirumira For This Useful Post: |
01-28-2021, 16:35 | #32 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Algérie Age: 43
Member: 570252 Status: Offline Thanks Meter: 207 | F11pro cph1969 Code: Operation : Write Flash [ v2.19 ] Repartition : Enabled Flash Verify : Disabled Reg.Pre-Erase : Enabled Verify HW/SW : Enabled SData Backup : Disabled Safe UserData : Disabled Flash Format : Disabled Files :24 [FL] : Set : preloader_oppo6771_18531.bin [FL] : Set : recovery.img [FL] : Set : opporeserve2.img [FL] : Set : md1img.img [FL] : Set : spmfw.img [FL] : Set : scp.img [FL] : Set : scp.img [FL] : Set : sspm.img [FL] : Set : sspm.img [FL] : Set : cam_vpu1.img [FL] : Set : cam_vpu2.img [FL] : Set : cam_vpu3.img [FL] : Set : lk.img [FL] : Set : lk.img [FL] : Set : boot.img [FL] : Set : logo.bin [FL] : Set : dtbo.img [FL] : Set : tee.img [FL] : Set : tee.img [FL] : Set : odm.img [FL] : Set : vendor.img [FL] : Set : system.img [FL] : Set : cache.img [FL] : Set : userdata.img [FL] : Total size : 0x22DE72888 [ 8,72 GB ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM25) MODE : BOOTROM PORT : 25 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6771 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Sylvia TYPE : MODERN RAPHAEL BROM : MEID : 9A767498A4949B5C4F28B4386E46C20F BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2044 | Manual : Disabled BROM : SOCID : 309D9D7A520C18944C934226EA714CF5F548284A98B91606A5B353073FBD243E BROM : SLA : Local Auth BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6771 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : MT6752 EMI : SRC : preloader_oppo6771_18531.bin EMI : CNT : 000B EMI : [00] : eMMC : LP_DDR4X : ID : 150100445636444D42 : VEN : SAMSUNG | DEV : DV6DMB : RAM : [ 4,00 GB ] EMI : [01] : eMMC : LP_DDR4X : ID : 150100335636434D42 : VEN : SAMSUNG | DEV : 3V6CMB : RAM : [ 6,00 GB ] EMI : [02] : eMMC : LP_DDR4X : ID : 150100334836434142 : VEN : SAMSUNG | DEV : 3H6CAB : RAM : [ 6,00 GB ] EMI : [03] : eMMC : LP_DDR4X : ID : 90014A68433861503E : VEN : HYNIX | DEV : hC8aP> : RAM : [ 6,00 GB ] EMI : [04] : eMMC : LP_DDR4X : ID : 13014E53304A394B39 : VEN : MICRON | DEV : S0J9K9 : RAM : [ 4,00 GB ] EMI : [05] : eMMC : LP_DDR4X : ID : 150100444836444142 : VEN : SAMSUNG | DEV : DH6DAB : RAM : [ 4,00 GB ] EMI : [06] : eMMC : LP_DDR4X : ID : 90014A68433861503E : VEN : HYNIX | DEV : hC8aP> : RAM : [ 4,00 GB ] EMI : [07] : eMMC : LP_DDR4X : ID : 13014E53304A394B38 : VEN : MICRON | DEV : S0J9K8 : RAM : [ 4,00 GB ] EMI : [08] : eMMC : LP_DDR4X : ID : 13014E53304A394D39 : VEN : MICRON | DEV : S0J9M9 : RAM : [ 6,00 GB ] EMI : [09] : eMMC : LP_DDR4X : ID : 13014E53304A394438 : VEN : MICRON | DEV : S0J9D8 : RAM : [ 4,00 GB ] EMI : [0A] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 6,00 GB ] EMI : Init EMI from PRELOADER EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00039000 [ 228,00 KB ] DRAM: 0x180000000 [ 6,00 GB ] EMMC: 90014A6844456150330349A9CA3C462F EMMC: VEN : HYNIX | OEM : 4A01 | DEV : hDEaP3 EMMC: BOOT1 : 0x00400000 [ 4,00 MB ] BOOT2 : 0x00400000 [ 4,00 MB ] RPMB : 0x01000000 [ 16,00 MB ] USER : 0x1D1F000000 [ 116,48 GB ] CHIP : MT6771 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 3778A8CCD28B9D90AA5ADF7D9DB7D30C DA : USB : HIGH-SPEED Boot done! [FL] : HW verification passed! SEC_DL : False (RAPHAEL) SEC_ID : 0x494E46494E495459424F584245535432 [FL] : Pre-Erase Erase : 0x0000000000000000 : 0x0000000004188000 Erase : 0x000000000CA88000 : 0x0000000001500000 Erase : 0x000000000FF88000 : 0x0000000006000000 Erase : 0x0000000017000000 : 0x0000000000800000 Erase : 0x000000001A800000 : 0x0000000000200000 Erase : 0x000000001AD00000 : 0x000000000C000000 Erase : 0x000000002AD00000 : 0x00000003C0B00000 [FL] : RePartition [FL] : RePartition Ok! [FL] : Flashing now ... Write : PRELOADER Update bootloader backup copy ... Update bootloader backup copy Ok! Write : RECOVERY Write : OPPORESERVE2 FAIL : SEC : IMG TYPE MISMATCH Write : MD1IMG Write : SPMFW Write : SCP1 Write : SCP2 Write : SSPM_1 Write : SSPM_2 Write : CAM_VPU1 Write : CAM_VPU2 Write : CAM_VPU3 Write : LK Write : LK2 Write : BOOT Write : LOGO Write : DTBO Write : TEE1 Write : TEE2 Write : ODM Write : VENDOR Write : SYSTEM Write : CACHE Write : USERDATA FAIL : ERROR ERR : 00x00000000 ERR : UltraFlash Failed! Error : Flashing failed! >>> Seems as something wrong with device! Check battery charge and device state! Reconnect Power/Cable! Code: FAIL : ERROR ERR : 00x00000000 ERR : UltraFlash Failed! Error : Flashing failed! >>> Seems as something wrong with device! Check battery charge and device state! Reconnect Power/Cable! |
01-28-2021, 16:43 | #33 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
It not should, because you connected in preloader port. | |
The Following 2 Users Say Thank You to JayDi For This Useful Post: |
01-28-2021, 16:43 | #34 (permalink) | |
Repeat flash. | |
The Following 3 Users Say Thank You to JayDi For This Useful Post: |
01-28-2021, 16:49 | #35 (permalink) | |
01-28-2021, 17:00 | #38 (permalink) |
Crazy Poster Join Date: May 2012 Location: tetouan Age: 34
Member: 1763949 Status: Offline Sonork: 100.1639086 Thanks Meter: 13 | PTFN : MediaTek USB Port (COM28) MODE : BOOTROM PORT : 28 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6779 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 CODE : Lafite TYPE : MODERN RAPHAEL BROM : MEID : 8E07917EF6D3F96B18D376CFEEAA8CC7 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2044 | Manual : Disabled BROM : SOCID : 16BD1226F49CAAA73DB16FDE0E0EF14A88185057EBA5917A87 3708F41A97E412 AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6779 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : 0x00007017 : DA SEND ERROR! ERROR : SECURE BOOT : SLA REQUIRED IN BROM MODE! INFO : BROM Level : CERT/AUTH required! Try boot device in PRELOADER mode with select PL/PL_CRYPTO/SWSEC type! Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! OPPO RENO2 z NOT DONE |
01-28-2021, 17:00 | #39 (permalink) |
01-28-2021, 17:08 | #41 (permalink) | |
01-28-2021, 17:52 | #43 (permalink) |
No Life Poster Join Date: Feb 2010 Location: 90-region Age: 39
Member: 1246378 Status: Offline Thanks Meter: 123 | Redmi 9A info meta mode done great Infinity TEAM Operation : Identify [ v2.19 ] Mode : META 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM94) MODE : BOOTROM PORT : 94 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : MEID : 764BE3D4011FB979EE5CF3042A510766 BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+EXT BROM : BOOTROM BROM : LOG : F0: 102B 0000 F3: 0000 0000 [0200] V0: 0000 0000 [0001] BROM : SOCID : 240968DA15F27CB497A725A7A0A8FD7E76D55D0855350E1687 003C87BB88470C BROM : SLA : Local Auth BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F BROM : Configuring target for META BROM : META configured! INIT : META confirmed! Boot done! AP_CHIP : MT6765 AP_SWTM : Sat Aug 15 01:54:26 WIB 2020 AP_SWVR : alps-mp-q0.mp1.tc8sp3-V1.4_lcsh.q0mp1.k62v1.64.bsp_P33 MD_CHIP : MT6765 MD_SWTM : 2000.00.00 MD_DSPV : 1.0 MD_DSPP : MOLY.LR12A.R3.MP.V107.5.P55 MD_SWVR : LCSH_Q0MP1_MT6762_SP_HW MD_HWVR : Unknown IMEI[1] : 86332xxxxxxxxxxx IMEI[2] : 86332xxxxxxxxxxx Done! Elapsed: 00:00:48 |
The Following 2 Users Say Thank You to ganjbek For This Useful Post: |
01-28-2021, 17:53 | #44 (permalink) |
Member: 1246378 Status: Offline Thanks Meter: 123 | Redmi 9A metamode info ok fors major Redmi 9A info meta mode done great Infinity TEAM Operation : Identify [ v2.19 ] Mode : META 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM94) MODE : BOOTROM PORT : 94 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : MEID : 764BE3D4011FB979EE5CF3042A510766 BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+EXT BROM : BOOTROM BROM : LOG : F0: 102B 0000 F3: 0000 0000 [0200] V0: 0000 0000 [0001] BROM : SOCID : 240968DA15F27CB497A725A7A0A8FD7E76D55D0855350E1687 003C87BB88470C BROM : SLA : Local Auth BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F BROM : Configuring target for META BROM : META configured! INIT : META confirmed! Boot done! AP_CHIP : MT6765 AP_SWTM : Sat Aug 15 01:54:26 WIB 2020 AP_SWVR : alps-mp-q0.mp1.tc8sp3-V1.4_lcsh.q0mp1.k62v1.64.bsp_P33 MD_CHIP : MT6765 MD_SWTM : 2000.00.00 MD_DSPV : 1.0 MD_DSPP : MOLY.LR12A.R3.MP.V107.5.P55 MD_SWVR : LCSH_Q0MP1_MT6762_SP_HW MD_HWVR : Unknown IMEI[1] : 86332xxxxxxxxxxx IMEI[2] : 86332xxxxxxxxxxx Done! Elapsed: 00:00:48 |
01-28-2021, 17:57 | #45 (permalink) | |
Member: 96478 Status: Offline Sonork: 100.1674604 Thanks Meter: 1,420 | Quote:
Code: Operation : Identify [ v2.19 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM14) MODE : BOOTROM PORT : 14 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : MEID : EC7D70944FBACEAF82C1B06A6E54F378 BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2044 | Manual : Disabled BROM : SLA : Local Auth BROM : SLA : Auth Passed! BROM : SLA : 0x000000FE AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6580 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 440301883631443921973847CB570520 DAInf: 4 : 2 : 156 DA : EXT_RAM NOT initialized! eMMC : OK eMMC : 880103443944313647389721200557CB NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 DRAM : 0x0178 EMI : DEV : INFINITY EMI : SRC : INFINITY-BOX_INTERNAL_EMIDB_v0 INIT : 0xBC : eMMC [ 0x40000000 : [ 1.00 GB ] ] DRAM : DRAM: 0x08000000 [ 128.00 MB ] DA : DRAM ready! DA : BOOT to 2nd DA ... DA : BOOT 2ND DA FAILED! ERROR : 000007D5 : BROM : CMD STARTCMD FAIL Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! | |
