Old 03-23-2021, 08:37   #256 (permalink)
Member: 896509
Thanks Meter: 29
How to pattern password unlock mt2 without data losing ? Tacno B1f
Old 03-30-2021, 19:23   #257 (permalink)
KrzychuG's Avatar
Member: 25996
Thanks Meter: 168
Any hope for bootloader unlock option without triggering factory reset, like the one Pandora seems to have?
Old 04-01-2021, 13:44   #258 (permalink)
Member: 1043909
Thanks Meter: 56,549
Originally Posted by KrzychuG View Post
Any hope for bootloader unlock option without triggering factory reset...
Probably yes, something is on the way
The Following 3 Users Say Thank You to YellowBoss For This Useful Post:
Old 04-02-2021, 16:15   #259 (permalink)
Member: 1003316
Thanks Meter: 5
allways same problem reset password realme c3 rmx2020
can any one help please
Operation : Reset Settings/Format FS [ v2.21 ]
Mode : META
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : MTK USB Port (COM7)
MODE : BOOTROM
PORT : 7
Waiting BOOT ack ...
BROM : Skip ACK verify
BROM : Init BROM
BROM init passed!
CHIP : MT6768 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000
TYPE : MODERN RAPHAEL
BROM : MEID : E64EDF2F8AD6DBFF99433746D547F181
BROM : SecLevel : 0x000000E5
BROM : SecMode : SBC+SDA+EXT
BROM : BOOTROM
BROM : LOG : F0: 102B 0000 F3: 0000 0000 [0200] V0: 0000 0000 [0001]
BROM : SOCID : 72816617FAF5398701B8665BD3DE351C00C4304BC8A537CAB9 FB61C07D515BBB
BROM : SLA : Local Auth
BROM : SLA : Auth Started!
BROM : SLA : Auth Passed!
BROM : SLA : 0x0000001F
BROM : Configuring target for META
BROM : META configured!
INIT : META confirmed!
Boot done!
AP_CHIP : MT6768
AP_SWTM : Fri Mar 13 23:52:57 CST 2020
AP_SWVR : RMX2020_11_A.16_200313_324edfd1
Format Ok : UserData
- > Format in META will NOT reset FRP!
Done!
Elapsed: 00:00:41
Reconnect Power/Cable!
Old 04-02-2021, 16:15   #260 (permalink)
Member: 1003316
Thanks Meter: 5
realme c3 rmx2020 password cant reseted
Mode : META
MODE : BOOTROM
PORT : 7
BROM : Init BROM
BROM init passed!
BROM : BOOTROM
Boot done!
AP_CHIP : MT6768
Done!
Elapsed: 00:00:41
Old 04-03-2021, 02:07   #261 (permalink)
kamal_singla's Avatar
Member: 2211790
Thanks Meter: 4,431
Try flash mode with tick sSLA and base 2044
Old 04-03-2021, 21:07   #262 (permalink)
Member: 1003316
Thanks Meter: 5
Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.21
Mode : FORCED USER FORMAT
MODE : BOOTROM
PORT : 7
BROM : Init BROM
BROM init passed!
CODE : Talbot
BROM : BROM|BL : 0x05|0xFE
BROM : BOOTROM
MODE : 0_base : BASE_v2044 | Manual : Disabled
AGENT : Look for suitable BootChain in DA ...
AGENT : MTK_AllInOne_DA.bin
AGENT : Found MT6768
AGENT : MTK_DOWNLOAD_AGENT
BROM : Sending 1st DA ...
BROM : DA sent
BROM :Transfer control to DA ...
DA : AGENT started!
DA : SETUP HW PARAMS FAILED! PROTO_VER is OLD?
Error : Fail to init protocol!
>>> Check and select CORRECT SETTINGS for your device!
Old 04-04-2021, 02:59   #263 (permalink)
Member: 2211790
Thanks Meter: 4,431
MODE : BOOTROM
PORT : 7
BROM : Init BROM
BROM init passed!
CODE : Talbot
BROM : BOOTROM
BROM : DA sent
DA : AGENT started!
Update drivers from support area and repeat
The Following User Says Thank You to kamal_singla For This Useful Post:
Old 04-04-2021, 17:28   #264 (permalink)
Member: 1003316
Thanks Meter: 5
finaly done reset password+FRP realme c3 rmx2020
Mode : FULL FACTORY ( FORCED + FRP )
PTFN : MediaTek USB Port_V1632 (COM7)
MODE : BOOTROM
PORT : 7
BROM : Init BROM
BROM init passed!
CODE : Talbot
BROM : SecLevel : 0x000000E0
BROM : SecMode : EXT
BROM : BOOTROM
MODE : 0_base : BASE_v2028 | Manual : Disabled
BROM : DA sent
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
DA : EXT_RAM NOT initialized!
EMI : DEV : INFINITY
EMI : SRC : PRELOADER_INFINITY_0
EMI : CNT : 0001
EMI : Init EMI from INTERNAL DB
EMI : EXT_RAM CFG Passed!
DA : BOOT to 2nd DA ...
DA : 2ND stage confirmed!
DA : SYNC with DA passed!
DA : Receiving HW info
SRAM: 0x00070000 [ 448,00 KB ]
DRAM: 0x100000000 [ 4,00 GB ]
EMMC: 90014A68433861503E0350F0DA2CC62D
EMMC: VEN : HYNIX | OEM : 4A01 | DEV : hC8aP>
EMMC:
BOOT1 : 0x00400000 [ 4,00 MB ]
BOOT2 : 0x00400000 [ 4,00 MB ]
RPMB : 0x01000000 [ 16,00 MB ]
USER : 0xE8F800000 [ 58,24 GB ]
CHIP : MT6768 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0001 , EVOL : 0x0000
RNID : 32C46CD7E482CBDDE9F2484AE0CA7A76
DA : USB : HIGH-SPEED
Boot done!
Format Ok : USERDATA
Format Ok : CACHE
Format Ok : RESET PROTECTION
Done!
Elapsed: 00:00:34
The Following 2 Users Say Thank You to BZAKI For This Useful Post:
Old 04-12-2021, 00:25   #265 (permalink)
xerraco's Avatar
Member: 890926
Thanks Meter: 1,661
I got this error
Load IDBase v21168 Ok!
UserName and/or Password not set! Can't continue!
Update failed! Check settings and/or internet connection!
Br,
xerraco
Old 04-12-2021, 10:18   #266 (permalink)
Member: 148515
Thanks Meter: 17,748
Originally Posted by xerraco View Post
I got this error
Br,
xerraco
To enable auto-update feature please enter in software settings your IOS username and password.
You should enter username and password that you are using to access IOS web account https://www.infinity-box.com/service/
Old 04-13-2021, 06:56   #267 (permalink)
xerraco's Avatar
Member: 890926
Thanks Meter: 1,661
Update configuration ...
Update Ok!
Load IDBase v210169 Ok!
Br,
xerraco
Old 04-13-2021, 15:14   #268 (permalink)
Member: 2649950
Thanks Meter: 28
SecureDevice : Paired type!
-> INFO : That device WILL dead after ReadOut Flashing!
-> INFO : Only partial flashing ( f.e. SYSTEM, VENDOR and etc. ) available!
-> INFO : In most cases you can "unsecure" device in Engineer mode
what does it mean?
Powered by Searchlight © 2021 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.13339 seconds with 8 queries
