01-29-2021, 05:28 | #1 (permalink) |
Product Supporter Join Date: Jun 2014 Location: India
Member: 2211790 Status: Offline Thanks Meter: 5,118 | Infinity Chinese Miracle-2 MTK/MediaTek v2.20 - Standalone MTK auth ON - NEW CPU Core: Changed: Protocol updated ( Raphael/Legacy ) AUTH: MT6752 with any security configuration supported standalone ! AUTH: MT6753 with any security configuration supported standalone ! AUTH: MT6768 with any security configuration supported standalone ! AUTH: MT6757 support fixed Service: Changed: Identify procedure revised - Support modern Android 10 devices - Support for Android 11 devices activated Changed: SmartReset procedure - Support modern Android 10 devices - Support for Android 11 devices activated Firmware Reader: Changed: Android 10 specific changes for modern devices Changed: Android 11 initial support Changed: New types supported Changed: Internal Database updated ModelDB: Changed: Some specific and brand list update Other: Changed: Many different changes and fixes download links are HERE Last edited by InfinityHelp; 01-29-2021 at 16:09. Reason: link fixed |
The Following 22 Users Say Thank You to kamal_singla For This Useful Post: |
01-29-2021, 06:15 | #7 (permalink) |
Freak Poster Join Date: Feb 2020 Location: Nigeria
Member: 2947987 Status: Offline Sonork: Null Thanks Meter: 71 | Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.20 Load IDBase v125162 Ok! Operation : HW Report [ v2.20 ] HWreport : Mode : eMMC 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM22) MODE : BOOTROM PORT : 22 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6771 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Sylvia TYPE : MODERN RAPHAEL BROM : MEID : B0E1B0DE6168A1C435F3E4E158BBE255 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : Oppo : F11-Reno2F | Manual : Disabled BROM : SOCID : 23D565F3DAE76A6CCF2382B6F28D012616BB7D9D35CAC5F2A0 ADFDD4CA1B8B96 AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6771 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : 0x00007017 : DA SEND ERROR! ERROR : SECURE BOOT : SLA REQUIRED IN BROM MODE! INFO : BROM Level : CERT/AUTH required! Try boot device in PRELOADER mode with select PL/PL_CRYPTO/SWSEC type! Info : LEGACY : HW reporting feature unavailable for current device! Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Done! Elapsed: 00:00:08 Operation : Reset Settings/Format FS [ v2.20 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM22) MODE : BOOTROM PORT : 22 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6771 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Sylvia TYPE : MODERN RAPHAEL BROM : MEID : B0E1B0DE6168A1C435F3E4E158BBE255 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : Oppo : F11-Reno2F | Manual : Disabled BROM : SOCID : 23D565F3DAE76A6CCF2382B6F28D012616BB7D9D35CAC5F2A0 ADFDD4CA1B8B96 AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6771 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : 0x00007017 : DA SEND ERROR! ERROR : SECURE BOOT : SLA REQUIRED IN BROM MODE! INFO : BROM Level : CERT/AUTH required! Try boot device in PRELOADER mode with select PL/PL_CRYPTO/SWSEC type! Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Last edited by Y Michael; 01-29-2021 at 06:22. |
01-29-2021, 06:21 | #8 (permalink) |
Member: 2947987 Status: Offline Sonork: Null Thanks Meter: 71 | Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.20 Load IDBase v125162 Ok! Operation : HW Report [ v2.20 ] HWreport : Mode : eMMC 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM22) MODE : BOOTROM PORT : 22 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6771 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Sylvia TYPE : MODERN RAPHAEL BROM : MEID : B0E1B0DE6168A1C435F3E4E158BBE255 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : Oppo : F11-Reno2F | Manual : Disabled BROM : SOCID : 23D565F3DAE76A6CCF2382B6F28D012616BB7D9D35CAC5F2A0 ADFDD4CA1B8B96 AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6771 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : 0x00007017 : DA SEND ERROR! ERROR : SECURE BOOT : SLA REQUIRED IN BROM MODE! INFO : BROM Level : CERT/AUTH required! Try boot device in PRELOADER mode with select PL/PL_CRYPTO/SWSEC type! Info : LEGACY : HW reporting feature unavailable for current device! Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Done! Elapsed: 00:00:08 Operation : Reset Settings/Format FS [ v2.20 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM22) MODE : BOOTROM PORT : 22 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6771 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Sylvia TYPE : MODERN RAPHAEL BROM : MEID : B0E1B0DE6168A1C435F3E4E158BBE255 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : Oppo : F11-Reno2F | Manual : Disabled BROM : SOCID : 23D565F3DAE76A6CCF2382B6F28D012616BB7D9D35CAC5F2A0 ADFDD4CA1B8B96 AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6771 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : 0x00007017 : DA SEND ERROR! ERROR : SECURE BOOT : SLA REQUIRED IN BROM MODE! INFO : BROM Level : CERT/AUTH required! Try boot device in PRELOADER mode with select PL/PL_CRYPTO/SWSEC type! Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! |
01-29-2021, 06:23 | #10 (permalink) | ||
Member: 2211790 Status: Offline Thanks Meter: 5,118 | Quote:
tick sSLA do Identify | ||
01-29-2021, 06:25 | #11 (permalink) |
Freak Poster Join Date: Dec 2007 Location: somewhere in KENYA
Member: 648607 Status: Offline Sonork: 100.1638674 Thanks Meter: 23 | Operation : Reset Settings/Format FS [ v2.20 ] Mode : FACTORY RESET ( WIPE ) 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM6) MODE : BOOTROM PORT : 6 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6771 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Sylvia TYPE : MODERN RAPHAEL BROM : MEID : 72B7F1C468354237E4DA0E4E8BC3A1E5 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : Oppo : F11-Reno2F | Manual : Disabled BROM : SOCID : 07E4A6C070A9C1D15AAE38273CDB7C30DF8504A06D2A316955 18E1DCB42EB73E AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6771 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : 0x00007017 : DA SEND ERROR! ERROR : SECURE BOOT : SLA REQUIRED IN BROM MODE! INFO : BROM Level : CERT/AUTH required! Try boot device in PRELOADER mode with select PL/PL_CRYPTO/SWSEC type! Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! |
01-29-2021, 06:35 | #13 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
Now just tick sSLA and repeat. | |
The Following 2 Users Say Thank You to JayDi For This Useful Post: |
01-29-2021, 06:52 | #14 (permalink) | |
Junior Member Join Date: Feb 2014 Location: Russia
Member: 2128235 Status: Offline Thanks Meter: 2 | Please add MT6799. Meizu pro 7 plus not connected Quote:
01-29-2021, 07:10 | #15 (permalink) |
No Life Poster Join Date: Aug 2011 Location: bagmati pradesh
Member: 1626780 Status: Offline Thanks Meter: 1,275 | vivo 1907 s1 full connect with cm2mt2 Operation : Identify [ v2.20 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM18) MODE : BOOTROM PORT : 18 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6768 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Talbot TYPE : MODERN RAPHAEL BROM : MEID : 164E72561BCA5D52642FE68CEF949CDA BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2044 | Manual : Disabled BROM : SOCID : D92113292826179565E5D651FF3DF96ACB3E6F3BEDA059376B 35A18BE92A9EFB BROM : SLA : Local Auth BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6768 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : PRELOADER_INFINITY_0 EMI : CNT : 0001 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00070000 [ 448.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC: 150100335636434D42020A2690AF66F3 EMMC: VEN : SAMSUNG | OEM : 01 | DEV : 3V6CMB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x1D1EC00000 [ 116.48 GB ] CHIP : MT6768 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0001 , EVOL : 0x0000 RNID : E5759BE251E944351CD7BD7D256AB355 DA : USB : HIGH-SPEED Boot done! Device PMT Info : PART : 0x0000000000000000 : 0x0000000000400000 : preloader PART : 0x0000000000000000 : 0x0000000000008000 : pgpt PART : 0x0000000000008000 : 0x0000000004000000 : recovery PART : 0x0000000004008000 : 0x0000000000080000 : misc PART : 0x0000000004088000 : 0x0000000000080000 : para PART : 0x0000000004108000 : 0x0000000001400000 : expdb PART : 0x0000000005508000 : 0x0000000000100000 : frp PART : 0x0000000005608000 : 0x0000000000800000 : vbmeta PART : 0x0000000005E08000 : 0x0000000000A00000 : backup PART : 0x0000000006808000 : 0x0000000004000000 : survival PART : 0x000000000A808000 : 0x0000000000A00000 : reserved PART : 0x000000000B208000 : 0x0000000004000000 : cust PART : 0x000000000F208000 : 0x0000000002000000 : metadata PART : 0x0000000011208000 : 0x0000000002000000 : nvcfg PART : 0x0000000013208000 : 0x0000000004000000 : nvdata PART : 0x0000000017208000 : 0x0000000003000000 : persist PART : 0x000000001A208000 : 0x0000000000800000 : protect1 PART : 0x000000001AA08000 : 0x0000000000DF8000 : protect2 PART : 0x000000001B800000 : 0x0000000000800000 : seccfg PART : 0x000000001C000000 : 0x0000000000200000 : sec1 PART : 0x000000001C200000 : 0x0000000000300000 : proinfo PART : 0x000000001C500000 : 0x0000000000080000 : efuse PART : 0x000000001C580000 : 0x0000000001A00000 : boot_para PART : 0x000000001DF80000 : 0x0000000004000000 : nvram PART : 0x0000000021F80000 : 0x0000000000800000 : logo PART : 0x0000000022780000 : 0x0000000008000000 : md1img PART : 0x000000002A780000 : 0x0000000000100000 : spmfw PART : 0x000000002A880000 : 0x0000000000600000 : scp1 PART : 0x000000002AE80000 : 0x0000000000600000 : scp2 PART : 0x000000002B480000 : 0x0000000000100000 : sspm_1 PART : 0x000000002B580000 : 0x0000000000100000 : sspm_2 PART : 0x000000002B680000 : 0x0000000001000000 : gz1 PART : 0x000000002C680000 : 0x0000000001000000 : gz2 PART : 0x000000002D680000 : 0x0000000000500000 : lk PART : 0x000000002DB80000 : 0x0000000000500000 : lk2 PART : 0x000000002E080000 : 0x0000000004000000 : boot PART : 0x0000000032080000 : 0x0000000000800000 : dtbo PART : 0x0000000032880000 : 0x0000000000500000 : tee1 PART : 0x0000000032D80000 : 0x0000000000A80000 : tee2 PART : 0x0000000033800000 : 0x0000000080000000 : vendor PART : 0x00000000B3800000 : 0x0000000160000000 : system PART : 0x0000000213800000 : 0x0000000010000000 : cache PART : 0x0000000223800000 : 0x0000001AF78F8000 : userdata PART : 0x0000001D1B0F8000 : 0x0000000002B00000 : otp PART : 0x0000001D1DBF8000 : 0x0000000001000000 : flashinfo PART : 0x0000001D1EBF8000 : 0x0000000000008000 : sgpt Product Brand : vivo Product Device : k68v1_64 Product Model : vivo 1907 Product Name : full_k68v1_64 Patch Level : QP1A.190711.020 Display ID : QP1A.190711.020 release-keys Ver. CodeName : REL Ver. Release : 10 Sec. Patch : 2020-10-01 Build Time : 07.11.2020 Product Info : k68v1_64 Product Board : k68v1_64 Board Platform : mt6768 Product Manfct : vivo USERDATA : FILESYSTEM : EXT4 with FBE ( File-Base Encryption ) NVRAM check : Passed! NVRAM : SEC NORMAL [ No extra security ] Backup sensetive data [ 11 ] Backup path : Backup\MT6768__E5759BE251E944351CD7BD7D256AB355\ [23] Read : NVRAM [14] Read : NVDATA [20] Read : PROINFO [33] Read : LK [13] Read : NVCFG [16] Read : PROTECT1 [17] Read : PROTECT2 [15] Read : PERSIST [0] Read : PRELOADER [18] Read : SECCFG Backup done! STORAGE : LifeStatus : eMMC : OK! Done! Elapsed: 00:00:49 |
The Following 3 Users Say Thank You to malka4u For This Useful Post: |
