Old 02-04-2021, 14:03   #61 (permalink)
Member: 793406
Sonork: 100.1647095
Thanks Meter: 67
Qualcomm update need .............................
The Following User Says Thank You to medo_mshakel For This Useful Post:
Old 02-04-2021, 14:51   #62 (permalink)
Member: 965992
Sonork: aloba
Thanks Meter: 5
The meta mode is not switching phone to meta mode, and I tried the old version again, it works in meta mode well
Old 02-04-2021, 16:15   #63 (permalink)
kundicom's Avatar
Member: 2650777
Sonork: 100.650600
Thanks Meter: 153
Realme 3 RMX1821 full flash done with cm2
Operation : Write Flash [ v2.21 ]
Repartition : Enabled
Flash Verify : Disabled
Reg.Pre-Erase : Enabled
Verify HW/SW : Enabled
SData Backup : Disabled
Safe UserData : Disabled
Flash Format : Disabled
Files :24
[FL] : Set : preloader_oppo6771.bin
[FL] : Set : recovery.img
[FL] : Set : opporeserve2.img
[FL] : Set : md1img.img
[FL] : Set : spmfw.img
[FL] : Set : scp.img
[FL] : Set : sspm.img
[FL] : Set : cam_vpu1.img
[FL] : Set : cam_vpu2.img
[FL] : Set : cam_vpu3.img
[FL] : Set : lk.img
[FL] : Set : lk.img
[FL] : Set : boot.img
[FL] : Set : logo.bin
[FL] : Set : dtbo.img
[FL] : Set : tee.img
[FL] : Set : odm.img
[FL] : Set : vendor.img
[FL] : Set : system.img
[FL] : Set : cache.img
[FL] : Set : userdata.img
[FL] : Total size : 0x206A87368 [ 8.10 GB ]
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : MediaTek USB Port_V1632 (COM14)
MODE : BOOTROM
PORT : 14
Waiting BOOT ack ...
BROM : Skip ACK verify
BROM : Init BROM
BROM init passed!
CHIP : MT6771 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000
CODE : Sylvia
TYPE : MODERN RAPHAEL
BROM : MEID : EFA581CB978DF9E9B3DEA4CA89E05C19
BROM : SecLevel : 0x000000E5
BROM : SecMode : SBC+SDA+EXT
BROM : BROM|BL : 0x05|0xFE
BROM : BOOTROM
MODE : 0_base : BASE_v2044 | Manual : Disabled
BROM : SOCID : 099A8A4A721FD83F242CFED464D63A6F0E595D273EF0F90C0A F781BC57634551
BROM : SLA : Local Auth
BROM : SLA : Auth Started!
BROM : SLA : Auth Passed!
BROM : SLA : 0x0000001F
AGENT : Look for suitable BootChain in DA ...
AGENT : MTK_AllInOne_DA.bin
AGENT : Found MT6771
AGENT : MTK_DOWNLOAD_AGENT
BROM : Sending 1st DA ...
BROM : DA sent
BROM :Transfer control to DA ...
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
DA : EXT_RAM NOT initialized!
EMI : DEV : MT6752
EMI : SRC : preloader_oppo6771.bin
EMI : CNT : 0009
EMI : [00] : eMMC : DDR3 : ID : 150100474436424D42 : VEN : SAMSUNG | DEV : GD6BMB : RAM : [ 3.00 GB ]
EMI : [01] : eMMC : DDR3 : ID : 90014A68423861503E : VEN : HYNIX | DEV : hB8aP> : RAM : [ 3.00 GB ]
EMI : [02] : eMMC : DDR3 : ID : 13014E53304A394638 : VEN : MICRON | DEV : S0J9F8 : RAM : [ 4.00 GB ]
EMI : [03] : eMMC : DDR3 : ID : 90014A484347386134 : VEN : HYNIX | DEV : HCG8a4 : RAM : [ 4.00 GB ]
EMI : [04] : eMMC : DDR3 : ID : 13014E53304A394E38 : VEN : MICRON | DEV : S0J9N8 : RAM : [ 4.00 GB ]
EMI : [05] : eMMC : DDR3 : ID : 150100475036424D42 : VEN : SAMSUNG | DEV : GP6BMB : RAM : [ 3.00 GB ]
EMI : [06] : eMMC : DDR3 : ID : 90014A68433861503E : VEN : HYNIX | DEV : hC8aP> : RAM : [ 3.00 GB ]
EMI : [07] : eMMC : DDR3 : ID : 150100514436334D42 : VEN : SAMSUNG | DEV : QD63MB : RAM : [ 2.00 GB ]
EMI : [08] : eMMC : DDR3 : ID : 150100524836344142 : VEN : SAMSUNG | DEV : RH64AB : RAM : [ 4.00 GB ]
EMI : Init EMI from PRELOADER
EMI : EXT_RAM CFG Passed!
DA : BOOT to 2nd DA ...
DA : 2ND stage confirmed!
DA : SYNC with DA passed!
DA : Receiving HW info
SRAM: 0x00039000 [ 228.00 KB ]
DRAM: 0x100000000 [ 4.00 GB ]
EMMC: 150100524836344142052CAC9AA016B3
EMMC: VEN : SAMSUNG | OEM : 01 | DEV : RH64AB
EMMC:
BOOT1 : 0x00400000 [ 4.00 MB ]
BOOT2 : 0x00400000 [ 4.00 MB ]
RPMB : 0x00400000 [ 4.00 MB ]
USER : 0xE8F800000 [ 58.24 GB ]
CHIP : MT6771 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000
RNID : 4FEF546E828194FDBCFDA05E24D3F284
DA : USB : HIGH-SPEED
Boot done!
[FL] : HW verification passed!
SEC_DL : False (RAPHAEL)
SEC_ID : 0x494E46494E495459424F584245535432
[FL] : Pre-Erase
Erase : 0x0000000000000000 : 0x0000000004188000
Erase : 0x0000000008A88000 : 0x0000000001500000
Erase : 0x000000000BF88000 : 0x0000000006000000
Erase : 0x0000000013000000 : 0x0000000000800000
Erase : 0x0000000016800000 : 0x0000000000200000
Erase : 0x0000000016D00000 : 0x000000000C000000
Erase : 0x000000002AD00000 : 0x00000003A6B00000
[FL] : RePartition
[FL] : RePartition Ok!
[FL] : Flashing now ...
Write : PRELOADER
Update bootloader backup copy ...
Update bootloader backup copy Ok!
Write : RECOVERY
Write : OPPORESERVE2
Write : MD1IMG
Write : SPMFW
Write : SCP1
Write : SCP2
Write : SSPM_1
Write : SSPM_2
Write : CAM_VPU1
Write : CAM_VPU2
Write : CAM_VPU3
Write : LK
Write : LK2
Write : BOOT
Write : LOGO
Write : DTBO
Write : TEE1
Write : TEE2
Write : ODM
Write : VENDOR
Write : SYSTEM
Write : CACHE
Write : USERDATA
[FL] : RePartition
[FL] : Flashing finished!
Done!
Elapsed: 00:07:02
Reconnect Power/Cable!
The Following 4 Users Say Thank You to kundicom For This Useful Post:
Old 02-04-2021, 16:17   #64 (permalink)
Member: 148515
Thanks Meter: 17,748
Originally Posted by amrMHF View Post
lol but where is answer
you only care for MTK and SPD can you please give some attention for Qualcomm CPU we just ASK, it's a little request
and we not need to open new thread to ask you
Work about more QLM software features is in progress. New software will be released as soon as it will be finished and well tested.
If you are not satisfied with Infinity QLM tool you are free to find and use another tool for qualcomm for now.
Also we will be very thankful to you if you can write here list of required supported CPU types, hardware configurations and software features that you want to see released in future Infinity QLM update. Team is waiting for your information !
Please let me know are you satisfied with the answer or do you need more information ?
Facebook - Telegram - Twitter
The Following 2 Users Say Thank You to InfinityHelp For This Useful Post:
Old 02-04-2021, 16:18   #65 (permalink)
Member: 148515
Old 02-04-2021, 16:19   #66 (permalink)
Member: 148515
ys butt only mtk..............................
Hey ! Make it better than others, finally start to work instead of cry !
Old 02-04-2021, 16:20   #67 (permalink)
Member: 148515
Originally Posted by azoukni2 View Post
thank for the good update infiity team
Old 02-04-2021, 16:41   #68 (permalink)
kundicom's Avatar
Member: 2650777
Sonork: 100.650600
Thanks Meter: 153
hello team please now you give Qualcomm update for oppo vivo?
The Following User Says Thank You to kundicom For This Useful Post:
Old 02-04-2021, 16:43   #69 (permalink)
Member: 148515
Yes sir, team is at your servivce ! But we hope on your little help !
Please write here list of required supported CPU types, hardware configurations and software features that you want to see released in future Infinity QLM update. Waiting for your information !
Old 02-04-2021, 18:33   #70 (permalink)
kundicom's Avatar
Member: 2650777
Sonork: 100.650600
Thanks Meter: 153
hello everyone RMX1821 Firmware is Here free gift for all MT6771_Android_scatter
https://www.mediafire.com/file/6gp3p..._cb5665f2/file
Old 02-04-2021, 19:39   #71 (permalink)
Member: 2979069
great team always great and great update,s
Old 02-04-2021, 23:36   #72 (permalink)
Member: 1613469
Thanks Meter: 192
HYUNDAI L553 (( MT6739 ))
Operation : HW Report [ v2.21 ]
HWreport : Mode : eMMC
PTFN : MediaTek USB Port (COM21)
MODE : BOOTROM
PORT : 21
BROM : Init BROM
BROM init passed!
CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000
CODE : Zion
BROM : MEID : 2306FA77E7F810E8128F3C21521F0FA1
BROM : SecLevel : 0x000000E1
BROM : SecMode : SBC+EXT
BROM : BOOTROM
BROM : SOCID : 7B3953DF16C22FF49DEF1214D980EFF2A03A19BCA3258F3FFA D6048450F469DE
AGENT : Found MT6739
BROM : DA sent
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
EMI : DEV : INFINITY
EMI : SRC : PRELOADER_INFINITY_0
EMI : CNT : 0002
EMI : Init EMI from INTERNAL DB
SRAM: 0x00020000 [ 128,00 KB ]
DRAM: 0x40000000 [ 1,00 GB ]
EMMC: 150100464536324D4203E92D6A11964F
EMMC: VEN : SAMSUNG | OEM : 01 | DEV : FE62MB
EMMC:
BOOT1 : 0x00400000 [ 4,00 MB ]
BOOT2 : 0x00400000 [ 4,00 MB ]
RPMB : 0x00400000 [ 4,00 MB ]
USER : 0x3A3E00000 [ 14,56 GB ]
CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000
RNID : 8C846268C1B72DE29B0BDEFF501D90D8
Boot done!
Memory Info :
CID : 150100464536324D4203E92D6A11964F
MEM : VEN : SAMSUNG | OEM : 01 | DEV : FE62MB
EXT_CSD Info :
TRIM timeout : 0 ms
Secure erase timeout : 8100 ms
Secure trim timeout : 5100 ms
HC erase unit size : 512 kbytes
HC erase timeout : 300 ms
HC write prot grp size: 8192 kbytes
HC erase grp def. : 0h
Sector count : 1d1f000h
HS timing : 0h
Bus width : 0h
Erase memory content : 0h
Partition config : 48h
Boot partition size : 4096 kbytes
Boot information : 7h
Boot config protection: 0h
Boot bus width : 0h
Boot area write prot : 0h
User area write prot : 0h
RPMB size : 4096 kbytes
H/W reset function : 1h
FW version(low) : 30h
Overall status :
STORAGE : LifeStatus : eMMC : OK!
RPMB : RPMB KEY NOT set! [State : CLEAN : USABLE]
Done!
Elapsed: 00:00:35
The Following User Says Thank You to washipolar For This Useful Post:
Old 02-05-2021, 00:15   #73 (permalink)
Member: 1724300
Thanks Meter: 5
Thumbs up cm2 king
Hello to the strong Infinite team
I have no complaints about updating a bit late because I know it is very difficult to find a solution.
But our business has been badly damaged since the Corona virus and it is not cost-effective to pay for CM2 again.
Also, did you forget the new update for Samsung? qlm?
best 2 ?
Sorry if my tone was sharp
Old 02-05-2021, 00:40   #74 (permalink)
apologized's Avatar
Member: 1712203
Thanks Meter: 179
like your name ,it's no end to the infinity
thanks keepUP
Old 02-05-2021, 01:17   #75 (permalink)
Member: 148515
best 2 ?
Thank you for your question !
Team has no problenm with memory and never forget anything.
Work about more software and features is in progress.
Powered by Searchlight © 2021 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.12458 seconds with 8 queries
