Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | [ Easy-JTAG ] | Direct Unlock Source | Search | Today's Posts | Mark Forums Read |
![]() | #16 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Dec 2007
Member: 652684 Status: Offline Thanks Meter: 20 | Operation : Read Firmware [ v2.21 ] ExtSparse : Enabled ForceRead : Enabled 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : LGE Mobile USB Serial Port (COM48) MODE : PRELOADER PORT PORT : 48 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6755 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x02 BROM : PRELOADER PORT MODE : 0_base : BASE_v2044 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6755 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : 0x00002001 : DA SEND ERROR! ERROR : SECURE BOOT : MISMATCH BOOT SIGNATURE! INFO : PRELOADER Level : CORRECT DA required : PL/PL_CRYPTO/SWSEC Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! just wanto read lg m400 not support |
![]() | #22 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2013 Location: gsm forum
Member: 1984655 Status: Offline Sonork: 119.30.39.25 Thanks Meter: 75 | Files :3 [FL] : Set : preloader_cactus.bin [FL] : Set : frp_by_softichnic.img [FL] : Set : account_by_softihnic.img [FL] : Total size : 0x0014B630 [ 1.29 MB ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1633 (COM5) MODE : BOOTROM PORT : 5 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN RAPHAEL BROM : MEID : F4021C49D88396013F0BFD01C54ADD6C BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : Xiaomi : 6A | Manual : Enabled BROM : SOCID : 1263A32AD30BF1586EF61B3350A104B6C02E955E119BA7B86F 1D74EB615A8982 AGENT : Look for suitable BootChain in DA ... AGENT : AGENT : Selected AGENT doesn't have required configuration! >>> Check and select CORRECT SETTINGS for your device! Reconnect Power/Cable! |
![]() | #23 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: May 2008
Member: 770503 Status: Offline Thanks Meter: 1,182 | Realme C12 jan/21 sec patch Read info Code: Operation : Identify [ v2.21 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM7) MODE : BOOTROM PORT : 7 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN RAPHAEL BROM : MEID : B31C0E693FB7A3084D5436D0807DDD95 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2044 | Manual : Disabled BROM : SOCID : 93AA076FD1A8E9A299442C4AA398774ABFF98CA7924CA0E5C40115E20BA70528 BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : PRELOADER_INFINITY_0 EMI : CNT : 0001 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: 150100445836384D4209148CCE269713 EMMC: VEN : SAMSUNG | OEM : 01 | DEV : DX68MB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 8AD711E3950CC33453E241F686B9E91 DA : USB : HIGH-SPEED Boot done! Patch Level : QP1A.190711.020 Display ID : QP1A.190711.020 release-keys Ver. CodeName : REL Ver. Release : 10 Sec. Patch : 2020-12-05 Build Time : 04.01.2021 Product Info : oppo6765 USERDATA : FILESYSTEM : EXT4 with FBE ( File-Base Encryption ) NVRAM check : Passed! NVRAM : SEC ENCRYPT [ IMEI ENCRYPTED ] Backup sensetive data [ 15 ] Backup path : Backup\MT6765__8AD711E30950CC33453E241F686B9E91\ [31] Read : NVRAM [14] Read : NVDATA [22] Read : PROINFO [36] Read : LK [13] Read : NVCFG [17] Read : PROTECT1 [18] Read : PROTECT2 [20] Read : PERSIST [0] Read : PRELOADER [19] Read : SECCFG [5] Read : OPPORESERVE1 [6] Read : OPPORESERVE2 [7] Read : OPPORESERVE3 Backup done! STORAGE : LifeStatus : eMMC : OK! Done! Elapsed: 00:01:15 |
The Following 5 Users Say Thank You to mbiborna For This Useful Post: |
![]() | #24 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2003 Location: Romania, Fagaras Age: 45
Member: 34379 Status: Offline Thanks Meter: 101 | Nokia 2.3 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.21 Load IDBase v21168 Ok! Update configuration ... Update Ok! Load IDBase v21168 Ok! Operation : Identify [ v2.21 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM59) MODE : BOOTROM PORT : 59 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0200 CODE : Merlot TYPE : MODERN RAPHAEL BROM : MEID : E733881ACC1E3CFA7F0657479A172332 BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2044 | Manual : Disabled BROM : SOCID : 94568E529B5CD2A4886611FBFB3B5AD22B1CD298D43C2998DF 135981B837DA2D AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6761 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : 0x00000001 : DA SEND ERROR! ERROR : BROM : DL MODE ERROR INFO : BROM Level : SLA AUTH or AUTH required! Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! |
![]() | #25 (permalink) | |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Feb 2016 Location: tunisia Age: 29
Member: 2529545 Status: Offline Thanks Meter: 68 | Quote:
ExtSparse : Enabled ForceRead : Disabled 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM35) MODE : BOOTROM PORT : 35 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN RAPHAEL BROM : MEID : DDA8B6A75BEA62DEBE4DA878D4C66C26 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2044 | Manual : Disabled BROM : SOCID : F98973474C2463BBE9E46390DCE30F53EF94C0CC5DA4682511 0215B223294418 BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : PRELOADER_INFINITY_0 EMI : CNT : 0005 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232,00 KB ] DRAM: 0x80000000 [ 2,00 GB ] EMMC: 90014A68423861503E0100437B3F57E9 EMMC: VEN : HYNIX | OEM : 4A01 | DEV : hB8aP> EMMC: BOOT1 : 0x00400000 [ 4,00 MB ] BOOT2 : 0x00400000 [ 4,00 MB ] RPMB : 0x01000000 [ 16,00 MB ] USER : 0x747C00000 [ 29,12 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 6E9E6C14C82EE64DEF26C6D22436F0D0 DA : USB : HIGH-SPEED Boot done! MT6765 Unsupport : 0x0000000027380000 : 0x0000000000100000 : vbmeta_odm Error : Device NOT supported for SAFE READ! >>> Send log and report.log (if exists) to support! Include device info also! Reconnect Power/Cable! | |
![]() | #26 (permalink) | |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jun 2014 Location: India
Member: 2211790 Status: Offline Thanks Meter: 5,031 | Quote:
The Following 3 Users Say Thank You to kamal_singla For This Useful Post: |
![]() | #27 (permalink) |
Member: 34379 Status: Offline Thanks Meter: 101 | PTFN : MediaTek USB Port (COM59) MODE : BOOTROM PORT : 59 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0200 CODE : Merlot TYPE : MODERN RAPHAEL BROM : MEID : E733881ACC1E3CFA7F0657479A172332 BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2044 | Manual : Disabled BROM : SOCID : 94568E529B5CD2A4886611FBFB3B5AD22B1CD298D43C2998DF 135981B837DA2D BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6761 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : PRELOADER_INFINITY_0 EMI : CNT : 0001 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] EMMC: 70010054413238333220317C7A35B63F EMMC: VEN : KINGSTON | OEM : 01 | DEV : TA2832 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x74A000000 [ 29.16 GB ] CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000 RNID : F43B42A9351EE08237F65866419B1A24 DA : USB : HIGH-SPEED Boot done! Error : SPLock identification failed! >>> Repeat operation in META mode [ Platform -> Global -> Meta ] |
![]() | #28 (permalink) | |
Product Supporter ![]() ![]() ![]() Join Date: May 2005
Member: 148515 Status: Online Thanks Meter: 19,150 | Quote:
Please explain | |
![]() | #29 (permalink) |
Member: 34379 Status: Offline Thanks Meter: 101 | Operation : SP Unlock [ v2.21 ] Mode : META 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM59) MODE : BOOTROM PORT : 59 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0200 TYPE : MODERN RAPHAEL BROM : MEID : E733881ACC1E3CFA7F0657479A172332 BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+EXT BROM : BOOTROM BROM : LOG : F0: 102B 0000 F3: 0000 0000 [0200] V0: 0000 0000 [0001] BROM : SOCID : 94568E529B5CD2A4886611FBFB3B5AD22B1CD298D43C2998DF 135981B837DA2D BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F BROM : Configuring target for META BROM : META configured! INIT : META confirmed! Boot done! AP_CHIP : MT6761 AP_SWTM : Thu Dec 19 04:33:28 CST 2019 AP_SWVR : alps-mp-p0.mp1-V5.137.2_wingtechsz.hmd.p0mp1.k39tv1.64.bsp_P23 MD_CHIP : MT6761 MD_SWVR : TK_MD_BASIC_HW IMEI : IMEI_NVRAM data damaged! [ Empty? ] Done! Elapsed: 00:00:45 |
